[petsc-users] hypre-boomeramg precondition
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Mar 24 15:00:25 CDT 2014
On Mar 24, 2014, at 2:54 PM, Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Dear All:
> I am solving a series of matrix which are from the same FEA model but have different number of meshes. In petsc, I use CR as the solver and hypre-boomeramg as the preconditioner. It works for a small system with 2 million DOFs. Also works for a system with 6 million DOFs. But always fail with an error ' memory out of range' for a 10 or 20 million system.
> Additionally, with solver CR + preconditioner bjacobi, Petsc could solve 10 and 20 million and even large systems easily.
> Also, with using top command in linux by monitoring the memory usage, I saw some peaks in the memory.
> So, I am wondering, is this because the memory usage of boomeramg, that larger systems always fail?
   BoomerAMG does require a good amount more memory than “simpler” solvers. There is nothing one can do about it except use more MPI processes with more total memory for larger problems.
   Barry
> Thanks
> Qiyue Lu
