[petsc-users] Problem with ksp view
Barry Smith
bsmith at mcs.anl.gov
Fri Jul 10 13:43:10 CDT 2015
Are you sure you named the files correctly and sent the right files. This is very confusing. What is in ksp_view_file.txt looks reasonable to me: You are running three level multigrid where the coarse solve is two level multigrid with a coarse solve of SuperLU_Dist. What is in ksp_view_command.txt is a jumbled mess which seems to be missing something.
If you run both on one process what happens?
Barry
> On Jul 10, 2015, at 1:14 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Hi,
> I am having a problem with KSPview. If I use the command line option, the output of KSPView is complete. If instead I call KSPView after KSPsolve and I have the ksp infos printed on file, the output misses some
> parts (see attached files).
> What can I do to fix this?
> Thanks,
> Michele
> <ksp_view_commandline.txt><ksp_view_file.txt>
