[petsc-users] Insufficient memory when using GMRES + Boomeramg
Wed Mar 26 20:15:54 CDT 2014
On Wed, Mar 26, 2014 at 7:54 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>  On 27/3/2014 12:14 AM, Matthew Knepley wrote:
>  On Wed, Mar 26, 2014 at 10:42 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  On 26/3/2014 11:22 PM, Matthew Knepley wrote:
>>  On Wed, Mar 26, 2014 at 9:59 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> I am running a CFD solver. The Poisson eqn was originally solved using
>>> HYPRE's geometric multigrid.
>>  Is this on a structured grid?
>> Yes.
>  Then you can replicate the Hypre structured MG with the PCMG, and it can
> be lighter memory than GAMG. You
> will need to code the problem in the style of SNES ex5, which is a Poisson
> for which geometric MG works from
> the command line.
>    Thanks,
>       Matt
> Hi Matt,
> First of all, is there an easier way out? Is it Boomeramg or GMRES which
> has a large memory requirement? Will changing e.g. GMRES to FGMRES or other
> ksp solvers solve the problem?
You could perhaps use a low-memory Krylov method, like BiCGStab. How big is
your Krylov space?
> Also, I switched from geometric multigrid (GMG) to Boomeramg because the
> latter is faster. If I use PCMG, am I going back to the GMG path, which was
> slower?
If multigrid is working correctly, it should take 10 iterates or so. I am
guessing something was wrong with the GMG, like coarse
BC.
     Matt
> Thanks!
>>      Matt
>>> Recently, I tested it with Boomeramg as the preconditioner and GMRES as
>>> the ksp solver. There's a 20% increase in speed.
>>> However, when I increased the grid resolution, I got the out of memory
>>> error. Changing the solver back to HYPRE solved the problem.
>>> So does GMRES  + Boomeramg used more memory than other solvers? Are
>>> there alternatives?
>>> Thank you.
>>> Yours sincerely,
>>> TAY wee-beng
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140326/394c8cf6/attachment.html>
