[petsc-users] DMNetworkGetEdgeRange() in parallel
Mon Feb 23 07:54:34 CST 2015
On Sun, Feb 22, 2015 at 3:59 PM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> Thanks. Once I obtain that Index Set with the routine DMPlexCreateCellNumbering()
> (I assume that the edges in DMNetwork correspond to cells in DMPlex) can I
> use it to partition a vector with as many components as edges I have in my
> network?
I do not completely understand the question.
If you want a partition of the edges, you can use DMPlexCreatePartition()
and its friend DMPlexDistribute(). What
are you trying to do?
   Matt
> Thanks
> Miguel
> On Sun, Feb 22, 2015 at 12:15 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sun, Feb 22, 2015 at 11:01 AM, Miguel Angel Salazar de Troya <
>>> Hi
>>> I noticed that the routine DMNetworkGetEdgeRange() returns the local
>>> indices for the edge range. Is there any way to obtain the global indices?
>>> So if my network has 10 edges, the processor 1 has the 0-4 edges and the
>>> processor 2, the 5-9 edges, how can I obtain this information?
>> One of the points of DMPlex is we do not require a global numbering.
>> Everything is numbered
>> locally, and the PetscSF maps local numbers to local numbers in order to
>> determine ownership.
>> If you want to create a global numbering for some reason, you can using
>> DMPlexCreatePointNumbering().
>> There are also cell and vertex versions that we use for output, so you
>> could do it just for edges as well.
>>   Thanks,
>>      Matt
>>> Thanks
>>> Miguel
>>> *Miguel Angel Salazar de Troya*
>>> Graduate Research Assistant
>>> Department of Mechanical Science and Engineering
>>> University of Illinois at Urbana-Champaign
>>> (217) 550-2360
>>> salaza11 at illinois.edu
>> experiments lead.
>> -- Norbert Wiener
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150223/91be4abd/attachment.html>
