[petsc-users] Problem with ksp view
Michele Rosso mrosso at uci.edu
Fri Jul 10 14:11:48 CDT 2015
Barry,
I made a mistake naming the files: the messy one is from the file while
the correct one is from command line. I am using a custom PC
(dmdarepart).
I attached 4 files:
ksp_view_cl_1proc.txt:  output on command line for 1 process run
ksp_view_cl_8proc.txt:  output on command line for 8 processes run
ksp_view_fl_1proc.txt:  output on file for 1 process run
ksp_view_fl_8proc.txt:  output on file for 8 processes run
This is what I do in the code:
       CALL KSPSolve( ksp, b, x, ierr )
       CALL PetscViewerASCIIOpen( PETSC_COMM_WORLD, ksp_view_file,
viewer, ierr )
       CALL KSPView( ksp, viewer, ierr )
       CALL PetscViewerDestroy( viewer, ierr )
I will try to provide a minimal example ASAP.
Michele
On Fri, 2015-07-10 at 13:43 -0500, Barry Smith wrote:
>    Are you sure you named the files correctly and sent the right files. This is very confusing. What is in ksp_view_file.txt looks reasonable to me: You are running three level multigrid where the coarse solve is two level multigrid with a coarse solve of SuperLU_Dist.  What is in ksp_view_command.txt is a jumbled mess which seems to be missing something.
>    If you run both on one process what happens?
>    Barry
> > On Jul 10, 2015, at 1:14 PM, Michele Rosso <mrosso at uci.edu> wrote:
> > Hi,
> > I am having a problem with KSPview. If I use the command line option, the output of KSPView is complete. If instead I call KSPView after KSPsolve and I have the ksp infos printed on  file, the output misses some
> > parts (see attached files).
> > What can I do to fix this?
> > Thanks,
> > Michele
> > <ksp_view_commandline.txt><ksp_view_file.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150710/aee6a1c7/attachment-0001.html>
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     1 MPI processes
      type: preonly
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     1 MPI processes
      type: dmdarepart
        DMDARepart: parent comm size reduction factor = 2
        DMDARepart: subcomm_size = 1
        KSP Object:        (mg_coarse_dmdarepart_)         1 MPI processes
          type: richardson
            Richardson: damping factor=1
          maximum iterations=10000, initial guess is zero
          using PRECONDITIONED norm type for convergence test
        PC Object:        (mg_coarse_dmdarepart_)         1 MPI processes
          type: mg
            MG: type is MULTIPLICATIVE, levels=2 cycles=v
            KSP Object:            (mg_coarse_dmdarepart_mg_coarse_)             1 MPI processes
              type: preonly
            PC Object:            (mg_coarse_dmdarepart_mg_coarse_)             1 MPI processes
              type: lu
                LU: out-of-place factorization
                tolerance for zero pivot 2.22045e-14
                using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
                matrix ordering: nd
                factor fill ratio given 0, needed 0
                  Factored matrix follows:
                    Mat Object:                     1 MPI processes
                      type: seqaij
                      rows=8, cols=8
                      package used to perform factorization: superlu_dist
                      total: nonzeros=0, allocated nonzeros=0
                      total number of mallocs used during MatSetValues calls =0
                        SuperLU_DIST run parameters:
                          Process grid nprow 1 x npcol 1
                          Equilibrate matrix TRUE
                          Matrix input mode 0
                          Replace tiny pivots TRUE
                          Use iterative refinement FALSE
                          Processors in row 1 col partition 1
                          Row permutation LargeDiag
                          Column permutation METIS_AT_PLUS_A
                          Parallel symbolic factorization FALSE
                          Repeated factorization SamePattern_SameRowPerm
              linear system matrix = precond matrix:
                type: seqaij
                rows=8, cols=8
                total: nonzeros=32, allocated nonzeros=32
                  not using I-node routines
          Down solver (pre-smoother) on level 1 -------------------------------
            KSP Object:            (mg_coarse_dmdarepart_mg_levels_1_)             1 MPI processes
              type: richardson
              maximum iterations=2
              tolerances:  relative=0, absolute=1e-50, divergence=10000
            PC Object:            (mg_coarse_dmdarepart_mg_levels_1_)             1 MPI processes
              type: sor
                SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
                type: seqaij
                rows=64, cols=64
                total: nonzeros=352, allocated nonzeros=352
          Up solver (post-smoother) same as down solver (pre-smoother)
            type: seqaij
            rows=64, cols=64
        type: seqaij
        rows=64, cols=64
    KSP Object:    (mg_levels_1_)     1 MPI processes
      type: richardson
    PC Object:    (mg_levels_1_)     1 MPI processes
      type: sor
        type: seqaij
        rows=512, cols=512
        total: nonzeros=3200, allocated nonzeros=3200
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     1 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     1 MPI processes
      type: sor
        type: seqaij
        rows=4096, cols=4096
        total: nonzeros=27136, allocated nonzeros=27136
    type: seqaij
#PETSc Option Table entries:
-ksp_initial_guess_nonzero yes
-ksp_norm_type unpreconditioned
-ksp_rtol 1e-9
-ksp_type cg
-ksp_view
-log_summary log_summary.txt
-mg_coarse_dmdarepart_ksp_type richardson
-mg_coarse_dmdarepart_mg_coarse_pc_factor_mat_solver_package superlu_dist
-mg_coarse_dmdarepart_mg_coarse_pc_type lu
-mg_coarse_dmdarepart_mg_levels_ksp_type richardson
-mg_coarse_dmdarepart_pc_mg_galerkin
-mg_coarse_dmdarepart_pc_mg_levels 2
-mg_coarse_dmdarepart_pc_type mg
-mg_coarse_ksp_type preonly
-mg_coarse_pc_dmdarepart_factor 2
-mg_coarse_pc_type dmdarepart
-mg_levels_ksp_max_it 1
-mg_levels_ksp_type richardson
-nx 16
-ny 16
-nz 16
-options_left
-pc_mg_galerkin
-pc_mg_levels 3
-pc_type mg
-px 1
-py 1
-pz 1
#End of PETSc Option Table entries
There are 6 unused database options. They are:
Option left: name:-nx value: 16
Option left: name:-ny value: 16
Option left: name:-nz value: 16
Option left: name:-px value: 1
Option left: name:-py value: 1
Option left: name:-pz value: 1
KSP Object: 8 MPI processes
  type: cg
PC Object: 8 MPI processes
  type: mg
    KSP Object:    (mg_coarse_)     8 MPI processes
      type: preonly
    PC Object:    (mg_coarse_)     8 MPI processes
      type: dmdarepart
        DMDARepart: subcomm_size = 4
      KSP Object:      (mg_coarse_dmdarepart_)       4 MPI processes
        type: richardson
      PC Object:      (mg_coarse_dmdarepart_)       4 MPI processes
        type: mg
          KSP Object:          (mg_coarse_dmdarepart_mg_coarse_)           4 MPI processes
            type: preonly
          PC Object:          (mg_coarse_dmdarepart_mg_coarse_)           4 MPI processes
            type: lu
              matrix ordering: natural
                  Mat Object:                   4 MPI processes
                    type: mpiaij
                    rows=8, cols=8
                        Process grid nprow 2 x npcol 2
                        Matrix input mode 1
                        Processors in row 2 col partition 2
              type: mpiaij
              rows=8, cols=8
                using I-node (on process 0) routines: found 1 nodes, limit used is 5
          KSP Object:          (mg_coarse_dmdarepart_mg_levels_1_)           4 MPI processes
            type: richardson
          PC Object:          (mg_coarse_dmdarepart_mg_levels_1_)           4 MPI processes
            type: sor
              type: mpiaij
              rows=64, cols=64
                not using I-node (on process 0) routines
          type: mpiaij
          rows=64, cols=64
      Mat Object:       8 MPI processes
        type: mpiaij
        rows=64, cols=64
    KSP Object:    (mg_levels_1_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_1_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=512, cols=512
    KSP Object:    (mg_levels_2_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     8 MPI processes
      type: sor
        type: mpiaij
    type: mpiaij
-ksp_rtol 1e-9
-ksp_type cg
-ksp_view
-nx 16
-ny 16
-nz 16
-options_left
-pc_mg_galerkin
-pc_mg_levels 3
-pc_type mg
-px 2
-py 2
-pz 2
Option left: name:-px value: 2
Option left: name:-py value: 2
Option left: name:-pz value: 2
  type: cg
  type: mg
      type: preonly
      type: dmdarepart
          type: richardson
          type: mg
              type: preonly
              type: lu
                matrix ordering: nd
                      type: seqaij
                      rows=8, cols=8
                          Matrix input mode 0
                type: seqaij
                rows=8, cols=8
              type: richardson
              type: sor
                type: seqaij
                rows=64, cols=64
            type: seqaij
            rows=64, cols=64
        type: seqaij
        rows=64, cols=64
      type: richardson
      type: sor
        type: seqaij
        rows=512, cols=512
      type: richardson
      type: sor
        type: seqaij
    type: seqaij
        type: richardson
        type: mg
            type: preonly
        type: mpiaij
        rows=64, cols=64
      type: richardson
      type: sor
        type: mpiaij
        rows=512, cols=512
      type: richardson
      type: sor
        type: mpiaij
    type: mpiaij
ses
            type: sor
              type: mpiaij
              rows=64, cols=64
          type: mpiaij
          rows=64, cols=64
