[petsc-users] petsc_gen_xdmf.py errors
Fande Kong
fdkong.jd at gmail.com
Wed Aug 12 19:09:07 CDT 2015
Thanks, Justin,
I can get a correct xml file now.
Fande Kong,
On Wed, Aug 12, 2015 at 2:39 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Sorry there was a typo. Here's the correct run:
> ./src/snes/examples/tutorials/ex12 -run_type test -refinement_limit 0.0
> -bc_type dirichlet -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5
> -vec_view hdf5:sol.h5::append
> On Wed, Aug 12, 2015 at 2:22 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> Fande,
>> Your sol.h5 is old and outdated. If you generate a more recent sol.h5
>> with the following SNES example inside your PETSC_DIR:
>> ./src/snes/examples/tutorial/ex12 -run_type test -refinement_limit 0.0
>> ./bin/petsc_gen_xdmf.py sol.h5
>> the resulting sol.xmf is compatible with Paraview
>> Thanks,
>> Justin
>> On Tue, Aug 11, 2015 at 8:53 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Hi all,
>>> I tried to use petsc_gen_xdmf.py to generate a xml file for visulaztion
>>> using paraview. I got the following errors:
>>> ./petsc_gen_xdmf.py sol.h5
>>> Traceback (most recent call last):
>>> File "./petsc_gen_xdmf.py", line 236, in <module>
>>> generateXdmf(sys.argv[1])
>>> File "./petsc_gen_xdmf.py", line 231, in generateXdmf
>>> Xdmf(xdmfFilename).write(hdfFilename, topoPath, numCells,
>>> numCorners, cellDim, geomPath, numVertices, spaceDim, time, vfields,
>>> cfields)
>>> File "./petsc_gen_xdmf.py", line 190, in write
>>> for vf in vfields: self.writeField(fp, len(time), t, cellDim,
>>> spaceDim, '/vertex_fields/'+vf[0], vf, 'Node')
>>> File "./petsc_gen_xdmf.py", line 164, in writeField
>>> self.writeFieldComponents(fp, numSteps, timestep, spaceDim, name, f,
>>> domain)
>>> File "./petsc_gen_xdmf.py", line 120, in writeFieldComponents
>>> dims = '1 %d 1' % (numSteps, dof, bs)
>>> TypeError: not all arguments converted during string formatting
>>> The hdf5 file is attached. Originally from Matthew. Configuration and
>>> make log files are also attached.
>>> Fande Kong,
>>> Thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150812/b7c893a6/attachment-0001.html>
