[petsc-users] Building PETSc with Intel mpi
Barry Smith
bsmith at mcs.anl.gov
Fri Mar 21 10:11:49 CDT 2014
Did you follow the directions here: http://www.mcs.anl.gov/petsc/documentation/faq.html#libimf
Did it make any difference?
On Mar 21, 2014, at 9:45 AM, Qin Lu <lu_qin_2000 at yahoo.com> wrote:
> Hello,
> I was trying to build PETSc-3.4.2 with Intel MPI using Intel-2013 compilers in Linux, but got the error below. The configure.log is attached.
> UNABLE to EXECUTE BINARIES for ./configure
> Cannot run executables created with FC. If this machine uses a batch system
> to submit jobs you will need to configure using ./configure with the additional option --with-batch.
> Otherwise there is problem with the compilers. Can you compile and run code with your C/C++ (and maybe Fortran) compilers?
> See http://www.mcs.anl.gov/petsc/documentation/faq.html#libimf
> Thanks a lot for any suggestions abut the problem,
> Regards,
> Qin
> <configure.log>
