[petsc-users] Preallocation Memory of Finite Element Method's Sparse Matrices
Barry Smith
bsmith at mcs.anl.gov
Fri Mar 21 15:15:44 CDT 2014
Thank you for reporting this. It was our error. In fact 4 is not enough under certain circumstances; consider where each process has only a single degree of freedom (vertex) then it is coupled to 8 other vertices ALL on other processes. Thus we really need to use 8 instead of 4 as the maximum number of off process coupling.
I have fixed this in master so it now runs on any number of processes.
Barry
On Mar 21, 2014, at 9:11 AM, 吕超 <luchao at mail.iggcas.ac.cn> wrote:
> Your faithfully:
> Last e-mail has some literal error, sorry~
> program src/ksp/ksp/examples/tutorials/ex3.c.html is about Bilinear elements on the unit square for Laplacian.
> After preallocation using
> "ierr = MatMPIAIJSetPreallocation(A,9,NULL,5,NULL);CHKERRQ(ierr); /* More than necessary */",
> Results of commands of "mpiexec -n 2 ./ex3" and "mpiexec -n 3 ./ex3" are "Norm of error 2.22327e-06 Iterations 6" and "Norm of error 3.12849e-07 Iterations 8". Both results are good!
> However, if I use "mpiexec -n 4 ./ex3" or 5,6,7...precesses, error "[2]PETSC ERROR: New nonzero at (4,29) (here is for process 4, other positions for different processes) caused a malloc!" appear!. For me, this error is unbelievable, because first, the preallocation is more than necessary,how can the new malloc appear? Second, the global number 4 point originally has no neighbor vertices whose global number is 29! This error has tortured me for a long time.
> This error seems meaningless, however, my recent 3d finite element method cannot be caculated by more processes owing to the new nonzero malloc error! And this is why I want to use 4 or much more processes to compute ex3.c.
> Thank you for all previous assistence and hope you have a good life!
> your sin cerely
> LV CHAO
> 2014/3/21
