[petsc-users] Complex numbers and HDF5 Viewer
Gianluca Meneghello gianmail at gmail.com
Wed Jul 15 19:52:10 CDT 2015
Thanks, I applied the patch and it now works perfectly.
Best,
Gianluca
On Wed, Jul 15, 2015 at 4:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Thanks for reporting this.
>   Yikes, this is a bug that crept in with the addition of the dim2 option
> that was added. I have fixed this in the maint, master, and next branches
> and here is the patch
> --- a/src/vec/vec/impls/mpi/pdvec.c
> +++ b/src/vec/vec/impls/mpi/pdvec.c
> @@ -736,7 +736,7 @@ PetscErrorCode VecView_MPI_HDF5(Vec xin, PetscViewer
> viewer)
>    ierr = PetscHDF5IntCast(xin->map->n/bs,count + dim);CHKERRQ(ierr);
>    ++dim;
> -  if (bs >= 1 || dim2) {
> +  if (bs > 1 || dim2) {
>      count[dim] = bs;
>      ++dim;
> @@ -760,7 +760,7 @@ PetscErrorCode VecView_MPI_HDF5(Vec xin, PetscViewer
> viewer)
>    ierr = PetscHDF5IntCast(low/bs,offset + dim);CHKERRQ(ierr);
>    ++dim;
>      offset[dim] = 0;
>      ++dim;
> > On Jul 15, 2015, at 1:25 PM, Gianluca Meneghello <gianmail at gmail.com>
> wrote:
> > Dear all,
> > I would like to write a complex Vec to an HDF5 viewer, but I receive an
> error.
> > Is it possible to write complex numbers to an HDF5 viewer?
> > The error is reproducible on my computer by running
> src/vec/vec/examples/tutorials/ex10.c when compiled with
> --with-scalar-type=complex (and --download-hdf5 if that is important). I
> attach the output of ./ex10 -hdf5.
> > Thanks for your help,
> > Gianluca
> > <ex10.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150715/3ced2c78/attachment.html>
