[petsc-users] Fail to Configure petsc-3.6.1
Wed Aug 5 15:56:19 CDT 2015
On Wed, Aug 5, 2015 at 3:51 PM, Justin Chang <jychang48 at gmail.com> wrote:
> no this is being built on my macbook laptop. The difference between
> yesterday and today is that I updated my gcc compiler (downloaded via brew)
> to gcc-5.0 and reinstalled openmpi accordingly
Can you go to the directory and execute it manually?
  cd
/Users/justin/Software/petsc/arch-darwin-c-opt-firedrake/externalpackages/hdf5-1.8.12
&& /usr/bin/make -j 4
Maybe there is a problem using multiple make threads on this machine...
     Matt
> On Wed, Aug 5, 2015 at 3:49 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Aug 5, 2015 at 3:43 PM, Justin Chang <jychang48 at gmail.com> wrote:
>>> Hi everyone,
>>> Not sure how related this may be, but I am also having trouble
>>> installing petsc 3.6.1 with hdf5. In fact ./configure hangs at "Running
>>> make on HDF5; this may take several minutes". I grew impatient after 30
>>> minutes so I had to kill it.
>>> Attached is the configure.log. Can y'all figure out what's going on here?
>> Is this being built on a system with nonlocal disk? This can make builds
>> take forever. The timeout on this operation is
>> 100 minutes.
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Justin
>>> On Wed, Aug 5, 2015 at 3:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> > On Aug 5, 2015, at 2:26 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> > Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> >>   Our approach is always to work around bugs and stupidity in other
>>>> packages design,
>>>> > Do we report it to them as a bug?
>>>>   When there is a place to report them then we should and sometimes do.
>>>>   Barry
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/bd3d148e/attachment-0001.html>
