[petsc-users] Tao iterations
    Justin Chang
    jychang48 at gmail.com
    Mon Jun  8 05:16:53 CDT 2015
Hi Jason,
One more question about BLMVM... if it only uses gradient information and
does not require the definitition of a Hessian Matrix, can this method be
applied to solve problems that are nonsymmetric by nature? (e.g.,
advection-diffusion equations). If I had wanted to solve the same equations
using TRON I would need to rewrite the problem as "normal equations" (i.e.,
min 1/2*||K*u - f||^2 or min 1/2*u^T*K^T*K*u - u^T*K^T*f)  so that I get a
symmetric Hessian (but this method results in extremely high condition
numbers and renders the numerical solution less reliable and accurate).
Justin
On Wed, Apr 29, 2015 at 5:53 PM, Justin Chang <jchang27 at uh.edu> wrote:
> Okay that's what I figured, thanks you very much
> On Wed, Apr 29, 2015 at 10:39 AM, Jason Sarich <jason.sarich at gmail.com>
> wrote:
>> Hi Justin,
>> This expected behavior due to the accumulation of numerical round-offs.
>> If this is a problem or if you just want to confirm that this is the cause,
>> you can try configuring PETSc for quad precision
>> (--with-precision=__float128, works with GNU compilers) and the results
>> should match better.
>> Jason
>> On Tue, Apr 28, 2015 at 10:19 PM, Justin Chang <jchang27 at uh.edu> wrote:
>>>   Jason (or anyone),
>>>  I am noticing that the iteration numbers reported by
>>> TaoGetSolutionStatus() for blmvm differ whenever I change the number of
>>> processes. The solution seems to remain the same though. Is there a reason
>>> why this could be happening?
>>>  Thanks,
>>> On Tue, Apr 21, 2015 at 10:40 AM, Jason Sarich <jason.sarich at gmail.com>
>>> wrote:
>>>> Justin,
>>>>  1) The big difference between TRON and BLMVM is that TRON requires
>>>> hessian information, BLMVM only uses gradient information. Thus TRON will
>>>> usually converge faster, but requires more information, memory, and a KSP
>>>> solver. GPCG (gradient projected conjugate gradient) is another
>>>> gradient-only option, but usually performs worse than BLMVM.
>>>>  2) TaoGetLinearSolveIterations() will get the total number of KSP
>>>> iterations per solve
>>>>  Jason
>>>> On Tue, Apr 21, 2015 at 10:33 AM, Justin Chang <jychang48 at gmail.com>
>>>> wrote:
>>>>>    Jason,
>>>>>  Tightening the tolerances did the trick. Thanks. Though I do have a
>>>>> couple more related questions:
>>>>>  1) Is there a general guideline for choosing tron over blmvm or vice
>>>>> versa? Also is there another tao type that is also suitable given only
>>>>> bounded constraints?
>>>>>  2) Is it possible to obtain the total number of KSP and/or PG
>>>>> iterations from tron?
>>>>>  Thanks,
>>>>>  Justin
>>>>> On Tue, Apr 21, 2015 at 9:52 AM, Jason Sarich <jason.sarich at gmail.com>
>>>>> wrote:
>>>>>>  Hi Justin,
>>>>>>  blmvm believes that it is already sufficiently close to a minimum,
>>>>>> so it doesn't do anything. You may need to tighten some of the tolerance to
>>>>>> force an iteration.
>>>>>>  Jason
>>>>>>  On Tue, Apr 21, 2015 at 9:48 AM, Justin Chang <jychang48 at gmail.com>
>>>>>> wrote:
>>>>>>>    Time step 1:
>>>>>>> Tao Object: 1 MPI processes
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>   TaoLineSearch Object:   1 MPI processes
>>>>>>>     type: more-thuente
>>>>>>>   Active Set subset type: subvec
>>>>>>>   convergence tolerances: fatol=0.0001,   frtol=0.0001
>>>>>>>   convergence tolerances: gatol=0,   steptol=0,   gttol=0
>>>>>>>   Residual in Function/Gradient:=0.0663148
>>>>>>>   Objective value=-55.5945
>>>>>>>   total number of iterations=35,                          (max: 2000)
>>>>>>>   total number of function/gradient evaluations=37,      (max: 4000)
>>>>>>>   Solution converged:   estimated |f(x)-f(X*)|/|f(X*)| <= frtol
>>>>>>>  Time step 2:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>>   Residual in Function/Gradient:=0.0682307
>>>>>>>   Objective value=-66.9675
>>>>>>>   total number of iterations=23,                          (max: 2000)
>>>>>>>   total number of function/gradient evaluations=25,      (max: 4000)
>>>>>>> Time step 3:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>>   Residual in Function/Gradient:=0.0680522
>>>>>>>   Objective value=-71.8211
>>>>>>>   total number of iterations=19,                          (max: 2000)
>>>>>>>   total number of function/gradient evaluations=22,      (max: 4000)
>>>>>>> Time step 4:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>>   Residual in Function/Gradient:=0.0551556
>>>>>>>   Objective value=-75.1252
>>>>>>>   total number of iterations=18,                          (max: 2000)
>>>>>>>   total number of function/gradient evaluations=20,      (max: 4000)
>>>>>>> Time step 5:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>>   Residual in Function/Gradient:=0.0675667
>>>>>>>   Objective value=-77.4414
>>>>>>>   total number of iterations=6,                          (max: 2000)
>>>>>>>   total number of function/gradient evaluations=8,      (max: 4000)
>>>>>>> Time step 6:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>>   Residual in Function/Gradient:=0.059143
>>>>>>>   Objective value=-79.5007
>>>>>>>   total number of iterations=3,                          (max: 2000)
>>>>>>>   total number of function/gradient evaluations=5,      (max: 4000)
>>>>>>> Time step 7:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>>   Residual in Function/Gradient:=0.0433683
>>>>>>>   Objective value=-81.3546
>>>>>>>   total number of iterations=5,                          (max: 2000)
>>>>>>> Time step 8:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>>   Residual in Function/Gradient:=0.0840676
>>>>>>>   Objective value=-82.9382
>>>>>>>   total number of iterations=0,                          (max: 2000)
>>>>>>>   total number of function/gradient evaluations=1,      (max: 4000)
>>>>>>> Time step 9:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>> Time step 10:
>>>>>>>   type: blmvm
>>>>>>>       Gradient steps: 0
>>>>>>>     type: more-thuente
>>>>>>> On Tue, Apr 21, 2015 at 9:28 AM, Jason Sarich <
>>>>>>> jason.sarich at gmail.com> wrote:
>>>>>>>> Hi Justin,
>>>>>>>>  what reason is blmvm giving for stopping the solve? (you can use
>>>>>>>> -tao_view or -tao_converged_reason to get this)
>>>>>>>>  Jason
>>>>>>>> On Mon, Apr 20, 2015 at 6:32 PM, Justin Chang <jychang48 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>>   Jason,
>>>>>>>>>  I am using TaoGetSolutionStatus(tao,&its, ...) and it gives me
>>>>>>>>> exactly what I want. However, I seem to be having an issue with blmvm
>>>>>>>>>  I wrote my own backward euler code for a transient linear
>>>>>>>>> diffusion problem with lower bounds >= 0 and upper bounds <= 1. For the
>>>>>>>>> first several time steps I am getting its > 0, and it decreases over time
>>>>>>>>> due to the nature of the discrete maximum principles. However, at some
>>>>>>>>> point my its become 0 and the solution does not "update", which seems to me
>>>>>>>>> that TaoSolve is not doing anything after that. This doesn't happen if I
>>>>>>>>> were to use tron (my KSP and PC are cg and jacobi respectively).
>>>>>>>>>  Do you know why this behavior may occur?
>>>>>>>>>  Thanks,
>>>>>>>>> On Tue, Apr 14, 2015 at 9:35 AM, Jason Sarich <
>>>>>>>>>> Hi Justin,
>>>>>>>>>>  I have pushed these changes to the "next" branch, your code
>>>>>>>>>> snippet should work fine there.
>>>>>>>>>>  Note that there is also available (since version 3.5.0) the
>>>>>>>>>> routine TaoGetSolutionStatus(tao,&its,NULL,NULL,NULL,NULL,NULL) which will
>>>>>>>>>> provide the
>>>>>>>>>> same information
>>>>>>>>>>  Jason
>>>>>>>>>> On Fri, Apr 10, 2015 at 6:28 PM, Justin Chang <
>>>>>>>>>> jychang48 at gmail.com> wrote:
>>>>>>>>>>>   Whatever is convenient and/or follow the "PETSc" standards.
>>>>>>>>>>> Something similar to SNESGetIterationNumber() or KSPGetIterationNumber()
>>>>>>>>>>> would be nice. Ideally I want my code to look like this:
>>>>>>>>>>>  ierr = TaoGetIterationNumber(tao,&its);CHKERRQ(ierr);
>>>>>>>>>>>  ierr = PetscPrintf(PETSC_COMM_WORLD, "Number of Tao iterations
>>>>>>>>>>> = %D\n", its);
>>>>>>>>>>>  Thanks :)
>>>>>>>>>>> On Fri, Apr 10, 2015 at 5:53 PM, Jason Sarich <
>>>>>>>>>>>> Hi Justin, I'll get this in. I assume that displaying the
>>>>>>>>>>>> number of iterations with tao_converged_reason is what you are asking for
>>>>>>>>>>>> in particular? Or did you have something else in mind?
>>>>>>>>>>>> Jason
>>>>>>>>>>>>  On Apr 10, 2015 16:42, "Smith, Barry F." <bsmith at mcs.anl.gov>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>   Justin,
>>>>>>>>>>>>>     Sorry TAO simply doesn't even collect this information
>>>>>>>>>>>>> currently. But yes we should definitely make it available!
>>>>>>>>>>>>>   Jason,
>>>>>>>>>>>>>      Could you please add this; almost all the TaoSolve_xxx()
>>>>>>>>>>>>> have a local variable iter; change that to tao->niter (I'm guess this is
>>>>>>>>>>>>> suppose to capture this information) and add a TaoGetIterationNumber() and
>>>>>>>>>>>>> the uses can access this. Also modify at the end of TaoSolve()
>>>>>>>>>>>>> -tao_converged_reason to also print the iteration count. At the same time
>>>>>>>>>>>>> since you add this you can add a tao->totalits which would accumulate all
>>>>>>>>>>>>> iterations over all the solves for that Tao object and the routine
>>>>>>>>>>>>> TaoGetTotalIterations() to access this.  Note that TaoSolve() would
>>>>>>>>>>>>> initialize tao->niter = 0 at the top.
>>>>>>>>>>>>>    Thanks
>>>>>>>>>>>>>   Barry
>>>>>>>>>>>>> > On Apr 10, 2015, at 4:16 PM, Justin Chang <jchang27 at uh.edu>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>  > Hi all,
>>>>>>>>>>>>> > Is there a way to generically obtain the number of Tao
>>>>>>>>>>>>> iterations? I am looking through the -help options for Tao and I don't see
>>>>>>>>>>>>> any metric where you can output this quantity in the manner that you could
>>>>>>>>>>>>> for SNES or KSP solves. I am currently using blmvm and tron, and the only
>>>>>>>>>>>>> way I can see getting this metric is by outputting -tao_view and/or
>>>>>>>>>>>>> -tao_monitor and manually finding this number. I find this cumbersome
>>>>>>>>>>>>> especially for transient problems where I would like to simply have this
>>>>>>>>>>>>> number printed for each step instead of ending up with unnecessary info.
>>>>>>>>>>>>> > Thanks,
>>>>>>>>>>>>> > Justin Chang
>>>>>>>>>>>>> > PhD Candidate, Civil Engineering - Computational Sciences
>>>>>>>>>>>>> > University of Houston, Department of Civil and Environmental
>>>>>>>>>>>>> Engineering
>>>>>>>>>>>>> > Houston, TX 77004
>>>>>>>>>>>>> > (512) 963-3262
>>>   Justin Chang
>>>  University of Houston, Department of Civil and Environmental Engineering
>>>  Houston, TX 77004
>>> (512) 963-3262
> Justin Chang
> Houston, TX 77004
> (512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150608/452df7ef/attachment-0001.html>
