[petsc-users] Nodes coordinates in distributed dmplex
Matthew Knepley
knepley at gmail.com
Fri Jul 10 11:14:31 CDT 2015
On Fri, Jul 10, 2015 at 6:48 AM, Alejandro D Otero <aotero at fi.uba.ar> wrote:
> Hi Matt, thanks for your answer.
> I got a vector from getCoordinates(). How are their components indexed?
> is (p * dim + d) with p: node, dim: of the problem, x_d coordinate of the
> node, ok?
> Which numbering for p? The local number of node, the number of point in
> the DAG of the dm, the original number of node?
All data layouts for Plex are described by a PetscSection (which is how it
should be in the rest of PETSc as well). The PetscSection is a map
from mesh points to (# dof, offset) pairs. Thus, the way I get coordinates
is the following:
DMGetCoordinatesLocal(dm, &coordinates);
DMGetCoordinateDM(dm, &cdm);
DMGetDefaultSection(cdm, &cs);
PetscSectionGetChart(cs, &pStart, &pEnd);
VecGetArrayRead(coordinates, &coords);
for (p = pStart; p < pEnd; ++p) {
PetscInt dof, off;
PetscSectionGetDof(cs, p, &dof);
PetscSectionGetOffset(cs, p, &off);
for (d = 0; d < dof; ++d) <compute with coords[off+d]>
VecRestoreArrayRead(coordinates, &coords);
> I am trying a simple square mesh with 16 4-node square elements parted
> into 2 process. Total of 25 nodes.
> The distributed dm seems alright to me. Each process gets a dm with 8
> elements an 15 nodes, which means that the 5 shared nodes are local to each
> process. But one of the process gives negative values for the shared nodes.
> How need them to be mapped to get the right number.
Where do you get negative point numbers? I encode off-process point numbers
as -(remote point + 1).
> It seems I'm using a wrong approach to this. May be I need to get the
> coordinates in a somehow different way. I'm working on a from-scratch
> implementation of a FEM code based on petsc4py. I want to code the problem
> matrices assembly from elemental matrices. I've already done this
> sequentially, but I got stuck when trying to compute elemental matrices in
> parallel because I don't understand the way of obtaining the coordinates of
> the nodes in for each element.
The way I get coordinates for the element c is
PetscScalar *coords = NULL;
PetscInt csize;
ierr = DMPlexVecGetClosure(dm, cs, coordinates, c, &csize,
&coords);CHKERRQ(ierr);
ierr = DMPlexVecRestoreClosure(dm, cs, coordinates, c, &csize,
Matt
> Again, thanks for your help,
> A.
> On Thu, Jul 9, 2015 at 5:18 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jul 9, 2015 at 7:42 AM, Alejandro D Otero <aotero at fi.uba.ar>
>> wrote:
>>> Hi, sorry if this is an obvious question, but I cannot figure out how to
>>> recover finite element nodes coordinates once I have distributed a mesh
>>> stored as a dmplex. I am using petsc4py as interface to petsc rutines.
>>> I first created a dmplex using:
>>> dm.createFromCellList()
>>> In a sequential run I got the coordinates with:
>>> Coords = dm.getCoordinates()
>>> which gave a sequential vector with the coordinates of the mesh nodes.
>>> When I distribute the mesh with:
>>> dm.distribute()
>>> each mpi process has it own dm but the indexing of the vector resulting
>>> from getCoordinates() or getCoordinatesLocal() seems not consistent with
>>> the local numbering of the cells and nodes.
>> When the mesh is distributed, the vertices are renumbered. Thus the
>> coordinates you get out are
>> for reordered local vertices, but they are consistent with the local
>> topology (cells still contain the
>> right vertices) and the overlap mapping (SF still connects the shared
>> vertices).
>> What do you need it to do?
>> Thanks,
>> Matt
>>> Which is the correct way of doing this in PETSc philosophy?
>>> Thanks in advance,
>>> Alejandro
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150710/0c3af8f5/attachment-0001.html>
