[petsc-users] KSP changes for successive solver
Michele Rosso
mrosso at uci.edu
Sun Jul 19 11:08:50 CDT 2015
Mark,
at first I thought the problem was due to my custom PC, but the same
happens if I use (see attached files):
-mg_coarse_ksp_type preonly
-mg_coarse_pc_type gamg
If instead I use a direct solver, say:
-mg_coarse_pc_type lu
the coarse KSP is set correctly.
Michele
On Sun, 2015-07-19 at 10:42 -0400, Mark Adams wrote:
> On Thu, Jul 16, 2015 at 5:53 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Hi,
> I am performing a series of solves inside a loop. The matrix
> for each solve changes but not enough to justify a rebuilt of
> the PC at each solve.
> Therefore I am using KSPSetReusePreconditioner to avoid
> rebuilding unless necessary. The solver is CG + MG with a
> custom PC at the coarse level.
> Ah, OK this is the problem. The code I just sent gets fooled but your
> custom PC, probably.
> We should just remove this paternal code:
> PetscBool preonly,lu,redundant,cholesky,svd
> If coarse solver is not direct method then DO NOT USE preonly
> ierr =
> PetscObjectTypeCompare((PetscObject)mglevels[0]->smoothd,KSPPREONLY,&preonly);CHKERRQ(ierr);
> if (preonly) {
> ierr =
> PetscObjectTypeCompare((PetscObject)cpc,PCBJACOBI,&bjaclu);CHKERRQ(ierr);
> if (bjaclu) {
> KSP *k2;
> PetscInt ii,first;
> ierr = PCBJacobiGetSubKSP(cpc,&ii,&first,&k2);CHKERRQ(ierr);
> if (ii==1) {
> PC pc2;
> ierr = KSPGetPC(k2[0],&pc2);CHKERRQ(ierr);
> ierr =
> PetscObjectTypeCompare((PetscObject)pc2,PCLU,&bjaclu);CHKERRQ(ierr);
> else bjaclu = PETSC_FALSE;
> ierr =
> PetscObjectTypeCompare((PetscObject)cpc,PCLU,&lu);CHKERRQ(ierr);
> ierr =
> PetscObjectTypeCompare((PetscObject)cpc,PCREDUNDANT,&redundant);CHKERRQ(ierr);
> ierr =
> PetscObjectTypeCompare((PetscObject)cpc,PCCHOLESKY,&cholesky);CHKERRQ(ierr);
> ierr =
> PetscObjectTypeCompare((PetscObject)cpc,PCSVD,&svd);CHKERRQ(ierr);
> if (!lu && !redundant && !cholesky && !svd && !bjaclu) {
> ierr = KSPSetType(mglevels[0]->smoothd,KSPGMRES);CHKERRQ(ierr);
> If KSP is not updated each time, everything works as it is
> supposed to.
> When instead I allow the default PETSc behavior, i.e.
> updating PC every time the matrix changes, the coarse level
> KSP , initially set to PREONLY, is changed into GMRES
> after the first solve. I am not sure where the problem lies
> (my PC or PETSc), so I would like to have your opinion on
> this.
> I attached the ksp_view for the 2 successive solve and the
> options stack.
> Thanks for your help,
> Michel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150719/ade6c0b3/attachment-0001.html>
KSP Object: 8192 MPI processes
type: cg
maximum iterations=10000
tolerances: relative=1e-09, absolute=1e-50, divergence=10000
left preconditioning
using nonzero initial guess
using UNPRECONDITIONED norm type for convergence test
PC Object: 8192 MPI processes
type: mg
MG: type is MULTIPLICATIVE, levels=5 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (mg_coarse_) 8192 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
PC Object: (mg_coarse_) 8192 MPI processes
type: gamg
MG: type is MULTIPLICATIVE, levels=4 cycles=v
GAMG specific options
Threshold for dropping small values from graph 0
AGG specific options
Symmetric graph false
KSP Object: (mg_coarse_mg_coarse_) 8192 MPI processes
type: preonly
PC Object: (mg_coarse_mg_coarse_) 8192 MPI processes
type: bjacobi
block Jacobi: number of blocks = 8192
Local solve info for each block is in the following KSP and PC objects:
[0] number of local blocks = 1, first local block number = 0
[0] local block number 0
KSP Object: (mg_coarse_mg_coarse_sub_) 1 MPI processes
type: preonly
PC Object: (mg_coarse_mg_coarse_sub_) 1 MPI processes
type: lu
LU: out-of-place factorization
tolerance for zero pivot 2.22045e-14
using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
matrix ordering: nd
factor fill ratio given 5, needed 1
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=6, cols=6
package used to perform factorization: petsc
total: nonzeros=36, allocated nonzeros=36
total number of mallocs used during MatSetValues calls =0
using I-node routines: found 2 nodes, limit used is 5
linear system matrix = precond matrix:
type: seqaij
rows=6, cols=6
[1] number of local blocks = 1, first local block number = 1
[1] local block number 0
type: preonly
type: lu
matrix ordering: nd
factor fill ratio given 5, needed 0
type: seqaij
rows=0, cols=0
total: nonzeros=1, allocated nonzeros=1
not using I-node routines
type: seqaij
rows=0, cols=0
total: nonzeros=0, allocated nonzeros=0
[2] number of local blocks = 1, first local block number = 2
[2] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[3] number of local blocks = 1, first local block number = 3
[3] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[4] number of local blocks = 1, first local block number = 4
[4] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[5] number of local blocks = 1, first local block number = 5
[5] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[6] number of local blocks = 1, first local block number = 6
[6] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[7] number of local blocks = 1, first local block number = 7
[7] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[8] number of local blocks = 1, first local block number = 8
[8] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[9] number of local blocks = 1, first local block number = 9
[9] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[10] number of local blocks = 1, first local block number = 10
[10] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[11] number of local blocks = 1, first local block number = 11
[11] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[12] number of local blocks = 1, first local block number = 12
[12] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[13] number of local blocks = 1, first local block number = 13
[13] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[14] number of local blocks = 1, first local block number = 14
[14] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[15] number of local blocks = 1, first local block number = 15
[15] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[16] number of local blocks = 1, first local block number = 16
[16] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[17] number of local blocks = 1, first local block number = 17
[17] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[18] number of local blocks = 1, first local block number = 18
[18] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[19] number of local blocks = 1, first local block number = 19
[19] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[20] number of local blocks = 1, first local block number = 20
[20] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[21] number of local blocks = 1, first local block number = 21
[21] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[22] number of local blocks = 1, first local block number = 22
[22] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[23] number of local blocks = 1, first local block number = 23
[23] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[24] number of local blocks = 1, first local block number = 24
[24] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[25] number of local blocks = 1, first local block number = 25
[25] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[26] number of local blocks = 1, first local block number = 26
[26] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[27] number of local blocks = 1, first local block number = 27
[27] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[28] number of local blocks = 1, first local block number = 28
[28] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[29] number of local blocks = 1, first local block number = 29
[29] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[30] number of local blocks = 1, first local block number = 30
[30] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[31] number of local blocks = 1, first local block number = 31
[31] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[32] number of local blocks = 1, first local block number = 32
[32] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[33] number of local blocks = 1, first local block number = 33
[33] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[34] number of local blocks = 1, first local block number = 34
[34] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[35] number of local blocks = 1, first local block number = 35
[35] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[36] number of local blocks = 1, first local block number = 36
[36] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[37] number of local blocks = 1, first local block number = 37
[37] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[38] number of local blocks = 1, first local block number = 38
[38] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[39] number of local blocks = 1, first local block number = 39
[39] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[40] number of local blocks = 1, first local block number = 40
[40] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[41] number of local blocks = 1, first local block number = 41
[41] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[42] number of local blocks = 1, first local block number = 42
[42] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[43] number of local blocks = 1, first local block number = 43
[43] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[44] number of local blocks = 1, first local block number = 44
[44] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[45] number of local blocks = 1, first local block number = 45
[45] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[46] number of local blocks = 1, first local block number = 46
[46] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[47] number of local blocks = 1, first local block number = 47
[47] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[48] number of local blocks = 1, first local block number = 48
[48] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[49] number of local blocks = 1, first local block number = 49
[49] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[50] number of local blocks = 1, first local block number = 50
[50] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[51] number of local blocks = 1, first local block number = 51
[51] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[52] number of local blocks = 1, first local block number = 52
[52] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[53] number of local blocks = 1, first local block number = 53
[53] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[54] number of local blocks = 1, first local block number = 54
[54] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[55] number of local blocks = 1, first local block number = 55
[55] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[56] number of local blocks = 1, first local block number = 56
[56] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[57] number of local blocks = 1, first local block number = 57
[57] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[58] number of local blocks = 1, first local block number = 58
[58] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[59] number of local blocks = 1, first local block number = 59
[59] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[60] number of local blocks = 1, first local block number = 60
[60] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[61] number of local blocks = 1, first local block number = 61
[61] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[62] number of local blocks = 1, first local block number = 62
[62] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[63] number of local blocks = 1, first local block number = 63
[63] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[64] number of local blocks = 1, first local block number = 64
[64] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[65] number of local blocks = 1, first local block number = 65
[65] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[66] number of local blocks = 1, first local block number = 66
[66] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[67] number of local blocks = 1, first local block number = 67
[67] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[68] number of local blocks = 1, first local block number = 68
[68] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[69] number of local blocks = 1, first local block number = 69
[69] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[70] number of local blocks = 1, first local block number = 70
[70] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[71] number of local blocks = 1, first local block number = 71
[71] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[72] number of local blocks = 1, first local block number = 72
[72] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[73] number of local blocks = 1, first local block number = 73
[73] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[74] number of local blocks = 1, first local block number = 74
[74] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[75] number of local blocks = 1, first local block number = 75
[75] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[76] number of local blocks = 1, first local block number = 76
[76] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[77] number of local blocks = 1, first local block number = 77
[77] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[78] number of local blocks = 1, first local block number = 78
[78] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[79] number of local blocks = 1, first local block number = 79
[79] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[80] number of local blocks = 1, first local block number = 80
[80] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[81] number of local blocks = 1, first local block number = 81
[81] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[82] number of local blocks = 1, first local block number = 82
[82] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[83] number of local blocks = 1, first local block number = 83
[83] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[84] number of local blocks = 1, first local block number = 84
[84] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[85] number of local blocks = 1, first local block number = 85
[85] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[86] number of local blocks = 1, first local block number = 86
[86] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[87] number of local blocks = 1, first local block number = 87
[87] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[88] number of local blocks = 1, first local block number = 88
[88] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[89] number of local blocks = 1, first local block number = 89
[89] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[90] number of local blocks = 1, first local block number = 90
[90] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[91] number of local blocks = 1, first local block number = 91
[91] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[92] number of local blocks = 1, first local block number = 92
[92] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[93] number of local blocks = 1, first local block number = 93
[93] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[94] number of local blocks = 1, first local block number = 94
[94] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[95] number of local blocks = 1, first local block number = 95
[95] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[96] number of local blocks = 1, first local block number = 96
[96] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[97] number of local blocks = 1, first local block number = 97
[97] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[98] number of local blocks = 1, first local block number = 98
[98] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[99] number of local blocks = 1, first local block number = 99
[99] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[100] number of local blocks = 1, first local block number = 100
[100] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[101] number of local blocks = 1, first local block number = 101
[101] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[102] number of local blocks = 1, first local block number = 102
[102] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[103] number of local blocks = 1, first local block number = 103
[103] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[104] number of local blocks = 1, first local block number = 104
[104] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[105] number of local blocks = 1, first local block number = 105
[105] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[106] number of local blocks = 1, first local block number = 106
[106] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[107] number of local blocks = 1, first local block number = 107
[107] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[108] number of local blocks = 1, first local block number = 108
[108] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[109] number of local blocks = 1, first local block number = 109
[109] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[110] number of local blocks = 1, first local block number = 110
[110] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[111] number of local blocks = 1, first local block number = 111
[111] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[112] number of local blocks = 1, first local block number = 112
[112] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[113] number of local blocks = 1, first local block number = 113
[113] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[114] number of local blocks = 1, first local block number = 114
[114] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[115] number of local blocks = 1, first local block number = 115
[115] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[116] number of local blocks = 1, first local block number = 116
[116] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[117] number of local blocks = 1, first local block number = 117
[117] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[118] number of local blocks = 1, first local block number = 118
[118] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[119] number of local blocks = 1, first local block number = 119
[119] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[120] number of local blocks = 1, first local block number = 120
[120] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[121] number of local blocks = 1, first local block number = 121
[121] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[122] number of local blocks = 1, first local block number = 122
[122] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[123] number of local blocks = 1, first local block number = 123
[123] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[124] number of local blocks = 1, first local block number = 124
[124] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[125] number of local blocks = 1, first local block number = 125
[125] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[126] number of local blocks = 1, first local block number = 126
[126] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[127] number of local blocks = 1, first local block number = 127
[127] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[128] number of local blocks = 1, first local block number = 128
[128] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[129] number of local blocks = 1, first local block number = 129
[129] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[130] number of local blocks = 1, first local block number = 130
[130] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[131] number of local blocks = 1, first local block number = 131
[131] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[132] number of local blocks = 1, first local block number = 132
[132] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[133] number of local blocks = 1, first local block number = 133
[133] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[134] number of local blocks = 1, first local block number = 134
[134] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[135] number of local blocks = 1, first local block number = 135
[135] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[136] number of local blocks = 1, first local block number = 136
[136] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[137] number of local blocks = 1, first local block number = 137
[137] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[138] number of local blocks = 1, first local block number = 138
[138] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[139] number of local blocks = 1, first local block number = 139
[139] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[140] number of local blocks = 1, first local block number = 140
[140] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[141] number of local blocks = 1, first local block number = 141
[141] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[142] number of local blocks = 1, first local block number = 142
[142] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[143] number of local blocks = 1, first local block number = 143
[143] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[144] number of local blocks = 1, first local block number = 144
[144] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[145] number of local blocks = 1, first local block number = 145
[145] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[146] number of local blocks = 1, first local block number = 146
[146] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[147] number of local blocks = 1, first local block number = 147
[147] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[148] number of local blocks = 1, first local block number = 148
[148] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[149] number of local blocks = 1, first local block number = 149
[149] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[150] number of local blocks = 1, first local block number = 150
[150] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[151] number of local blocks = 1, first local block number = 151
[151] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[152] number of local blocks = 1, first local block number = 152
[152] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[153] number of local blocks = 1, first local block number = 153
[153] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[154] number of local blocks = 1, first local block number = 154
[154] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[155] number of local blocks = 1, first local block number = 155
[155] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[156] number of local blocks = 1, first local block number = 156
[156] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[157] number of local blocks = 1, first local block number = 157
[157] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[158] number of local blocks = 1, first local block number = 158
[158] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[159] number of local blocks = 1, first local block number = 159
[159] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[160] number of local blocks = 1, first local block number = 160
[160] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[161] number of local blocks = 1, first local block number = 161
[161] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[162] number of local blocks = 1, first local block number = 162
[162] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[163] number of local blocks = 1, first local block number = 163
[163] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[164] number of local blocks = 1, first local block number = 164
[164] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[165] number of local blocks = 1, first local block number = 165
[165] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[166] number of local blocks = 1, first local block number = 166
[166] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[167] number of local blocks = 1, first local block number = 167
[167] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[168] number of local blocks = 1, first local block number = 168
[168] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[169] number of local blocks = 1, first local block number = 169
[169] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[170] number of local blocks = 1, first local block number = 170
[170] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[171] number of local blocks = 1, first local block number = 171
[171] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[172] number of local blocks = 1, first local block number = 172
[172] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[173] number of local blocks = 1, first local block number = 173
[173] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[174] number of local blocks = 1, first local block number = 174
[174] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[175] number of local blocks = 1, first local block number = 175
[175] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[176] number of local blocks = 1, first local block number = 176
[176] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[177] number of local blocks = 1, first local block number = 177
[177] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[178] number of local blocks = 1, first local block number = 178
[178] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[179] number of local blocks = 1, first local block number = 179
[179] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[180] number of local blocks = 1, first local block number = 180
[180] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[181] number of local blocks = 1, first local block number = 181
[181] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[182] number of local blocks = 1, first local block number = 182
[182] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[183] number of local blocks = 1, first local block number = 183
[183] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[184] number of local blocks = 1, first local block number = 184
[184] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[185] number of local blocks = 1, first local block number = 185
[185] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[186] number of local blocks = 1, first local block number = 186
[186] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[187] number of local blocks = 1, first local block number = 187
[187] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[188] number of local blocks = 1, first local block number = 188
[188] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[189] number of local blocks = 1, first local block number = 189
[189] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[190] number of local blocks = 1, first local block number = 190
[190] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[191] number of local blocks = 1, first local block number = 191
[191] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[192] number of local blocks = 1, first local block number = 192
[192] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[193] number of local blocks = 1, first local block number = 193
[193] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[194] number of local blocks = 1, first local block number = 194
[194] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[195] number of local blocks = 1, first local block number = 195
[195] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[196] number of local blocks = 1, first local block number = 196
[196] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[197] number of local blocks = 1, first local block number = 197
[197] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[198] number of local blocks = 1, first local block number = 198
[198] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[199] number of local blocks = 1, first local block number = 199
[199] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[200] number of local blocks = 1, first local block number = 200
[200] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[201] number of local blocks = 1, first local block number = 201
[201] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[202] number of local blocks = 1, first local block number = 202
[202] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[203] number of local blocks = 1, first local block number = 203
[203] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[204] number of local blocks = 1, first local block number = 204
[204] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[205] number of local blocks = 1, first local block number = 205
[205] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[206] number of local blocks = 1, first local block number = 206
[206] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[207] number of local blocks = 1, first local block number = 207
[207] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[208] number of local blocks = 1, first local block number = 208
[208] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[209] number of local blocks = 1, first local block number = 209
[209] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[210] number of local blocks = 1, first local block number = 210
[210] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[211] number of local blocks = 1, first local block number = 211
[211] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[212] number of local blocks = 1, first local block number = 212
[212] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[213] number of local blocks = 1, first local block number = 213
[213] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[214] number of local blocks = 1, first local block number = 214
[214] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[215] number of local blocks = 1, first local block number = 215
[215] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[216] number of local blocks = 1, first local block number = 216
[216] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[217] number of local blocks = 1, first local block number = 217
[217] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[218] number of local blocks = 1, first local block number = 218
[218] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[219] number of local blocks = 1, first local block number = 219
[219] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[220] number of local blocks = 1, first local block number = 220
[220] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[221] number of local blocks = 1, first local block number = 221
[221] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[222] number of local blocks = 1, first local block number = 222
[222] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[223] number of local blocks = 1, first local block number = 223
[223] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[224] number of local blocks = 1, first local block number = 224
[224] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[225] number of local blocks = 1, first local block number = 225
[225] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[226] number of local blocks = 1, first local block number = 226
[226] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[227] number of local blocks = 1, first local block number = 227
[227] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[228] number of local blocks = 1, first local block number = 228
[228] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[229] number of local blocks = 1, first local block number = 229
[229] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[230] number of local blocks = 1, first local block number = 230
[230] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[231] number of local blocks = 1, first local block number = 231
[231] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[232] number of local blocks = 1, first local block number = 232
[232] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[233] number of local blocks = 1, first local block number = 233
[233] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[234] number of local blocks = 1, first local block number = 234
[234] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[235] number of local blocks = 1, first local block number = 235
[235] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[236] number of local blocks = 1, first local block number = 236
[236] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[237] number of local blocks = 1, first local block number = 237
[237] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[238] number of local blocks = 1, first local block number = 238
[238] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[239] number of local blocks = 1, first local block number = 239
[239] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[240] number of local blocks = 1, first local block number = 240
[240] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[241] number of local blocks = 1, first local block number = 241
[241] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[242] number of local blocks = 1, first local block number = 242
[242] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[243] number of local blocks = 1, first local block number = 243
[243] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[244] number of local blocks = 1, first local block number = 244
[244] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[245] number of local blocks = 1, first local block number = 245
[245] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[246] number of local blocks = 1, first local block number = 246
[246] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[247] number of local blocks = 1, first local block number = 247
[247] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[248] number of local blocks = 1, first local block number = 248
[248] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[249] number of local blocks = 1, first local block number = 249
[249] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[250] number of local blocks = 1, first local block number = 250
[250] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[251] number of local blocks = 1, first local block number = 251
[251] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[252] number of local blocks = 1, first local block number = 252
[252] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[253] number of local blocks = 1, first local block number = 253
[253] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[254] number of local blocks = 1, first local block number = 254
[254] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[255] number of local blocks = 1, first local block number = 255
[255] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[256] number of local blocks = 1, first local block number = 256
[256] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[257] number of local blocks = 1, first local block number = 257
[257] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[258] number of local blocks = 1, first local block number = 258
[258] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[259] number of local blocks = 1, first local block number = 259
[259] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[260] number of local blocks = 1, first local block number = 260
[260] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[261] number of local blocks = 1, first local block number = 261
[261] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[262] number of local blocks = 1, first local block number = 262
[262] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[263] number of local blocks = 1, first local block number = 263
[263] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[264] number of local blocks = 1, first local block number = 264
[264] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[265] number of local blocks = 1, first local block number = 265
[265] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[266] number of local blocks = 1, first local block number = 266
[266] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[267] number of local blocks = 1, first local block number = 267
[267] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[268] number of local blocks = 1, first local block number = 268
[268] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[269] number of local blocks = 1, first local block number = 269
[269] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[270] number of local blocks = 1, first local block number = 270
[270] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[271] number of local blocks = 1, first local block number = 271
[271] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[272] number of local blocks = 1, first local block number = 272
[272] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[273] number of local blocks = 1, first local block number = 273
[273] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[274] number of local blocks = 1, first local block number = 274
[274] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[275] number of local blocks = 1, first local block number = 275
[275] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[276] number of local blocks = 1, first local block number = 276
[276] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[277] number of local blocks = 1, first local block number = 277
[277] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[278] number of local blocks = 1, first local block number = 278
[278] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[279] number of local blocks = 1, first local block number = 279
[279] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[280] number of local blocks = 1, first local block number = 280
[280] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[281] number of local blocks = 1, first local block number = 281
[281] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[282] number of local blocks = 1, first local block number = 282
[282] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[283] number of local blocks = 1, first local block number = 283
[283] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[284] number of local blocks = 1, first local block number = 284
[284] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[285] number of local blocks = 1, first local block number = 285
[285] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[286] number of local blocks = 1, first local block number = 286
[286] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[287] number of local blocks = 1, first local block number = 287
[287] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[288] number of local blocks = 1, first local block number = 288
[288] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[289] number of local blocks = 1, first local block number = 289
[289] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[290] number of local blocks = 1, first local block number = 290
[290] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[291] number of local blocks = 1, first local block number = 291
[291] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[292] number of local blocks = 1, first local block number = 292
[292] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[293] number of local blocks = 1, first local block number = 293
[293] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[294] number of local blocks = 1, first local block number = 294
[294] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[295] number of local blocks = 1, first local block number = 295
[295] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[296] number of local blocks = 1, first local block number = 296
[296] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[297] number of local blocks = 1, first local block number = 297
[297] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[298] number of local blocks = 1, first local block number = 298
[298] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[299] number of local blocks = 1, first local block number = 299
[299] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[300] number of local blocks = 1, first local block number = 300
[300] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[301] number of local blocks = 1, first local block number = 301
[301] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[302] number of local blocks = 1, first local block number = 302
[302] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[303] number of local blocks = 1, first local block number = 303
[303] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[304] number of local blocks = 1, first local block number = 304
[304] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[305] number of local blocks = 1, first local block number = 305
[305] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[306] number of local blocks = 1, first local block number = 306
[306] local block number 0
type: preonly
left preconditioning
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[307] number of local blocks = 1, first local block number = 307
[307] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[308] number of local blocks = 1, first local block number = 308
[308] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[309] number of local blocks = 1, first local block number = 309
[309] local block number 0
type: preonly
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[310] number of local blocks = 1, first local block number = 310
[310] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[311] number of local blocks = 1, first local block number = 311
[311] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[312] number of local blocks = 1, first local block number = 312
[312] local block number 0
KSP Object: (mg_coarse_mg_coarse_sub_) 1 MPI processes
type: preonly
PC Object: (mg_coarse_mg_coarse_sub_) 1 MPI processes
type: lu
LU: out-of-place factorization
tolerance for zero pivot 2.22045e-14
using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
matrix ordering: nd
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=0, cols=0
package used to perform factorization: petsc
total number of mallocs used during MatSetValues calls =0
linear system matrix = precond matrix:
type: seqaij
rows=0, cols=0
[313] number of local blocks = 1, first local block number = 313
[313] local block number 0
type: preonly
type: lu
matrix ordering: nd
factor fill ratio given 5, needed 0
type: seqaij
rows=0, cols=0
total: nonzeros=1, allocated nonzeros=1
not using I-node routines
type: seqaij
rows=0, cols=0
total: nonzeros=0, allocated nonzeros=0
[314] number of local blocks = 1, first local block number = 314
[314] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[315] number of local blocks = 1, first local block number = 315
[315] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[316] number of local blocks = 1, first local block number = 316
[316] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[317] number of local blocks = 1, first local block number = 317
[317] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[318] number of local blocks = 1, first local block number = 318
[318] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[319] number of local blocks = 1, first local block number = 319
[319] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[320] number of local blocks = 1, first local block number = 320
[320] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[321] number of local blocks = 1, first local block number = 321
[321] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[322] number of local blocks = 1, first local block number = 322
[322] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[323] number of local blocks = 1, first local block number = 323
[323] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[324] number of local blocks = 1, first local block number = 324
[324] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[325] number of local blocks = 1, first local block number = 325
[325] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[326] number of local blocks = 1, first local block number = 326
[326] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[327] number of local blocks = 1, first local block number = 327
[327] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[328] number of local blocks = 1, first local block number = 328
[328] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[329] number of local blocks = 1, first local block number = 329
[329] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[330] number of local blocks = 1, first local block number = 330
[330] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[331] number of local blocks = 1, first local block number = 331
[331] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[332] number of local blocks = 1, first local block number = 332
[332] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[333] number of local blocks = 1, first local block number = 333
[333] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[334] number of local blocks = 1, first local block number = 334
[334] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[335] number of local blocks = 1, first local block number = 335
[335] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[336] number of local blocks = 1, first local block number = 336
[336] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[337] number of local blocks = 1, first local block number = 337
[337] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[338] number of local blocks = 1, first local block number = 338
[338] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[339] number of local blocks = 1, first local block number = 339
[339] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[340] number of local blocks = 1, first local block number = 340
[340] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[341] number of local blocks = 1, first local block number = 341
[341] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[342] number of local blocks = 1, first local block number = 342
[342] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[343] number of local blocks = 1, first local block number = 343
[343] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[344] number of local blocks = 1, first local block number = 344
[344] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[345] number of local blocks = 1, first local block number = 345
[345] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[346] number of local blocks = 1, first local block number = 346
[346] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[347] number of local blocks = 1, first local block number = 347
[347] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[348] number of local blocks = 1, first local block number = 348
[348] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[349] number of local blocks = 1, first local block number = 349
[349] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[350] number of local blocks = 1, first local block number = 350
[350] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[351] number of local blocks = 1, first local block number = 351
[351] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[352] number of local blocks = 1, first local block number = 352
[352] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[353] number of local blocks = 1, first local block number = 353
[353] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[354] number of local blocks = 1, first local block number = 354
[354] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[355] number of local blocks = 1, first local block number = 355
[355] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[356] number of local blocks = 1, first local block number = 356
[356] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[357] number of local blocks = 1, first local block number = 357
[357] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[358] number of local blocks = 1, first local block number = 358
[358] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[359] number of local blocks = 1, first local block number = 359
[359] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[360] number of local blocks = 1, first local block number = 360
[360] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[361] number of local blocks = 1, first local block number = 361
[361] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[362] number of local blocks = 1, first local block number = 362
[362] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[363] number of local blocks = 1, first local block number = 363
[363] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[364] number of local blocks = 1, first local block number = 364
[364] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[365] number of local blocks = 1, first local block number = 365
[365] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[366] number of local blocks = 1, first local block number = 366
[366] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[367] number of local blocks = 1, first local block number = 367
[367] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[368] number of local blocks = 1, first local block number = 368
[368] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[369] number of local blocks = 1, first local block number = 369
[369] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[370] number of local blocks = 1, first local block number = 370
[370] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[371] number of local blocks = 1, first local block number = 371
[371] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[372] number of local blocks = 1, first local block number = 372
[372] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[373] number of local blocks = 1, first local block number = 373
[373] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[374] number of local blocks = 1, first local block number = 374
[374] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[375] number of local blocks = 1, first local block number = 375
[375] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[376] number of local blocks = 1, first local block number = 376
[376] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[377] number of local blocks = 1, first local block number = 377
[377] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[378] number of local blocks = 1, first local block number = 378
[378] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[379] number of local blocks = 1, first local block number = 379
[379] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[380] number of local blocks = 1, first local block number = 380
[380] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[381] number of local blocks = 1, first local block number = 381
[381] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[382] number of local blocks = 1, first local block number = 382
[382] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[383] number of local blocks = 1, first local block number = 383
[383] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[384] number of local blocks = 1, first local block number = 384
[384] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[385] number of local blocks = 1, first local block number = 385
[385] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[386] number of local blocks = 1, first local block number = 386
[386] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[387] number of local blocks = 1, first local block number = 387
[387] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[388] number of local blocks = 1, first local block number = 388
[388] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[389] number of local blocks = 1, first local block number = 389
[389] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[390] number of local blocks = 1, first local block number = 390
[390] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[391] number of local blocks = 1, first local block number = 391
[391] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[392] number of local blocks = 1, first local block number = 392
[392] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[393] number of local blocks = 1, first local block number = 393
[393] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[394] number of local blocks = 1, first local block number = 394
[394] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[395] number of local blocks = 1, first local block number = 395
[395] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[396] number of local blocks = 1, first local block number = 396
[396] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[397] number of local blocks = 1, first local block number = 397
[397] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[398] number of local blocks = 1, first local block number = 398
[398] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[399] number of local blocks = 1, first local block number = 399
[399] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[400] number of local blocks = 1, first local block number = 400
[400] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[401] number of local blocks = 1, first local block number = 401
[401] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[402] number of local blocks = 1, first local block number = 402
[402] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[403] number of local blocks = 1, first local block number = 403
[403] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[404] number of local blocks = 1, first local block number = 404
[404] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[405] number of local blocks = 1, first local block number = 405
[405] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[406] number of local blocks = 1, first local block number = 406
[406] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[407] number of local blocks = 1, first local block number = 407
[407] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[408] number of local blocks = 1, first local block number = 408
[408] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[409] number of local blocks = 1, first local block number = 409
[409] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[410] number of local blocks = 1, first local block number = 410
[410] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[411] number of local blocks = 1, first local block number = 411
[411] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[412] number of local blocks = 1, first local block number = 412
[412] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[413] number of local blocks = 1, first local block number = 413
[413] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[414] number of local blocks = 1, first local block number = 414
[414] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[415] number of local blocks = 1, first local block number = 415
[415] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[416] number of local blocks = 1, first local block number = 416
[416] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[417] number of local blocks = 1, first local block number = 417
[417] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[418] number of local blocks = 1, first local block number = 418
[418] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[419] number of local blocks = 1, first local block number = 419
[419] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[420] number of local blocks = 1, first local block number = 420
[420] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[421] number of local blocks = 1, first local block number = 421
[421] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[422] number of local blocks = 1, first local block number = 422
[422] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[423] number of local blocks = 1, first local block number = 423
[423] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[424] number of local blocks = 1, first local block number = 424
[424] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[425] number of local blocks = 1, first local block number = 425
[425] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[426] number of local blocks = 1, first local block number = 426
[426] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[427] number of local blocks = 1, first local block number = 427
[427] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[428] number of local blocks = 1, first local block number = 428
[428] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[429] number of local blocks = 1, first local block number = 429
[429] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[430] number of local blocks = 1, first local block number = 430
[430] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[431] number of local blocks = 1, first local block number = 431
[431] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[432] number of local blocks = 1, first local block number = 432
[432] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[433] number of local blocks = 1, first local block number = 433
[433] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[434] number of local blocks = 1, first local block number = 434
[434] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[435] number of local blocks = 1, first local block number = 435
[435] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[436] number of local blocks = 1, first local block number = 436
[436] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[437] number of local blocks = 1, first local block number = 437
[437] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[438] number of local blocks = 1, first local block number = 438
[438] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[439] number of local blocks = 1, first local block number = 439
[439] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[440] number of local blocks = 1, first local block number = 440
[440] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[441] number of local blocks = 1, first local block number = 441
[441] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[442] number of local blocks = 1, first local block number = 442
[442] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[443] number of local blocks = 1, first local block number = 443
[443] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[444] number of local blocks = 1, first local block number = 444
[444] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[445] number of local blocks = 1, first local block number = 445
[445] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[446] number of local blocks = 1, first local block number = 446
[446] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[447] number of local blocks = 1, first local block number = 447
[447] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[448] number of local blocks = 1, first local block number = 448
[448] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[449] number of local blocks = 1, first local block number = 449
[449] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[450] number of local blocks = 1, first local block number = 450
[450] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[451] number of local blocks = 1, first local block number = 451
[451] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[452] number of local blocks = 1, first local block number = 452
[452] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[453] number of local blocks = 1, first local block number = 453
[453] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[454] number of local blocks = 1, first local block number = 454
[454] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[455] number of local blocks = 1, first local block number = 455
[455] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[456] number of local blocks = 1, first local block number = 456
[456] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[457] number of local blocks = 1, first local block number = 457
[457] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[458] number of local blocks = 1, first local block number = 458
[458] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[459] number of local blocks = 1, first local block number = 459
[459] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[460] number of local blocks = 1, first local block number = 460
[460] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[461] number of local blocks = 1, first local block number = 461
[461] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[462] number of local blocks = 1, first local block number = 462
[462] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[463] number of local blocks = 1, first local block number = 463
[463] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[464] number of local blocks = 1, first local block number = 464
[464] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[465] number of local blocks = 1, first local block number = 465
[465] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[466] number of local blocks = 1, first local block number = 466
[466] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[467] number of local blocks = 1, first local block number = 467
[467] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[468] number of local blocks = 1, first local block number = 468
[468] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[469] number of local blocks = 1, first local block number = 469
[469] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[470] number of local blocks = 1, first local block number = 470
[470] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[471] number of local blocks = 1, first local block number = 471
[471] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[472] number of local blocks = 1, first local block number = 472
[472] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[473] number of local blocks = 1, first local block number = 473
[473] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[474] number of local blocks = 1, first local block number = 474
[474] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[475] number of local blocks = 1, first local block number = 475
[475] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[476] number of local blocks = 1, first local block number = 476
[476] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[477] number of local blocks = 1, first local block number = 477
[477] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[478] number of local blocks = 1, first local block number = 478
[478] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[479] number of local blocks = 1, first local block number = 479
[479] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[480] number of local blocks = 1, first local block number = 480
[480] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[481] number of local blocks = 1, first local block number = 481
[481] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[482] number of local blocks = 1, first local block number = 482
[482] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[483] number of local blocks = 1, first local block number = 483
[483] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[484] number of local blocks = 1, first local block number = 484
[484] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[485] number of local blocks = 1, first local block number = 485
[485] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[486] number of local blocks = 1, first local block number = 486
[486] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[487] number of local blocks = 1, first local block number = 487
[487] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[488] number of local blocks = 1, first local block number = 488
[488] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[489] number of local blocks = 1, first local block number = 489
[489] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[490] number of local blocks = 1, first local block number = 490
[490] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[491] number of local blocks = 1, first local block number = 491
[491] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[492] number of local blocks = 1, first local block number = 492
[492] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[493] number of local blocks = 1, first local block number = 493
[493] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[494] number of local blocks = 1, first local block number = 494
[494] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[495] number of local blocks = 1, first local block number = 495
[495] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[496] number of local blocks = 1, first local block number = 496
[496] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[497] number of local blocks = 1, first local block number = 497
[497] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[498] number of local blocks = 1, first local block number = 498
[498] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[499] number of local blocks = 1, first local block number = 499
[499] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[500] number of local blocks = 1, first local block number = 500
[500] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[501] number of local blocks = 1, first local block number = 501
[501] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[502] number of local blocks = 1, first local block number = 502
[502] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[503] number of local blocks = 1, first local block number = 503
[503] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[504] number of local blocks = 1, first local block number = 504
[504] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[505] number of local blocks = 1, first local block number = 505
[505] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[506] number of local blocks = 1, first local block number = 506
[506] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[507] number of local blocks = 1, first local block number = 507
[507] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[508] number of local blocks = 1, first local block number = 508
[508] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[509] number of local blocks = 1, first local block number = 509
[509] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[510] number of local blocks = 1, first local block number = 510
[510] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[511] number of local blocks = 1, first local block number = 511
[511] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[512] number of local blocks = 1, first local block number = 512
[512] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[513] number of local blocks = 1, first local block number = 513
[513] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[514] number of local blocks = 1, first local block number = 514
[514] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[515] number of local blocks = 1, first local block number = 515
[515] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[516] number of local blocks = 1, first local block number = 516
[516] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[517] number of local blocks = 1, first local block number = 517
[517] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[518] number of local blocks = 1, first local block number = 518
[518] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[519] number of local blocks = 1, first local block number = 519
[519] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[520] number of local blocks = 1, first local block number = 520
[520] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[521] number of local blocks = 1, first local block number = 521
[521] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[522] number of local blocks = 1, first local block number = 522
[522] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[523] number of local blocks = 1, first local block number = 523
[523] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[524] number of local blocks = 1, first local block number = 524
[524] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[525] number of local blocks = 1, first local block number = 525
[525] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[526] number of local blocks = 1, first local block number = 526
[526] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[527] number of local blocks = 1, first local block number = 527
[527] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[528] number of local blocks = 1, first local block number = 528
[528] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[529] number of local blocks = 1, first local block number = 529
[529] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[530] number of local blocks = 1, first local block number = 530
[530] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[531] number of local blocks = 1, first local block number = 531
[531] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[532] number of local blocks = 1, first local block number = 532
[532] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[533] number of local blocks = 1, first local block number = 533
[533] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[534] number of local blocks = 1, first local block number = 534
[534] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[535] number of local blocks = 1, first local block number = 535
[535] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[536] number of local blocks = 1, first local block number = 536
[536] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[537] number of local blocks = 1, first local block number = 537
[537] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[538] number of local blocks = 1, first local block number = 538
[538] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[539] number of local blocks = 1, first local block number = 539
[539] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[540] number of local blocks = 1, first local block number = 540
[540] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[541] number of local blocks = 1, first local block number = 541
[541] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[542] number of local blocks = 1, first local block number = 542
[542] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[543] number of local blocks = 1, first local block number = 543
[543] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[544] number of local blocks = 1, first local block number = 544
[544] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[545] number of local blocks = 1, first local block number = 545
[545] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[546] number of local blocks = 1, first local block number = 546
[546] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[547] number of local blocks = 1, first local block number = 547
[547] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[548] number of local blocks = 1, first local block number = 548
[548] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[549] number of local blocks = 1, first local block number = 549
[549] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[550] number of local blocks = 1, first local block number = 550
[550] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[551] number of local blocks = 1, first local block number = 551
[551] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[552] number of local blocks = 1, first local block number = 552
[552] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[553] number of local blocks = 1, first local block number = 553
[553] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[554] number of local blocks = 1, first local block number = 554
[554] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[555] number of local blocks = 1, first local block number = 555
[555] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[556] number of local blocks = 1, first local block number = 556
[556] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[557] number of local blocks = 1, first local block number = 557
[557] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[558] number of local blocks = 1, first local block number = 558
[558] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[559] number of local blocks = 1, first local block number = 559
[559] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[560] number of local blocks = 1, first local block number = 560
[560] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[561] number of local blocks = 1, first local block number = 561
[561] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[562] number of local blocks = 1, first local block number = 562
[562] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[563] number of local blocks = 1, first local block number = 563
[563] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[564] number of local blocks = 1, first local block number = 564
[564] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[565] number of local blocks = 1, first local block number = 565
[565] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[566] number of local blocks = 1, first local block number = 566
[566] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[567] number of local blocks = 1, first local block number = 567
[567] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[568] number of local blocks = 1, first local block number = 568
[568] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[569] number of local blocks = 1, first local block number = 569
[569] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[570] number of local blocks = 1, first local block number = 570
[570] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[571] number of local blocks = 1, first local block number = 571
[571] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[572] number of local blocks = 1, first local block number = 572
[572] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[573] number of local blocks = 1, first local block number = 573
[573] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[574] number of local blocks = 1, first local block number = 574
[574] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[575] number of local blocks = 1, first local block number = 575
[575] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[576] number of local blocks = 1, first local block number = 576
[576] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[577] number of local blocks = 1, first local block number = 577
[577] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[578] number of local blocks = 1, first local block number = 578
[578] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[579] number of local blocks = 1, first local block number = 579
[579] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[580] number of local blocks = 1, first local block number = 580
[580] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[581] number of local blocks = 1, first local block number = 581
[581] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[582] number of local blocks = 1, first local block number = 582
[582] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[583] number of local blocks = 1, first local block number = 583
[583] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[584] number of local blocks = 1, first local block number = 584
[584] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[585] number of local blocks = 1, first local block number = 585
[585] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[586] number of local blocks = 1, first local block number = 586
[586] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[587] number of local blocks = 1, first local block number = 587
[587] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[588] number of local blocks = 1, first local block number = 588
[588] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[589] number of local blocks = 1, first local block number = 589
[589] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[590] number of local blocks = 1, first local block number = 590
[590] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[591] number of local blocks = 1, first local block number = 591
[591] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[592] number of local blocks = 1, first local block number = 592
[592] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[593] number of local blocks = 1, first local block number = 593
[593] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[594] number of local blocks = 1, first local block number = 594
[594] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[595] number of local blocks = 1, first local block number = 595
[595] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[596] number of local blocks = 1, first local block number = 596
[596] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[597] number of local blocks = 1, first local block number = 597
[597] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[598] number of local blocks = 1, first local block number = 598
[598] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[599] number of local blocks = 1, first local block number = 599
[599] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[600] number of local blocks = 1, first local block number = 600
[600] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[601] number of local blocks = 1, first local block number = 601
[601] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[602] number of local blocks = 1, first local block number = 602
[602] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[603] number of local blocks = 1, first local block number = 603
[603] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[604] number of local blocks = 1, first local block number = 604
[604] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[605] number of local blocks = 1, first local block number = 605
[605] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[606] number of local blocks = 1, first local block number = 606
[606] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[607] number of local blocks = 1, first local block number = 607
[607] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[608] number of local blocks = 1, first local block number = 608
[608] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[609] number of local blocks = 1, first local block number = 609
[609] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[610] number of local blocks = 1, first local block number = 610
[610] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[611] number of local blocks = 1, first local block number = 611
[611] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[612] number of local blocks = 1, first local block number = 612
[612] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[613] number of local blocks = 1, first local block number = 613
[613] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[614] number of local blocks = 1, first local block number = 614
[614] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[615] number of local blocks = 1, first local block number = 615
[615] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[616] number of local blocks = 1, first local block number = 616
[616] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[617] number of local blocks = 1, first local block number = 617
[617] local block number 0
type: preonly
left preconditioning
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[618] number of local blocks = 1, first local block number = 618
[618] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[619] number of local blocks = 1, first local block number = 619
[619] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[620] number of local blocks = 1, first local block number = 620
[620] local block number 0
type: preonly
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[621] number of local blocks = 1, first local block number = 621
[621] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[622] number of local blocks = 1, first local block number = 622
[622] local block number 0
type: preonly
type: lu
matrix ordering: nd
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[623] number of local blocks = 1, first local block number = 623
[623] local block number 0
KSP Object: (mg_coarse_mg_coarse_sub_) 1 MPI processes
type: preonly
