[petsc-users] Spatial distribution of the residual after an implicit TS timestep
Mani Chandra
mc0710 at gmail.com
Sat Mar 15 18:35:58 CDT 2014
Thanks, those functions are what I was looking for.
On Sat, Mar 15, 2014 at 6:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Mar 15, 2014 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> You can write a custom monitor and set it with TSMonitorSet()
>> This routine would call TSGetSNES() then SNESGetSolution() then call
>> SNESComputeFunction() then call VecView() on the result.
>> But note that just because the residual is big somewhere doesn’t mean
>> the error need be.
>> You could also run with -snes_monitor_residual to see how the
>> residual is being reduced inside the nonlinear solve (that is, what parts
>> of the residual are most stubborn).
> If you really want to play with the residual, inside your monitor you can
> use:
> TSGetSNES()
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESGetFunction.html#SNESGetFunction
> Thanks,
> Matt
>> Barry
>> On Mar 15, 2014, at 5:47 PM, Mani Chandra <mc0710 at gmail.com> wrote:
>> > Hi,
>> > Is there anyway I can VecView the residual after TS has completed an
>> implicit time step? I'd like to see where in my domain most of the errors
>> are coming from. I looked at TSMonitor but that doesn't seem to give me
>> access to the residual at the end of the current time step.
>> > Thanks,
>> > Mani
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140315/9740e3df/attachment-0001.html>
