[petsc-users] Tao iterations
Jed Brown jed at jedbrown.org
Mon Jun 8 09:39:39 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> Hi Jason,
> One more question about BLMVM... if it only uses gradient information and
> does not require the definitition of a Hessian Matrix, can this method be
> applied to solve problems that are nonsymmetric by nature? (e.g.,
> advection-diffusion equations).
Such equations do not have an associated objective functional, thus you
don't have the "gradient" of something, you just have a system of
nonlinear equations.  (There are ways to formulate such systems as
optimization, but they have issues like you mention.)  Reformulating
nonlinear equations as optimization can also turn a problem with a
unique solution into one with local minima, for which it may be
impossible to guarantee that you have reached a global minimum.
Use SNES for solving nonlinear equations.  You can try the quasi-Newton
methods, which are related to BLMVM.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150608/c32f7762/attachment.pgp>
