[petsc-users] GMRES -> PCMG -> PCASM pre- post- smoother
Aulisa, Eugenio
eugenio.aulisa at ttu.edu
Thu Aug 20 07:00:16 CDT 2015
Thanks Lorenzo
If I well understood what you say is
Set up PCASM for the smoother_down[i] and then
feed it up to smoother_up[i]
Does this assure that only one
memory allocation is done for PCASM?
Eugenio
From: Lorenzo Alessio Botti [lorenzoalessiobotti at gmail.com]
Sent: Thursday, August 20, 2015 5:29 AM
To: petsc-users at mcs.anl.gov
Cc: Aulisa, Eugenio
Subject: GMRES -> PCMG -> PCASM pre- post- smoother
I tried to achieve this behaviour getting all the smothers and setting the same preconditioner to the down and up smoother on the same level.
smoothers.resize(nLevels+1);
smoothers_up.resize(nLevels);
for (PetscInt i = 0; i < nLevels; i++)
PCMGGetSmootherDown(M_pc,nLevels-i,&(smoothers[i]));
KSPSetInitialGuessNonzero(smoothers[i],PETSC_TRUE); // for full and wCicle
PCMGGetSmootherUp(M_pc,nLevels-i,&(smoothers_up[i]));
PCMGSetNumberSmoothDown(M_pc,1);
PCMGSetNumberSmoothUp(M_pc,1);
… set coarse solver options here
PC pc;
KSPSetType(smoothers[i], KSPGMRES);
KSPGetPC(smoothers[i], &pc);
KSPSetPCSide(smoothers[i], PC_RIGHT);
PCSetType(pc, PCASM);
PCFactorSetPivotInBlocks(pc, PETSC_TRUE);
PCFactorSetAllowDiagonalFill(pc);
PCFactorSetReuseFill(pc, PETSC_TRUE);
PCFactorSetReuseOrdering(pc, PETSC_TRUE);
KSPSetType(smoothers_up[i], KSPGMRES);
KSPSetPC(smoothers_up[i], pc);
KSPSetPCSide(smoothers_up[i], PC_RIGHT);
KSPSetConvergenceTest(smoothers[i],KSPConvergedSkip,NULL,NULL);
KSPSetConvergenceTest(smoothers_up[i],KSPConvergedSkip,NULL,NULL);
KSPSetNormType(smoothers[i],KSP_NORM_NONE);
KSPSetNormType(smoothers_up[i],KSP_NORM_NONE);
Is this correct?
Note moreover that for Full Multigrid and W cicles to work as expected I need to add the KSPSetInitialGuessNonZero option.
Bests
Lorenzo
Message: 4
Date: Thu, 20 Aug 2015 02:37:13 -0500
From: Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>
To: "Aulisa, Eugenio" <eugenio.aulisa at ttu.edu<mailto:eugenio.aulisa at ttu.edu>>
Cc: "petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>" <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Subject: Re: [petsc-users] GMRES -> PCMG -> PCASM pre- post- smoother
Message-ID: <1CF3ABE1-214C-4BBC-B8FF-93416EC26EFC at mcs.anl.gov<mailto:1CF3ABE1-214C-4BBC-B8FF-93416EC26EFC at mcs.anl.gov>>
Content-Type: text/plain; charset="us-ascii"
What you describe is not the expected behavior. I expected exactly the result that you expected.
Do you perhaps have some PETSc options around that may be changing the post-smoother? On the command line or in the file petscrc or in the environmental variable PETSC_OPTIONS? Can you send us some code that we could run that reproduces the problem?
Barry
On Aug 19, 2015, at 9:26 PM, Aulisa, Eugenio <eugenio.aulisa at ttu.edu<mailto:eugenio.aulisa at ttu.edu>> wrote:
I am solving an iteration of
where I build my particular ASM domain decomposition.
In setting the PCMG I would like at each level
to use the same pre- and post-smoother
and for this reason I am using
PCMGGetSmoother ( pcMG, level , &subksp );
to extract and set at each level the ksp object.
In setting PCASM then I use
KSPGetPC ( subksp, &subpc );
PCSetType ( subpc, PCASM );
and then set my own decomposition
PCASMSetLocalSubdomains(subpc,_is_loc_idx.size(),&_is_ovl[0],&_is_loc[0]);
Now everything compiles, and runs with no memory leakage,
but I do not get the expected convergence.
When I checked the output of -ksp_view, I saw something that puzzled me:
at each level >0, while in the MG pre-smoother the ASM domain decomposition
is the one that I set, for example with 4 processes I get
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (level-2) 4 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=1
using preconditioner applied to right hand side for initial guess
tolerances: relative=1e-12, absolute=1e-20, divergence=1e+50
left preconditioning
using nonzero initial guess
using NONE norm type for convergence test
PC Object: (level-2) 4 MPI processes
type: asm
Additive Schwarz: total subdomain blocks = 198, amount of overlap = 0
Additive Schwarz: restriction/interpolation type - RESTRICT
[0] number of local blocks = 52
[1] number of local blocks = 48
[2] number of local blocks = 48
[3] number of local blocks = 50
Local solve info for each block is in the following KSP and PC objects:
in the post-smoother I have the default ASM decomposition with overlapping 1:
Up solver (post-smoother) on level 2 -------------------------------
type: gmres
maximum iterations=2
type: asm
Additive Schwarz: total subdomain blocks = 4, amount of overlap = 1
Local solve is same for all blocks, in the following KSP and PC objects:
KSP Object: (level-2sub_) 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
So it seams that by using
I was capable to set both the pre- and post- smoothers to be PCASM
but everything I did after that applied only to the
pre-smoother, while the post-smoother got the default PCASM options.
I know that I can use
PCMGGetSmootherDown and PCMGGetSmootherUp, but that would
probably double the memory allocation and the computational time in the ASM.
Is there any way I can just use PCMGGetSmoother
and use the same PCASM in the pre- and post- smoother?
I hope I was clear enough.
Thanks a lot for your help,
Eugenio
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150820/5b709b6e/attachment-0001.html>
