[petsc-users] Question concerning ilu and bcgs
Matthew Knepley
knepley at gmail.com
Wed Feb 18 10:33:44 CST 2015
On Wed, Feb 18, 2015 at 10:31 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
> So far I just try around, I haven't looked into literature yet.
> However, both MATLAB's ilu+gmres and ilu+bcgs work. Is it possible that
> some parameter or options need to be tuned in using PETSc's ilu or hypre's
> ilu? Besides, is there a way to view how good the performance of the pc is
> and output the matrices L and U, so that I can do some test in MATLAB?
1) Its not clear exactly what Matlab is doing
2) PETSc uses ILU(0) by default (you can set it to use ILU(k))
3) I don't know what Hypre's ILU can do
I would really discourage from using ILU. I cannot imagine it is faster
than sparse direct factorization
for your system, such as from SuperLU or MUMPS.
Matt
> Hui
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Wednesday, February 18, 2015 8:09 AM
> *To:* Sun, Hui
> *Cc:* hong at aspiritech.org; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Question concerning ilu and bcgs
> On Wed, Feb 18, 2015 at 10:02 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>> Yes I've tried other solvers, gmres/ilu does not work, neither does
>> bcgs/ilu. Here are the options:
>> -pc_type ilu -pc_factor_nonzeros_along_diagonal -pc_factor_levels 0
>> -pc_factor_reuse_ordering -ksp_ty\
>> pe bcgs -ksp_rtol 1e-6 -ksp_max_it 10 -ksp_monitor_short -ksp_view
> Note here that ILU(0) is an unreliable and generally crappy
> preconditioner. Have you looked in the
> literature for the kinds of preconditioners that are effective for your
> problem?
> Thanks,
> Matt
>> Here is the output:
>> 0 KSP Residual norm 211292
>> 1 KSP Residual norm 13990.2
>> 2 KSP Residual norm 9870.08
>> 3 KSP Residual norm 9173.9
>> 4 KSP Residual norm 9121.94
>> 5 KSP Residual norm 7386.1
>> 6 KSP Residual norm 6222.55
>> 7 KSP Residual norm 7192.94
>> 8 KSP Residual norm 33964
>> 9 KSP Residual norm 33960.4
>> 10 KSP Residual norm 1068.54
>> KSP Object: 1 MPI processes
>> type: bcgs
>> maximum iterations=10, initial guess is zero
>> tolerances: relative=1e-06, absolute=1e-50, divergence=10000
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>> type: ilu
>> ILU: out-of-place factorization
>> ILU: Reusing reordering from past factorization
>> 0 levels of fill
>> tolerance for zero pivot 2.22045e-14
>> using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>> matrix ordering: natural
>> factor fill ratio given 1, needed 1
>> Factored matrix follows:
>> Mat Object: 1 MPI processes
>> type: seqaij
>> rows=62500, cols=62500
>> package used to perform factorization: petsc
>> total: nonzeros=473355, allocated nonzeros=473355
>> total number of mallocs used during MatSetValues calls =0
>> not using I-node routines
>> linear system matrix = precond matrix:
>> type: seqaij
>> total: nonzeros=473355, allocated nonzeros=7.8125e+06
>> Time cost: 0.307149, 0.268402, 0.0990018
>> *From:* hong at aspiritech.org [hong at aspiritech.org]
>> *Sent:* Wednesday, February 18, 2015 7:49 AM
>> *To:* Sun, Hui
>> *Cc:* Matthew Knepley; petsc-users at mcs.anl.gov
>> Have you tried other solvers, e.g., PETSc default gmres/ilu, bcgs/ilu
>> etc.
>> The matrix is small. If it is ill-conditioned, then pc_type lu would work
>> the best.
>> Hong
>> On Wed, Feb 18, 2015 at 9:34 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>> With options:
>>> -pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000
>>> -pc_hypre_pilut_tol 1e-3 -ksp_type bcgs -ksp_rtol 1e-10 -ksp_max_it 10
>>> -ksp_monitor_short -ksp_converged_reason -ksp_view
>>> Here is the full output:
>>> 0 KSP Residual norm 1404.62
>>> 1 KSP Residual norm 88.9068
>>> 2 KSP Residual norm 64.73
>>> 3 KSP Residual norm 71.0224
>>> 4 KSP Residual norm 69.5044
>>> 5 KSP Residual norm 455.458
>>> 6 KSP Residual norm 174.876
>>> 7 KSP Residual norm 183.031
>>> 8 KSP Residual norm 650.675
>>> 9 KSP Residual norm 79.2441
>>> 10 KSP Residual norm 84.1985
>>> Linear solve did not converge due to DIVERGED_ITS iterations 10
>>> type: bcgs
>>> tolerances: relative=1e-10, absolute=1e-50, divergence=10000
>>> type: hypre
>>> HYPRE Pilut preconditioning
>>> HYPRE Pilut: maximum number of iterations 1000
>>> HYPRE Pilut: drop tolerance 0.001
>>> HYPRE Pilut: default factor row size
>>> type: seqaij
>>> Time cost: 0.756198, 0.662984, 0.105672
>>> *Sent:* Wednesday, February 18, 2015 3:30 AM
>>> *To:* Sun, Hui
>>> *Cc:* petsc-users at mcs.anl.gov
>>> On Wed, Feb 18, 2015 at 12:33 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>>> I have a matrix system Ax = b, A is of type MatSeqAIJ or MatMPIAIJ,
>>>> depending on the number of cores.
>>>> I try to solve this problem by pc_type ilu and ksp_type bcgs, it does
>>>> not converge. The options I specify are:
>>>> -pc_hypre_pilut_tol 1e-3 -ksp_type b\
>>>> cgs -ksp_rtol 1e-10 -ksp_max_it 1000 -ksp_monitor_short
>>> 1) Run with -ksp_view, so we can see exactly what was used
>>> 2) ILUT is unfortunately not a well-defined algorithm, and I believe
>>> the parallel version makes different decisions
>>> than the serial version.
>>> Thanks,
>>> Matt
>>>> The first a few lines of the output are:
>>>> This clearly indicates non-convergence. However, I output the sparse
>>>> matrix A and vector b to MATLAB, and run the following command:
>>>> [L,U] = ilu(A,struct('type','ilutp','droptol',1e-3));
>>>> [ux1,fl1,rr1,it1,rv1] = bicgstab(A,b,1e-10,1000,L,U);
>>>> And it converges in MATLAB, with flag fl1=0, relative residue
>>>> rr1=8.2725e-11, and iteration it1=89.5. I'm wondering how can I figure out
>>>> what's wrong.
>>>> Best,
>>>> Hui
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150218/a047edb6/attachment.html>
