[petsc-users] Question concerning ilu and bcgs
Sun, Hui hus003 at ucsd.edu
Wed Feb 18 10:31:03 CST 2015
So far I just try around, I haven't looked into literature yet.
However, both MATLAB's ilu+gmres and ilu+bcgs work. Is it possible that some parameter or options need to be tuned in using PETSc's ilu or hypre's ilu? Besides, is there a way to view how good the performance of the pc is and output the matrices L and U, so that I can do some test in MATLAB?
Hui
Sent: Wednesday, February 18, 2015 8:09 AM
To: Sun, Hui
Cc: hong at aspiritech.org; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Question concerning ilu and bcgs
On Wed, Feb 18, 2015 at 10:02 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
Yes I've tried other solvers, gmres/ilu does not work, neither does bcgs/ilu. Here are the options:
-pc_type ilu -pc_factor_nonzeros_along_diagonal -pc_factor_levels 0 -pc_factor_reuse_ordering -ksp_ty\
pe bcgs -ksp_rtol 1e-6 -ksp_max_it 10 -ksp_monitor_short -ksp_view
Note here that ILU(0) is an unreliable and generally crappy preconditioner. Have you looked in the
literature for the kinds of preconditioners that are effective for your problem?
     Matt
Here is the output:
  0 KSP Residual norm 211292
  1 KSP Residual norm 13990.2
  2 KSP Residual norm 9870.08
  3 KSP Residual norm 9173.9
  4 KSP Residual norm 9121.94
  5 KSP Residual norm 7386.1
  6 KSP Residual norm 6222.55
  7 KSP Residual norm 7192.94
  8 KSP Residual norm 33964
  9 KSP Residual norm 33960.4
 10 KSP Residual norm 1068.54
KSP Object: 1 MPI processes
  type: bcgs
  maximum iterations=10, initial guess is zero
  tolerances:  relative=1e-06, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: ilu
    ILU: out-of-place factorization
    ILU: Reusing reordering from past factorization
    0 levels of fill
    tolerance for zero pivot 2.22045e-14
    using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
    matrix ordering: natural
    factor fill ratio given 1, needed 1
      Factored matrix follows:
        Mat Object:         1 MPI processes
          type: seqaij
          rows=62500, cols=62500
          package used to perform factorization: petsc
          total: nonzeros=473355, allocated nonzeros=473355
          total number of mallocs used during MatSetValues calls =0
            not using I-node routines
  linear system matrix = precond matrix:
    type: seqaij
    total: nonzeros=473355, allocated nonzeros=7.8125e+06
Time cost: 0.307149,  0.268402,  0.0990018
From: hong at aspiritech.org<mailto:hong at aspiritech.org> [hong at aspiritech.org<mailto:hong at aspiritech.org>]
Sent: Wednesday, February 18, 2015 7:49 AM
To: Sun, Hui
Cc: Matthew Knepley; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
 Have you tried other solvers, e.g., PETSc default gmres/ilu, bcgs/ilu etc.
The matrix is small. If it is ill-conditioned, then pc_type lu would work the best.
Hong
On Wed, Feb 18, 2015 at 9:34 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
With options:
-pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000 -pc_hypre_pilut_tol 1e-3 -ksp_type bcgs -ksp_rtol 1e-10 -ksp_max_it 10 -ksp_monitor_short -ksp_converged_reason -ksp_view
Here is the full output:
  0 KSP Residual norm 1404.62
  1 KSP Residual norm 88.9068
  2 KSP Residual norm 64.73
  3 KSP Residual norm 71.0224
  4 KSP Residual norm 69.5044
  5 KSP Residual norm 455.458
  6 KSP Residual norm 174.876
  7 KSP Residual norm 183.031
  8 KSP Residual norm 650.675
  9 KSP Residual norm 79.2441
 10 KSP Residual norm 84.1985
Linear solve did not converge due to DIVERGED_ITS iterations 10
  type: bcgs
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
  type: hypre
    HYPRE Pilut preconditioning
    HYPRE Pilut: maximum number of iterations 1000
    HYPRE Pilut: drop tolerance 0.001
    HYPRE Pilut: default factor row size
    type: seqaij
Time cost: 0.756198,  0.662984,  0.105672
From: Matthew Knepley [knepley at gmail.com<mailto:knepley at gmail.com>]
Sent: Wednesday, February 18, 2015 3:30 AM
To: Sun, Hui
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Wed, Feb 18, 2015 at 12:33 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
I have a matrix system Ax = b, A is of type MatSeqAIJ or MatMPIAIJ, depending on the number of cores.
I try to solve this problem by pc_type ilu and ksp_type bcgs, it does not converge. The options I specify are:
-pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000 -pc_hypre_pilut_tol 1e-3 -ksp_type b\
cgs -ksp_rtol 1e-10 -ksp_max_it 1000 -ksp_monitor_short -ksp_converged_reason
1) Run with -ksp_view, so we can see exactly what was used
2) ILUT is unfortunately not a well-defined algorithm, and I believe the parallel version makes different decisions
    than the serial version.
    Matt
The first a few lines of the output are:
This clearly indicates non-convergence. However, I output the sparse matrix A and vector b to MATLAB, and run the following command:
[L,U] = ilu(A,struct('type','ilutp','droptol',1e-3));
[ux1,fl1,rr1,it1,rv1] = bicgstab(A,b,1e-10,1000,L,U);
And it converges in MATLAB, with flag fl1=0, relative residue rr1=8.2725e-11, and iteration it1=89.5. I'm wondering how can I figure out what's wrong.
Best,
Hui
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150218/2040483f/attachment-0001.html>
