[petsc-users] Reg : Petsc installation failed
    Satish Balay
    balay at mcs.anl.gov
    Fri Jun 19 11:35:45 CDT 2015
Please keep the conversation on list. [or use petsc-maint]
On Fri, 19 Jun 2015, Manish Kumar K wrote:
> Hi Satish,
>     I did as per your  following instructions mentioned below for PETSC to install on my system using MS compilers ,
> For some reasons its flagging me the same error .
> I have attached configure.log file with this email and snap shot of error in bash.
> Steps followed
> 1)I installed Cygwin freshly and used latest PETSc release 3.6.
Hm - I see latest cygwin as:
CYGWIN_NT-6.1 ps4 2.0.4(0.287/5/3) 2015-06-09 12:22 x86_64 Cygwin
However configure.log has:
('CYGWIN_NT-6.1', 'EESBLRW106', '2.0.2(0.287/5/3)', '2015-05-08 17:00', 'x86_64', '')
a slightly older version. Are you sure you've install a fresh cygwin?
Also can you try the following? Copy/paste and e-mail the complete output.
cd src/benchmarks
/cygdrive/d/Software/Cygwin64/package/petsc/bin/win32fe/win32fe cl -c sizeof.c
echo $?
/cygdrive/d/Software/Cygwin64/package/petsc/bin/win32fe/win32fe cl -o sizeof.exe sizeof.c
echo $?
./sizeof.exe
Satish
balay at ps4 ~/petsc/src/benchmarks
$ ~/petsc/bin/win32fe/win32fe.exe cl -c sizeof.c
sizeof.c
$ echo $?
0
$ ~/petsc/bin/win32fe/win32fe.exe cl -o sizeof.exe sizeof.o
$ echo $?
0
$ ./sizeof.exe
long double : 8
double      : 8
int         : 4
char        : 1
short       : 2
long        : 4
long long   : 8
int *       : 8
size_t      : 8
> And followed same command as per the instructions mentioned at this link
> http://www.mcs.anl.gov/petsc/documentation/installation.html#windows
> Kindly help me out in this .
> Let me know if I missed anything.
> Regards
> Manish K
> _______________________________________________________________________________________________________________________________________
> -----Original Message-----
> From: Satish Balay [mailto:balay at mcs.anl.gov]
> Sent: Thursday, June 18, 2015 7:45 PM
> To: Manish Kumar K
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Reg : Petsc installation failed
> Executing: /package/petsc/petsc-3.5.3/bin/win32fe/win32fe cl -c -o /cygdrive/c/Users/20055335/AppData/Local/Temp/petsc-leuQLz/config.setCompilers/conftest.o -I/cygdrive/c/Users/20055335/AppData/Local/Temp/petsc-leuQLz/config.setCompilers   /cygdrive/c/Users/20055335/AppData/Local/Temp/petsc-leuQLz/config.setCompilers/conftest.c
> Possible ERROR while running compiler: exit code 50176 <<<<<
> For some reason the compiler is returning error codes. Just to eliminate cygwin from the equation - can you do the following:
> 1. reboot the machine
> 2. [make sure you don't start any cygwin processes] 3. run cygwin setup [it defaults to update mode] - and run it to completion.
> It should run rebaseall at the end.
> 4. Use petsc-3.6
> And rerun configure [from compiler-cmd,bash per instructions]
> Satish
> On Thu, 18 Jun 2015, Manish Kumar K wrote:
> > Dear PETSc Team,
> >          I am configuring and trying to install PETSc libraries  using
> > Cygwin shell for windows
> > I checked instructions at:
> > And invoked following command
> > Step 1:
> > ./configure --with-cc='win32fe cl' --with-fc=0
> > --download-f2cblaslapack=1
> > C compiler you provided with -with-cc=win32fe cl does not work.
> > Cannot compile C with /package/petsc/petsc-3.5.3/bin/win32fe/win32fe cl.
> > I am sending you the log file for this .
> > Please help me out in this .
> > Regards
> > Manish K
> > [https://relayq.larsentoubro.com/DigitalSignature2015.jpg]
> > L&T Technology Services Ltd
> > www.LntTechservices.com<http://www.lnttechservices.com/>
> > This Email may contain confidential or privileged information for the intended recipient (s). If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
