[petsc-users] Reg : Petsc installation failed
    Satish Balay
    balay at mcs.anl.gov
    Thu Jun 18 09:15:05 CDT 2015
Executing: /package/petsc/petsc-3.5.3/bin/win32fe/win32fe cl -c -o /cygdrive/c/Users/20055335/AppData/Local/Temp/petsc-leuQLz/config.setCompilers/conftest.o -I/cygdrive/c/Users/20055335/AppData/Local/Temp/petsc-leuQLz/config.setCompilers   /cygdrive/c/Users/20055335/AppData/Local/Temp/petsc-leuQLz/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 50176
For some reason the compiler is returning error codes. Just to eliminate cygwin from
the equation - can you do the following:
1. reboot the machine
2. [make sure you don't start any cygwin processes]
3. run cygwin setup [it defaults to update mode] - and run it to completion.
It should run rebaseall at the end.
4. Use petsc-3.6
And rerun configure [from compiler-cmd,bash per instructions]
Satish
On Thu, 18 Jun 2015, Manish Kumar K wrote:
> Dear PETSc Team,
>          I am configuring and trying to install PETSc libraries  using Cygwin shell for windows
> I checked instructions at:
> http://www.mcs.anl.gov/petsc/documentation/installation.html#windows
> And invoked following command
> Step 1:
> ./configure --with-cc='win32fe cl' --with-fc=0 --download-f2cblaslapack=1
> C compiler you provided with -with-cc=win32fe cl does not work.
> Cannot compile C with /package/petsc/petsc-3.5.3/bin/win32fe/win32fe cl.
> I am sending you the log file for this .
> Please help me out in this .
> Regards
> Manish K
> [https://relayq.larsentoubro.com/DigitalSignature2015.jpg]
> L&T Technology Services Ltd
> www.LntTechservices.com<http://www.lnttechservices.com/>
> This Email may contain confidential or privileged information for the intended recipient (s). If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
