[petsc-users] Fail to Configure petsc-3.6.1
Matthew Knepley
knepley at gmail.com
Wed Aug 5 12:35:52 CDT 2015
On Wed, Aug 5, 2015 at 10:29 AM, Jed Brown <jed at jedbrown.org> wrote:
> Rongliang Chen <rongliang.chan at gmail.com> writes:
> > Hi Jed,
> > Thanks for your reply.
> > I checked the netcdf and hdf5's config.log and could not find any
> > possible solutions. Can you help me check these two files again? The two
> > files are attached. Thanks.
> It looks to me like libhdf5.a needs to be linked with -ldl, which partly
> defeats the intent of static linking. PETSc folks, do we blame this on
> HDF5 with --disable-shared not being a truly static build? Should we
Yes, this is an error in the HDF5 buildsystem.
> pass LDLIBS=-ldl so that NetCDF can link?
That would work I think, but looks very strange for a static build (as you
said). It appears to me
that HDF5 is not suitable for a static build, and I would reconsider this
strategy.
Matt
> This likely all works if you use shared libraries. (I can't believe
> this is still a debate in 2015.)
> configure:16585: mpicc -o conftest -g3 -O0
> -I/home/rlchen/soft/petsc-3.6.1/64bit-debug/include conftest.c -lhdf5 -lm
> -Wl,-rpath,/home/rlchen/soft/petsc-3.6.1/64bit-debug/lib
> -L/home/rlchen/soft/petsc-3.6.1/64bit-debug/lib -lhdf5hl_fortran
> -lhdf5_fortran -lhdf5_hl -lhdf5 -lz >&5
> /home/rlchen/soft/petsc-3.6.1/64bit-debug/lib/libhdf5.a(H5PL.o): In
> function `H5PL__open':
> /home/rlchen/soft/petsc-3.6.1/64bit-debug/externalpackages/hdf5-1.8.12/src/H5PL.c:535:
> undefined reference to `dlopen'
> /home/rlchen/soft/petsc-3.6.1/64bit-debug/externalpackages/hdf5-1.8.12/src/H5PL.c:536:
> undefined reference to `dlerror'
> /home/rlchen/soft/petsc-3.6.1/64bit-debug/externalpackages/hdf5-1.8.12/src/H5PL.c:544:
> undefined reference to `dlsym'
> function `H5PL__search_table':
> /home/rlchen/soft/petsc-3.6.1/64bit-debug/externalpackages/hdf5-1.8.12/src/H5PL.c:627:
> function `H5PL__close':
> /home/rlchen/soft/petsc-3.6.1/64bit-debug/externalpackages/hdf5-1.8.12/src/H5PL.c:661:
> undefined reference to `dlclose'
> collect2: error: ld returned 1 exit status
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/c92f9837/attachment.html>
