[petsc-users] Spatial distribution of the residual after an implicit TS timestep
Sat Mar 15 18:29:24 CDT 2014
On Sat, Mar 15, 2014 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    You can write a custom monitor and set it with TSMonitorSet()
>     This routine would call TSGetSNES() then SNESGetSolution() then call
> SNESComputeFunction() then call VecView() on the result.
>     But note that just because the residual is big somewhere doesn't mean
> the error need be.
>     You could also run with -snes_monitor_residual to see how the residual
> is being reduced inside the nonlinear solve (that is, what parts of the
> residual are most stubborn).
If you really want to play with the residual, inside your monitor you can
use:
  TSGetSNES()
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESGetFunction.html#SNESGetFunction
     Matt
>     Barry
> On Mar 15, 2014, at 5:47 PM, Mani Chandra <mc0710 at gmail.com> wrote:
> > Hi,
> > Is there anyway I can VecView the residual after TS has completed an
> implicit time step? I'd like to see where in my domain most of the errors
> are coming from. I looked at TSMonitor but that doesn't seem to give me
> access to the residual at the end of the current time step.
> > Thanks,
> > Mani
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140315/b7c921e4/attachment.html>
