[petsc-users] Direct solvers
    Jed Brown
    jed at jedbrown.org
    Thu Feb  5 23:23:43 CST 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>>  Memory allocated 3649788624 Memory used by process 3943817216
>> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
>> [0]PETSC ERROR: Memory requested 18446744066373113856
> This memory size here is truly absurd. If you have access to a linux
> system I suggest running the program with valgrind to see if there is
> memory corruption messing things up
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
I've heard that Valgrind works on OSX 10.10.
http://ranf.tl/2014/11/28/valgrind-on-mac-os-x-10-10-yosemite/
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150205/f9bcbc7f/attachment.pgp>
