[petsc-users] Building PETSc with Intel mpi
Sat Mar 22 17:24:02 CDT 2014
Is this MPI install functional and useable on this machine?
Perhaps you should heck with the sysadmin on this machine on the
correct way to use this MPI.
Googling on this error gives:
http://stackoverflow.com/questions/12075403/gcc-reduce-libc-required-version
Perhaps you can try the additional conifgure option:
LDFLAGS=-static or LDFLAGS="-Wl,--hash-style=both"
Satish
On Sat, 22 Mar 2014, Qin Lu wrote:
> I tried what you suggested and got the following error (configure .log attached):
> sh:
> ERROR while running executable: Could not execute "/tmp/petsc-cd5uJs/config.setCompilers/conftest":
> /tmp/petsc-cd5uJs/config.setCompilers/conftest: error while loading shared libraries: /apps/compilers/intel_2013/impi/4.1.0.024/intel64/lib/libmpi.so.4: requires glibc 2.5 or later dynamic linker
> What can I do about this?
> Thanks,
> Qin
> ________________________________
>  From: Barry Smith <bsmith at mcs.anl.gov>
> To: Qin Lu <lu_qin_2000 at yahoo.com>
> Cc: petsc-users <petsc-users at mcs.anl.gov>
> Sent: Saturday, March 22, 2014 11:46 AM
> Subject: Re: [petsc-users] Building PETSc with Intel mpi
> On Mar 22, 2014, at 10:15 AM, Qin Lu <lu_qin_2000 at yahoo.com> wrote:
> > The Intel mpi's wrappers to Intel compilers are mpiicc and mpiifort (not mpicc and mpif90), can PETSc's configure automatically pick them? Or I have to specify them explicitly (--with-cc=mpiicc --with-fc=mpiifort --with-mpi-compilers=0)?
>   List
>    do not list --with-mpi-compilers=0 or —with-mpi-dir or —with-mpi-libs
>   Barry
> > Thanks,
> > Qin
> > From: Satish Balay <balay at mcs.anl.gov>
> > Cc: Barry Smith <bsmith at mcs.anl.gov>; petsc-users <petsc-users at mcs.anl.gov>
> > Sent: Saturday, March 22, 2014 12:09 AM
> > > --with-mpi-dir=/apps/compilers/intel_2013/impi/4.1.0.024/intel64 --with-mpi-compilers=0
> > Does this mpi not come with mpicc/mpif90 wrappers? If they do - its best to use them.
> > If not - its best to look at the docs for this compiler - and specify it with the appropriate
> > --with-mpi-include --with-mpi-lib options, [instead of the above]
> > Satish
> > On Fri, 21 Mar 2014, Qin Lu wrote:
> > > Sourcing the .csh files of the compiler fixed the problem. Thanks! However, later it got another error (see the attached configure.log for details):
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > > Fortran error! mpi_init() could not be located!
> > > It seems the configure did not link the Intel MPI libs. I used --with-mpi-dir to specify the MPI directory, can configure get the correct Intel MPI lib names? If I have to specify the lib names (using --with-mpi-lib?), which libs should I specify? I saw a lot of libs under the directory, such as libmpi.a, libmpi_ipl64.a, libmpi_mt.a, etc.
> > > Thanks a lot,
> > > Qin
> > > Sent: Friday, March 21, 2014 10:11 AM
> > >   Did you follow the directions here: http://www.mcs.anl.gov/petsc/documentation/faq.html#libimf
> > >   Did it make any difference?
> > > On Mar 21, 2014, at 9:45 AM, Qin Lu <lu_qin_2000 at yahoo.com> wrote:
> > > > Hello,
> > > > I was trying to build PETSc-3.4.2 with Intel MPI using Intel-2013 compilers in Linux, but got the error below. The configure.log is attached.
> > > >                     UNABLE to EXECUTE BINARIES for ./configure
> > > > Cannot run executables created with FC. If this machine uses a batch system
> > > > to submit jobs you will need to configure using ./configure with the additional option  --with-batch.
> > > >  Otherwise there is problem with the compilers. Can you compile and run code with your C/C++ (and maybe Fortran) compilers?
> > > > See http://www.mcs.anl.gov/petsc/documentation/faq.html#libimf
> > > > Thanks a lot for any suggestions abut the problem,
> > > > Regards,
> > > > Qin
> > > > <configure.log>
