[petsc-users] DMNetworkGetEdgeRange() in parallel
    Miguel Angel Salazar de Troya
    salazardetroya at gmail.com
    Sun Feb 22 15:59:44 CST 2015
Thanks. Once I obtain that Index Set with the routine
DMPlexCreateCellNumbering()
(I assume that the edges in DMNetwork correspond to cells in DMPlex) can I
use it to partition a vector with as many components as edges I have in my
network?
Thanks
Miguel
On Sun, Feb 22, 2015 at 12:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Feb 22, 2015 at 11:01 AM, Miguel Angel Salazar de Troya <
> salazardetroya at gmail.com> wrote:
>> Hi
>> I noticed that the routine DMNetworkGetEdgeRange() returns the local
>> indices for the edge range. Is there any way to obtain the global indices?
>> So if my network has 10 edges, the processor 1 has the 0-4 edges and the
>> processor 2, the 5-9 edges, how can I obtain this information?
> One of the points of DMPlex is we do not require a global numbering.
> Everything is numbered
> locally, and the PetscSF maps local numbers to local numbers in order to
> determine ownership.
> If you want to create a global numbering for some reason, you can using
> DMPlexCreatePointNumbering().
> There are also cell and vertex versions that we use for output, so you
> could do it just for edges as well.
>   Thanks,
>      Matt
>> Thanks
>> Miguel
>> *Miguel Angel Salazar de Troya*
>> Graduate Research Assistant
>> Department of Mechanical Science and Engineering
>> University of Illinois at Urbana-Champaign
>> (217) 550-2360
>> salaza11 at illinois.edu
> experiments lead.
> -- Norbert Wiener
(217) 550-2360
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150222/ebaa99da/attachment-0001.html>
