[petsc-users] Preallocation Memory of Finite Element Method's Sparse Matrices
Jed Brown
jed at jedbrown.org
Fri Mar 21 21:12:51 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
> Thank you for reporting this. It was our error. In fact 4 is not
> enough under certain circumstances; consider where each process has
> only a single degree of freedom (vertex) then it is coupled to 8
> other vertices ALL on other processes. Thus we really need to use 8
> instead of 4 as the maximum number of off process coupling.
Note that _your_ code should generally not have this problem because you
should use a non-pathological partition.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140321/efd0d0be/attachment.pgp>
