[petsc-users] changing solver options at runtime
Barry Smith
bsmith at mcs.anl.gov
Thu Feb 26 23:55:58 CST 2015
TSSetOptionsPrefix() or SNESSetOptionsPrefix() or KSPSetOptionsPrefix(); you can call them at any time and then any call to TS/SNES/KSPSetFromOptions() on that object after that will use the command line options associated with that prefix. Check the manual pages.
Barry
> On Feb 26, 2015, at 11:01 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
> Is there a way to change, between two consecutive linear solves, the command line options that petsc uses to initialize the solver (using xxxSetFromOptions)?
> I am attempting a multidisciplinary simulation, such that each discipline has its own linear system of equations to solve (perhaps repeatedly), and I wish to set separate options for each disciplinary solve. Passing the options at command line will set the same values for each discipline, which is what I wish to change. Of course, this can be done by writing code to set each option, but the convenience of doing it through command line options is very attractive.
> Any help will be greatly appreciated.
> Thanks,
> Manav
