[petsc-users] Complex numbers and HDF5 Viewer
Barry Smith
bsmith at mcs.anl.gov
Wed Jul 15 18:44:17 CDT 2015
Thanks for reporting this.
Yikes, this is a bug that crept in with the addition of the dim2 option that was added. I have fixed this in the maint, master, and next branches and here is the patch
--- a/src/vec/vec/impls/mpi/pdvec.c
+++ b/src/vec/vec/impls/mpi/pdvec.c
@@ -736,7 +736,7 @@ PetscErrorCode VecView_MPI_HDF5(Vec xin, PetscViewer viewer)
ierr = PetscHDF5IntCast(xin->map->n/bs,count + dim);CHKERRQ(ierr);
++dim;
- if (bs >= 1 || dim2) {
+ if (bs > 1 || dim2) {
count[dim] = bs;
++dim;
@@ -760,7 +760,7 @@ PetscErrorCode VecView_MPI_HDF5(Vec xin, PetscViewer viewer)
ierr = PetscHDF5IntCast(low/bs,offset + dim);CHKERRQ(ierr);
++dim;
offset[dim] = 0;
++dim;
> On Jul 15, 2015, at 1:25 PM, Gianluca Meneghello <gianmail at gmail.com> wrote:
> Dear all,
> I would like to write a complex Vec to an HDF5 viewer, but I receive an error.
> Is it possible to write complex numbers to an HDF5 viewer?
> The error is reproducible on my computer by running src/vec/vec/examples/tutorials/ex10.c when compiled with --with-scalar-type=complex (and --download-hdf5 if that is important). I attach the output of ./ex10 -hdf5.
> Thanks for your help,
> Gianluca
> <ex10.log>
