[petsc-users] Varying TAO optimization solve iterations using BLMVM
Thu Jun 18 13:45:23 CDT 2015
On Thu, Jun 18, 2015 at 12:15 PM, Jason Sarich <jason.sarich at gmail.com>
wrote:
> Hi Justin,
> I can't tell for sure why this is happening, have you tried using quad
> precision to make sure that numerical cutoffs isn't the problem?
> 1 The Hessian being approximate and the resulting implicit computation is
> the source of the cutoff, but would not be causing different convergence
> rates in infinite precision.
> 2 the local size may affect load balancing but not the resulting
> norms/convergence rate.
This sounds to be like the preconditioner is dependent on the partition.
Can you send -tao_view -snes_view
  Matt
> Jason
> On Thu, Jun 18, 2015 at 10:44 AM, Justin Chang <jychang48 at gmail.com>
> wrote:
>>  I solved a transient diffusion across multiple cores using TAO BLMVM.
>> When I simulate the same problem but on different numbers of processing
>> cores, the number of solve iterations change quite drastically. The
>> numerical solution is the same, but these changes are quite vast. I
>> attached a PDF showing a comparison between KSP and TAO. KSP remains
>> largely invariant with number of processors but TAO (with bounded
>> constraints) fluctuates.
>> My question is, why is this happening? I understand that accumulation of
>> numerical round-offs may attribute to this, but the differences seem quite
>> vast to me. My initial thought was that
>>  1) the Hessian is only projected and not explicitly computed, which may
>> have something to do with the rate of convergence
>> 2) local problem size. Certain regions of my domain have different number
>> of "violations" which need to be corrected by the bounded constraints so
>> the rate of convergence depends on how these regions are partitioned?
>> Any thoughts?
>> Thanks,
>> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150618/b6b69e2f/attachment.html>
