[petsc-users] Insufficient memory when using GMRES + Boomeramg
    Matthew Knepley
    knepley at gmail.com
    Wed Mar 26 11:14:40 CDT 2014
On Wed, Mar 26, 2014 at 10:42 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  On 26/3/2014 11:22 PM, Matthew Knepley wrote:
>  On Wed, Mar 26, 2014 at 9:59 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I am running a CFD solver. The Poisson eqn was originally solved using
>> HYPRE's geometric multigrid.
>  Is this on a structured grid?
> Yes.
Then you can replicate the Hypre structured MG with the PCMG, and it can be
lighter memory than GAMG. You
will need to code the problem in the style of SNES ex5, which is a Poisson
for which geometric MG works from
the command line.
     Matt
>     Matt
>> Recently, I tested it with Boomeramg as the preconditioner and GMRES as
>> the ksp solver. There's a 20% increase in speed.
>> However, when I increased the grid resolution, I got the out of memory
>> error. Changing the solver back to HYPRE solved the problem.
>> So does GMRES  + Boomeramg used more memory than other solvers? Are there
>> alternatives?
>> Thank you.
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140326/26cccf9b/attachment-0001.html>
