[petsc-users] GMRES -> PCMG -> PCASM pre- post- smoother
Lorenzo Alessio Botti lorenzoalessiobotti at gmail.com
Thu Aug 20 05:29:10 CDT 2015
I tried to achieve this behaviour getting all the smothers and setting the same preconditioner to the down and up smoother on the same level.
    smoothers.resize(nLevels+1);
    smoothers_up.resize(nLevels);
    for (PetscInt i = 0; i < nLevels; i++)
      PCMGGetSmootherDown(M_pc,nLevels-i,&(smoothers[i]));
      KSPSetInitialGuessNonzero(smoothers[i],PETSC_TRUE); // for full and wCicle
      PCMGGetSmootherUp(M_pc,nLevels-i,&(smoothers_up[i]));
    PCMGSetNumberSmoothDown(M_pc,1);
    PCMGSetNumberSmoothUp(M_pc,1);
… set coarse solver options here
      PC pc;
      KSPSetType(smoothers[i], KSPGMRES);
      KSPGetPC(smoothers[i], &pc);
      KSPSetPCSide(smoothers[i], PC_RIGHT);
      PCSetType(pc, PCASM);
      PCFactorSetPivotInBlocks(pc, PETSC_TRUE);
      PCFactorSetAllowDiagonalFill(pc);
      PCFactorSetReuseFill(pc, PETSC_TRUE);
      PCFactorSetReuseOrdering(pc, PETSC_TRUE);
      KSPSetType(smoothers_up[i], KSPGMRES);
      KSPSetPC(smoothers_up[i], pc);
      KSPSetPCSide(smoothers_up[i], PC_RIGHT);
      KSPSetConvergenceTest(smoothers[i],KSPConvergedSkip,NULL,NULL);
      KSPSetConvergenceTest(smoothers_up[i],KSPConvergedSkip,NULL,NULL);
      KSPSetNormType(smoothers[i],KSP_NORM_NONE);
      KSPSetNormType(smoothers_up[i],KSP_NORM_NONE);
Is this correct?
Note moreover that for Full Multigrid and W cicles to work as expected I need to add the KSPSetInitialGuessNonZero option.
Bests
Lorenzo
> Message: 4
> Date: Thu, 20 Aug 2015 02:37:13 -0500
> From: Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
> To: "Aulisa, Eugenio" <eugenio.aulisa at ttu.edu <mailto:eugenio.aulisa at ttu.edu>>
> Cc: "petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>" <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: Re: [petsc-users] GMRES -> PCMG -> PCASM pre- post- smoother
> Message-ID: <1CF3ABE1-214C-4BBC-B8FF-93416EC26EFC at mcs.anl.gov <mailto:1CF3ABE1-214C-4BBC-B8FF-93416EC26EFC at mcs.anl.gov>>
> Content-Type: text/plain; charset="us-ascii"
>   What you describe is not the expected behavior. I expected exactly the result that you expected.
> Do you perhaps have some PETSc options around that may be changing the post-smoother? On the command line or in the file petscrc or in the environmental variable PETSC_OPTIONS?  Can you send us some code that we could run that reproduces the problem?
>  Barry
>> On Aug 19, 2015, at 9:26 PM, Aulisa, Eugenio <eugenio.aulisa at ttu.edu <mailto:eugenio.aulisa at ttu.edu>> wrote:
>> Hi,
>> I am solving an iteration of
>> where I build my particular ASM domain decomposition.
>> In setting the PCMG I would like at each level
>> to use the same pre- and post-smoother
>> and for this reason I am using
>> PCMGGetSmoother ( pcMG, level , &subksp );
>> to extract and set at each level the ksp object.
>> In setting PCASM then I use
>> KSPGetPC ( subksp, &subpc );
>> PCSetType ( subpc, PCASM );
>> and then set my own decomposition
>> PCASMSetLocalSubdomains(subpc,_is_loc_idx.size(),&_is_ovl[0],&_is_loc[0]);
>> Now everything compiles, and runs with no memory leakage,
>> but I do not get the expected convergence.
>> When I checked the output of -ksp_view, I saw something that puzzled me:
>> at each level >0, while in the MG pre-smoother the ASM domain decomposition
>> is the one that I set, for example with 4 processes  I get
>> Down solver (pre-smoother) on level 2 -------------------------------
>>   KSP Object:    (level-2)     4 MPI processes
>>     type: gmres
>>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>       GMRES: happy breakdown tolerance 1e-30
>>     maximum iterations=1
>>     using preconditioner applied to right hand side for initial guess
>>     tolerances:  relative=1e-12, absolute=1e-20, divergence=1e+50
>>     left preconditioning
>>     using nonzero initial guess
>>     using NONE norm type for convergence test
>>   PC Object:    (level-2)     4 MPI processes
>>     type: asm
>>       Additive Schwarz: total subdomain blocks = 198, amount of overlap = 0
>>       Additive Schwarz: restriction/interpolation type - RESTRICT
>>       [0] number of local blocks = 52
>>       [1] number of local blocks = 48
>>       [2] number of local blocks = 48
>>       [3] number of local blocks = 50
>>       Local solve info for each block is in the following KSP and PC objects:
>> in the post-smoother I have the default ASM  decomposition with overlapping 1:
>> Up solver (post-smoother) on level 2 -------------------------------
>>     type: gmres
>>     maximum iterations=2
>>     type: asm
>>       Additive Schwarz: total subdomain blocks = 4, amount of overlap = 1
>>       Local solve is same for all blocks, in the following KSP and PC objects:
>>     KSP Object:      (level-2sub_)       1 MPI processes
>>       type: preonly
>>       maximum iterations=10000, initial guess is zero
>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>> So it seams that by using
>> I was capable  to set both the pre- and post- smoothers to be PCASM
>> but everything I did after that applied only to the
>> pre-smoother, while the post-smoother got the default PCASM options.
>> I know that I can use
>> PCMGGetSmootherDown and PCMGGetSmootherUp, but that would
>> probably double the memory allocation and the computational time in the ASM.
>> Is there any way I can just use PCMGGetSmoother
>> and use the same PCASM in the pre- and post- smoother?
>> I hope I was clear enough.
>> Thanks a lot for your help,
>> Eugenio
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150820/951ee85c/attachment-0001.html>
