[petsc-users] DMNetworkGetEdgeRange() in parallel
Matthew Knepley
knepley at gmail.com
Tue Feb 24 18:49:32 CST 2015
On Tue, Feb 24, 2015 at 6:42 PM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> I implemented the code as agreed, but I don't get the results I expected.
> When I create the vector with DMCreateGlobalVector(), I obtain a vector
> with a layout similar to the original DMNetwork, instead of the cloned
> network with the new PetscSection. The code is as follows:
> DMClone(dm, &dmEdge);
> PetscSectionCreate(PETSC_COMM_WORLD, &s);
> PetscSectionSetNumFields(s, 1);
> PetscSectionSetFieldComponents(s, 0, 1);
> // Now to set the chart, I pick the edge range
> DMNetworkGetEdgeRange(dmEdge, & eStart, & eEnd)
> PetscSectionSetChart(s, eStart, eEnd);
> for(PetscInt e = eStart; c < eEnd; ++e) {
> PetscSectionSetDof(s, e, 1);
> PetscSectionSetFieldDof(s, e, 0, 1);
> PetscSectionSetUp(s);
> DMSetDefaultSection(dmEdge s);
> DMCreateGlobalVector(dmEdge, &globalVec);
> When I get into DMCreateGlobalVector(dmEdge, &globalVec) in the debugger,
> in the function DMCreateSubDM_Section_Private() I call PetscSectionView()
> on the section
I have no idea why you would be in DMCreateSubDM().
Just view globalVec. If the code is as above, it will give you a vector
with that layout. If not
it should be trivial to make a small code and send it. I do this everywhere
is PETSc, so the
basic mechanism certainly works.
Matt
> obtained by DMGetDefaultGlobalSection(dm, §ionGlobal), and I obtain a
> PetscSection nothing like the one I see when I call PetscSectionView() on
> the PetscSection I created above. Does this have anything to do? I tried
> to compare this strange PetscSection with the one from the original
> DMNetwork, I call DMGetDefaultGlobalSection(dm, §ionGlobal) before
> the first line of the snippet above and I get this error message.
> 0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: DM must have a default PetscSection in order to create a
> global PetscSection
> Thanks in advance
> Miguel
> On Mon, Feb 23, 2015 at 3:24 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Feb 23, 2015 at 2:15 PM, Miguel Angel Salazar de Troya <
>>> Thanks a lot, the partition should be done before setting up the
>>> section, right?
>> The partition will be automatic. All you have to do is make the local
>> section. The DM is already partitioned,
>> and the Section will inherit that.
>> Matt
>>> Miguel
>>> On Mon, Feb 23, 2015 at 2:05 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Feb 23, 2015 at 1:40 PM, Miguel Angel Salazar de Troya <
>>>>> Wouldn't including the edge variables in the global vector make the
>>>>> code slower? I'm using the global vector in a TS, using one of the explicit
>>>>> RK schemes. The edge variables would not be updated in the RHSFunction
>>>>> evaluation. I only change the edge variables in the TSUpdate. If the global
>>>>> vector had the edge variables, it would be a much larger vector, and all
>>>>> the vector operations performed by the TS would be slower. Although the
>>>>> vector F returned by the RHSFunction would be zero in the edge variable
>>>>> components. I guess that being the vector sparse that would not be a
>>>>> problem.
>>>>> I think I'm more interested in the PetscSection approach because it
>>>>> might require less modifications in my code. However, I don't know how I
>>>>> could do this. Maybe something like this?
>>>>> DMNetworkGetEdgeRange(dm, & eStart, & eEnd
>>>>> PetscSectionSetFieldDof(s, e, 1, 1);
>>>> It should be PetscSectionSetFieldDof(s, e, 0, 1);
>>>>> Now in the manual I see this:
>>>> First you want to do:
>>>> and then use dmEdge below.
>>>>> DMSetDefaultSection(dm, s);
>>>>> DMGetLocalVector(dm, &localVec);
>>>>> DMGetGlobalVector(dm, &globalVec);
>>>>> Setting up the default section in the DM would interfere with the
>>>>> section already set up with the variables in the vertices?
>>>> Yep, thats why you would use a clone.
>>>> Thanks,
>>>> Matt
>>>>> Thanks a lot for your responses.
>>>>> On Mon, Feb 23, 2015 at 11:37 AM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Feb 23, 2015 at 9:27 AM, Miguel Angel Salazar de Troya <
>>>>>>> I'm iterating through local edges given in DMNetworkGetEdgeRange().
>>>>>>> For each edge, I extract or modify its corresponding value in a global
>>>>>>> petsc vector. Therefore that vector must have as many components as edges
>>>>>>> there are in the network. To extract the value in the vector, I use
>>>>>>> VecGetArray() and a variable counter that is incremented in each iteration.
>>>>>>> The array that I obtain in VecGetArray() has to be the same size
>>>>>>> than the edge range. That variable counter starts as 0, so if the array
>>>>>>> that I obtained in VecGetArray() is x_array, x_array[0] must be the
>>>>>>> component in the global vector that corresponds with the start edge given
>>>>>>> I need that global petsc vector because I will use it in other
>>>>>>> operations, it's not just data. Sorry for the confusion. Thanks in advance.
>>>>>> This sounds like an assembly operation. The usual paradigm is to
>>>>>> compute in the local space, and then communicate to get to the global
>>>>>> space. So you would make a PetscSection that had 1 (or some) unknowns on
>>>>>> each cell (edge) and then you can use DMCreateGlobal/LocalVector() and
>>>>>> DMLocalToGlobal() to do this.
>>>>>> Does that make sense?
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Miguel
>>>>>>> On Mon, Feb 23, 2015 at 9:09 AM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Mon, Feb 23, 2015 at 8:42 AM, Miguel Angel Salazar de Troya <
>>>>>>>>> Thanks, that will help me. Now what I would like to have is the
>>>>>>>>> following: if I have two processors and ten edges, the partitioning results
>>>>>>>>> in the first processor having the edges 0-4 and the second processor, the
>>>>>>>>> edges 5-9. I also have a global vector with as many components as edges,
>>>>>>>>> 10. How can I partition it so the first processor also has the 0-4
>>>>>>>>> components and the second, the 5-9 components of the vector?
>>>>>>>> I think it would help to know what you want to accomplish. This is
>>>>>>>> how you are proposing to do it.'
>>>>>>>> If you just want to put data on edges, DMNetwork has a facility for
>>>>>>>> that already.
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> Miguel
>>>>>>>>> On Feb 23, 2015 8:08 AM, "Abhyankar, Shrirang G." <
>>>>>>>>> abhyshr at mcs.anl.gov> wrote:
>>>>>>>>>> Miguel,
>>>>>>>>>> One possible way is to store the global numbering of any
>>>>>>>>>> edge/vertex in the "component" attached to it. Once the mesh gets
>>>>>>>>>> partitioned, the components are also distributed so you can easily retrieve
>>>>>>>>>> the global number of any edge/vertex by accessing its component. This is
>>>>>>>>>> what is done in the DMNetwork example pf.c although the global numbering is
>>>>>>>>>> not used for anything.
>>>>>>>>>> Shri
>>>>>>>>>> From: Matthew Knepley <knepley at gmail.com>
>>>>>>>>>> Date: Mon, 23 Feb 2015 07:54:34 -0600
>>>>>>>>>> To: Miguel Angel Salazar de Troya <salazardetroya at gmail.com>
>>>>>>>>>> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
>>>>>>>>>> Subject: Re: [petsc-users] DMNetworkGetEdgeRange() in parallel
>>>>>>>>>> On Sun, Feb 22, 2015 at 3:59 PM, Miguel Angel Salazar de Troya
>>>>>>>>>> <salazardetroya at gmail.com> wrote:
>>>>>>>>>>> Thanks. Once I obtain that Index Set with the routine DMPlexCreateCellNumbering()
>>>>>>>>>>> (I assume that the edges in DMNetwork correspond to cells in DMPlex) can I
>>>>>>>>>>> use it to partition a vector with as many components as edges I have in my
>>>>>>>>>>> network?
>>>>>>>>>> I do not completely understand the question.
>>>>>>>>>> If you want a partition of the edges, you can use
>>>>>>>>>> DMPlexCreatePartition() and its friend DMPlexDistribute(). What
>>>>>>>>>> are you trying to do?
>>>>>>>>>> Matt
>>>>>>>>>>> Thanks
>>>>>>>>>>> Miguel
>>>>>>>>>>> On Sun, Feb 22, 2015 at 12:15 PM, Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Sun, Feb 22, 2015 at 11:01 AM, Miguel Angel Salazar de
>>>>>>>>>>>> Troya <salazardetroya at gmail.com> wrote:
>>>>>>>>>>>>> Hi
>>>>>>>>>>>>> I noticed that the routine DMNetworkGetEdgeRange() returns
>>>>>>>>>>>>> the local indices for the edge range. Is there any way to obtain the global
>>>>>>>>>>>>> indices? So if my network has 10 edges, the processor 1 has the 0-4 edges
>>>>>>>>>>>>> and the processor 2, the 5-9 edges, how can I obtain this information?
>>>>>>>>>>>> One of the points of DMPlex is we do not require a global
>>>>>>>>>>>> numbering. Everything is numbered
>>>>>>>>>>>> locally, and the PetscSF maps local numbers to local numbers in
>>>>>>>>>>>> order to determine ownership.
>>>>>>>>>>>> If you want to create a global numbering for some reason, you
>>>>>>>>>>>> can using DMPlexCreatePointNumbering().
>>>>>>>>>>>> There are also cell and vertex versions that we use for output,
>>>>>>>>>>>> so you could do it just for edges as well.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Matt
>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>> Miguel
>>>>>>>>>>>>> *Miguel Angel Salazar de Troya*
>>>>>>>>>>>>> Graduate Research Assistant
>>>>>>>>>>>>> Department of Mechanical Science and Engineering
>>>>>>>>>>>>> University of Illinois at Urbana-Champaign
>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>> salaza11 at illinois.edu
>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> (217) 550-2360
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> (217) 550-2360
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> (217) 550-2360
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> (217) 550-2360
>> experiments lead.
>> -- Norbert Wiener
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150224/6db3724e/attachment-0001.html>
