[petsc-users] DMNetworkGetEdgeRange() in parallel
    Miguel Angel Salazar de Troya
    salazardetroya at gmail.com
    Mon Feb 23 14:15:00 CST 2015
Thanks a lot, the partition should be done before setting up the section,
right?
Miguel
On Mon, Feb 23, 2015 at 2:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Feb 23, 2015 at 1:40 PM, Miguel Angel Salazar de Troya <
> salazardetroya at gmail.com> wrote:
>> Wouldn't including the edge variables in the global vector make the code
>> slower? I'm using the global vector in a TS, using one of the explicit RK
>> schemes. The edge variables would not be updated in the RHSFunction
>> evaluation. I only change the edge variables in the TSUpdate. If the global
>> vector had the edge variables, it would be a much larger vector, and all
>> the vector operations performed by the TS would be slower. Although the
>> vector F returned by the RHSFunction would be zero in the edge variable
>> components. I guess that being the vector sparse that would not be a
>> problem.
>> I think I'm more interested in the PetscSection approach because it might
>> require less modifications in my code. However, I don't know how I could do
>> this. Maybe something like this?
>> PetscSectionCreate(PETSC_COMM_WORLD, &s);
>> PetscSectionSetNumFields(s, 1);
>> PetscSectionSetFieldComponents(s, 0, 1);
>> // Now to set the chart, I pick the edge range
>> DMNetworkGetEdgeRange(dm, & eStart, & eEnd
>> PetscSectionSetChart(s, eStart, eEnd);
>> for(PetscInt e = eStart; c < eEnd; ++e) {
>>      PetscSectionSetDof(s, e, 1);
>>      PetscSectionSetFieldDof(s, e, 1, 1);
> It should be PetscSectionSetFieldDof(s, e, 0, 1);
>> PetscSectionSetUp(s);
>> Now in the manual I see this:
> First you want to do:
>   DMClone(dm, &dmEdge);
> and then use dmEdge below.
>> DMSetDefaultSection(dm, s);
>> DMGetLocalVector(dm, &localVec);
>> DMGetGlobalVector(dm, &globalVec);
>> Setting up the default section in the DM would interfere with the section
>> already set up with the variables in the vertices?
> Yep, thats why you would use a clone.
>   Thanks,
>      Matt
>> Thanks a lot for your responses.
>> On Mon, Feb 23, 2015 at 11:37 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Feb 23, 2015 at 9:27 AM, Miguel Angel Salazar de Troya <
>>>> I'm iterating through local edges given in DMNetworkGetEdgeRange().
>>>> For each edge, I extract or modify its corresponding value in a global
>>>> petsc vector. Therefore that vector must have as many components as edges
>>>> there are in the network. To extract the value in the vector, I use
>>>> VecGetArray() and a variable counter that is incremented in each iteration.
>>>> The array that I obtain in VecGetArray() has to be the same size than
>>>> the edge range. That variable counter starts as 0, so if the array that I
>>>> obtained in VecGetArray() is x_array, x_array[0] must be the component
>>>> in the global vector that corresponds with the start edge given in
>>>> I need that global petsc vector because I will use it in other
>>>> operations, it's not just data. Sorry for the confusion. Thanks in advance.
>>> This sounds like an assembly operation. The usual paradigm is to compute
>>> in the local space, and then communicate to get to the global space. So you
>>> would make a PetscSection that had 1 (or some) unknowns on each cell (edge)
>>> and then you can use DMCreateGlobal/LocalVector() and DMLocalToGlobal() to
>>> do this.
>>> Does that make sense?
>>>   Thanks,
>>>      Matt
>>>> Miguel
>>>> On Mon, Feb 23, 2015 at 9:09 AM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Feb 23, 2015 at 8:42 AM, Miguel Angel Salazar de Troya <
>>>>>> Thanks, that will help me. Now what I would like to have is the
>>>>>> following: if I have two processors and ten edges, the partitioning results
>>>>>> in the first processor having the edges 0-4 and the second processor, the
>>>>>> edges 5-9. I also have a global vector with as many components as edges,
>>>>>> 10. How can I partition it so the first processor also has the 0-4
>>>>>> components and the second, the 5-9 components of the vector?
>>>>> I think it would help to know what you want to accomplish. This is how
>>>>> you are proposing to do it.'
>>>>> If you just want to put data on edges, DMNetwork has a facility for
>>>>> that already.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Miguel
>>>>>> On Feb 23, 2015 8:08 AM, "Abhyankar, Shrirang G." <
>>>>>> abhyshr at mcs.anl.gov> wrote:
>>>>>>>  Miguel,
>>>>>>>    One possible way is to store the global numbering of any
>>>>>>> edge/vertex in the "component" attached to it. Once the mesh gets
>>>>>>> partitioned, the components are also distributed so you can easily retrieve
>>>>>>> the global number of any edge/vertex by accessing its component. This is
>>>>>>> what is done in the DMNetwork example pf.c although the global numbering is
>>>>>>> not used for anything.
>>>>>>>  Shri
>>>>>>>  From: Matthew Knepley <knepley at gmail.com>
>>>>>>> Date: Mon, 23 Feb 2015 07:54:34 -0600
>>>>>>> To: Miguel Angel Salazar de Troya <salazardetroya at gmail.com>
>>>>>>> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
>>>>>>> Subject: Re: [petsc-users] DMNetworkGetEdgeRange() in parallel
>>>>>>>   On Sun, Feb 22, 2015 at 3:59 PM, Miguel Angel Salazar de Troya <
>>>>>>>> Thanks. Once I obtain that Index Set with the routine DMPlexCreateCellNumbering()
>>>>>>>> (I assume that the edges in DMNetwork correspond to cells in DMPlex) can I
>>>>>>>> use it to partition a vector with as many components as edges I have in my
>>>>>>>> network?
>>>>>>>  I do not completely understand the question.
>>>>>>>  If you want a partition of the edges, you can use
>>>>>>> DMPlexCreatePartition() and its friend DMPlexDistribute(). What
>>>>>>> are you trying to do?
>>>>>>>     Matt
>>>>>>>>  Thanks
>>>>>>>> Miguel
>>>>>>>> On Sun, Feb 22, 2015 at 12:15 PM, Matthew Knepley <
>>>>>>>>>  On Sun, Feb 22, 2015 at 11:01 AM, Miguel Angel Salazar de Troya <
>>>>>>>>>> Hi
>>>>>>>>>>  I noticed that the routine DMNetworkGetEdgeRange() returns the
>>>>>>>>>> local indices for the edge range. Is there any way to obtain the global
>>>>>>>>>> indices? So if my network has 10 edges, the processor 1 has the 0-4 edges
>>>>>>>>>> and the processor 2, the 5-9 edges, how can I obtain this information?
>>>>>>>>>  One of the points of DMPlex is we do not require a global
>>>>>>>>> numbering. Everything is numbered
>>>>>>>>> locally, and the PetscSF maps local numbers to local numbers in
>>>>>>>>> order to determine ownership.
>>>>>>>>>  If you want to create a global numbering for some reason, you
>>>>>>>>> can using DMPlexCreatePointNumbering().
>>>>>>>>> There are also cell and vertex versions that we use for output, so
>>>>>>>>> you could do it just for edges as well.
>>>>>>>>>    Thanks,
>>>>>>>>>       Matt
>>>>>>>>>>  Thanks
>>>>>>>>>>  Miguel
>>>>>>>>>>  *Miguel Angel Salazar de Troya*
>>>>>>>>>> Graduate Research Assistant
>>>>>>>>>> Department of Mechanical Science and Engineering
>>>>>>>>>> University of Illinois at Urbana-Champaign
>>>>>>>>>> (217) 550-2360
>>>>>>>>>> salaza11 at illinois.edu
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> (217) 550-2360
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> (217) 550-2360
>>> experiments lead.
>>> -- Norbert Wiener
>> (217) 550-2360
> experiments lead.
> -- Norbert Wiener
(217) 550-2360
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150223/0a5f8aa2/attachment.html>
