[petsc-users] Insert values into matrix using MatSetValuesStencil or MatSetValuesLocal
    TAY wee-beng
    zonexo at gmail.com
    Wed Aug 26 00:02:33 CDT 2015
Hi Timothee,
Yes, I only parallelized in j and k. ksta,jsta are the starting k and j
values. kend,jend are the ending k and j values.
However, now I am using only 1 procs.
I was going to resend you my code but then I realised my mistake. I used:
*/call
MatSetValuesStencil(A_mat,ione,row,iseven,col,value_insert,INSERT_VALUES,ierr)/**/
for all pts, including those at the boundary. Hence, those coupling
outside the boundary is also included.
I changed to:
*/call
MatSetValuesStencil(A_mat,ione,row,ione,col(:,7),value_insert(7),INSERT_VALUES,ierr)/*
so I am now entering values individually.
Is there anyway I can use the 1st option to enter all the values
together even those some pts are invalid. I think it should be faster.
Can I somehow tell PETSc to ignore them?
Thank you
Yours sincerely,
TAY wee-beng
On 26/8/2015 12:24 PM, Timothée Nicolas wrote:
> What is the definition of ksta, kend, jsta, jend ? Etc ? You are
> parallelized only in j and k ?
> What I said about the "-1" holds only if you have translated the start
> and end points to FORTRAN numbering after getting the corners and
> ghost corners from the DMDA (see ex ex5f90.F from snes)
> Would you mind sending the complete routine with the complete
> definitions of ksta,kend,jsta,jend,and size_x ?
> Timothee
> 2015-08-26 13:12 GMT+09:00 TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>>:
>     Hi,
>     I have wrote the routine for my Poisson eqn. I have only 1 DOF,
>     which is for pressure. The center cell is coupled with 6 other
>     cells (north, south, east, west, front, back), so together 7
>     couplings.
>     size x/y/z = 4/8/10
>     */MatStencil  :: row(4,1),col(4,7)/**/
>     /**/PetscScalar :: value_insert(7)/**/
>     /**/PetscInt :: ione,iseven/**/
>     /**/ione = 1;   iseven = 7/**/
>     /**/do k=ksta,kend/**/
>     /**/        do j = jsta,jend/**/
>     /**/            do i=1,size_x/**/
>     /**/                row(MatStencil_i,1) = i - 1/**/
>     /**/                row(MatStencil_j,1) = j - 1/**/
>     /**/                row(MatStencil_k,1) = k - 1/**/
>     /**/                row(MatStencil_c,1) = 0 ! 1 - 1/**/
>     /**/                value_insert = 0.d0/**/
>     /**/                if (i /= size_x) then/**/
>     /**/                    col(MatStencil_i,3) = i + 1 - 1 !east/**/
>     /**/                    col(MatStencil_j,3) = j - 1/**/
>     /**/                    col(MatStencil_k,3) = k - 1/**/
>     /**/                    col(MatStencil_c,3) = 0/**/
>     /**/                    value_insert(3) =
>     (cp_yz(j,k)%fc_E)/(cp_x(i)%pd_E+cp_x(i+1)%pd_W)/**/
>     /**/                end if/**/
>     /**/                if (i /= 1) then/**/
>     /**/                    col(MatStencil_i,5) = i - 1 - 1 !west/**/
>     /**/                    col(MatStencil_j,5) = j - 1/**/
>     /**/                    col(MatStencil_k,5) = k - 1/**/
>     /**/                    col(MatStencil_c,5) = 0/**/
>     /**/                    value_insert(5) =
>     (cp_yz(j,k)%fc_E)/(cp_x(i)%pd_W+cp_x(i-1)%pd_E)/**/
>     /**/                end if/**/
>     /**/                if (j /= size_y) then/**/
>     /**/                    col(MatStencil_i,2) = i - 1 !north/**/
>     /**/                    col(MatStencil_j,2) = j + 1 - 1/**/
>     /**/                    col(MatStencil_k,2) = k - 1/**/
>     /**/                    col(MatStencil_c,2) = 0/**/
>     /**/                    value_insert(2) =
>     (cp_zx(i,k)%fc_N)/(cp_y(j)%pd_N+cp_y(j+1)%pd_S)/**/
>     /**/                end if/**/
>     /**/                col(MatStencil_i,1) = i - 1/**/
>     /**/                col(MatStencil_j,1) = j - 1/**/
>     /**/                col(MatStencil_k,1) = k - 1/**/
>     /**/                col(MatStencil_c,1) = 0/**/
>     /**/                value_insert(1) = -value_insert(2) -
>     value_insert(3) - value_insert(4) - value_insert(5) -
>     value_insert(6) - value_insert(7)/**/
>     /**/                call
>     /**/            end do/**/
>     /**/        end do/**/
>     /**/    end do/*
>     but I got the error :
>     [0]PETSC ERROR: Argument out of range
>     [0]PETSC ERROR: Inserting a new nonzero at (3,0) in the matrix.
>     The error happens at i = 4, j = 1, k = 1. So I guess it has
>     something to do with the boundary condition. However, I can't
>     figure out what's wrong. Can someone help?
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
>     On 24/8/2015 5:54 PM, Timothée Nicolas wrote:
>>     Hi,
>>     ex5 of snes can give you an example of the two routines.
>>     The C version ex5.c uses MatSetValuesStencil whereas the
>>     Fortran90 version ex5f90.F uses MatSetValuesLocal.
>>     However, I use MatSetValuesStencil also in Fortran, there is no
>>     problem, and no need to mess around with DMDAGetAO, I think.
>>     To input values in the matrix, you need to do the following :
>>     ! Declare the matstencils for matrix columns and rows
>>     MatStencil  :: row(4,1),col(4,n)
>>     ! Declare the quantity which will store the actual matrix elements
>>     PetscScalar :: v(8)
>>     The first dimension in row and col is 4 to allow for 3 spatial
>>     dimensions (even if you use only 2) plus one degree of freedom if
>>     you have several fields in your DMDA. The second dimension is 1
>>     for row (you input one row at a time) and n for col, where n is
>>     the number of columns that you input. For instance, if at node
>>     (1,i,j)  (1 is the index of the degree of freedom), you have,
>>     say, 6 couplings, with nodes (1,i,j), (1,i+1,j), (1,i-1,j),
>>     (1,i,j-1), (1,i,j+1), (2,i,j) for example, then you need to set n=6
>>     Then you define the row number by naturally doing the following,
>>     inside a local loop :
>>     row(MatStencil_i,1) = i          -1
>>     row(MatStencil_j,1) = j          -1
>>     row(MatStencil_c,1) = 1          -1
>>     the -1 are here because FORTRAN indexing is different from the
>>     native C indexing. I put them on the right to make this more
>>     apparent.
>>     Then the column information. For instance to declare the coupling
>>     with node (1,i,j), (1,i-1,j) and (2,i,j) (you can make up for the
>>     rest) you will have to write (still within the same local loop on
>>     i and j)
>>     col(MatStencil_i,1) = i         -1
>>     col(MatStencil_j,1) = j         -1
>>     col(MatStencil_c,1) = 1         -1
>>     v(1) = whatever_it_is
>>     col(MatStencil_i,2) = i-1       -1
>>     col(MatStencil_j,2) = j         -1
>>     col(MatStencil_c,2) = 1         -1
>>     v(2) = whatever_it_is
>>     col(MatStencil_i,3) = i       -1
>>     col(MatStencil_j,3) = j         -1
>>     col(MatStencil_c,3) = 2         -1
>>     v(3) = whatever_it_is
>>     Note that the index of the degree of freedom (or what field you
>>     are coupling to), is indicated by MatStencil_c
>>     Finally use MatSetValuesStencil
>>     ione = 1
>>     isix = 6
>>     call
>>     MatSetValuesStencil(Matrix,ione,row,isix,col,v,INSERT_VALUES,ierr)
>>     If it is not clear don't hesitate to ask more details. For me it
>>     worked that way, I succesfully computed a Jacobian that way. It
>>     is very sensitive. If you slightly depart from the right
>>     jacobian, you will see a huge difference compared to using
>>     matrix free with -snes_mf, so you can hardly make a mistake
>>     because you would see it. That's how I finally got it to work.
>>     Best
>>     Timothee
>>     2015-08-24 18:09 GMT+09:00 Wee-Beng Tay <zonexo at gmail.com
>>         Hi,
>>         I'm modifying my 3d fortran code from MPI along 1 direction
>>         (z) to MPI along 2 directions (y,z)
>>         Previously I was using MatSetValues with global indices.
>>         However, now I'm using DM and global indices is much more
>>         difficult.
>>         I come across MatSetValuesStencil or MatSetValuesLocal.
>>         So what's the difference bet the one since they both seem to
>>         work locally?
>>         Which is a simpler/better option?
>>         Is there an example in Fortran for MatSetValuesStencil?
>>         Do I also need to use DMDAGetAO together
>>         with MatSetValuesStencil or MatSetValuesLocal?
>>         Thanks!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150826/4deb536d/attachment.html>
