[petsc-users] Building PETSc with Intel mpi
    Qin Lu
    lu_qin_2000 at yahoo.com
    Fri Mar 21 09:45:53 CDT 2014
Hello,
I was trying to build PETSc-3.4.2 with Intel MPI using Intel-2013 compilers in Linux, but got the error below. The configure.log is attached.
                    UNABLE to EXECUTE BINARIES for ./configure
Cannot run executables created with FC. If this machine uses a batch system
to submit jobs you will need to configure using ./configure with the additional option  --with-batch.
 Otherwise there is problem with the compilers. Can you compile and run code with your C/C++ (and maybe Fortran) compilers?
See http://www.mcs.anl.gov/petsc/documentation/faq.html#libimf
Thanks a lot for any suggestions abut the problem,
Qin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140321/39a0132c/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140321/39a0132c/attachment-0001.obj>
