[petsc-users] Can't expand MemType 1: jcol 16104
Anthony Paul Haas aph at email.arizona.edu
Mon Jul 27 13:25:30 CDT 2015
Hi Hong,
No that is not the correct matrix. Note that I forgot to mention that it is
a complex matrix. I tried loading the matrix I sent you this morning with:
!...Load a Matrix in Binary Format
      call
PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_READ,viewer,ierr)
      call MatCreate(PETSC_COMM_WORLD,DLOAD,ierr)
      call MatSetType(DLOAD,MATAIJ,ierr)
      call MatLoad(DLOAD,viewer,ierr)
      call PetscViewerDestroy(viewer,ierr)
      call MatView(DLOAD,PETSC_VIEWER_STDOUT_WORLD,ierr)
The first 37 rows should look like this:
Mat Object: 2 MPI processes
  type: mpiaij
row 0: (0, 1)
row 1: (1, 1)
row 2: (2, 1)
row 3: (3, 1)
row 4: (4, 1)
row 5: (5, 1)
row 6: (6, 1)
row 7: (7, 1)
row 8: (8, 1)
row 9: (9, 1)
row 10: (10, 1)
row 11: (11, 1)
row 12: (12, 1)
row 13: (13, 1)
row 14: (14, 1)
row 15: (15, 1)
row 16: (16, 1)
row 17: (17, 1)
row 18: (18, 1)
row 19: (19, 1)
row 20: (20, 1)
row 21: (21, 1)
row 22: (22, 1)
row 23: (23, 1)
row 24: (24, 1)
row 25: (25, 1)
row 26: (26, 1)
row 27: (27, 1)
row 28: (28, 1)
row 29: (29, 1)
row 30: (30, 1)
row 31: (31, 1)
row 32: (32, 1)
row 33: (33, 1)
row 34: (34, 1)
row 35: (35, 1)
row 36: (1, -41.2444)  (35, -41.2444)  (36, 118.049 - 0.999271 i) (37,
-21.447)  (38, 5.18873)  (39, -2.34856)  (40, 1.3607)  (41, -0.898206)
(42, 0.642715)  (43, -0.48593)  (44, 0.382471)  (45, -0.310476)  (46,
0.258302)  (47, -0.219268)  (48, 0.189304)  (49, -0.165815)  (50,
0.147076)  (51, -0.131907)  (52, 0.119478)  (53, -0.109189)  (54, 0.1006)
(55, -0.0933795)  (56, 0.0872779)  (57, -0.0821019)  (58, 0.0777011)  (59,
-0.0739575)  (60, 0.0707775)  (61, -0.0680868)  (62, 0.0658258)  (63,
-0.0639473)  (64, 0.0624137)  (65, -0.0611954)  (66, 0.0602698)  (67,
-0.0596202)  (68, 0.0592349)  (69, -0.0295536)  (71, -21.447)  (106,
5.18873)  (141, -2.34856)  (176, 1.3607)  (211, -0.898206)  (246,
0.642715)  (281, -0.48593)  (316, 0.382471)  (351, -0.310476)  (386,
0.258302)  (421, -0.219268)  (456, 0.189304)  (491, -0.165815)  (526,
0.147076)  (561, -0.131907)  (596, 0.119478)  (631, -0.109189)  (666,
0.1006)  (701, -0.0933795)  (736, 0.0872779)  (771, -0.0821019)  (806,
0.0777011)  (841, -0.0739575)  (876, 0.0707775)  (911, -0.0680868)  (946,
0.0658258)  (981, -0.0639473)  (1016, 0.0624137)  (1051, -0.0611954)
(1086, 0.0602698)  (1121, -0.0596202)  (1156, 0.0592349)  (1191,
-0.0295536)  (1261, 0)  (3676, 117.211)  (3711, -58.4801)  (3746,
-78.3633)  (3781, 29.4911)  (3816, -15.8073)  (3851, 9.94324)  (3886,
-6.87205)  (3921, 5.05774)  (3956, -3.89521)  (3991, 3.10522)  (4026,
-2.54388)  (4061, 2.13082)  (4096, -1.8182)  (4131, 1.57606)  (4166,
-1.38491)  (4201, 1.23155)  (4236, -1.10685)  (4271, 1.00428)  (4306,
-0.919116)  (4341, 0.847829)  (4376, -0.787776)  (4411, 0.736933)  (4446,
-0.693735)  (4481, 0.656958)  (4516, -0.625638)  (4551, 0.599007)  (4586,
-0.576454)  (4621, 0.557491)  (4656, -0.541726)  (4691, 0.528849)  (4726,
-0.518617)  (4761, 0.51084)  (4796, -0.50538)  (4831, 0.502142)  (4866,
-0.250534)
Anthony
On Fri, Jul 24, 2015 at 7:56 PM, Hong <hzhang at mcs.anl.gov> wrote:
> Anthony:
> I test your Amat_binary.m
> using petsc/src/ksp/ksp/examples/tutorials/ex10.c.
> Your matrix has many zero rows:
> ./ex10 -f0 ~/tmp/Amat_binary.m -rhs 0 -mat_view |more
> Mat Object: 1 MPI processes
>   type: seqaij
> row 0: (0, 1)
> row 1: (1, 0)
> row 2: (2, 1)
> row 3: (3, 0)
> row 4: (4, 1)
> row 5: (5, 0)
> row 6: (6, 1)
> row 7: (7, 0)
> row 8: (8, 1)
> row 9: (9, 0)
> row 36: (1, 1)  (35, 0)  (36, 1)  (37, 0)  (38, 1)  (39, 0)  (40, 1)  (41,
> 0)  (42, 1)  (43, 0)  (44, 1)  (45,
> 0)  (46, 1)  (47, 0)  (48, 1)  (49, 0)  (50, 1)  (51, 0)  (52, 1)  (53, 0)
>  (54, 1)  (55, 0)  (56, 1)  (57, 0)
>  (58, 1)  (59, 0)  (60, 1)  ...
> Do you send us correct matrix?
>> I ran my code through valgrind and gdb as suggested by Barry. I am now
>> coming back to some problem I have had while running with parallel symbolic
>> factorization. I am attaching a test matrix (petsc binary format) that I LU
>> decompose and then use to solve a linear system (see code below). I can run
>> on 2 processors with parsymbfact or with 4 processors without parsymbfact.
>> However, if I run on 4 procs with parsymbfact, the code is just hanging.
>> Below is the simplified test case that I have used to test. The matrix A
>> and B are built somewhere else in my program. The matrix I am attaching is
>> A-sigma*B (see below).
>> One thing is that I don't know for sparse matrices what is the optimum
>> number of processors to use for a LU decomposition? Does it depend on the
>> total number of nonzero? Do you have an easy way to compute it?
> You have to experiment your matrix on a target machine to find out.
> Hong
>>      Subroutine HowBigLUCanBe(rank)
>>       IMPLICIT NONE
>>       integer(i4b),intent(in) :: rank
>>       integer(i4b)            :: i,ct
>>       real(dp)                :: begin,endd
>>       complex(dpc)            :: sigma
>>       PetscErrorCode ierr
>>       if (rank==0) call cpu_time(begin)
>>       if (rank==0) then
>>          write(*,*)
>>          write(*,*)'Testing How Big LU Can Be...'
>>          write(*,*)'============================'
>>          write(*,*)
>>       endif
>>       sigma = (1.0d0,0.0d0)
>>       call MatAXPY(A,-sigma,B,DIFFERENT_NONZERO_PATTERN,ierr) ! on exit A
>> = A-sigma*B
>> !.....Write Matrix to ASCII and Binary Format
>>       !call PetscViewerASCIIOpen(PETSC_COMM_WORLD,"Amat.m",viewer,ierr)
>>       !call MatView(DXX,viewer,ierr)
>>       !call PetscViewerDestroy(viewer,ierr)
>>       call
>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_WRITE,viewer,ierr)
>>       call MatView(A,viewer,ierr)
>> !.....Create Linear Solver Context
>>       call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>> !.....Set operators. Here the matrix that defines the linear system also
>> serves as the preconditioning matrix.
>>       !call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr) !aha
>> commented and replaced by next line
>>       call KSPSetOperators(ksp,A,A,ierr) ! remember: here A = A-sigma*B
>> !.....Set Relative and Absolute Tolerances and Uses Default for
>> Divergence Tol
>>       tol = 1.e-10
>>       call
>> KSPSetTolerances(ksp,tol,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr)
>> !.....Set the Direct (LU) Solver
>>       call KSPSetType(ksp,KSPPREONLY,ierr)
>>       call KSPGetPC(ksp,pc,ierr)
>>       call PCSetType(pc,PCLU,ierr)
>>       call PCFactorSetMatSolverPackage(pc,MATSOLVERSUPERLU_DIST,ierr) !
>> MATSOLVERSUPERLU_DIST MATSOLVERMUMPS
>> !.....Create Right-Hand-Side Vector
>>       call MatCreateVecs(A,frhs,PETSC_NULL_OBJECT,ierr)
>>       call MatCreateVecs(A,sol,PETSC_NULL_OBJECT,ierr)
>>       allocate(xwork1(IendA-IstartA))
>>       allocate(loc(IendA-IstartA))
>>       ct=0
>>       do i=IstartA,IendA-1
>>          ct=ct+1
>>          loc(ct)=i
>>          xwork1(ct)=(1.0d0,0.0d0)
>>       enddo
>>       call VecSetValues(frhs,IendA-IstartA,loc,xwork1,INSERT_VALUES,ierr)
>>       call VecZeroEntries(sol,ierr)
>>       deallocate(xwork1,loc)
>> !.....Assemble Vectors
>>       call VecAssemblyBegin(frhs,ierr)
>>       call VecAssemblyEnd(frhs,ierr)
>> !.....Solve the Linear System
>>       call KSPSolve(ksp,frhs,sol,ierr)
>>       !call VecView(sol,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>       if (rank==0) then
>>          call cpu_time(endd)
>>          write(*,*)
>>          print '("Total time for HowBigLUCanBe = ",f21.3,"
>> seconds.")',endd-begin
>>       endif
>>       call SlepcFinalize(ierr)
>>       STOP
>>     end Subroutine HowBigLUCanBe
>> On 07/08/2015 11:23 AM, Xiaoye S. Li wrote:
>>  Indeed, the parallel symbolic factorization routine needs power of 2
>> processes, however, you can use however many processes you need;
>> internally, we redistribute matrix to nearest power of 2 processes, do
>> symbolic, then redistribute back to all the processes to do factorization,
>> triangular solve etc.  So, there is no  restriction from the users
>> viewpoint.
>>  It's difficult to tell what the problem is.  Do you think you can print
>> your matrix, then, I can do some debugging by running superlu_dist
>> standalone?
>>  Sherry
>> On Wed, Jul 8, 2015 at 10:34 AM, Anthony Paul Haas <aph at email.arizona.edu
>> > wrote:
>>>   Hi,
>>>  I have used the switch -mat_superlu_dist_parsymbfact in my pbs script.
>>> However, although my program worked fine with sequential symbolic
>>> factorization, I get one of the following 2 behaviors when I run with
>>> parallel symbolic factorization (depending on the number of processors that
>>> I use):
>>>  1) the program just hangs (it seems stuck in some subroutine ==> see
>>> test.out-hangs)
>>>  2) I get a floating point exception ==> see
>>> test.out-floating-point-exception
>>>  Note that as suggested in the Superlu manual, I use a power of 2
>>> number of procs. Are there any tunable parameters for the parallel symbolic
>>> factorization? Note that when I build my sparse matrix, most elements I add
>>> are nonzero of course but to simplify the programming, I also add a few
>>> zero elements in the sparse matrix. I was thinking that maybe if the
>>> parallel symbolic factorization proceed by block, there could be some
>>> blocks where the pivot would be zero, hence creating the FPE??
>>>  Thanks,
>>>  Anthony
>>> On Wed, Jul 8, 2015 at 6:46 AM, Xiaoye S. Li <xsli at lbl.gov> wrote:
>>>>  Did you find out how to change option to use parallel symbolic
>>>> factorization?  Perhaps PETSc team can help.
>>>>  Sherry
>>>> On Tue, Jul 7, 2015 at 3:58 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
>>>>>  Is there an inquiry function that tells you all the available
>>>>> options?
>>>>>  Sherry
>>>>> On Tue, Jul 7, 2015 at 3:25 PM, Anthony Paul Haas <
>>>>> aph at email.arizona.edu> wrote:
>>>>>>    Hi Sherry,
>>>>>>  Thanks for your message. I have used superlu_dist default options.
>>>>>> I did not realize that I was doing serial symbolic factorization. That is
>>>>>> probably the cause of my problem.
>>>>>>  Each node on Garnet has 60GB usable memory and I can run with
>>>>>> 1,2,4,8,16 or 32 core per node.
>>>>>>  So I should use:
>>>>>> -mat_superlu_dist_r 20
>>>>>> -mat_superlu_dist_c 32
>>>>>>  How do you specify the parallel symbolic factorization option? is it
>>>>>> -mat_superlu_dist_matinput 1
>>>>>>  Thanks,
>>>>>>  Anthony
>>>>>> On Tue, Jul 7, 2015 at 3:08 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
>>>>>>>  For superlu_dist failure, this occurs during symbolic
>>>>>>> factorization.  Since you are using serial symbolic factorization, it
>>>>>>> requires the entire graph of A to be available in the memory of one MPI
>>>>>>> task. How much memory do you have for each MPI task?
>>>>>>>  It won't help even if you use more processes.  You should try to
>>>>>>> use parallel symbolic factorization option.
>>>>>>>  Another point.  You set up process grid as:
>>>>>>>        Process grid nprow 32 x npcol 20
>>>>>>>  For better performance, you show swap the grid dimension. That is,
>>>>>>> it's better to use 20 x 32, never gives nprow larger than npcol.
>>>>>>>  Sherry
>>>>>>> On Tue, Jul 7, 2015 at 1:27 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>>>    I would suggest running a sequence of problems, 101 by 101 111
>>>>>>>> by 111 etc and get the memory usage in each case (when you run out of
>>>>>>>> memory you can get NO useful information out about memory needs). You can
>>>>>>>> then plot memory usage as a function of problem size to get a handle on how
>>>>>>>> much memory it is using.  You can also run on more and more processes
>>>>>>>> (which have a total of more memory) to see how large a problem you may be
>>>>>>>> able to reach.
>>>>>>>>    MUMPS also has an "out of core" version (which we have never
>>>>>>>> used) that could in theory anyways let you get to large problems if you
>>>>>>>> have lots of disk space, but you are on your own figuring out how to use it.
>>>>>>>>   Barry
>>>>>>>> > On Jul 7, 2015, at 2:37 PM, Anthony Paul Haas <
>>>>>>>> > Hi Jose,
>>>>>>>> > In my code, I use once PETSc to solve a linear system to get the
>>>>>>>> baseflow (without using SLEPc) and then I use SLEPc to do the stability
>>>>>>>> analysis of that baseflow. This is why, there are some SLEPc options that
>>>>>>>> are not used in test.out-superlu_dist-151x151 (when I am solving for the
>>>>>>>> baseflow with PETSc only). I have attached a 101x101 case for which I get
>>>>>>>> the eigenvalues. That case works fine. However If i increase to 151x151, I
>>>>>>>> get the error that you can see in test.out-superlu_dist-151x151 (similar
>>>>>>>> error with mumps: see test.out-mumps-151x151 line 2918 ). If you look a the
>>>>>>>> very end of the files test.out-superlu_dist-151x151 and
>>>>>>>> test.out-mumps-151x151, you will see that the last info message printed is:
>>>>>>>> > On Processor (after EPSSetFromOptions)  0    memory:
>>>>>>>> 0.65073152000E+08          =====>  (see line 807 of module_petsc.F90)
>>>>>>>> > This means that the memory error probably occurs in the call to
>>>>>>>> EPSSolve (see module_petsc.F90 line 810). I would like to evaluate how much
>>>>>>>> memory is required by the most memory intensive operation within EPSSolve.
>>>>>>>> Since I am solving a generalized EVP, I would imagine that it would be the
>>>>>>>> LU decomposition. But is there an accurate way of doing it?
>>>>>>>> > Before starting with iterative solvers, I would like to exploit
>>>>>>>> as much as I can direct solvers. I tried GMRES with default preconditioner
>>>>>>>> at some point but I had convergence problem. What solver/preconditioner
>>>>>>>> would you recommend for a generalized non-Hermitian (EPS_GNHEP) EVP?
>>>>>>>> > Thanks,
>>>>>>>> > Anthony
>>>>>>>> > On Tue, Jul 7, 2015 at 12:17 AM, Jose E. Roman <
>>>>>>>> jroman at dsic.upv.es> wrote:
>>>>>>>> > El 07/07/2015, a las 02:33, Anthony Haas escribió:
>>>>>>>> > > Hi,
>>>>>>>> > > I am computing eigenvalues using PETSc/SLEPc and superlu_dist
>>>>>>>> for the LU decomposition (my problem is a generalized eigenvalue problem).
>>>>>>>> The code runs fine for a grid with 101x101 but when I increase to 151x151,
>>>>>>>> I get the following error:
>>>>>>>> > > Can't expand MemType 1: jcol 16104   (and then [NID 00037]
>>>>>>>> 2015-07-06 19:19:17 Apid 31025976: OOM killer terminated this process.)
>>>>>>>> > > It seems to be a memory problem. I monitor the memory usage as
>>>>>>>> far as I can and it seems that memory usage is pretty low. The most memory
>>>>>>>> intensive part of the program is probably the LU decomposition in the
>>>>>>>> context of the generalized EVP. Is there a way to evaluate how much memory
>>>>>>>> will be required for that step? I am currently running the debug version of
>>>>>>>> the code which I would assume would use more memory?
>>>>>>>> > > I have attached the output of the job. Note that the program
>>>>>>>> uses twice PETSc: 1) to solve a linear system for which no problem occurs,
>>>>>>>> and, 2) to solve the Generalized EVP with SLEPc, where I get the error.
>>>>>>>> > > Thanks
>>>>>>>> > > Anthony
>>>>>>>> > > <test.out-superlu_dist-151x151>
>>>>>>>> > In the output you are attaching there are no SLEPc objects in the
>>>>>>>> report and SLEPc options are not used. It seems that SLEPc calls are
>>>>>>>> skipped?
>>>>>>>> > Do you get the same error with MUMPS? Have you tried to solve
>>>>>>>> linear systems with a preconditioned iterative solver?
>>>>>>>> > Jose
>>>>>>>> <module_petsc.F90><test.out-mumps-151x151><test.out_superlu_dist-101x101><test.out-superlu_dist-151x151>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150727/ff4933d7/attachment-0001.html>
