[petsc-users] failed to compile HDF5 on vesta
Fande Kong
fdkong.jd at gmail.com
Sun Aug 2 22:22:34 CDT 2015
Hi, Barry,
Looks like they did not have fblaslapack installed. I could compile
the fblaslapack when I switched the compiler from XL to gcc.
Fande Kong,
On Sun, Aug 2, 2015 at 11:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> You shouldn't need --download-fblaslapack almost every system has it
> already installed.
> Barry
> Looks like the Fortran compiler on this system is rejecting the "old"
> Fortran in blas/lapack code.
> > On Aug 1, 2015, at 7:55 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > HI barry,
> > Thanks a lot. I could compile hdf5, but failed to compile fblaslapack.
> Log file is attached.
> > Fande Kong,
> > On Sat, Aug 1, 2015 at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Try with --with-shared-libraries=0 The HDF5 build is having some
> issue with shared libraries
> > Barry
> > > On Aug 1, 2015, at 4:01 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > > Hi all,
> > > I want to install petsc on vesta (an IBM Blue Gene at Argonne). Failed
> to compile HDF5. The configure log file is attached. Any suggestions would
> be greatly appreciated.
> > > Thanks,
> > > Fande Kong,
> > > <configure.log>
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150802/b62edabd/attachment.html>
