[petsc-users] PETSc and AMPI
Jed Brown
jed at jedbrown.org
Sun Feb 1 22:15:26 CST 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>>> We could possibly "cheat" with AMPI to essentially have
>>> PetscInitialize()/Finalize() run through most their code only on
>>> thread 0 (assuming we have a way of determining thread 0)
>> Just guard it with a lock.
> Not sure what you mean here. We want that code to be only run
> through once, we don't want or need it to be run by each thread. It
> makes no sense for each thread to call TSInitializePackage() for
> example.
Yes, as long as the threads see TSPackageInitialized as true, it's safe
to call. So the only problem is that we have a race condition. One way
to do this is to make TSPackageInitialized an int. The code looks
something like this (depending on the primitives)
if (AtomicCompareAndSwap(&TSPackageInitialized,0,1)) {
do the initialization
TSPackageInitialized = 2;
MemoryFenceWrite();
} else {
while (AccessOnce(TSPackageInitialized) != 2) CPURelax();
>> What about debugging and profiling?
> This is the same issue for "thread safety"* as well as AMPI. I
> don't think AMPI introduces any particular additional hitches.
> Barry
> * in the sense that it is currently implemented meaning each thread
> works on each own objects so doesn't need to lock "MatSetValues"
> etc. This other "thread safety" has its own can of worms.
If AMPI creates threads dynamically, we don't have the luxury of having
hooks that can run when threads are spawned or finish. How do we ensure
that profiling information has been propagated into the parent
structure?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150201/1d18d7fe/attachment.pgp>
