[petsc-users] Parameter to pick KSP for estimating eigenvalues	for Chebyshev
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Jun 17 15:27:23 CDT 2015
  It is now in maint, master and next and will be in the next patch release.
  Barry
> On Jun 17, 2015, at 3:19 PM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> On 17 June 2015 at 20:33, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Hmm. How can I reproduce this? I tested my fix with both -pc_type mg and -pc_type gamg and it changed in both cases -mg_levels_esteig_ksp_type cg
> I've tried again, and it works. Thanks. I must have screwed up and not
> linked to the patched version of PETSc.
> Will the patch find its way into the dev version?
> Garth
>>  Barry
>>> On Jun 17, 2015, at 12:59 PM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>>> On 17 June 2015 at 15:43, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>  I introduced a bug in my cleanup. The kspest eigenestimator was created AFTER the KSPSetFromOptions_Chebyshev() hence the options for controlling the KSP estimator were never processed.
>>>>  I've attached a patch, please let me know how it goes.
>>> I've applied the patch, but I still can't change the Krylov method for
>>> estimating the eigenvalues.
>>> Garth
>>>> Barry
>>>>> On Jun 17, 2015, at 6:24 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>>>>> It used to be possible to pick the Krylov solver used to estimate the
>>>>> eigenvalues for Chebyshev, via the parameter system
>>>>> ("mg_levels_est_ksp_type" and "gamg_est_ksp_type"). I know there was
>>>>> some clean-up, with the parameters becoming
>>>>> "mg_levels_ksp_chebyshev_esteig_foo", but an option to pick the Krylov
>>>>> solver appears to be missing. Or have I overlooked it?
>>>>> Garth
