[petsc-users] PETSc and AMPI
Barry Smith
bsmith at mcs.anl.gov
Mon Feb 2 07:48:40 CST 2015
> On Feb 1, 2015, at 10:15 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> We could possibly "cheat" with AMPI to essentially have
>>>> PetscInitialize()/Finalize() run through most their code only on
>>>> thread 0 (assuming we have a way of determining thread 0)
>>> Just guard it with a lock.
>> Not sure what you mean here. We want that code to be only run
>> through once, we don't want or need it to be run by each thread. It
>> makes no sense for each thread to call TSInitializePackage() for
>> example.
> Yes, as long as the threads see TSPackageInitialized as true, it's safe
> to call. So the only problem is that we have a race condition. One way
> to do this is to make TSPackageInitialized an int. The code looks
> something like this (depending on the primitives)
> if (AtomicCompareAndSwap(&TSPackageInitialized,0,1)) {
> do the initialization
> TSPackageInitialized = 2;
> MemoryFenceWrite();
> } else {
> while (AccessOnce(TSPackageInitialized) != 2) CPURelax();
Way more complicated then needed :-)
>>> What about debugging and profiling?
>> This is the same issue for "thread safety"* as well as AMPI. I
>> don't think AMPI introduces any particular additional hitches.
>> Barry
>> * in the sense that it is currently implemented meaning each thread
>> works on each own objects so doesn't need to lock "MatSetValues"
>> etc. This other "thread safety" has its own can of worms.
> If AMPI creates threads dynamically,
How could it possibly create threads dynamically and still be running in the MPI 1 model of a consistent number of MPI "processes" at all times?
> we don't have the luxury of having
> hooks that can run when threads are spawned or finish. How do we ensure
> that profiling information has been propagated into the parent
> structure?
