[petsc-users] failed to compile HDF5 on vesta
Barry Smith
bsmith at mcs.anl.gov
Sun Aug 2 11:30:50 CDT 2015
You shouldn't need --download-fblaslapack almost every system has it already installed.
Barry
Looks like the Fortran compiler on this system is rejecting the "old" Fortran in blas/lapack code.
> On Aug 1, 2015, at 7:55 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> HI barry,
> Thanks a lot. I could compile hdf5, but failed to compile fblaslapack. Log file is attached.
> Fande Kong,
> On Sat, Aug 1, 2015 at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Try with --with-shared-libraries=0 The HDF5 build is having some issue with shared libraries
> Barry
> > On Aug 1, 2015, at 4:01 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > Hi all,
> > I want to install petsc on vesta (an IBM Blue Gene at Argonne). Failed to compile HDF5. The configure log file is attached. Any suggestions would be greatly appreciated.
> > Thanks,
> > Fande Kong,
> > <configure.log>
> <configure.log>
