[petsc-users] TSSolve problems
Abhyankar, Shrirang G. abhyshr at anl.gov
Thu Jul 23 16:35:16 CDT 2015
Xinya,
  Take a look at the example
$PETSC_DIR/src/snes/examples/tutorials/network/pflow/pf.c This example
models power grid steady-state equations (power flow) using DMNetwork.
Shri
-----Original Message-----
Date: Thursday, July 23, 2015 at 3:18 PM
To: Shri <abhyshr at anl.gov>
Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Subject: RE: [petsc-users] TSSolve problems
>Shri,
>Thank you for your suggestion.
>In the code, DMDACreat1D was used to create distributed array to manage
>parallel grid and vectors:
>DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, 4*ngen, 1, 1, NULL, &da);
>How to use DMPlex/DMnetwork instead of DMDA? Which function should I call?
>Thanks Again.
>Regards
>Xinya
>__________________________________________________
>Xinya Li
>Scientist
>EED/Hydrology
>Pacific Northwest National Laboratory
>From: Abhyankar, Shrirang G. [mailto:abhyshr at anl.gov]
>Sent: Tuesday, June 30, 2015 7:00 AM
>To: Li, Xinya
>Cc: petsc-users at mcs.anl.gov
>Subject: Re: [petsc-users] TSSolve problems
>Note also that the use of DMDA is incorrect in your example. DMDA is for
>managing structured grids, while your example application (power grid
>dynamics simulation) has an unstructured network. Using DMNetwork or
>DMPlex would be more appropriate.
>Shri
>From: barry smith <bsmith at mcs.anl.gov>
>Date: Monday, June 29, 2015 at 10:28 PM
>To: "Li, Xinya" <Xinya.Li at pnnl.gov>
>>> On Jun 29, 2015, at 1:35 PM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
>>> Yes. it is C++.
>>> I attached the major routines for TSSolve.
>>   Thanks. There is not much in the functions to explain why they are
>>taking the vast bulk of the time but I am going to go out on a limb and
>>guess that it is the C++ implementation of complex numbers and the use
>>of the cos() and sin() of those complex numbers that it causing the
>>terrible performance.
>>  Since your code has actually very little C++ specific stuff in it I
>>would suggest building PETSc without the --with-clanguage=c++ and use C
>>for everything, changing your code as needed to remove the C++ isms. In
>>C99 complex is a native data type (not a C++ class) so can potentially
>>give better performance.
>>  Barry
>>> Thanks
>>> Xinya
>>> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
>>> Sent: Monday, June 29, 2015 11:27 AM
>>> To: Li, Xinya
>>>  Is your code C++?
>>>                             count        time               percent
>>>time
>>> TSStep                     600    3.1174e+02    100
>>> TSFunctionEval      2937    1.4288e+02     46
>>> TSJacobianEval      1737    1.3074e+02    42
>>> KSPSolve                1737    3.5144e+01    11
>>>  Ok I pulled out the important time from the table.  46 percent of
>>>the time is in your function evaluation, 42 percent in the Jacobian
>>>evaluation and 11 percent in the linear solve.
>>>  The only way to improve the time significantly is by speeding up the
>>>function and Jacobian computations. What is happening in those
>>>routines, can you email them?
>>>  Barry
>>>> On Jun 29, 2015, at 11:57 AM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
>>>> Barry,
>>>> Here is the new output without debugging.
>>>> Thank you.
>>>> Xinya
>>>> Sent: Friday, June 26, 2015 12:04 PM
>>>> To: Li, Xinya
>>>>     #                          WARNING!!!                    #
>>>>     #   This code was compiled with a debugging option,      #
>>>>     #   To get timing results run ./configure                #
>>>>     #   using --with-debugging=no, the performance will      #
>>>>     #   be generally two or three times faster.              #
>>>> First you need to configure PETSc again without all the debugging.
>>>>So do, for example,
>>>> export PETSC=arch-opt
>>>> ./configure --with-cc=gcc --with-fc=gfortran --with-cxx=g++
>>>>--with-scalar-type=complex --with-clanguage=C++
>>>>--with-cxx-dialect=C++11  --download-mpich --download-superlu_dist
>>>>--download-mumps --download-scalapack --download-parmetis
>>>>--download-metis --download-elemental make all test
>>>> then recompile and rerun your example again with -log_summary and
>>>>send the output.
>>>> Note that you should not pass --download-fblaslapack nor the fortran
>>>>kernel stuff.
>>>> Barry
>>>>> On Jun 26, 2015, at 12:16 PM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
>>>>> Barry,
>>>>> Thank you for your response.
>>>>> Attached is the output. SNESSolve was taking most of the time.
>>>>> Xinya
>>>>> Sent: Thursday, June 25, 2015 5:47 PM
>>>>> To: Li, Xinya
>>>>> Run with -ts_view -log_summary and send the output. This will tell
>>>>>the current solvers and where the time is being spent.
>>>>> Barry
>>>>>> On Jun 25, 2015, at 6:37 PM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
>>>>>> Dear Sir,
>>>>>> I am using the ts solver to solve a set of ODE and DAE. The
>>>>>>Jacobian matrix is a 1152 *1152 sparse complex matrix.
>>>>>> Each TSStep in TSSolve is taking nearly 1 second. Thus, I need  to
>>>>>>improve the speed of TSSolve.
>>>>>> Which parts should be taking into account to accelerate TSSolve?
>>>>>> Thank you very much.
>>>>>> Regards
>>>>>> Xinya Li
>>>>>> Scientist
>>>>>> EED/Hydrology
>>>>>> 902 Battelle Boulevard
>>>>>> P.O. Box 999, MSIN K9-33
>>>>>> Richland, WA  99352 USA
>>>>>> Tel:  509-372-6248
>>>>>> Fax: 509-372-6089
>>>>>> Xinya.Li at pnl.gov
>>>>> <288g1081b_short.log>
>>>> <d288gen.log>
>>> <simulation.C>
