[petsc-users] Custom vector owenrship ranges
Tue Mar 18 08:09:28 CDT 2014
On Tue, Mar 18, 2014 at 7:53 AM, Mohammad Bahaa <m.bahaa.eldein at gmail.com>wrote:
> I'm using "PETSC_COMM_SELF" communicator for running n serial independent
> processes, I need to sum up a certain vector from the n processes in one
> vector, however, vectors involved in each process vary in size, and I
> couldn't find any function to define custom ownership ranges, so assuming I
> have a 4 processes run with each computing an "x" vector as follows:
> 1. process (1) with x of length 51
> 2. process (2) with x of length 49
> 3. process (3) with x of length 52
> 4. process (4) with x of length 48
Let your local length be n, so that on proc 3 n== 52. Then
  VecCreate(comm, &v);
  VecSetSizes(v, n, PETSC_DETERMINE);
  VecSetFromOptions(v);
  <fill up v>
  VecSum(v, &sum);
You could also make a parallel Vec from your Seq vecs:
  VecGetArray(lv, &array);
  VecCreateMPIWithArray(comm, 1, n, PETSC_DETERMINE, array, &v);
     Matt
> The processes sum up to 100 elements, when I define a vector "x_all" of
> size "100" with "PETSC_COMM_WORLD" communicator, the ownership ranges are
> equal, which isn't the case, how to customize them ?
> Mohamamd Bahaa ElDin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140318/39f2d084/attachment.html>
