[petsc-users] from standard fortran program to PETSc
    Anthony Haas
    aph at email.arizona.edu
    Fri Jun 19 12:46:11 CDT 2015
I have a Fortran90 program that solves a complex linear generalized
eigenvalue problem (GEVP) using standard fortran 90 programming:
Subroutines, modules, allocatable arrays, real(8), int,...
This program uses Lapack to solve the GEVP. The program is mainly made off:
1) set dimensions of problem and initialize arrays,...
2) compute the baseflow (for instance boundary layer flow)
3) build the (stability) complex generalized eigenvalue problem ==>
build (dense) matrices A and B
4) solve the GEVP with Lapack
Now I want to use PETSc + SLEPc to use sparse matrices. Do I need to
rewrite/modify everything in terms of PETSc variables as follows:
- int -> PetscInt
- real(8) -> PetscScalar
- complex*16 -> PetscScalar
or is it possible to reuse all that F90 code? For instance I have a
similarity solver that computes Blasius solution. If that similarity
solver provides me with u and v velocities in terms of standard
fortran90 real(8) variables, how should I do to use these variables to
build my complex matrix? Should I convert them to Petsc variables? How?
what should I do with my Fortran90 allocatable arrays?
real(dp),allocatable,dimension(:,:) :: u-->
PetscScalar,allocatable,dimension(:,:) :: u ????
Thanks a lot,
Anthony
