[petsc-users] Fwd: Re: Fieldsplit schur complement with preonly solves
Luc
luc.berger.vergiat at gmail.com
Tue Mar 11 10:31:17 CDT 2014
Oops, the message below was not sent to the mailing list.
Sorry.
-------- Original Message --------
Subject: Re: Fieldsplit schur complement with preonly solves
Date: Tue, 11 Mar 2014 11:22:32 -0400
To: Matthew Knepley <knepley at gmail.com>
Here are the -ksp_monitor and -ksp_view.
For some reason I don't get anything out of
-fieldsplit_0_ksp_monitor or -fieldsplit_1_ksp_monitor
Is the output of these options stored in some file?
Best,
Luc
On 03/11/2014 11:06 AM, Matthew Knepley wrote:
> On Tue, Mar 11, 2014 at 9:56 AM, Luc Berger-Vergiat
> <luc.berger.vergiat at gmail.com <mailto:luc.berger.vergiat at gmail.com>>
> wrote:
> Hi all,
> I am testing some preconditioners for a FEM problem involving
> different types of fields (displacements, temperature, stresses
> and plastic strain).
> To make sure that things are working correctly I am first solving
> this problem with:
> -ksp_type preonly -pc_type lu, which works fine obviously.
> Then I move on to do:
> -ksp_type gmres -pc_type lu, and I get very good convergence
> (one gmres linear iteration per time step) which I expected.
> So solving the problem exactly in a preconditioner to gmres leads
> to optimal results.
> This can be done using a Schur complement, but when I pass the
> following options:
> -ksp_type gmres -pc_type fieldsplit -pc_fieldsplit_type schur
> -pc_fieldsplit_schur_factorization_type full
> -pc_fieldsplit_0_fields 2,3 -pc_fieldsplit_1_fields 0,1
> -fieldsplit_0_ksp_type preonly -fieldsplit_0_pc_type
> lu -fieldsplit_1_ksp_type preonly -fieldsplit_1_pc_type lu
> My results are terrible, gmres does not converge and my FEM code
> reduces the size of the time step in order to converge.
> This does not make much sense to me...
> For any convergence question, we need the output of -ksp_view
> -ksp_monitor, and for this we would also like
> -fieldsplit_0_ksp_monitor -fieldsplit_1_ksp_monitor
> Yes, something is wrong. Very often this is caused by submatrices
> which have a null space. Of course that null space
> should show up in LU, unless you are perturbing the factorization.
> Matt
> Curiously if I use the following options:
> -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type
> lu -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type lu
> then the global gmres converges in two iterations.
> So using a pair of ksp gmres/pc lu on the A00 block and the Schur
> complements works, but using lu directly doesn't.
> Because I think that all this is quite strange, I decided to dump
> some matrices out. Namely, I dumped the complete FEM jacobian, I
> also do a MatView on jac->B, jac->C and the result of
> KSPGetOperators on kspA. These returns three out of the four
> blocks needed to do the Schur complement. They are correct and I
> assume that the last block is also correct.
> When I import jac->B, jac->C and the matrix corresponding to kspA
> in MATLAB to compute the inverse of the Schur complement and pass
> it to gmres as preconditioner the problem is solved in 1 iteration.
> So MATLAB says:
> should yield only one iteration (maybe two depending on
> implementation).
> Any ideas why the Petsc doesn't solve this correctly?
> Best,
> Luc
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140311/8df46e47/attachment-0001.html>
0 KSP Residual norm 5.897183365409e+03
1 KSP Residual norm 2.357360750913e+03
2 KSP Residual norm 1.245115753185e+03
3 KSP Residual norm 7.494498291470e+02
4 KSP Residual norm 4.899331176210e+02
5 KSP Residual norm 3.296614155229e+02
6 KSP Residual norm 2.535141099025e+02
7 KSP Residual norm 1.848120199314e+02
8 KSP Residual norm 1.434395424307e+02
9 KSP Residual norm 1.080331131990e+02
10 KSP Residual norm 9.338277500035e+01
11 KSP Residual norm 6.544635890670e+01
12 KSP Residual norm 5.424636369024e+01
13 KSP Residual norm 5.030472769304e+01
14 KSP Residual norm 4.672584713181e+01
15 KSP Residual norm 4.207789949290e+01
16 KSP Residual norm 3.300863895958e+01
17 KSP Residual norm 2.550023161038e+01
18 KSP Residual norm 1.894202108393e+01
19 KSP Residual norm 1.481671652453e+01
20 KSP Residual norm 1.154264257191e+01
21 KSP Residual norm 9.426943797892e+00
22 KSP Residual norm 8.052410603809e+00
23 KSP Residual norm 6.907745793925e+00
24 KSP Residual norm 6.044753173613e+00
25 KSP Residual norm 5.537563785495e+00
26 KSP Residual norm 5.103038012673e+00
27 KSP Residual norm 4.657330910529e+00
28 KSP Residual norm 4.292761843691e+00
29 KSP Residual norm 4.029372196066e+00
30 KSP Residual norm 3.799130941110e+00
31 KSP Residual norm 3.719459377334e+00
32 KSP Residual norm 3.673829927252e+00
33 KSP Residual norm 3.593224950113e+00
34 KSP Residual norm 3.489258916404e+00
35 KSP Residual norm 3.363266816929e+00
36 KSP Residual norm 3.209234608324e+00
37 KSP Residual norm 3.042439215741e+00
38 KSP Residual norm 2.877622671449e+00
39 KSP Residual norm 2.728546188987e+00
40 KSP Residual norm 2.547527479156e+00
41 KSP Residual norm 2.395477146243e+00
42 KSP Residual norm 2.212193386074e+00
43 KSP Residual norm 1.972111351765e+00
44 KSP Residual norm 1.786505669346e+00
45 KSP Residual norm 1.719636784341e+00
46 KSP Residual norm 1.676148900999e+00
47 KSP Residual norm 1.591488773403e+00
48 KSP Residual norm 1.499202550326e+00
49 KSP Residual norm 1.422194063089e+00
50 KSP Residual norm 1.359790559159e+00
51 KSP Residual norm 1.285046681774e+00
52 KSP Residual norm 1.203288780427e+00
53 KSP Residual norm 1.136928971789e+00
54 KSP Residual norm 1.107297202580e+00
55 KSP Residual norm 1.101074698660e+00
56 KSP Residual norm 1.093331606685e+00
57 KSP Residual norm 1.083704496039e+00
58 KSP Residual norm 1.040484535384e+00
59 KSP Residual norm 9.771849314513e-01
60 KSP Residual norm 9.344826248494e-01
61 KSP Residual norm 9.325693177458e-01
62 KSP Residual norm 9.303050370074e-01
63 KSP Residual norm 9.291459224090e-01
64 KSP Residual norm 9.290645462896e-01
65 KSP Residual norm 9.287381711083e-01
66 KSP Residual norm 9.282629835097e-01
67 KSP Residual norm 9.277741376833e-01
68 KSP Residual norm 9.271803369073e-01
69 KSP Residual norm 9.250217569118e-01
70 KSP Residual norm 9.212099392648e-01
71 KSP Residual norm 9.212073588376e-01
72 KSP Residual norm 9.211767536689e-01
73 KSP Residual norm 9.084092709913e-01
74 KSP Residual norm 8.947842875988e-01
75 KSP Residual norm 8.914265297804e-01
76 KSP Residual norm 8.820940650258e-01
77 KSP Residual norm 8.733506393051e-01
78 KSP Residual norm 8.725287382103e-01
79 KSP Residual norm 8.725284775915e-01
80 KSP Residual norm 8.713202203880e-01
81 KSP Residual norm 8.711493244369e-01
82 KSP Residual norm 8.675811306599e-01
83 KSP Residual norm 8.645022544578e-01
84 KSP Residual norm 8.644418675588e-01
85 KSP Residual norm 8.546661807528e-01
86 KSP Residual norm 8.020619997764e-01
87 KSP Residual norm 7.517756437439e-01
88 KSP Residual norm 7.337219408201e-01
89 KSP Residual norm 7.270134369251e-01
90 KSP Residual norm 7.259315359628e-01
91 KSP Residual norm 7.259103097075e-01
92 KSP Residual norm 7.258080643414e-01
93 KSP Residual norm 7.256618341910e-01
94 KSP Residual norm 7.247786879048e-01
95 KSP Residual norm 7.236668099862e-01
96 KSP Residual norm 7.224299688377e-01
97 KSP Residual norm 7.220913973301e-01
98 KSP Residual norm 7.220752382894e-01
99 KSP Residual norm 7.219128793284e-01
100 KSP Residual norm 7.213346547480e-01
101 KSP Residual norm 7.207984556253e-01
102 KSP Residual norm 7.179896279491e-01
103 KSP Residual norm 7.173049295420e-01
104 KSP Residual norm 7.171924631613e-01
105 KSP Residual norm 7.171536072092e-01
106 KSP Residual norm 7.167957189647e-01
107 KSP Residual norm 7.148539622376e-01
108 KSP Residual norm 7.118563897705e-01
109 KSP Residual norm 7.113376449982e-01
110 KSP Residual norm 7.104632681400e-01
111 KSP Residual norm 7.062410993373e-01
112 KSP Residual norm 6.985958984486e-01
113 KSP Residual norm 6.967438053741e-01
114 KSP Residual norm 6.961598269050e-01
115 KSP Residual norm 6.960411975255e-01
116 KSP Residual norm 6.875341285503e-01
117 KSP Residual norm 6.799113001347e-01
118 KSP Residual norm 6.662584363706e-01
119 KSP Residual norm 6.500754715525e-01
120 KSP Residual norm 6.491541601024e-01
121 KSP Residual norm 6.491536786911e-01
122 KSP Residual norm 6.491467894184e-01
123 KSP Residual norm 6.491463412984e-01
124 KSP Residual norm 6.490930020745e-01
125 KSP Residual norm 6.490182995735e-01
126 KSP Residual norm 6.487114361681e-01
127 KSP Residual norm 6.486007337274e-01
128 KSP Residual norm 6.485960401344e-01
129 KSP Residual norm 6.485907316401e-01
130 KSP Residual norm 6.485302185413e-01
131 KSP Residual norm 6.485010111033e-01
132 KSP Residual norm 6.480725604192e-01
133 KSP Residual norm 6.480715558631e-01
134 KSP Residual norm 6.473276661987e-01
135 KSP Residual norm 6.467991125520e-01
136 KSP Residual norm 6.460739427552e-01
137 KSP Residual norm 6.450574376839e-01
138 KSP Residual norm 6.449856151333e-01
139 KSP Residual norm 6.449807015520e-01
140 KSP Residual norm 6.448411288002e-01
141 KSP Residual norm 6.430292960800e-01
142 KSP Residual norm 6.351901300089e-01
143 KSP Residual norm 6.293336513308e-01
144 KSP Residual norm 6.284759302154e-01
145 KSP Residual norm 6.263015684893e-01
146 KSP Residual norm 6.237643741697e-01
147 KSP Residual norm 6.187993755041e-01
148 KSP Residual norm 6.105134599993e-01
149 KSP Residual norm 5.978549909096e-01
150 KSP Residual norm 5.859768500068e-01
151 KSP Residual norm 5.857999341728e-01
152 KSP Residual norm 5.857974249440e-01
153 KSP Residual norm 5.857552092023e-01
154 KSP Residual norm 5.857373718886e-01
155 KSP Residual norm 5.857146512030e-01
156 KSP Residual norm 5.856517770978e-01
157 KSP Residual norm 5.856306370807e-01
158 KSP Residual norm 5.855913715132e-01
159 KSP Residual norm 5.855365875377e-01
160 KSP Residual norm 5.855358521319e-01
161 KSP Residual norm 5.854920296868e-01
162 KSP Residual norm 5.854915803861e-01
163 KSP Residual norm 5.854161398357e-01
164 KSP Residual norm 5.852145740669e-01
165 KSP Residual norm 5.852108880492e-01
166 KSP Residual norm 5.850803934245e-01
167 KSP Residual norm 5.850137305528e-01
168 KSP Residual norm 5.849717031248e-01
169 KSP Residual norm 5.849602723989e-01
170 KSP Residual norm 5.847074198265e-01
171 KSP Residual norm 5.807492285585e-01
172 KSP Residual norm 5.757451061380e-01
173 KSP Residual norm 5.692901264535e-01
174 KSP Residual norm 5.660871794540e-01
175 KSP Residual norm 5.646756478719e-01
176 KSP Residual norm 5.607237018444e-01
177 KSP Residual norm 5.568961372015e-01
178 KSP Residual norm 5.463721879174e-01
179 KSP Residual norm 5.297241830339e-01
180 KSP Residual norm 5.084608751613e-01
181 KSP Residual norm 5.067075313753e-01
182 KSP Residual norm 5.066794639501e-01
183 KSP Residual norm 5.064206960247e-01
184 KSP Residual norm 5.062486457591e-01
185 KSP Residual norm 5.061886567870e-01
186 KSP Residual norm 5.061870041614e-01
187 KSP Residual norm 5.061616211607e-01
188 KSP Residual norm 5.057570655971e-01
189 KSP Residual norm 5.051560913380e-01
190 KSP Residual norm 5.033621039962e-01
191 KSP Residual norm 5.031066356944e-01
192 KSP Residual norm 5.022197408323e-01
193 KSP Residual norm 5.022145697213e-01
194 KSP Residual norm 4.976476425674e-01
195 KSP Residual norm 4.976218395910e-01
196 KSP Residual norm 4.966905050003e-01
197 KSP Residual norm 4.925609944257e-01
198 KSP Residual norm 4.905718755718e-01
199 KSP Residual norm 4.844897921087e-01
200 KSP Residual norm 4.801159231515e-01
201 KSP Residual norm 4.799282062344e-01
202 KSP Residual norm 4.797247904383e-01
203 KSP Residual norm 4.794104209663e-01
204 KSP Residual norm 4.621238886554e-01
205 KSP Residual norm 4.525659945242e-01
206 KSP Residual norm 4.474609940274e-01
207 KSP Residual norm 4.447765101316e-01
208 KSP Residual norm 4.440608627726e-01
209 KSP Residual norm 4.416362777456e-01
210 KSP Residual norm 4.413541708428e-01
211 KSP Residual norm 4.413514515529e-01
212 KSP Residual norm 4.413309756150e-01
213 KSP Residual norm 4.413301745276e-01
214 KSP Residual norm 4.413119977039e-01
215 KSP Residual norm 4.412786574722e-01
216 KSP Residual norm 4.411335800621e-01
217 KSP Residual norm 4.410378827798e-01
218 KSP Residual norm 4.409620278464e-01
219 KSP Residual norm 4.409041814846e-01
220 KSP Residual norm 4.408410716864e-01
221 KSP Residual norm 4.405698903578e-01
222 KSP Residual norm 4.403397095690e-01
223 KSP Residual norm 4.401057585458e-01
224 KSP Residual norm 4.401053843369e-01
225 KSP Residual norm 4.400183730374e-01
226 KSP Residual norm 4.399042116281e-01
227 KSP Residual norm 4.398823250934e-01
228 KSP Residual norm 4.395598770197e-01
229 KSP Residual norm 4.393612765410e-01
230 KSP Residual norm 4.393536185966e-01
231 KSP Residual norm 4.384077355453e-01
232 KSP Residual norm 4.367582404156e-01
233 KSP Residual norm 4.357974590007e-01
234 KSP Residual norm 4.351967466584e-01
235 KSP Residual norm 4.340367621424e-01
236 KSP Residual norm 4.328657551427e-01
237 KSP Residual norm 4.328092628837e-01
238 KSP Residual norm 4.302195000259e-01
239 KSP Residual norm 4.250813928306e-01
240 KSP Residual norm 4.228819748046e-01
241 KSP Residual norm 4.228461571431e-01
242 KSP Residual norm 4.228332252601e-01
243 KSP Residual norm 4.228155186454e-01
244 KSP Residual norm 4.227881271753e-01
245 KSP Residual norm 4.227222839989e-01
246 KSP Residual norm 4.226121850177e-01
247 KSP Residual norm 4.226059298702e-01
248 KSP Residual norm 4.225526732207e-01
249 KSP Residual norm 4.224635593563e-01
250 KSP Residual norm 4.223966346858e-01
251 KSP Residual norm 4.223167024361e-01
252 KSP Residual norm 4.217803998648e-01
253 KSP Residual norm 4.215341658431e-01
254 KSP Residual norm 4.214152712861e-01
255 KSP Residual norm 4.207464541866e-01
256 KSP Residual norm 4.187263493199e-01
257 KSP Residual norm 4.174849400571e-01
258 KSP Residual norm 4.174743800366e-01
259 KSP Residual norm 4.172591554628e-01
260 KSP Residual norm 4.166154379809e-01
261 KSP Residual norm 4.162453690155e-01
262 KSP Residual norm 4.158343913450e-01
263 KSP Residual norm 4.158042411120e-01
264 KSP Residual norm 4.156480136324e-01
265 KSP Residual norm 4.150731220767e-01
266 KSP Residual norm 4.141177271256e-01
267 KSP Residual norm 4.137210438868e-01
268 KSP Residual norm 4.134313759421e-01
269 KSP Residual norm 4.133954495632e-01
270 KSP Residual norm 4.131588004462e-01
271 KSP Residual norm 4.131569777177e-01
272 KSP Residual norm 4.131566073891e-01
273 KSP Residual norm 4.131560869169e-01
274 KSP Residual norm 4.131523705316e-01
275 KSP Residual norm 4.131492847718e-01
276 KSP Residual norm 4.131429444088e-01
277 KSP Residual norm 4.131427961128e-01
278 KSP Residual norm 4.131427092386e-01
279 KSP Residual norm 4.131383827821e-01
280 KSP Residual norm 4.131280730710e-01
281 KSP Residual norm 4.131220026688e-01
282 KSP Residual norm 4.131220017715e-01
283 KSP Residual norm 4.131166850171e-01
284 KSP Residual norm 4.131152639803e-01
285 KSP Residual norm 4.131014038484e-01
286 KSP Residual norm 4.130990488669e-01
287 KSP Residual norm 4.130978784657e-01
288 KSP Residual norm 4.130954308308e-01
289 KSP Residual norm 4.130951613684e-01
290 KSP Residual norm 4.130858755040e-01
291 KSP Residual norm 4.130618206915e-01
292 KSP Residual norm 4.130614178608e-01
293 KSP Residual norm 4.130600046533e-01
294 KSP Residual norm 4.130493047400e-01
295 KSP Residual norm 4.130435934454e-01
296 KSP Residual norm 4.130366996329e-01
297 KSP Residual norm 4.130234922487e-01
298 KSP Residual norm 4.130177314227e-01
299 KSP Residual norm 4.130176522204e-01
300 KSP Residual norm 4.129534057140e-01
301 KSP Residual norm 4.129528591173e-01
302 KSP Residual norm 4.129523752066e-01
303 KSP Residual norm 4.129520369631e-01
304 KSP Residual norm 4.129520332031e-01
305 KSP Residual norm 4.129519983974e-01
306 KSP Residual norm 4.129519167264e-01
307 KSP Residual norm 4.129518697287e-01
308 KSP Residual norm 4.129518516031e-01
309 KSP Residual norm 4.129512056879e-01
310 KSP Residual norm 4.129511076424e-01
311 KSP Residual norm 4.129509443352e-01
312 KSP Residual norm 4.129509177932e-01
313 KSP Residual norm 4.129470826923e-01
314 KSP Residual norm 4.129415428082e-01
315 KSP Residual norm 4.129401406169e-01
316 KSP Residual norm 4.129308860592e-01
317 KSP Residual norm 4.129308818234e-01
318 KSP Residual norm 4.129219682038e-01
319 KSP Residual norm 4.129215984358e-01
320 KSP Residual norm 4.129129234473e-01
321 KSP Residual norm 4.128984258494e-01
322 KSP Residual norm 4.128860599457e-01
323 KSP Residual norm 4.128511524188e-01
324 KSP Residual norm 4.128236156004e-01
325 KSP Residual norm 4.128156355028e-01
326 KSP Residual norm 4.128127833751e-01
327 KSP Residual norm 4.127940181798e-01
328 KSP Residual norm 4.127122873232e-01
329 KSP Residual norm 4.126848237241e-01
330 KSP Residual norm 4.125288390034e-01
331 KSP Residual norm 4.125279039617e-01
332 KSP Residual norm 4.125271137848e-01
333 KSP Residual norm 4.125270674022e-01
334 KSP Residual norm 4.125263302909e-01
335 KSP Residual norm 4.125238543296e-01
336 KSP Residual norm 4.125218710270e-01
337 KSP Residual norm 4.125189823191e-01
338 KSP Residual norm 4.125189815044e-01
339 KSP Residual norm 4.125154375438e-01
340 KSP Residual norm 4.125093701825e-01
341 KSP Residual norm 4.124941653848e-01
342 KSP Residual norm 4.124679316366e-01
343 KSP Residual norm 4.124319450569e-01
344 KSP Residual norm 4.124012371420e-01
345 KSP Residual norm 4.123849460237e-01
346 KSP Residual norm 4.123834839950e-01
347 KSP Residual norm 4.123605873795e-01
348 KSP Residual norm 4.122541751975e-01
349 KSP Residual norm 4.121422741887e-01
350 KSP Residual norm 4.120897806200e-01
351 KSP Residual norm 4.120891912321e-01
352 KSP Residual norm 4.120771333064e-01
353 KSP Residual norm 4.120442427028e-01
354 KSP Residual norm 4.120092981965e-01
355 KSP Residual norm 4.119909465725e-01
356 KSP Residual norm 4.119848164775e-01
357 KSP Residual norm 4.119789382657e-01
358 KSP Residual norm 4.119315361600e-01
359 KSP Residual norm 4.119131664202e-01
360 KSP Residual norm 4.118477844444e-01
361 KSP Residual norm 4.118475092192e-01
362 KSP Residual norm 4.118472864054e-01
363 KSP Residual norm 4.118472457491e-01
364 KSP Residual norm 4.118472000918e-01
365 KSP Residual norm 4.118471179103e-01
366 KSP Residual norm 4.118470061776e-01
367 KSP Residual norm 4.118465675721e-01
368 KSP Residual norm 4.118462409935e-01
369 KSP Residual norm 4.118458954947e-01
370 KSP Residual norm 4.118455957542e-01
371 KSP Residual norm 4.118455643951e-01
372 KSP Residual norm 4.118424156274e-01
373 KSP Residual norm 4.118246220348e-01
374 KSP Residual norm 4.118126881061e-01
375 KSP Residual norm 4.118124918127e-01
376 KSP Residual norm 4.118122309987e-01
377 KSP Residual norm 4.118017305429e-01
378 KSP Residual norm 4.117616375652e-01
379 KSP Residual norm 4.117460260214e-01
380 KSP Residual norm 4.117321680683e-01
381 KSP Residual norm 4.117288094339e-01
382 KSP Residual norm 4.117258670197e-01
383 KSP Residual norm 4.117199535337e-01
384 KSP Residual norm 4.116750446358e-01
385 KSP Residual norm 4.115800705535e-01
386 KSP Residual norm 4.115565946326e-01
387 KSP Residual norm 4.115486254259e-01
388 KSP Residual norm 4.115459153423e-01
389 KSP Residual norm 4.114557593727e-01
390 KSP Residual norm 4.112968818723e-01
391 KSP Residual norm 4.112961924634e-01
392 KSP Residual norm 4.112949197149e-01
393 KSP Residual norm 4.112948837894e-01
394 KSP Residual norm 4.112948740443e-01
395 KSP Residual norm 4.112948499530e-01
396 KSP Residual norm 4.112948467462e-01
397 KSP Residual norm 4.112948227425e-01
398 KSP Residual norm 4.112948085304e-01
399 KSP Residual norm 4.112928219621e-01
400 KSP Residual norm 4.112925574665e-01
401 KSP Residual norm 4.112919632366e-01
402 KSP Residual norm 4.112919546621e-01
403 KSP Residual norm 4.112919249106e-01
404 KSP Residual norm 4.112918910125e-01
405 KSP Residual norm 4.112918906290e-01
406 KSP Residual norm 4.112904523160e-01
407 KSP Residual norm 4.112889761952e-01
408 KSP Residual norm 4.112843834422e-01
409 KSP Residual norm 4.112838117561e-01
410 KSP Residual norm 4.112722694344e-01
411 KSP Residual norm 4.112711141168e-01
412 KSP Residual norm 4.112621822774e-01
413 KSP Residual norm 4.112590845289e-01
414 KSP Residual norm 4.112365791858e-01
415 KSP Residual norm 4.111837342472e-01
416 KSP Residual norm 4.111830086772e-01
417 KSP Residual norm 4.111820985151e-01
418 KSP Residual norm 4.111820230480e-01
419 KSP Residual norm 4.111348589695e-01
420 KSP Residual norm 4.111180639749e-01
421 KSP Residual norm 4.111179949939e-01
422 KSP Residual norm 4.111175895202e-01
423 KSP Residual norm 4.111175866420e-01
424 KSP Residual norm 4.111175831555e-01
425 KSP Residual norm 4.111175827722e-01
426 KSP Residual norm 4.111171539621e-01
427 KSP Residual norm 4.111169842172e-01
428 KSP Residual norm 4.111169804173e-01
429 KSP Residual norm 4.111168641763e-01
430 KSP Residual norm 4.111165776093e-01
431 KSP Residual norm 4.111153424518e-01
432 KSP Residual norm 4.111153414850e-01
433 KSP Residual norm 4.111149617146e-01
434 KSP Residual norm 4.111146980847e-01
435 KSP Residual norm 4.111124920750e-01
436 KSP Residual norm 4.111121681870e-01
437 KSP Residual norm 4.111086423635e-01
438 KSP Residual norm 4.111039338682e-01
439 KSP Residual norm 4.111019904632e-01
440 KSP Residual norm 4.111015684753e-01
441 KSP Residual norm 4.111013970140e-01
442 KSP Residual norm 4.110912618426e-01
443 KSP Residual norm 4.110860817412e-01
444 KSP Residual norm 4.110854091652e-01
445 KSP Residual norm 4.110810902494e-01
446 KSP Residual norm 4.110610594641e-01
447 KSP Residual norm 4.110606454688e-01
448 KSP Residual norm 4.110432570908e-01
449 KSP Residual norm 4.110138359395e-01
450 KSP Residual norm 4.110136781584e-01
451 KSP Residual norm 4.110136775392e-01
452 KSP Residual norm 4.110135379090e-01
453 KSP Residual norm 4.110134425567e-01
454 KSP Residual norm 4.110134424107e-01
455 KSP Residual norm 4.110133660199e-01
456 KSP Residual norm 4.110132437712e-01
457 KSP Residual norm 4.110131945190e-01
458 KSP Residual norm 4.110131905299e-01
459 KSP Residual norm 4.110130498558e-01
460 KSP Residual norm 4.110130444200e-01
461 KSP Residual norm 4.110126777100e-01
462 KSP Residual norm 4.110123152607e-01
463 KSP Residual norm 4.110120695804e-01
464 KSP Residual norm 4.110119203523e-01
465 KSP Residual norm 4.110085511638e-01
466 KSP Residual norm 4.110056808585e-01
467 KSP Residual norm 4.110047668793e-01
468 KSP Residual norm 4.110044035482e-01
469 KSP Residual norm 4.109971203534e-01
470 KSP Residual norm 4.109939550888e-01
471 KSP Residual norm 4.109926575893e-01
472 KSP Residual norm 4.109872068754e-01
473 KSP Residual norm 4.109758171529e-01
474 KSP Residual norm 4.109749842280e-01
475 KSP Residual norm 4.109497845184e-01
476 KSP Residual norm 4.109107070657e-01
477 KSP Residual norm 4.109103430697e-01
478 KSP Residual norm 4.108817299023e-01
479 KSP Residual norm 4.108089708079e-01
480 KSP Residual norm 4.108054952434e-01
481 KSP Residual norm 4.108054845016e-01
482 KSP Residual norm 4.108052143682e-01
483 KSP Residual norm 4.108050354278e-01
484 KSP Residual norm 4.108050325079e-01
485 KSP Residual norm 4.108049126057e-01
486 KSP Residual norm 4.108044472506e-01
487 KSP Residual norm 4.108043930173e-01
488 KSP Residual norm 4.108043914606e-01
489 KSP Residual norm 4.108043803213e-01
490 KSP Residual norm 4.108043254200e-01
491 KSP Residual norm 4.108039841525e-01
492 KSP Residual norm 4.108029422594e-01
493 KSP Residual norm 4.108026670949e-01
494 KSP Residual norm 4.108024171313e-01
495 KSP Residual norm 4.107994970936e-01
496 KSP Residual norm 4.107950800220e-01
497 KSP Residual norm 4.107923429724e-01
498 KSP Residual norm 4.107911889666e-01
499 KSP Residual norm 4.107819505236e-01
500 KSP Residual norm 4.107779816439e-01
501 KSP Residual norm 4.107779709289e-01
502 KSP Residual norm 4.107687322328e-01
503 KSP Residual norm 4.107368207616e-01
504 KSP Residual norm 4.107364849640e-01
505 KSP Residual norm 4.107117215986e-01
506 KSP Residual norm 4.106175458852e-01
507 KSP Residual norm 4.106107266722e-01
508 KSP Residual norm 4.105548526365e-01
509 KSP Residual norm 4.104107852856e-01
510 KSP Residual norm 4.103941912561e-01
511 KSP Residual norm 4.103941476280e-01
512 KSP Residual norm 4.103936896686e-01
513 KSP Residual norm 4.103933316433e-01
514 KSP Residual norm 4.103933295040e-01
515 KSP Residual norm 4.103930603956e-01
516 KSP Residual norm 4.103921856336e-01
517 KSP Residual norm 4.103918481555e-01
518 KSP Residual norm 4.103918343146e-01
519 KSP Residual norm 4.103915618419e-01
520 KSP Residual norm 4.103913620199e-01
521 KSP Residual norm 4.103909841362e-01
522 KSP Residual norm 4.103894926924e-01
523 KSP Residual norm 4.103889195587e-01
524 KSP Residual norm 4.103887983649e-01
525 KSP Residual norm 4.103859745916e-01
526 KSP Residual norm 4.103814413798e-01
527 KSP Residual norm 4.103765009219e-01
528 KSP Residual norm 4.103764971619e-01
529 KSP Residual norm 4.103679491786e-01
530 KSP Residual norm 4.103575142635e-01
531 KSP Residual norm 4.103558497423e-01
532 KSP Residual norm 4.103505396724e-01
533 KSP Residual norm 4.102947800976e-01
534 KSP Residual norm 4.102826711851e-01
535 KSP Residual norm 4.102525969885e-01
536 KSP Residual norm 4.100855886617e-01
537 KSP Residual norm 4.100545989712e-01
538 KSP Residual norm 4.100101599087e-01
539 KSP Residual norm 4.097539286712e-01
540 KSP Residual norm 4.096396804056e-01
541 KSP Residual norm 4.096393703566e-01
542 KSP Residual norm 4.096384449171e-01
543 KSP Residual norm 4.096379939185e-01
544 KSP Residual norm 4.096379804106e-01
545 KSP Residual norm 4.096367773644e-01
546 KSP Residual norm 4.096339941082e-01
547 KSP Residual norm 4.096333642593e-01
548 KSP Residual norm 4.096333455589e-01
549 KSP Residual norm 4.096322654032e-01
550 KSP Residual norm 4.096308522703e-01
551 KSP Residual norm 4.096303889525e-01
552 KSP Residual norm 4.096233735061e-01
553 KSP Residual norm 4.096214918319e-01
554 KSP Residual norm 4.096207777904e-01
555 KSP Residual norm 4.096113673654e-01
556 KSP Residual norm 4.095817218270e-01
557 KSP Residual norm 4.095405610225e-01
558 KSP Residual norm 4.095402598581e-01
559 KSP Residual norm 4.095079233661e-01
560 KSP Residual norm 4.094566001358e-01
561 KSP Residual norm 4.094294099890e-01
562 KSP Residual norm 4.094208769187e-01
563 KSP Residual norm 4.091925561988e-01
564 KSP Residual norm 4.091310281156e-01
565 KSP Residual norm 4.090731720975e-01
566 KSP Residual norm 4.084766246016e-01
567 KSP Residual norm 4.082589104266e-01
568 KSP Residual norm 4.080959563688e-01
569 KSP Residual norm 4.066323778778e-01
570 KSP Residual norm 4.053880392822e-01
571 KSP Residual norm 4.053847086380e-01
572 KSP Residual norm 4.053811758091e-01
573 KSP Residual norm 4.053806836266e-01
574 KSP Residual norm 4.053800554073e-01
575 KSP Residual norm 4.053758077681e-01
576 KSP Residual norm 4.053685458044e-01
577 KSP Residual norm 4.053676845986e-01
578 KSP Residual norm 4.053665216163e-01
579 KSP Residual norm 4.053640067292e-01
580 KSP Residual norm 4.053619886212e-01
581 KSP Residual norm 4.053615593351e-01
582 KSP Residual norm 4.053334835005e-01
583 KSP Residual norm 4.053288100912e-01
584 KSP Residual norm 4.053251849159e-01
585 KSP Residual norm 4.053208544494e-01
586 KSP Residual norm 4.052818327609e-01
587 KSP Residual norm 4.051672403346e-01
588 KSP Residual norm 4.051578151395e-01
589 KSP Residual norm 4.051364262623e-01
590 KSP Residual norm 4.050918117160e-01
591 KSP Residual norm 4.050622051936e-01
592 KSP Residual norm 4.050592625161e-01
593 KSP Residual norm 4.048774208725e-01
594 KSP Residual norm 4.048440401025e-01
595 KSP Residual norm 4.048079905008e-01
596 KSP Residual norm 4.047186348599e-01
597 KSP Residual norm 4.047128038647e-01
598 KSP Residual norm 4.045992122695e-01
599 KSP Residual norm 4.044997235089e-01
600 KSP Residual norm 4.044991824407e-01
601 KSP Residual norm 4.044991813075e-01
602 KSP Residual norm 4.044989382049e-01
603 KSP Residual norm 4.044988170758e-01
604 KSP Residual norm 4.044987600540e-01
605 KSP Residual norm 4.044985496110e-01
606 KSP Residual norm 4.044984397910e-01
607 KSP Residual norm 4.044983591982e-01
608 KSP Residual norm 4.044980602256e-01
609 KSP Residual norm 4.044980551814e-01
610 KSP Residual norm 4.044980509617e-01
611 KSP Residual norm 4.044979975454e-01
612 KSP Residual norm 4.044978002484e-01
613 KSP Residual norm 4.044962707393e-01
614 KSP Residual norm 4.044939386660e-01
615 KSP Residual norm 4.044930078891e-01
616 KSP Residual norm 4.044888755844e-01
617 KSP Residual norm 4.044691825578e-01
618 KSP Residual norm 4.044671952381e-01
619 KSP Residual norm 4.044627494625e-01
620 KSP Residual norm 4.044558962554e-01
621 KSP Residual norm 4.044504773942e-01
622 KSP Residual norm 4.044504300599e-01
623 KSP Residual norm 4.044310074684e-01
624 KSP Residual norm 4.044138556143e-01
625 KSP Residual norm 4.044137690543e-01
626 KSP Residual norm 4.043802684583e-01
627 KSP Residual norm 4.043464246674e-01
628 KSP Residual norm 4.043177621619e-01
629 KSP Residual norm 4.043086641092e-01
630 KSP Residual norm 4.040580113182e-01
631 KSP Residual norm 4.040567944878e-01
632 KSP Residual norm 4.040565354371e-01
633 KSP Residual norm 4.040562171575e-01
634 KSP Residual norm 4.040560416300e-01
635 KSP Residual norm 4.040560371803e-01
636 KSP Residual norm 4.040560275825e-01
637 KSP Residual norm 4.040560200332e-01
638 KSP Residual norm 4.040559460965e-01
639 KSP Residual norm 4.040557718662e-01
640 KSP Residual norm 4.040557700203e-01
641 KSP Residual norm 4.040555224838e-01
642 KSP Residual norm 4.040423235951e-01
643 KSP Residual norm 4.040417473433e-01
644 KSP Residual norm 4.040211135337e-01
645 KSP Residual norm 4.040197408867e-01
646 KSP Residual norm 4.040086355585e-01
647 KSP Residual norm 4.040066297924e-01
648 KSP Residual norm 4.040010440714e-01
649 KSP Residual norm 4.039900815634e-01
650 KSP Residual norm 4.039900670898e-01
651 KSP Residual norm 4.039897452619e-01
652 KSP Residual norm 4.039861721040e-01
653 KSP Residual norm 4.039166464094e-01
654 KSP Residual norm 4.039128737908e-01
655 KSP Residual norm 4.037218643476e-01
656 KSP Residual norm 4.034182638644e-01
657 KSP Residual norm 4.034022923546e-01
658 KSP Residual norm 4.025007116701e-01
659 KSP Residual norm 4.004351448644e-01
660 KSP Residual norm 4.000770467007e-01
661 KSP Residual norm 4.000765424816e-01
662 KSP Residual norm 4.000745033088e-01
663 KSP Residual norm 4.000744315150e-01
664 KSP Residual norm 4.000727234553e-01
665 KSP Residual norm 4.000726252273e-01
666 KSP Residual norm 4.000707344499e-01
667 KSP Residual norm 4.000654208963e-01
668 KSP Residual norm 4.000627735776e-01
669 KSP Residual norm 4.000505209179e-01
670 KSP Residual norm 4.000380459841e-01
671 KSP Residual norm 4.000213132017e-01
672 KSP Residual norm 3.999661348653e-01
673 KSP Residual norm 3.999654402867e-01
674 KSP Residual norm 3.998686958127e-01
675 KSP Residual norm 3.996434209160e-01
676 KSP Residual norm 3.994710833261e-01
677 KSP Residual norm 3.994690989318e-01
678 KSP Residual norm 3.994480541024e-01
679 KSP Residual norm 3.993946501573e-01
680 KSP Residual norm 3.993163561782e-01
681 KSP Residual norm 3.993155363856e-01
682 KSP Residual norm 3.991682106454e-01
683 KSP Residual norm 3.989095131221e-01
684 KSP Residual norm 3.988447880332e-01
685 KSP Residual norm 3.980527307200e-01
686 KSP Residual norm 3.976530797501e-01
687 KSP Residual norm 3.976529261326e-01
688 KSP Residual norm 3.971495227501e-01
689 KSP Residual norm 3.971214559329e-01
690 KSP Residual norm 3.970677700679e-01
691 KSP Residual norm 3.970677000834e-01
692 KSP Residual norm 3.970674595462e-01
693 KSP Residual norm 3.970672677623e-01
694 KSP Residual norm 3.970668443087e-01
695 KSP Residual norm 3.970661849035e-01
696 KSP Residual norm 3.970659072119e-01
697 KSP Residual norm 3.970653773571e-01
698 KSP Residual norm 3.970651594645e-01
699 KSP Residual norm 3.970645405759e-01
700 KSP Residual norm 3.970617640726e-01
701 KSP Residual norm 3.970592329678e-01
702 KSP Residual norm 3.970340573152e-01
703 KSP Residual norm 3.970325907197e-01
704 KSP Residual norm 3.969751743134e-01
705 KSP Residual norm 3.969681550599e-01
706 KSP Residual norm 3.969680210402e-01
707 KSP Residual norm 3.969656301657e-01
708 KSP Residual norm 3.969561724977e-01
709 KSP Residual norm 3.969559381409e-01
710 KSP Residual norm 3.969403066484e-01
711 KSP Residual norm 3.969332811307e-01
712 KSP Residual norm 3.969258794885e-01
713 KSP Residual norm 3.968626450839e-01
714 KSP Residual norm 3.968490348324e-01
715 KSP Residual norm 3.967889983150e-01
716 KSP Residual norm 3.967612973961e-01
717 KSP Residual norm 3.967189091810e-01
718 KSP Residual norm 3.967116052214e-01
719 KSP Residual norm 3.967103743918e-01
720 KSP Residual norm 3.964678774111e-01
721 KSP Residual norm 3.964677499049e-01
722 KSP Residual norm 3.964677498644e-01
723 KSP Residual norm 3.964674592538e-01
724 KSP Residual norm 3.964674442235e-01
725 KSP Residual norm 3.964671514341e-01
726 KSP Residual norm 3.964671233807e-01
727 KSP Residual norm 3.964669431869e-01
728 KSP Residual norm 3.964661596295e-01
729 KSP Residual norm 3.964655641204e-01
730 KSP Residual norm 3.964643267593e-01
731 KSP Residual norm 3.964608185073e-01
732 KSP Residual norm 3.964524985033e-01
733 KSP Residual norm 3.964511179722e-01
734 KSP Residual norm 3.964340604507e-01
735 KSP Residual norm 3.964306584905e-01
736 KSP Residual norm 3.964306150295e-01
737 KSP Residual norm 3.964117313003e-01
738 KSP Residual norm 3.964109484137e-01
739 KSP Residual norm 3.963811465750e-01
740 KSP Residual norm 3.963810211576e-01
741 KSP Residual norm 3.963552548206e-01
742 KSP Residual norm 3.963527621093e-01
743 KSP Residual norm 3.962884937912e-01
744 KSP Residual norm 3.962227620727e-01
745 KSP Residual norm 3.961775911195e-01
746 KSP Residual norm 3.960895737119e-01
747 KSP Residual norm 3.959492929184e-01
748 KSP Residual norm 3.959453326018e-01
749 KSP Residual norm 3.956989412461e-01
750 KSP Residual norm 3.953191573018e-01
751 KSP Residual norm 3.953189967861e-01
752 KSP Residual norm 3.953189963497e-01
753 KSP Residual norm 3.953187292499e-01
754 KSP Residual norm 3.953186187047e-01
755 KSP Residual norm 3.953174325272e-01
756 KSP Residual norm 3.953172754251e-01
757 KSP Residual norm 3.953165950643e-01
758 KSP Residual norm 3.953164517133e-01
759 KSP Residual norm 3.953150346775e-01
760 KSP Residual norm 3.953141483769e-01
761 KSP Residual norm 3.953073504038e-01
762 KSP Residual norm 3.952994568912e-01
763 KSP Residual norm 3.952971919403e-01
764 KSP Residual norm 3.952827414252e-01
765 KSP Residual norm 3.952820455482e-01
766 KSP Residual norm 3.952813224923e-01
767 KSP Residual norm 3.952773900448e-01
768 KSP Residual norm 3.952770215516e-01
769 KSP Residual norm 3.952757562885e-01
770 KSP Residual norm 3.952717645913e-01
771 KSP Residual norm 3.952717536957e-01
772 KSP Residual norm 3.952692221769e-01
773 KSP Residual norm 3.952685011520e-01
774 KSP Residual norm 3.952670550720e-01
775 KSP Residual norm 3.952648252931e-01
776 KSP Residual norm 3.952511747549e-01
777 KSP Residual norm 3.952095173270e-01
778 KSP Residual norm 3.951831681530e-01
779 KSP Residual norm 3.951633567641e-01
780 KSP Residual norm 3.951200363359e-01
781 KSP Residual norm 3.951200298459e-01
782 KSP Residual norm 3.951200297803e-01
783 KSP Residual norm 3.951199966919e-01
784 KSP Residual norm 3.951199060006e-01
785 KSP Residual norm 3.951199059440e-01
786 KSP Residual norm 3.951198051427e-01
787 KSP Residual norm 3.951197440224e-01
788 KSP Residual norm 3.951196683846e-01
789 KSP Residual norm 3.951192323114e-01
790 KSP Residual norm 3.951191986847e-01
791 KSP Residual norm 3.951168474838e-01
792 KSP Residual norm 3.951166021478e-01
793 KSP Residual norm 3.951154752648e-01
794 KSP Residual norm 3.951147391700e-01
795 KSP Residual norm 3.951137837719e-01
796 KSP Residual norm 3.951129050510e-01
797 KSP Residual norm 3.951111903597e-01
798 KSP Residual norm 3.951108050269e-01
799 KSP Residual norm 3.951066690325e-01
800 KSP Residual norm 3.951054856874e-01
801 KSP Residual norm 3.950996393735e-01
802 KSP Residual norm 3.950923810045e-01
803 KSP Residual norm 3.950739106683e-01
804 KSP Residual norm 3.950002133546e-01
805 KSP Residual norm 3.949960347810e-01
806 KSP Residual norm 3.949028709805e-01
807 KSP Residual norm 3.948668717591e-01
808 KSP Residual norm 3.948050837012e-01
809 KSP Residual norm 3.948007549716e-01
810 KSP Residual norm 3.947595592930e-01
811 KSP Residual norm 3.947595501001e-01
812 KSP Residual norm 3.947595438239e-01
813 KSP Residual norm 3.947594535466e-01
814 KSP Residual norm 3.947594064932e-01
815 KSP Residual norm 3.947592318762e-01
816 KSP Residual norm 3.947589476911e-01
817 KSP Residual norm 3.947589329835e-01
818 KSP Residual norm 3.947584808126e-01
819 KSP Residual norm 3.947582620980e-01
820 KSP Residual norm 3.947576789265e-01
821 KSP Residual norm 3.947530845594e-01
822 KSP Residual norm 3.947502415111e-01
823 KSP Residual norm 3.947458876651e-01
824 KSP Residual norm 3.947396615082e-01
825 KSP Residual norm 3.947316317585e-01
826 KSP Residual norm 3.947298389369e-01
827 KSP Residual norm 3.947177075405e-01
828 KSP Residual norm 3.947168519283e-01
829 KSP Residual norm 3.947090646616e-01
830 KSP Residual norm 3.947019725950e-01
831 KSP Residual norm 3.947003533281e-01
832 KSP Residual norm 3.946953469962e-01
833 KSP Residual norm 3.946873271876e-01
834 KSP Residual norm 3.946805698304e-01
835 KSP Residual norm 3.946480679733e-01
836 KSP Residual norm 3.945927421717e-01
837 KSP Residual norm 3.945103145113e-01
838 KSP Residual norm 3.944688068986e-01
839 KSP Residual norm 3.944606176654e-01
840 KSP Residual norm 3.944392218041e-01
841 KSP Residual norm 3.944392196483e-01
842 KSP Residual norm 3.944392155635e-01
843 KSP Residual norm 3.944391252336e-01
844 KSP Residual norm 3.944390181193e-01
845 KSP Residual norm 3.944390111415e-01
846 KSP Residual norm 3.944389080843e-01
847 KSP Residual norm 3.944388933527e-01
848 KSP Residual norm 3.944388480814e-01
849 KSP Residual norm 3.944387436866e-01
850 KSP Residual norm 3.944387353326e-01
851 KSP Residual norm 3.944380632260e-01
852 KSP Residual norm 3.944380605171e-01
853 KSP Residual norm 3.944379695991e-01
854 KSP Residual norm 3.944379536730e-01
855 KSP Residual norm 3.944379302972e-01
856 KSP Residual norm 3.944376861138e-01
857 KSP Residual norm 3.944376281034e-01
858 KSP Residual norm 3.944368880080e-01
859 KSP Residual norm 3.944358177390e-01
860 KSP Residual norm 3.944357729065e-01
861 KSP Residual norm 3.944337298839e-01
862 KSP Residual norm 3.944326459537e-01
863 KSP Residual norm 3.944274089630e-01
864 KSP Residual norm 3.944060372374e-01
865 KSP Residual norm 3.944053971987e-01
866 KSP Residual norm 3.943963435966e-01
867 KSP Residual norm 3.943961994499e-01
868 KSP Residual norm 3.943928081242e-01
869 KSP Residual norm 3.943918918297e-01
870 KSP Residual norm 3.943892952181e-01
871 KSP Residual norm 3.943892950235e-01
872 KSP Residual norm 3.943892932463e-01
873 KSP Residual norm 3.943892873370e-01
874 KSP Residual norm 3.943892859476e-01
875 KSP Residual norm 3.943892850121e-01
876 KSP Residual norm 3.943892846531e-01
877 KSP Residual norm 3.943892739880e-01
878 KSP Residual norm 3.943892738871e-01
879 KSP Residual norm 3.943892175320e-01
880 KSP Residual norm 3.943891924999e-01
881 KSP Residual norm 3.943891899316e-01
882 KSP Residual norm 3.943891565422e-01
883 KSP Residual norm 3.943891279450e-01
884 KSP Residual norm 3.943890891100e-01
885 KSP Residual norm 3.943888105957e-01
886 KSP Residual norm 3.943887766644e-01
887 KSP Residual norm 3.943885430499e-01
888 KSP Residual norm 3.943879560517e-01
889 KSP Residual norm 3.943879518064e-01
890 KSP Residual norm 3.943870096605e-01
891 KSP Residual norm 3.943865923245e-01
892 KSP Residual norm 3.943865220344e-01
893 KSP Residual norm 3.943858738521e-01
894 KSP Residual norm 3.943824193180e-01
895 KSP Residual norm 3.943799967223e-01
896 KSP Residual norm 3.943799834026e-01
897 KSP Residual norm 3.943780007471e-01
898 KSP Residual norm 3.943776544020e-01
899 KSP Residual norm 3.943775575326e-01
900 KSP Residual norm 3.943760304866e-01
901 KSP Residual norm 3.943760303549e-01
902 KSP Residual norm 3.943760297405e-01
903 KSP Residual norm 3.943760240670e-01
904 KSP Residual norm 3.943760140434e-01
905 KSP Residual norm 3.943760131839e-01
906 KSP Residual norm 3.943760106045e-01
907 KSP Residual norm 3.943760010940e-01
908 KSP Residual norm 3.943760010880e-01
909 KSP Residual norm 3.943759826394e-01
910 KSP Residual norm 3.943759781647e-01
911 KSP Residual norm 3.943759524710e-01
912 KSP Residual norm 3.943759178695e-01
913 KSP Residual norm 3.943759079375e-01
914 KSP Residual norm 3.943758922601e-01
915 KSP Residual norm 3.943757695610e-01
916 KSP Residual norm 3.943757360833e-01
917 KSP Residual norm 3.943755513856e-01
918 KSP Residual norm 3.943750708635e-01
919 KSP Residual norm 3.943750581555e-01
920 KSP Residual norm 3.943745567396e-01
921 KSP Residual norm 3.943741565194e-01
922 KSP Residual norm 3.943741522063e-01
923 KSP Residual norm 3.943732024225e-01
924 KSP Residual norm 3.943699659052e-01
925 KSP Residual norm 3.943688401003e-01
926 KSP Residual norm 3.943688222022e-01
927 KSP Residual norm 3.943679058852e-01
928 KSP Residual norm 3.943675951917e-01
929 KSP Residual norm 3.943675951520e-01
930 KSP Residual norm 3.943669294280e-01
931 KSP Residual norm 3.943669293703e-01
932 KSP Residual norm 3.943669290600e-01
933 KSP Residual norm 3.943669268442e-01
934 KSP Residual norm 3.943669237765e-01
935 KSP Residual norm 3.943669237243e-01
936 KSP Residual norm 3.943669214658e-01
937 KSP Residual norm 3.943669149406e-01
938 KSP Residual norm 3.943669149383e-01
939 KSP Residual norm 3.943668993861e-01
940 KSP Residual norm 3.943668950971e-01
941 KSP Residual norm 3.943668801731e-01
942 KSP Residual norm 3.943668589586e-01
943 KSP Residual norm 3.943668542770e-01
944 KSP Residual norm 3.943668398040e-01
945 KSP Residual norm 3.943667391126e-01
946 KSP Residual norm 3.943667100270e-01
947 KSP Residual norm 3.943665861475e-01
948 KSP Residual norm 3.943662577209e-01
949 KSP Residual norm 3.943662536439e-01
950 KSP Residual norm 3.943658601713e-01
951 KSP Residual norm 3.943655438533e-01
952 KSP Residual norm 3.943655400518e-01
953 KSP Residual norm 3.943648416325e-01
954 KSP Residual norm 3.943621887261e-01
955 KSP Residual norm 3.943610992566e-01
956 KSP Residual norm 3.943610981974e-01
957 KSP Residual norm 3.943602916328e-01
958 KSP Residual norm 3.943599707828e-01
959 KSP Residual norm 3.943599698134e-01
960 KSP Residual norm 3.943592984477e-01
961 KSP Residual norm 3.943592983882e-01
962 KSP Residual norm 3.943592980681e-01
963 KSP Residual norm 3.943592958402e-01
964 KSP Residual norm 3.943592927808e-01
965 KSP Residual norm 3.943592927181e-01
966 KSP Residual norm 3.943592908846e-01
967 KSP Residual norm 3.943592856572e-01
968 KSP Residual norm 3.943592856527e-01
969 KSP Residual norm 3.943592708723e-01
970 KSP Residual norm 3.943592667882e-01
971 KSP Residual norm 3.943592529122e-01
972 KSP Residual norm 3.943592330760e-01
973 KSP Residual norm 3.943592279270e-01
974 KSP Residual norm 3.943592177113e-01
975 KSP Residual norm 3.943591392718e-01
976 KSP Residual norm 3.943591168455e-01
977 KSP Residual norm 3.943590118187e-01
978 KSP Residual norm 3.943587414604e-01
979 KSP Residual norm 3.943587368107e-01
980 KSP Residual norm 3.943584394872e-01
981 KSP Residual norm 3.943581992643e-01
982 KSP Residual norm 3.943581965979e-01
983 KSP Residual norm 3.943576468368e-01
984 KSP Residual norm 3.943557301453e-01
985 KSP Residual norm 3.943550381450e-01
986 KSP Residual norm 3.943550328739e-01
987 KSP Residual norm 3.943544687752e-01
988 KSP Residual norm 3.943542756703e-01
989 KSP Residual norm 3.943542726753e-01
990 KSP Residual norm 3.943536647745e-01
991 KSP Residual norm 3.943536647206e-01
992 KSP Residual norm 3.943536644561e-01
993 KSP Residual norm 3.943536624356e-01
994 KSP Residual norm 3.943536593549e-01
995 KSP Residual norm 3.943536591722e-01
996 KSP Residual norm 3.943536579745e-01
997 KSP Residual norm 3.943536536516e-01
998 KSP Residual norm 3.943536536213e-01
999 KSP Residual norm 3.943536455575e-01
1000 KSP Residual norm 3.943536434321e-01
1001 KSP Residual norm 3.943536331741e-01
1002 KSP Residual norm 3.943536192670e-01
1003 KSP Residual norm 3.943536162840e-01
1004 KSP Residual norm 3.943536078132e-01
1005 KSP Residual norm 3.943535487363e-01
1006 KSP Residual norm 3.943535317372e-01
1007 KSP Residual norm 3.943534512078e-01
1008 KSP Residual norm 3.943532427298e-01
1009 KSP Residual norm 3.943532393100e-01
1010 KSP Residual norm 3.943530043021e-01
1011 KSP Residual norm 3.943528110823e-01
1012 KSP Residual norm 3.943528092284e-01
1013 KSP Residual norm 3.943523699781e-01
1014 KSP Residual norm 3.943507352991e-01
1015 KSP Residual norm 3.943500800704e-01
1016 KSP Residual norm 3.943500790732e-01
1017 KSP Residual norm 3.943495791957e-01
1018 KSP Residual norm 3.943493639277e-01
1019 KSP Residual norm 3.943493614596e-01
1020 KSP Residual norm 3.943489901691e-01
1021 KSP Residual norm 3.943489901360e-01
1022 KSP Residual norm 3.943489899587e-01
1023 KSP Residual norm 3.943489887649e-01
1024 KSP Residual norm 3.943489872290e-01
1025 KSP Residual norm 3.943489872192e-01
1026 KSP Residual norm 3.943489860026e-01
1027 KSP Residual norm 3.943489828437e-01
1028 KSP Residual norm 3.943489828372e-01
1029 KSP Residual norm 3.943489734058e-01
1030 KSP Residual norm 3.943489707597e-01
1031 KSP Residual norm 3.943489626177e-01
1032 KSP Residual norm 3.943489509429e-01
1033 KSP Residual norm 3.943489480207e-01
1034 KSP Residual norm 3.943489415534e-01
1035 KSP Residual norm 3.943488929503e-01
1036 KSP Residual norm 3.943488787539e-01
1037 KSP Residual norm 3.943488166225e-01
1038 KSP Residual norm 3.943486552307e-01
1039 KSP Residual norm 3.943486527389e-01
1040 KSP Residual norm 3.943484701326e-01
1041 KSP Residual norm 3.943483226279e-01
1042 KSP Residual norm 3.943483210128e-01
1043 KSP Residual norm 3.943479872156e-01
1044 KSP Residual norm 3.943468073679e-01
1045 KSP Residual norm 3.943463764717e-01
1046 KSP Residual norm 3.943463733813e-01
1047 KSP Residual norm 3.943460250791e-01
1048 KSP Residual norm 3.943459094312e-01
1049 KSP Residual norm 3.943459066341e-01
1050 KSP Residual norm 3.943455077790e-01
1051 KSP Residual norm 3.943455077436e-01
1052 KSP Residual norm 3.943455075754e-01
1053 KSP Residual norm 3.943455062735e-01
1054 KSP Residual norm 3.943455042461e-01
1055 KSP Residual norm 3.943455041074e-01
1056 KSP Residual norm 3.943455034097e-01
1057 KSP Residual norm 3.943455007714e-01
1058 KSP Residual norm 3.943455007511e-01
1059 KSP Residual norm 3.943454958810e-01
1060 KSP Residual norm 3.943454946027e-01
1061 KSP Residual norm 3.943454882116e-01
1062 KSP Residual norm 3.943454795274e-01
1063 KSP Residual norm 3.943454776190e-01
1064 KSP Residual norm 3.943454725902e-01
1065 KSP Residual norm 3.943454369596e-01
1066 KSP Residual norm 3.943454268295e-01
1067 KSP Residual norm 3.943453767855e-01
1068 KSP Residual norm 3.943452483256e-01
1069 KSP Residual norm 3.943452461156e-01
1070 KSP Residual norm 3.943451035768e-01
1071 KSP Residual norm 3.943449862056e-01
1072 KSP Residual norm 3.943449850755e-01
1073 KSP Residual norm 3.943447160190e-01
1074 KSP Residual norm 3.943437254806e-01
1075 KSP Residual norm 3.943433354215e-01
1076 KSP Residual norm 3.943433344102e-01
1077 KSP Residual norm 3.943430281787e-01
1078 KSP Residual norm 3.943428982356e-01
1079 KSP Residual norm 3.943428971044e-01
1080 KSP Residual norm 3.943426675940e-01
1081 KSP Residual norm 3.943426675735e-01
1082 KSP Residual norm 3.943426674667e-01
1083 KSP Residual norm 3.943426667408e-01
1084 KSP Residual norm 3.943426657997e-01
1085 KSP Residual norm 3.943426657927e-01
1086 KSP Residual norm 3.943426650588e-01
1087 KSP Residual norm 3.943426631258e-01
1088 KSP Residual norm 3.943426631236e-01
1089 KSP Residual norm 3.943426575574e-01
1090 KSP Residual norm 3.943426559965e-01
1091 KSP Residual norm 3.943426511138e-01
1092 KSP Residual norm 3.943426441433e-01
1093 KSP Residual norm 3.943426424387e-01
1094 KSP Residual norm 3.943426384778e-01
1095 KSP Residual norm 3.943426090272e-01
1096 KSP Residual norm 3.943426004029e-01
1097 KSP Residual norm 3.943425628787e-01
1098 KSP Residual norm 3.943424654735e-01
1099 KSP Residual norm 3.943424640157e-01
1100 KSP Residual norm 3.943423528668e-01
1101 KSP Residual norm 3.943422630375e-01
1102 KSP Residual norm 3.943422620626e-01
1103 KSP Residual norm 3.943420589782e-01
1104 KSP Residual norm 3.943413372247e-01
1105 KSP Residual norm 3.943410722608e-01
1106 KSP Residual norm 3.943410703604e-01
1107 KSP Residual norm 3.943408559021e-01
1108 KSP Residual norm 3.943407843331e-01
1109 KSP Residual norm 3.943407827702e-01
1110 KSP Residual norm 3.943405400209e-01
1111 KSP Residual norm 3.943405399994e-01
1112 KSP Residual norm 3.943405398983e-01
1113 KSP Residual norm 3.943405391183e-01
1114 KSP Residual norm 3.943405379088e-01
1115 KSP Residual norm 3.943405378289e-01
1116 KSP Residual norm 3.943405374040e-01
1117 KSP Residual norm 3.943405358188e-01
1118 KSP Residual norm 3.943405358087e-01
1119 KSP Residual norm 3.943405327802e-01
1120 KSP Residual norm 3.943405319810e-01
1121 KSP Residual norm 3.943405281037e-01
1122 KSP Residual norm 3.943405228095e-01
1123 KSP Residual norm 3.943405216286e-01
1124 KSP Residual norm 3.943405186135e-01
1125 KSP Residual norm 3.943404970603e-01
1126 KSP Residual norm 3.943404909509e-01
1127 KSP Residual norm 3.943404605765e-01
1128 KSP Residual norm 3.943403828450e-01
1129 KSP Residual norm 3.943403815135e-01
1130 KSP Residual norm 3.943402953680e-01
1131 KSP Residual norm 3.943402245405e-01
1132 KSP Residual norm 3.943402238466e-01
1133 KSP Residual norm 3.943400611758e-01
1134 KSP Residual norm 3.943394662452e-01
1135 KSP Residual norm 3.943392350873e-01
1136 KSP Residual norm 3.943392342578e-01
1137 KSP Residual norm 3.943390496868e-01
1138 KSP Residual norm 3.943389735494e-01
1139 KSP Residual norm 3.943389731976e-01
1140 KSP Residual norm 3.943388288574e-01
1141 KSP Residual norm 3.943388288446e-01
1142 KSP Residual norm 3.943388287791e-01
1143 KSP Residual norm 3.943388283265e-01
1144 KSP Residual norm 3.943388277262e-01
1145 KSP Residual norm 3.943388277192e-01
1146 KSP Residual norm 3.943388272892e-01
1147 KSP Residual norm 3.943388261151e-01
1148 KSP Residual norm 3.943388261146e-01
1149 KSP Residual norm 3.943388228863e-01
1150 KSP Residual norm 3.943388219851e-01
1151 KSP Residual norm 3.943388190465e-01
1152 KSP Residual norm 3.943388148732e-01
1153 KSP Residual norm 3.943388138677e-01
1154 KSP Residual norm 3.943388114816e-01
1155 KSP Residual norm 3.943387938411e-01
1156 KSP Residual norm 3.943387886911e-01
1157 KSP Residual norm 3.943387659994e-01
1158 KSP Residual norm 3.943387072626e-01
1159 KSP Residual norm 3.943387063847e-01
1160 KSP Residual norm 3.943386393307e-01
1161 KSP Residual norm 3.943385850698e-01
1162 KSP Residual norm 3.943385844852e-01
1163 KSP Residual norm 3.943384615936e-01
1164 KSP Residual norm 3.943380236045e-01
1165 KSP Residual norm 3.943378622640e-01
1166 KSP Residual norm 3.943378610995e-01
1167 KSP Residual norm 3.943377299902e-01
1168 KSP Residual norm 3.943376855678e-01
1169 KSP Residual norm 3.943376848166e-01
1170 KSP Residual norm 3.943375406501e-01
1171 KSP Residual norm 3.943375406374e-01
1172 KSP Residual norm 3.943375405775e-01
1173 KSP Residual norm 3.943375401194e-01
1174 KSP Residual norm 3.943375394162e-01
1175 KSP Residual norm 3.943375393734e-01
1176 KSP Residual norm 3.943375391123e-01
1177 KSP Residual norm 3.943375381645e-01
1178 KSP Residual norm 3.943375381597e-01
1179 KSP Residual norm 3.943375362799e-01
1180 KSP Residual norm 3.943375357804e-01
1181 KSP Residual norm 3.943375334535e-01
1182 KSP Residual norm 3.943375302625e-01
1183 KSP Residual norm 3.943375295443e-01
1184 KSP Residual norm 3.943375277343e-01
1185 KSP Residual norm 3.943375147299e-01
1186 KSP Residual norm 3.943375110409e-01
1187 KSP Residual norm 3.943374928063e-01
1188 KSP Residual norm 3.943374461831e-01
1189 KSP Residual norm 3.943374453969e-01
1190 KSP Residual norm 3.943373935859e-01
1191 KSP Residual norm 3.943373510679e-01
1192 KSP Residual norm 3.943373506452e-01
1193 KSP Residual norm 3.943372530137e-01
1194 KSP Residual norm 3.943368974961e-01
1195 KSP Residual norm 3.943367606756e-01
1196 KSP Residual norm 3.943367600800e-01
1197 KSP Residual norm 3.943366498015e-01
1198 KSP Residual norm 3.943366054760e-01
1199 KSP Residual norm 3.943366053900e-01
1200 KSP Residual norm 3.943365153677e-01
1201 KSP Residual norm 3.943365153597e-01
1202 KSP Residual norm 3.943365153197e-01
1203 KSP Residual norm 3.943365150387e-01
1204 KSP Residual norm 3.943365146581e-01
1205 KSP Residual norm 3.943365146517e-01
1206 KSP Residual norm 3.943365144011e-01
1207 KSP Residual norm 3.943365136929e-01
1208 KSP Residual norm 3.943365136929e-01
1209 KSP Residual norm 3.943365118217e-01
1210 KSP Residual norm 3.943365113018e-01
1211 KSP Residual norm 3.943365095367e-01
1212 KSP Residual norm 3.943365070410e-01
1213 KSP Residual norm 3.943365064456e-01
1214 KSP Residual norm 3.943365050184e-01
1215 KSP Residual norm 3.943364945040e-01
1216 KSP Residual norm 3.943364914463e-01
1217 KSP Residual norm 3.943364777718e-01
1218 KSP Residual norm 3.943364424684e-01
1219 KSP Residual norm 3.943364419367e-01
1220 KSP Residual norm 3.943364017084e-01
1221 KSP Residual norm 3.943363691117e-01
1222 KSP Residual norm 3.943363687627e-01
1223 KSP Residual norm 3.943362947849e-01
1224 KSP Residual norm 3.943360306129e-01
1225 KSP Residual norm 3.943359330157e-01
1226 KSP Residual norm 3.943359323126e-01
1227 KSP Residual norm 3.943358527374e-01
1228 KSP Residual norm 3.943358253456e-01
1229 KSP Residual norm 3.943358250000e-01
1230 KSP Residual norm 3.943357400253e-01
1231 KSP Residual norm 3.943357400178e-01
1232 KSP Residual norm 3.943357399825e-01
1233 KSP Residual norm 3.943357397144e-01
1234 KSP Residual norm 3.943357393073e-01
1235 KSP Residual norm 3.943357392845e-01
1236 KSP Residual norm 3.943357391246e-01
1237 KSP Residual norm 3.943357385594e-01
1238 KSP Residual norm 3.943357385572e-01
1239 KSP Residual norm 3.943357373994e-01
1240 KSP Residual norm 3.943357370901e-01
1241 KSP Residual norm 3.943357357000e-01
1242 KSP Residual norm 3.943357337871e-01
1243 KSP Residual norm 3.943357333539e-01
1244 KSP Residual norm 3.943357322692e-01
1245 KSP Residual norm 3.943357244500e-01
1246 KSP Residual norm 3.943357222280e-01
1247 KSP Residual norm 3.943357113359e-01
1248 KSP Residual norm 3.943356834877e-01
1249 KSP Residual norm 3.943356830252e-01
1250 KSP Residual norm 3.943356519811e-01
1251 KSP Residual norm 3.943356265466e-01
1252 KSP Residual norm 3.943356262910e-01
1253 KSP Residual norm 3.943355679312e-01
1254 KSP Residual norm 3.943353560604e-01
1255 KSP Residual norm 3.943352750766e-01
1256 KSP Residual norm 3.943352746789e-01
1257 KSP Residual norm 3.943352090492e-01
1258 KSP Residual norm 3.943351832141e-01
1259 KSP Residual norm 3.943351831988e-01
1260 KSP Residual norm 3.943351276975e-01
1261 KSP Residual norm 3.943351276926e-01
1262 KSP Residual norm 3.943351276682e-01
1263 KSP Residual norm 3.943351274954e-01
1264 KSP Residual norm 3.943351272574e-01
1265 KSP Residual norm 3.943351272524e-01
1266 KSP Residual norm 3.943351271061e-01
1267 KSP Residual norm 3.943351266808e-01
1268 KSP Residual norm 3.943351266808e-01
1269 KSP Residual norm 3.943351255923e-01
1270 KSP Residual norm 3.943351252911e-01
1271 KSP Residual norm 3.943351242337e-01
1272 KSP Residual norm 3.943351227437e-01
1273 KSP Residual norm 3.943351223907e-01
1274 KSP Residual norm 3.943351215395e-01
1275 KSP Residual norm 3.943351152847e-01
1276 KSP Residual norm 3.943351134717e-01
1277 KSP Residual norm 3.943351052609e-01
1278 KSP Residual norm 3.943350841050e-01
1279 KSP Residual norm 3.943350837836e-01
1280 KSP Residual norm 3.943350597275e-01
1281 KSP Residual norm 3.943350402122e-01
1282 KSP Residual norm 3.943350400044e-01
1283 KSP Residual norm 3.943349956396e-01
1284 KSP Residual norm 3.943348369709e-01
1285 KSP Residual norm 3.943347781970e-01
1286 KSP Residual norm 3.943347777776e-01
1287 KSP Residual norm 3.943347297547e-01
1288 KSP Residual norm 3.943347129942e-01
1289 KSP Residual norm 3.943347128357e-01
1290 KSP Residual norm 3.943346628223e-01
1291 KSP Residual norm 3.943346628179e-01
1292 KSP Residual norm 3.943346627971e-01
1293 KSP Residual norm 3.943346626400e-01
1294 KSP Residual norm 3.943346624038e-01
1295 KSP Residual norm 3.943346623915e-01
1296 KSP Residual norm 3.943346622942e-01
1297 KSP Residual norm 3.943346619576e-01
1298 KSP Residual norm 3.943346619565e-01
1299 KSP Residual norm 3.943346612490e-01
1300 KSP Residual norm 3.943346610591e-01
1301 KSP Residual norm 3.943346602304e-01
1302 KSP Residual norm 3.943346590869e-01
1303 KSP Residual norm 3.943346588267e-01
1304 KSP Residual norm 3.943346581780e-01
1305 KSP Residual norm 3.943346534900e-01
1306 KSP Residual norm 3.943346521554e-01
1307 KSP Residual norm 3.943346456642e-01
1308 KSP Residual norm 3.943346290637e-01
1309 KSP Residual norm 3.943346287914e-01
1310 KSP Residual norm 3.943346102369e-01
1311 KSP Residual norm 3.943345950547e-01
1312 KSP Residual norm 3.943345949008e-01
1313 KSP Residual norm 3.943345600925e-01
1314 KSP Residual norm 3.943344339997e-01
1315 KSP Residual norm 3.943343860399e-01
1316 KSP Residual norm 3.943343857851e-01
1317 KSP Residual norm 3.943343467895e-01
1318 KSP Residual norm 3.943343316836e-01
1319 KSP Residual norm 3.943343316824e-01
1320 KSP Residual norm 3.943342977885e-01
1321 KSP Residual norm 3.943342977855e-01
1322 KSP Residual norm 3.943342977708e-01
1323 KSP Residual norm 3.943342976654e-01
1324 KSP Residual norm 3.943342975184e-01
1325 KSP Residual norm 3.943342975147e-01
1326 KSP Residual norm 3.943342974291e-01
1327 KSP Residual norm 3.943342971744e-01
1328 KSP Residual norm 3.943342971744e-01
1329 KSP Residual norm 3.943342965385e-01
1330 KSP Residual norm 3.943342963631e-01
1331 KSP Residual norm 3.943342957310e-01
1332 KSP Residual norm 3.943342948425e-01
1333 KSP Residual norm 3.943342946331e-01
1334 KSP Residual norm 3.943342941261e-01
1335 KSP Residual norm 3.943342904077e-01
1336 KSP Residual norm 3.943342893327e-01
1337 KSP Residual norm 3.943342844159e-01
1338 KSP Residual norm 3.943342717655e-01
1339 KSP Residual norm 3.943342715718e-01
1340 KSP Residual norm 3.943342572137e-01
1341 KSP Residual norm 3.943342455547e-01
1342 KSP Residual norm 3.943342454312e-01
1343 KSP Residual norm 3.943342188924e-01
1344 KSP Residual norm 3.943341238583e-01
1345 KSP Residual norm 3.943340885746e-01
1346 KSP Residual norm 3.943340883261e-01
1347 KSP Residual norm 3.943340594624e-01
1348 KSP Residual norm 3.943340492740e-01
1349 KSP Residual norm 3.943340492002e-01
1350 KSP Residual norm 3.943340197419e-01
1351 KSP Residual norm 3.943340197393e-01
1352 KSP Residual norm 3.943340197270e-01
1353 KSP Residual norm 3.943340196348e-01
1354 KSP Residual norm 3.943340194971e-01
1355 KSP Residual norm 3.943340194904e-01
1356 KSP Residual norm 3.943340194315e-01
1357 KSP Residual norm 3.943340192312e-01
1358 KSP Residual norm 3.943340192306e-01
1359 KSP Residual norm 3.943340188010e-01
1360 KSP Residual norm 3.943340186852e-01
1361 KSP Residual norm 3.943340181917e-01
1362 KSP Residual norm 3.943340175092e-01
1363 KSP Residual norm 3.943340173533e-01
1364 KSP Residual norm 3.943340169659e-01
1365 KSP Residual norm 3.943340141611e-01
1366 KSP Residual norm 3.943340133614e-01
1367 KSP Residual norm 3.943340094971e-01
1368 KSP Residual norm 3.943339996111e-01
1369 KSP Residual norm 3.943339994505e-01
1370 KSP Residual norm 3.943339883781e-01
1371 KSP Residual norm 3.943339793271e-01
1372 KSP Residual norm 3.943339792348e-01
1373 KSP Residual norm 3.943339584980e-01
1374 KSP Residual norm 3.943338835001e-01
1375 KSP Residual norm 3.943338550770e-01
1376 KSP Residual norm 3.943338549176e-01
1377 KSP Residual norm 3.943338317588e-01
1378 KSP Residual norm 3.943338228967e-01
1379 KSP Residual norm 3.943338228966e-01
1380 KSP Residual norm 3.943338023423e-01
1381 KSP Residual norm 3.943338023405e-01
1382 KSP Residual norm 3.943338023317e-01
1383 KSP Residual norm 3.943338022678e-01
1384 KSP Residual norm 3.943338021778e-01
1385 KSP Residual norm 3.943338021753e-01
1386 KSP Residual norm 3.943338021250e-01
1387 KSP Residual norm 3.943338019728e-01
1388 KSP Residual norm 3.943338019728e-01
1389 KSP Residual norm 3.943338015998e-01
1390 KSP Residual norm 3.943338014973e-01
1391 KSP Residual norm 3.943338011199e-01
1392 KSP Residual norm 3.943338005905e-01
1393 KSP Residual norm 3.943338004663e-01
1394 KSP Residual norm 3.943338001645e-01
1395 KSP Residual norm 3.943337979542e-01
1396 KSP Residual norm 3.943337973164e-01
1397 KSP Residual norm 3.943337943777e-01
1398 KSP Residual norm 3.943337868243e-01
1399 KSP Residual norm 3.943337867079e-01
1400 KSP Residual norm 3.943337781477e-01
1401 KSP Residual norm 3.943337711914e-01
1402 KSP Residual norm 3.943337711179e-01
1403 KSP Residual norm 3.943337552685e-01
1404 KSP Residual norm 3.943336984544e-01
1405 KSP Residual norm 3.943336773196e-01
1406 KSP Residual norm 3.943336771728e-01
1407 KSP Residual norm 3.943336598734e-01
1408 KSP Residual norm 3.943336537114e-01
1409 KSP Residual norm 3.943336536763e-01
1410 KSP Residual norm 3.943336363009e-01
1411 KSP Residual norm 3.943336362993e-01
1412 KSP Residual norm 3.943336362921e-01
1413 KSP Residual norm 3.943336362378e-01
1414 KSP Residual norm 3.943336361572e-01
1415 KSP Residual norm 3.943336361535e-01
1416 KSP Residual norm 3.943336361180e-01
1417 KSP Residual norm 3.943336359988e-01
1418 KSP Residual norm 3.943336359985e-01
1419 KSP Residual norm 3.943336357388e-01
1420 KSP Residual norm 3.943336356687e-01
1421 KSP Residual norm 3.943336353749e-01
1422 KSP Residual norm 3.943336349680e-01
1423 KSP Residual norm 3.943336348747e-01
1424 KSP Residual norm 3.943336346436e-01
1425 KSP Residual norm 3.943336329680e-01
1426 KSP Residual norm 3.943336324896e-01
1427 KSP Residual norm 3.943336301901e-01
1428 KSP Residual norm 3.943336243055e-01
1429 KSP Residual norm 3.943336242106e-01
1430 KSP Residual norm 3.943336176095e-01
1431 KSP Residual norm 3.943336122176e-01
1432 KSP Residual norm 3.943336121624e-01
1433 KSP Residual norm 3.943335998160e-01
1434 KSP Residual norm 3.943335552172e-01
1435 KSP Residual norm 3.943335383598e-01
1436 KSP Residual norm 3.943335382618e-01
1437 KSP Residual norm 3.943335245080e-01
1438 KSP Residual norm 3.943335192935e-01
1439 KSP Residual norm 3.943335192927e-01
1440 KSP Residual norm 3.943335068901e-01
1441 KSP Residual norm 3.943335068890e-01
1442 KSP Residual norm 3.943335068837e-01
1443 KSP Residual norm 3.943335068452e-01
1444 KSP Residual norm 3.943335067905e-01
1445 KSP Residual norm 3.943335067889e-01
1446 KSP Residual norm 3.943335067592e-01
1447 KSP Residual norm 3.943335066684e-01
1448 KSP Residual norm 3.943335066684e-01
1449 KSP Residual norm 3.943335064489e-01
1450 KSP Residual norm 3.943335063887e-01
1451 KSP Residual norm 3.943335061636e-01
1452 KSP Residual norm 3.943335058484e-01
1453 KSP Residual norm 3.943335057746e-01
1454 KSP Residual norm 3.943335055950e-01
1455 KSP Residual norm 3.943335042811e-01
1456 KSP Residual norm 3.943335039025e-01
1457 KSP Residual norm 3.943335021483e-01
1458 KSP Residual norm 3.943334976426e-01
1459 KSP Residual norm 3.943334975728e-01
1460 KSP Residual norm 3.943334924725e-01
1461 KSP Residual norm 3.943334883254e-01
1462 KSP Residual norm 3.943334882818e-01
1463 KSP Residual norm 3.943334788263e-01
1464 KSP Residual norm 3.943334449040e-01
1465 KSP Residual norm 3.943334322644e-01
1466 KSP Residual norm 3.943334321778e-01
1467 KSP Residual norm 3.943334218295e-01
1468 KSP Residual norm 3.943334181170e-01
1469 KSP Residual norm 3.943334180998e-01
1470 KSP Residual norm 3.943334078354e-01
1471 KSP Residual norm 3.943334078345e-01
1472 KSP Residual norm 3.943334078302e-01
1473 KSP Residual norm 3.943334077982e-01
1474 KSP Residual norm 3.943334077509e-01
1475 KSP Residual norm 3.943334077488e-01
1476 KSP Residual norm 3.943334077274e-01
1477 KSP Residual norm 3.943334076565e-01
1478 KSP Residual norm 3.943334076564e-01
1479 KSP Residual norm 3.943334075000e-01
1480 KSP Residual norm 3.943334074577e-01
1481 KSP Residual norm 3.943334072828e-01
1482 KSP Residual norm 3.943334070403e-01
1483 KSP Residual norm 3.943334069846e-01
1484 KSP Residual norm 3.943334068468e-01
1485 KSP Residual norm 3.943334058468e-01
1486 KSP Residual norm 3.943334055610e-01
1487 KSP Residual norm 3.943334041930e-01
1488 KSP Residual norm 3.943334006909e-01
1489 KSP Residual norm 3.943334006347e-01
1490 KSP Residual norm 3.943333967016e-01
1491 KSP Residual norm 3.943333934908e-01
1492 KSP Residual norm 3.943333934578e-01
1493 KSP Residual norm 3.943333861090e-01
1494 KSP Residual norm 3.943333595875e-01
1495 KSP Residual norm 3.943333495827e-01
1496 KSP Residual norm 3.943333495229e-01
1497 KSP Residual norm 3.943333413528e-01
1498 KSP Residual norm 3.943333382771e-01
1499 KSP Residual norm 3.943333382760e-01
1500 KSP Residual norm 3.943333308189e-01
1501 KSP Residual norm 3.943333308182e-01
1502 KSP Residual norm 3.943333308151e-01
1503 KSP Residual norm 3.943333307919e-01
1504 KSP Residual norm 3.943333307588e-01
1505 KSP Residual norm 3.943333307578e-01
1506 KSP Residual norm 3.943333307403e-01
1507 KSP Residual norm 3.943333306861e-01
1508 KSP Residual norm 3.943333306861e-01
1509 KSP Residual norm 3.943333305567e-01
1510 KSP Residual norm 3.943333305212e-01
1511 KSP Residual norm 3.943333303870e-01
1512 KSP Residual norm 3.943333301994e-01
1513 KSP Residual norm 3.943333301555e-01
1514 KSP Residual norm 3.943333300486e-01
1515 KSP Residual norm 3.943333292674e-01
1516 KSP Residual norm 3.943333290426e-01
1517 KSP Residual norm 3.943333279963e-01
1518 KSP Residual norm 3.943333253103e-01
1519 KSP Residual norm 3.943333252686e-01
1520 KSP Residual norm 3.943333222309e-01
1521 KSP Residual norm 3.943333197598e-01
1522 KSP Residual norm 3.943333197339e-01
1523 KSP Residual norm 3.943333140968e-01
1524 KSP Residual norm 3.943332938600e-01
1525 KSP Residual norm 3.943332863098e-01
1526 KSP Residual norm 3.943332862587e-01
1527 KSP Residual norm 3.943332800767e-01
1528 KSP Residual norm 3.943332778465e-01
1529 KSP Residual norm 3.943332778378e-01
1530 KSP Residual norm 3.943332717656e-01
1531 KSP Residual norm 3.943332717651e-01
1532 KSP Residual norm 3.943332717625e-01
1533 KSP Residual norm 3.943332717436e-01
1534 KSP Residual norm 3.943332717158e-01
1535 KSP Residual norm 3.943332717146e-01
1536 KSP Residual norm 3.943332717018e-01
1537 KSP Residual norm 3.943332716596e-01
1538 KSP Residual norm 3.943332716595e-01
1539 KSP Residual norm 3.943332715656e-01
1540 KSP Residual norm 3.943332715401e-01
1541 KSP Residual norm 3.943332714361e-01
1542 KSP Residual norm 3.943332712916e-01
1543 KSP Residual norm 3.943332712584e-01
1544 KSP Residual norm 3.943332711763e-01
1545 KSP Residual norm 3.943332705798e-01
1546 KSP Residual norm 3.943332704093e-01
1547 KSP Residual norm 3.943332695954e-01
1548 KSP Residual norm 3.943332675113e-01
1549 KSP Residual norm 3.943332674780e-01
1550 KSP Residual norm 3.943332651354e-01
1551 KSP Residual norm 3.943332632238e-01
1552 KSP Residual norm 3.943332632041e-01
1553 KSP Residual norm 3.943332588306e-01
1554 KSP Residual norm 3.943332430574e-01
1555 KSP Residual norm 3.943332371161e-01
1556 KSP Residual norm 3.943332370799e-01
1557 KSP Residual norm 3.943332322252e-01
1558 KSP Residual norm 3.943332304074e-01
1559 KSP Residual norm 3.943332304063e-01
1560 KSP Residual norm 3.943332259340e-01
1561 KSP Residual norm 3.943332259336e-01
1562 KSP Residual norm 3.943332259317e-01
1563 KSP Residual norm 3.943332259178e-01
1564 KSP Residual norm 3.943332258979e-01
1565 KSP Residual norm 3.943332258973e-01
1566 KSP Residual norm 3.943332258869e-01
1567 KSP Residual norm 3.943332258546e-01
1568 KSP Residual norm 3.943332258546e-01
1569 KSP Residual norm 3.943332257781e-01
1570 KSP Residual norm 3.943332257572e-01
1571 KSP Residual norm 3.943332256772e-01
1572 KSP Residual norm 3.943332255655e-01
1573 KSP Residual norm 3.943332255395e-01
1574 KSP Residual norm 3.943332254759e-01
1575 KSP Residual norm 3.943332250113e-01
1576 KSP Residual norm 3.943332248777e-01
1577 KSP Residual norm 3.943332242540e-01
1578 KSP Residual norm 3.943332226535e-01
1579 KSP Residual norm 3.943332226285e-01
1580 KSP Residual norm 3.943332208198e-01
1581 KSP Residual norm 3.943332193478e-01
1582 KSP Residual norm 3.943332193324e-01
1583 KSP Residual norm 3.943332159733e-01
1584 KSP Residual norm 3.943332039079e-01
1585 KSP Residual norm 3.943331994016e-01
1586 KSP Residual norm 3.943331993714e-01
1587 KSP Residual norm 3.943331956819e-01
1588 KSP Residual norm 3.943331943450e-01
1589 KSP Residual norm 3.943331943406e-01
1590 KSP Residual norm 3.943331907439e-01
1591 KSP Residual norm 3.943331907436e-01
1592 KSP Residual norm 3.943331907421e-01
1593 KSP Residual norm 3.943331907309e-01
1594 KSP Residual norm 3.943331907144e-01
1595 KSP Residual norm 3.943331907138e-01
1596 KSP Residual norm 3.943331907061e-01
1597 KSP Residual norm 3.943331906810e-01
1598 KSP Residual norm 3.943331906810e-01
1599 KSP Residual norm 3.943331906247e-01
1600 KSP Residual norm 3.943331906094e-01
1601 KSP Residual norm 3.943331905475e-01
1602 KSP Residual norm 3.943331904614e-01
1603 KSP Residual norm 3.943331904416e-01
1604 KSP Residual norm 3.943331903927e-01
1605 KSP Residual norm 3.943331900372e-01
1606 KSP Residual norm 3.943331899354e-01
1607 KSP Residual norm 3.943331894512e-01
1608 KSP Residual norm 3.943331882110e-01
1609 KSP Residual norm 3.943331881912e-01
1610 KSP Residual norm 3.943331867962e-01
1611 KSP Residual norm 3.943331856583e-01
1612 KSP Residual norm 3.943331856465e-01
1613 KSP Residual norm 3.943331830438e-01
1614 KSP Residual norm 3.943331736618e-01
1615 KSP Residual norm 3.943331701318e-01
1616 KSP Residual norm 3.943331701100e-01
1617 KSP Residual norm 3.943331672244e-01
1618 KSP Residual norm 3.943331661484e-01
1619 KSP Residual norm 3.943331661475e-01
1620 KSP Residual norm 3.943331634707e-01
1621 KSP Residual norm 3.943331634704e-01
1622 KSP Residual norm 3.943331634693e-01
1623 KSP Residual norm 3.943331634610e-01
1624 KSP Residual norm 3.943331634490e-01
1625 KSP Residual norm 3.943331634486e-01
1626 KSP Residual norm 3.943331634425e-01
1627 KSP Residual norm 3.943331634232e-01
1628 KSP Residual norm 3.943331634232e-01
1629 KSP Residual norm 3.943331633780e-01
1630 KSP Residual norm 3.943331633656e-01
1631 KSP Residual norm 3.943331633180e-01
1632 KSP Residual norm 3.943331632515e-01
1633 KSP Residual norm 3.943331632360e-01
1634 KSP Residual norm 3.943331631981e-01
1635 KSP Residual norm 3.943331629218e-01
1636 KSP Residual norm 3.943331628424e-01
1637 KSP Residual norm 3.943331624707e-01
1638 KSP Residual norm 3.943331615173e-01
1639 KSP Residual norm 3.943331615024e-01
1640 KSP Residual norm 3.943331604255e-01
1641 KSP Residual norm 3.943331595489e-01
1642 KSP Residual norm 3.943331595398e-01
1643 KSP Residual norm 3.943331575387e-01
1644 KSP Residual norm 3.943331503481e-01
1645 KSP Residual norm 3.943331476604e-01
1646 KSP Residual norm 3.943331476425e-01
1647 KSP Residual norm 3.943331454420e-01
1648 KSP Residual norm 3.943331446419e-01
1649 KSP Residual norm 3.943331446396e-01
1650 KSP Residual norm 3.943331425071e-01
1651 KSP Residual norm 3.943331425069e-01
1652 KSP Residual norm 3.943331425060e-01
1653 KSP Residual norm 3.943331424993e-01
1654 KSP Residual norm 3.943331424896e-01
1655 KSP Residual norm 3.943331424892e-01
1656 KSP Residual norm 3.943331424846e-01
1657 KSP Residual norm 3.943331424697e-01
1658 KSP Residual norm 3.943331424697e-01
1659 KSP Residual norm 3.943331424360e-01
1660 KSP Residual norm 3.943331424269e-01
1661 KSP Residual norm 3.943331423900e-01
1662 KSP Residual norm 3.943331423388e-01
1663 KSP Residual norm 3.943331423269e-01
1664 KSP Residual norm 3.943331422978e-01
1665 KSP Residual norm 3.943331420860e-01
1666 KSP Residual norm 3.943331420253e-01
1667 KSP Residual norm 3.943331417372e-01
1668 KSP Residual norm 3.943331409991e-01
1669 KSP Residual norm 3.943331409874e-01
1670 KSP Residual norm 3.943331401568e-01
1671 KSP Residual norm 3.943331394794e-01
1672 KSP Residual norm 3.943331394724e-01
1673 KSP Residual norm 3.943331379235e-01
1674 KSP Residual norm 3.943331323422e-01
1675 KSP Residual norm 3.943331302441e-01
1676 KSP Residual norm 3.943331302310e-01
1677 KSP Residual norm 3.943331285153e-01
1678 KSP Residual norm 3.943331278776e-01
1679 KSP Residual norm 3.943331278770e-01
1680 KSP Residual norm 3.943331262767e-01
1681 KSP Residual norm 3.943331262766e-01
1682 KSP Residual norm 3.943331262759e-01
1683 KSP Residual norm 3.943331262709e-01
1684 KSP Residual norm 3.943331262638e-01
1685 KSP Residual norm 3.943331262635e-01
1686 KSP Residual norm 3.943331262599e-01
1687 KSP Residual norm 3.943331262484e-01
1688 KSP Residual norm 3.943331262484e-01
1689 KSP Residual norm 3.943331262216e-01
1690 KSP Residual norm 3.943331262142e-01
1691 KSP Residual norm 3.943331261859e-01
1692 KSP Residual norm 3.943331261463e-01
1693 KSP Residual norm 3.943331261371e-01
1694 KSP Residual norm 3.943331261145e-01
1695 KSP Residual norm 3.943331259502e-01
1696 KSP Residual norm 3.943331259030e-01
1697 KSP Residual norm 3.943331256816e-01
1698 KSP Residual norm 3.943331251137e-01
1699 KSP Residual norm 3.943331251048e-01
1700 KSP Residual norm 3.943331244637e-01
1701 KSP Residual norm 3.943331239417e-01
1702 KSP Residual norm 3.943331239363e-01
1703 KSP Residual norm 3.943331227444e-01
1704 KSP Residual norm 3.943331184604e-01
1705 KSP Residual norm 3.943331168581e-01
1706 KSP Residual norm 3.943331168475e-01
1707 KSP Residual norm 3.943331155357e-01
1708 KSP Residual norm 3.943331150575e-01
1709 KSP Residual norm 3.943331150562e-01
1710 KSP Residual norm 3.943331137907e-01
1711 KSP Residual norm 3.943331137906e-01
1712 KSP Residual norm 3.943331137901e-01
1713 KSP Residual norm 3.943331137861e-01
1714 KSP Residual norm 3.943331137804e-01
1715 KSP Residual norm 3.943331137802e-01
1716 KSP Residual norm 3.943331137774e-01
1717 KSP Residual norm 3.943331137685e-01
1718 KSP Residual norm 3.943331137685e-01
1719 KSP Residual norm 3.943331137484e-01
1720 KSP Residual norm 3.943331137429e-01
1721 KSP Residual norm 3.943331137210e-01
1722 KSP Residual norm 3.943331136905e-01
1723 KSP Residual norm 3.943331136834e-01
1724 KSP Residual norm 3.943331136661e-01
1725 KSP Residual norm 3.943331135399e-01
1726 KSP Residual norm 3.943331135037e-01
1727 KSP Residual norm 3.943331133323e-01
1728 KSP Residual norm 3.943331128930e-01
1729 KSP Residual norm 3.943331128861e-01
1730 KSP Residual norm 3.943331123916e-01
1731 KSP Residual norm 3.943331119884e-01
1732 KSP Residual norm 3.943331119842e-01
1733 KSP Residual norm 3.943331110623e-01
1734 KSP Residual norm 3.943331077417e-01
1735 KSP Residual norm 3.943331064942e-01
1736 KSP Residual norm 3.943331064864e-01
1737 KSP Residual norm 3.943331054661e-01
1738 KSP Residual norm 3.943331050877e-01
1739 KSP Residual norm 3.943331050873e-01
1740 KSP Residual norm 3.943331041317e-01
1741 KSP Residual norm 3.943331041316e-01
1742 KSP Residual norm 3.943331041312e-01
1743 KSP Residual norm 3.943331041283e-01
1744 KSP Residual norm 3.943331041240e-01
1745 KSP Residual norm 3.943331041238e-01
1746 KSP Residual norm 3.943331041217e-01
1747 KSP Residual norm 3.943331041148e-01
1748 KSP Residual norm 3.943331041148e-01
1749 KSP Residual norm 3.943331040989e-01
1750 KSP Residual norm 3.943331040946e-01
1751 KSP Residual norm 3.943331040777e-01
1752 KSP Residual norm 3.943331040541e-01
1753 KSP Residual norm 3.943331040486e-01
1754 KSP Residual norm 3.943331040352e-01
1755 KSP Residual norm 3.943331039374e-01
1756 KSP Residual norm 3.943331039094e-01
1757 KSP Residual norm 3.943331037775e-01
1758 KSP Residual norm 3.943331034393e-01
1759 KSP Residual norm 3.943331034340e-01
1760 KSP Residual norm 3.943331030524e-01
1761 KSP Residual norm 3.943331027416e-01
1762 KSP Residual norm 3.943331027384e-01
1763 KSP Residual norm 3.943331020286e-01
1764 KSP Residual norm 3.943330994768e-01
1765 KSP Residual norm 3.943330985219e-01
1766 KSP Residual norm 3.943330985156e-01
1767 KSP Residual norm 3.943330977339e-01
1768 KSP Residual norm 3.943330974483e-01
1769 KSP Residual norm 3.943330974476e-01
1770 KSP Residual norm 3.943330966962e-01
1771 KSP Residual norm 3.943330966961e-01
1772 KSP Residual norm 3.943330966958e-01
1773 KSP Residual norm 3.943330966935e-01
1774 KSP Residual norm 3.943330966900e-01
1775 KSP Residual norm 3.943330966899e-01
1776 KSP Residual norm 3.943330966883e-01
1777 KSP Residual norm 3.943330966830e-01
1778 KSP Residual norm 3.943330966830e-01
1779 KSP Residual norm 3.943330966710e-01
1780 KSP Residual norm 3.943330966677e-01
1781 KSP Residual norm 3.943330966546e-01
1782 KSP Residual norm 3.943330966365e-01
1783 KSP Residual norm 3.943330966323e-01
1784 KSP Residual norm 3.943330966220e-01
1785 KSP Residual norm 3.943330965468e-01
1786 KSP Residual norm 3.943330965252e-01
1787 KSP Residual norm 3.943330964232e-01
1788 KSP Residual norm 3.943330961618e-01
1789 KSP Residual norm 3.943330961577e-01
1790 KSP Residual norm 3.943330958633e-01
1791 KSP Residual norm 3.943330956233e-01
1792 KSP Residual norm 3.943330956208e-01
1793 KSP Residual norm 3.943330950721e-01
1794 KSP Residual norm 3.943330930963e-01
1795 KSP Residual norm 3.943330923543e-01
1796 KSP Residual norm 3.943330923497e-01
1797 KSP Residual norm 3.943330917428e-01
1798 KSP Residual norm 3.943330915181e-01
1799 KSP Residual norm 3.943330915178e-01
1800 KSP Residual norm 3.943330909476e-01
1801 KSP Residual norm 3.943330909476e-01
1802 KSP Residual norm 3.943330909473e-01
1803 KSP Residual norm 3.943330909456e-01
1804 KSP Residual norm 3.943330909430e-01
1805 KSP Residual norm 3.943330909429e-01
1806 KSP Residual norm 3.943330909416e-01
1807 KSP Residual norm 3.943330909376e-01
1808 KSP Residual norm 3.943330909376e-01
1809 KSP Residual norm 3.943330909281e-01
1810 KSP Residual norm 3.943330909255e-01
1811 KSP Residual norm 3.943330909155e-01
1812 KSP Residual norm 3.943330909014e-01
1813 KSP Residual norm 3.943330908982e-01
1814 KSP Residual norm 3.943330908902e-01
1815 KSP Residual norm 3.943330908320e-01
1816 KSP Residual norm 3.943330908153e-01
1817 KSP Residual norm 3.943330907368e-01
1818 KSP Residual norm 3.943330905354e-01
1819 KSP Residual norm 3.943330905323e-01
1820 KSP Residual norm 3.943330903051e-01
1821 KSP Residual norm 3.943330901200e-01
1822 KSP Residual norm 3.943330901181e-01
1823 KSP Residual norm 3.943330896955e-01
1824 KSP Residual norm 3.943330881757e-01
1825 KSP Residual norm 3.943330876068e-01
1826 KSP Residual norm 3.943330876031e-01
1827 KSP Residual norm 3.943330871373e-01
1828 KSP Residual norm 3.943330869669e-01
1829 KSP Residual norm 3.943330869666e-01
1830 KSP Residual norm 3.943330865203e-01
1831 KSP Residual norm 3.943330865202e-01
1832 KSP Residual norm 3.943330865201e-01
1833 KSP Residual norm 3.943330865187e-01
1834 KSP Residual norm 3.943330865166e-01
1835 KSP Residual norm 3.943330865166e-01
1836 KSP Residual norm 3.943330865156e-01
1837 KSP Residual norm 3.943330865124e-01
1838 KSP Residual norm 3.943330865124e-01
1839 KSP Residual norm 3.943330865053e-01
1840 KSP Residual norm 3.943330865033e-01
1841 KSP Residual norm 3.943330864956e-01
1842 KSP Residual norm 3.943330864847e-01
1843 KSP Residual norm 3.943330864822e-01
1844 KSP Residual norm 3.943330864761e-01
1845 KSP Residual norm 3.943330864313e-01
1846 KSP Residual norm 3.943330864185e-01
1847 KSP Residual norm 3.943330863578e-01
1848 KSP Residual norm 3.943330862022e-01
1849 KSP Residual norm 3.943330861997e-01
1850 KSP Residual norm 3.943330860245e-01
1851 KSP Residual norm 3.943330858816e-01
1852 KSP Residual norm 3.943330858801e-01
1853 KSP Residual norm 3.943330855536e-01
1854 KSP Residual norm 3.943330843778e-01
1855 KSP Residual norm 3.943330839365e-01
1856 KSP Residual norm 3.943330839337e-01
1857 KSP Residual norm 3.943330835726e-01
1858 KSP Residual norm 3.943330834392e-01
1859 KSP Residual norm 3.943330834390e-01
1860 KSP Residual norm 3.943330830987e-01
1861 KSP Residual norm 3.943330830987e-01
1862 KSP Residual norm 3.943330830986e-01
1863 KSP Residual norm 3.943330830975e-01
1864 KSP Residual norm 3.943330830960e-01
1865 KSP Residual norm 3.943330830959e-01
1866 KSP Residual norm 3.943330830952e-01
1867 KSP Residual norm 3.943330830927e-01
1868 KSP Residual norm 3.943330830927e-01
1869 KSP Residual norm 3.943330830871e-01
1870 KSP Residual norm 3.943330830856e-01
1871 KSP Residual norm 3.943330830796e-01
1872 KSP Residual norm 3.943330830713e-01
1873 KSP Residual norm 3.943330830693e-01
1874 KSP Residual norm 3.943330830646e-01
1875 KSP Residual norm 3.943330830299e-01
1876 KSP Residual norm 3.943330830200e-01
1877 KSP Residual norm 3.943330829732e-01
1878 KSP Residual norm 3.943330828534e-01
1879 KSP Residual norm 3.943330828515e-01
1880 KSP Residual norm 3.943330827162e-01
1881 KSP Residual norm 3.943330826061e-01
1882 KSP Residual norm 3.943330826049e-01
1883 KSP Residual norm 3.943330823533e-01
1884 KSP Residual norm 3.943330814483e-01
1885 KSP Residual norm 3.943330811094e-01
1886 KSP Residual norm 3.943330811072e-01
1887 KSP Residual norm 3.943330808298e-01
1888 KSP Residual norm 3.943330807281e-01
1889 KSP Residual norm 3.943330807279e-01
1890 KSP Residual norm 3.943330804628e-01
1891 KSP Residual norm 3.943330804628e-01
1892 KSP Residual norm 3.943330804627e-01
1893 KSP Residual norm 3.943330804619e-01
1894 KSP Residual norm 3.943330804607e-01
1895 KSP Residual norm 3.943330804606e-01
1896 KSP Residual norm 3.943330804600e-01
1897 KSP Residual norm 3.943330804582e-01
1898 KSP Residual norm 3.943330804582e-01
1899 KSP Residual norm 3.943330804539e-01
1900 KSP Residual norm 3.943330804527e-01
1901 KSP Residual norm 3.943330804481e-01
1902 KSP Residual norm 3.943330804417e-01
1903 KSP Residual norm 3.943330804402e-01
1904 KSP Residual norm 3.943330804365e-01
1905 KSP Residual norm 3.943330804099e-01
1906 KSP Residual norm 3.943330804022e-01
1907 KSP Residual norm 3.943330803661e-01
1908 KSP Residual norm 3.943330802735e-01
1909 KSP Residual norm 3.943330802720e-01
1910 KSP Residual norm 3.943330801677e-01
1911 KSP Residual norm 3.943330800826e-01
1912 KSP Residual norm 3.943330800818e-01
1913 KSP Residual norm 3.943330798874e-01
1914 KSP Residual norm 3.943330791877e-01
1915 KSP Residual norm 3.943330789251e-01
1916 KSP Residual norm 3.943330789234e-01
1917 KSP Residual norm 3.943330787086e-01
1918 KSP Residual norm 3.943330786293e-01
1919 KSP Residual norm 3.943330786292e-01
1920 KSP Residual norm 3.943330784262e-01
1921 KSP Residual norm 3.943330784262e-01
1922 KSP Residual norm 3.943330784261e-01
1923 KSP Residual norm 3.943330784255e-01
1924 KSP Residual norm 3.943330784246e-01
1925 KSP Residual norm 3.943330784246e-01
1926 KSP Residual norm 3.943330784241e-01
1927 KSP Residual norm 3.943330784227e-01
1928 KSP Residual norm 3.943330784227e-01
1929 KSP Residual norm 3.943330784193e-01
1930 KSP Residual norm 3.943330784184e-01
1931 KSP Residual norm 3.943330784148e-01
1932 KSP Residual norm 3.943330784099e-01
1933 KSP Residual norm 3.943330784087e-01
1934 KSP Residual norm 3.943330784059e-01
1935 KSP Residual norm 3.943330783853e-01
1936 KSP Residual norm 3.943330783794e-01
1937 KSP Residual norm 3.943330783515e-01
1938 KSP Residual norm 3.943330782802e-01
1939 KSP Residual norm 3.943330782790e-01
1940 KSP Residual norm 3.943330781985e-01
1941 KSP Residual norm 3.943330781329e-01
1942 KSP Residual norm 3.943330781323e-01
1943 KSP Residual norm 3.943330779824e-01
1944 KSP Residual norm 3.943330774436e-01
1945 KSP Residual norm 3.943330772417e-01
1946 KSP Residual norm 3.943330772404e-01
1947 KSP Residual norm 3.943330770752e-01
1948 KSP Residual norm 3.943330770146e-01
1949 KSP Residual norm 3.943330770145e-01
1950 KSP Residual norm 3.943330768567e-01
1951 KSP Residual norm 3.943330768567e-01
1952 KSP Residual norm 3.943330768567e-01
1953 KSP Residual norm 3.943330768562e-01
1954 KSP Residual norm 3.943330768555e-01
1955 KSP Residual norm 3.943330768554e-01
1956 KSP Residual norm 3.943330768551e-01
1957 KSP Residual norm 3.943330768540e-01
1958 KSP Residual norm 3.943330768540e-01
1959 KSP Residual norm 3.943330768514e-01
1960 KSP Residual norm 3.943330768507e-01
1961 KSP Residual norm 3.943330768480e-01
1962 KSP Residual norm 3.943330768441e-01
1963 KSP Residual norm 3.943330768433e-01
1964 KSP Residual norm 3.943330768411e-01
1965 KSP Residual norm 3.943330768252e-01
1966 KSP Residual norm 3.943330768206e-01
1967 KSP Residual norm 3.943330767991e-01
1968 KSP Residual norm 3.943330767440e-01
1969 KSP Residual norm 3.943330767431e-01
1970 KSP Residual norm 3.943330766810e-01
1971 KSP Residual norm 3.943330766304e-01
1972 KSP Residual norm 3.943330766299e-01
1973 KSP Residual norm 3.943330765142e-01
1974 KSP Residual norm 3.943330760978e-01
1975 KSP Residual norm 3.943330759415e-01
1976 KSP Residual norm 3.943330759405e-01
1977 KSP Residual norm 3.943330758127e-01
1978 KSP Residual norm 3.943330757655e-01
1979 KSP Residual norm 3.943330757655e-01
1980 KSP Residual norm 3.943330756446e-01
1981 KSP Residual norm 3.943330756446e-01
1982 KSP Residual norm 3.943330756446e-01
1983 KSP Residual norm 3.943330756442e-01
1984 KSP Residual norm 3.943330756436e-01
1985 KSP Residual norm 3.943330756436e-01
1986 KSP Residual norm 3.943330756433e-01
1987 KSP Residual norm 3.943330756425e-01
1988 KSP Residual norm 3.943330756425e-01
1989 KSP Residual norm 3.943330756405e-01
1990 KSP Residual norm 3.943330756400e-01
1991 KSP Residual norm 3.943330756378e-01
1992 KSP Residual norm 3.943330756349e-01
1993 KSP Residual norm 3.943330756342e-01
1994 KSP Residual norm 3.943330756325e-01
1995 KSP Residual norm 3.943330756202e-01
1996 KSP Residual norm 3.943330756167e-01
1997 KSP Residual norm 3.943330756002e-01
1998 KSP Residual norm 3.943330755577e-01
1999 KSP Residual norm 3.943330755570e-01
2000 KSP Residual norm 3.943330755091e-01
2001 KSP Residual norm 3.943330754700e-01
2002 KSP Residual norm 3.943330754696e-01
2003 KSP Residual norm 3.943330753804e-01
2004 KSP Residual norm 3.943330750596e-01
2005 KSP Residual norm 3.943330749394e-01
2006 KSP Residual norm 3.943330749386e-01
2007 KSP Residual norm 3.943330748402e-01
2008 KSP Residual norm 3.943330748041e-01
2009 KSP Residual norm 3.943330748040e-01
2010 KSP Residual norm 3.943330747100e-01
2011 KSP Residual norm 3.943330747100e-01
2012 KSP Residual norm 3.943330747099e-01
2013 KSP Residual norm 3.943330747097e-01
2014 KSP Residual norm 3.943330747092e-01
2015 KSP Residual norm 3.943330747092e-01
2016 KSP Residual norm 3.943330747090e-01
2017 KSP Residual norm 3.943330747083e-01
2018 KSP Residual norm 3.943330747083e-01
2019 KSP Residual norm 3.943330747068e-01
2020 KSP Residual norm 3.943330747064e-01
2021 KSP Residual norm 3.943330747048e-01
2022 KSP Residual norm 3.943330747025e-01
2023 KSP Residual norm 3.943330747020e-01
2024 KSP Residual norm 3.943330747007e-01
2025 KSP Residual norm 3.943330746912e-01
2026 KSP Residual norm 3.943330746885e-01
2027 KSP Residual norm 3.943330746757e-01
2028 KSP Residual norm 3.943330746429e-01
2029 KSP Residual norm 3.943330746424e-01
2030 KSP Residual norm 3.943330746054e-01
2031 KSP Residual norm 3.943330745753e-01
2032 KSP Residual norm 3.943330745750e-01
2033 KSP Residual norm 3.943330745061e-01
2034 KSP Residual norm 3.943330742582e-01
2035 KSP Residual norm 3.943330741653e-01
2036 KSP Residual norm 3.943330741647e-01
2037 KSP Residual norm 3.943330740886e-01
2038 KSP Residual norm 3.943330740606e-01
2039 KSP Residual norm 3.943330740605e-01
2040 KSP Residual norm 3.943330739887e-01
2041 KSP Residual norm 3.943330739887e-01
2042 KSP Residual norm 3.943330739887e-01
2043 KSP Residual norm 3.943330739885e-01
2044 KSP Residual norm 3.943330739881e-01
2045 KSP Residual norm 3.943330739881e-01
2046 KSP Residual norm 3.943330739880e-01
2047 KSP Residual norm 3.943330739874e-01
2048 KSP Residual norm 3.943330739874e-01
2049 KSP Residual norm 3.943330739863e-01
2050 KSP Residual norm 3.943330739859e-01
2051 KSP Residual norm 3.943330739847e-01
2052 KSP Residual norm 3.943330739829e-01
2053 KSP Residual norm 3.943330739825e-01
2054 KSP Residual norm 3.943330739815e-01
2055 KSP Residual norm 3.943330739742e-01
2056 KSP Residual norm 3.943330739721e-01
2057 KSP Residual norm 3.943330739622e-01
2058 KSP Residual norm 3.943330739369e-01
2059 KSP Residual norm 3.943330739366e-01
2060 KSP Residual norm 3.943330739080e-01
2061 KSP Residual norm 3.943330738848e-01
2062 KSP Residual norm 3.943330738845e-01
2063 KSP Residual norm 3.943330738314e-01
2064 KSP Residual norm 3.943330736404e-01
2065 KSP Residual norm 3.943330735688e-01
2066 KSP Residual norm 3.943330735684e-01
2067 KSP Residual norm 3.943330735098e-01
2068 KSP Residual norm 3.943330734883e-01
2069 KSP Residual norm 3.943330734882e-01
2070 KSP Residual norm 3.943330734324e-01
2071 KSP Residual norm 3.943330734324e-01
2072 KSP Residual norm 3.943330734324e-01
2073 KSP Residual norm 3.943330734322e-01
2074 KSP Residual norm 3.943330734320e-01
2075 KSP Residual norm 3.943330734320e-01
2076 KSP Residual norm 3.943330734319e-01
2077 KSP Residual norm 3.943330734315e-01
2078 KSP Residual norm 3.943330734315e-01
2079 KSP Residual norm 3.943330734306e-01
2080 KSP Residual norm 3.943330734303e-01
2081 KSP Residual norm 3.943330734293e-01
2082 KSP Residual norm 3.943330734280e-01
2083 KSP Residual norm 3.943330734277e-01
2084 KSP Residual norm 3.943330734269e-01
2085 KSP Residual norm 3.943330734213e-01
2086 KSP Residual norm 3.943330734196e-01
2087 KSP Residual norm 3.943330734120e-01
2088 KSP Residual norm 3.943330733925e-01
2089 KSP Residual norm 3.943330733922e-01
2090 KSP Residual norm 3.943330733702e-01
2091 KSP Residual norm 3.943330733522e-01
2092 KSP Residual norm 3.943330733521e-01
2093 KSP Residual norm 3.943330733111e-01
2094 KSP Residual norm 3.943330731635e-01
2095 KSP Residual norm 3.943330731082e-01
2096 KSP Residual norm 3.943330731079e-01
2097 KSP Residual norm 3.943330730626e-01
2098 KSP Residual norm 3.943330730459e-01
2099 KSP Residual norm 3.943330730459e-01
2100 KSP Residual norm 3.943330730030e-01
2101 KSP Residual norm 3.943330730030e-01
2102 KSP Residual norm 3.943330730030e-01
2103 KSP Residual norm 3.943330730029e-01
2104 KSP Residual norm 3.943330730027e-01
2105 KSP Residual norm 3.943330730027e-01
2106 KSP Residual norm 3.943330730026e-01
2107 KSP Residual norm 3.943330730023e-01
2108 KSP Residual norm 3.943330730023e-01
2109 KSP Residual norm 3.943330730016e-01
2110 KSP Residual norm 3.943330730014e-01
2111 KSP Residual norm 3.943330730006e-01
2112 KSP Residual norm 3.943330729996e-01
2113 KSP Residual norm 3.943330729993e-01
2114 KSP Residual norm 3.943330729987e-01
2115 KSP Residual norm 3.943330729944e-01
2116 KSP Residual norm 3.943330729932e-01
2117 KSP Residual norm 3.943330729873e-01
2118 KSP Residual norm 3.943330729722e-01
2119 KSP Residual norm 3.943330729720e-01
2120 KSP Residual norm 3.943330729550e-01
2121 KSP Residual norm 3.943330729412e-01
2122 KSP Residual norm 3.943330729410e-01
2123 KSP Residual norm 3.943330729094e-01
2124 KSP Residual norm 3.943330727957e-01
2125 KSP Residual norm 3.943330727531e-01
2126 KSP Residual norm 3.943330727528e-01
2127 KSP Residual norm 3.943330727179e-01
2128 KSP Residual norm 3.943330727051e-01
2129 KSP Residual norm 3.943330727051e-01
2130 KSP Residual norm 3.943330726717e-01
2131 KSP Residual norm 3.943330726717e-01
2132 KSP Residual norm 3.943330726717e-01
2133 KSP Residual norm 3.943330726716e-01
2134 KSP Residual norm 3.943330726714e-01
2135 KSP Residual norm 3.943330726714e-01
2136 KSP Residual norm 3.943330726713e-01
2137 KSP Residual norm 3.943330726711e-01
2138 KSP Residual norm 3.943330726711e-01
2139 KSP Residual norm 3.943330726705e-01
2140 KSP Residual norm 3.943330726704e-01
2141 KSP Residual norm 3.943330726698e-01
2142 KSP Residual norm 3.943330726690e-01
2143 KSP Residual norm 3.943330726688e-01
2144 KSP Residual norm 3.943330726684e-01
2145 KSP Residual norm 3.943330726650e-01
2146 KSP Residual norm 3.943330726641e-01
2147 KSP Residual norm 3.943330726595e-01
2148 KSP Residual norm 3.943330726479e-01
2149 KSP Residual norm 3.943330726477e-01
2150 KSP Residual norm 3.943330726346e-01
2151 KSP Residual norm 3.943330726239e-01
2152 KSP Residual norm 3.943330726238e-01
2153 KSP Residual norm 3.943330725994e-01
2154 KSP Residual norm 3.943330725116e-01
2155 KSP Residual norm 3.943330724787e-01
2156 KSP Residual norm 3.943330724785e-01
2157 KSP Residual norm 3.943330724515e-01
2158 KSP Residual norm 3.943330724416e-01
2159 KSP Residual norm 3.943330724416e-01
2160 KSP Residual norm 3.943330724162e-01
2161 KSP Residual norm 3.943330724161e-01
2162 KSP Residual norm 3.943330724161e-01
2163 KSP Residual norm 3.943330724161e-01
2164 KSP Residual norm 3.943330724159e-01
2165 KSP Residual norm 3.943330724159e-01
2166 KSP Residual norm 3.943330724159e-01
2167 KSP Residual norm 3.943330724157e-01
2168 KSP Residual norm 3.943330724157e-01
2169 KSP Residual norm 3.943330724153e-01
2170 KSP Residual norm 3.943330724152e-01
2171 KSP Residual norm 3.943330724147e-01
2172 KSP Residual norm 3.943330724141e-01
2173 KSP Residual norm 3.943330724140e-01
2174 KSP Residual norm 3.943330724136e-01
2175 KSP Residual norm 3.943330724110e-01
2176 KSP Residual norm 3.943330724103e-01
2177 KSP Residual norm 3.943330724068e-01
2178 KSP Residual norm 3.943330723978e-01
2179 KSP Residual norm 3.943330723977e-01
2180 KSP Residual norm 3.943330723876e-01
2181 KSP Residual norm 3.943330723793e-01
2182 KSP Residual norm 3.943330723792e-01
2183 KSP Residual norm 3.943330723604e-01
2184 KSP Residual norm 3.943330722927e-01
2185 KSP Residual norm 3.943330722673e-01
2186 KSP Residual norm 3.943330722672e-01
2187 KSP Residual norm 3.943330722464e-01
2188 KSP Residual norm 3.943330722388e-01
2189 KSP Residual norm 3.943330722388e-01
2190 KSP Residual norm 3.943330722189e-01
2191 KSP Residual norm 3.943330722189e-01
2192 KSP Residual norm 3.943330722189e-01
2193 KSP Residual norm 3.943330722188e-01
2194 KSP Residual norm 3.943330722187e-01
2195 KSP Residual norm 3.943330722187e-01
2196 KSP Residual norm 3.943330722187e-01
2197 KSP Residual norm 3.943330722185e-01
2198 KSP Residual norm 3.943330722185e-01
2199 KSP Residual norm 3.943330722182e-01
2200 KSP Residual norm 3.943330722181e-01
2201 KSP Residual norm 3.943330722178e-01
2202 KSP Residual norm 3.943330722173e-01
2203 KSP Residual norm 3.943330722172e-01
2204 KSP Residual norm 3.943330722169e-01
2205 KSP Residual norm 3.943330722149e-01
2206 KSP Residual norm 3.943330722143e-01
2207 KSP Residual norm 3.943330722116e-01
2208 KSP Residual norm 3.943330722047e-01
2209 KSP Residual norm 3.943330722046e-01
2210 KSP Residual norm 3.943330721968e-01
2211 KSP Residual norm 3.943330721904e-01
2212 KSP Residual norm 3.943330721904e-01
2213 KSP Residual norm 3.943330721759e-01
2214 KSP Residual norm 3.943330721236e-01
2215 KSP Residual norm 3.943330721040e-01
2216 KSP Residual norm 3.943330721039e-01
2217 KSP Residual norm 3.943330720878e-01
2218 KSP Residual norm 3.943330720819e-01
2219 KSP Residual norm 3.943330720819e-01
2220 KSP Residual norm 3.943330720668e-01
2221 KSP Residual norm 3.943330720668e-01
2222 KSP Residual norm 3.943330720668e-01
2223 KSP Residual norm 3.943330720668e-01
2224 KSP Residual norm 3.943330720667e-01
2225 KSP Residual norm 3.943330720667e-01
2226 KSP Residual norm 3.943330720667e-01
2227 KSP Residual norm 3.943330720666e-01
2228 KSP Residual norm 3.943330720666e-01
2229 KSP Residual norm 3.943330720663e-01
2230 KSP Residual norm 3.943330720663e-01
2231 KSP Residual norm 3.943330720660e-01
2232 KSP Residual norm 3.943330720656e-01
2233 KSP Residual norm 3.943330720655e-01
2234 KSP Residual norm 3.943330720653e-01
2235 KSP Residual norm 3.943330720638e-01
2236 KSP Residual norm 3.943330720633e-01
2237 KSP Residual norm 3.943330720613e-01
2238 KSP Residual norm 3.943330720559e-01
2239 KSP Residual norm 3.943330720558e-01
2240 KSP Residual norm 3.943330720498e-01
2241 KSP Residual norm 3.943330720449e-01
2242 KSP Residual norm 3.943330720449e-01
2243 KSP Residual norm 3.943330720337e-01
2244 KSP Residual norm 3.943330719934e-01
2245 KSP Residual norm 3.943330719782e-01
2246 KSP Residual norm 3.943330719782e-01
2247 KSP Residual norm 3.943330719658e-01
2248 KSP Residual norm 3.943330719612e-01
2249 KSP Residual norm 3.943330719612e-01
2250 KSP Residual norm 3.943330719495e-01
2251 KSP Residual norm 3.943330719495e-01
2252 KSP Residual norm 3.943330719495e-01
2253 KSP Residual norm 3.943330719494e-01
2254 KSP Residual norm 3.943330719494e-01
2255 KSP Residual norm 3.943330719494e-01
2256 KSP Residual norm 3.943330719493e-01
2257 KSP Residual norm 3.943330719493e-01
2258 KSP Residual norm 3.943330719493e-01
2259 KSP Residual norm 3.943330719491e-01
2260 KSP Residual norm 3.943330719490e-01
2261 KSP Residual norm 3.943330719488e-01
2262 KSP Residual norm 3.943330719485e-01
2263 KSP Residual norm 3.943330719484e-01
2264 KSP Residual norm 3.943330719483e-01
2265 KSP Residual norm 3.943330719471e-01
2266 KSP Residual norm 3.943330719468e-01
2267 KSP Residual norm 3.943330719452e-01
2268 KSP Residual norm 3.943330719410e-01
2269 KSP Residual norm 3.943330719410e-01
2270 KSP Residual norm 3.943330719363e-01
2271 KSP Residual norm 3.943330719325e-01
2272 KSP Residual norm 3.943330719325e-01
2273 KSP Residual norm 3.943330719239e-01
2274 KSP Residual norm 3.943330718927e-01
2275 KSP Residual norm 3.943330718811e-01
2276 KSP Residual norm 3.943330718810e-01
2277 KSP Residual norm 3.943330718715e-01
2278 KSP Residual norm 3.943330718679e-01
2279 KSP Residual norm 3.943330718679e-01
2280 KSP Residual norm 3.943330718588e-01
2281 KSP Residual norm 3.943330718588e-01
2282 KSP Residual norm 3.943330718588e-01
2283 KSP Residual norm 3.943330718588e-01
2284 KSP Residual norm 3.943330718588e-01
2285 KSP Residual norm 3.943330718588e-01
2286 KSP Residual norm 3.943330718588e-01
2287 KSP Residual norm 3.943330718587e-01
2288 KSP Residual norm 3.943330718587e-01
2289 KSP Residual norm 3.943330718585e-01
2290 KSP Residual norm 3.943330718585e-01
2291 KSP Residual norm 3.943330718583e-01
2292 KSP Residual norm 3.943330718581e-01
2293 KSP Residual norm 3.943330718581e-01
2294 KSP Residual norm 3.943330718579e-01
2295 KSP Residual norm 3.943330718570e-01
2296 KSP Residual norm 3.943330718568e-01
2297 KSP Residual norm 3.943330718555e-01
2298 KSP Residual norm 3.943330718523e-01
2299 KSP Residual norm 3.943330718523e-01
2300 KSP Residual norm 3.943330718487e-01
2301 KSP Residual norm 3.943330718458e-01
2302 KSP Residual norm 3.943330718458e-01
2303 KSP Residual norm 3.943330718391e-01
2304 KSP Residual norm 3.943330718151e-01
2305 KSP Residual norm 3.943330718061e-01
2306 KSP Residual norm 3.943330718060e-01
2307 KSP Residual norm 3.943330717987e-01
2308 KSP Residual norm 3.943330717960e-01
2309 KSP Residual norm 3.943330717960e-01
2310 KSP Residual norm 3.943330717887e-01
2311 KSP Residual norm 3.943330717887e-01
2312 KSP Residual norm 3.943330717887e-01
2313 KSP Residual norm 3.943330717887e-01
2314 KSP Residual norm 3.943330717887e-01
2315 KSP Residual norm 3.943330717887e-01
2316 KSP Residual norm 3.943330717887e-01
2317 KSP Residual norm 3.943330717886e-01
2318 KSP Residual norm 3.943330717886e-01
2319 KSP Residual norm 3.943330717885e-01
2320 KSP Residual norm 3.943330717885e-01
2321 KSP Residual norm 3.943330717883e-01
2322 KSP Residual norm 3.943330717882e-01
2323 KSP Residual norm 3.943330717881e-01
2324 KSP Residual norm 3.943330717880e-01
2325 KSP Residual norm 3.943330717873e-01
2326 KSP Residual norm 3.943330717871e-01
2327 KSP Residual norm 3.943330717862e-01
2328 KSP Residual norm 3.943330717837e-01
2329 KSP Residual norm 3.943330717837e-01
2330 KSP Residual norm 3.943330717809e-01
2331 KSP Residual norm 3.943330717787e-01
2332 KSP Residual norm 3.943330717786e-01
2333 KSP Residual norm 3.943330717735e-01
2334 KSP Residual norm 3.943330717550e-01
2335 KSP Residual norm 3.943330717480e-01
2336 KSP Residual norm 3.943330717480e-01
2337 KSP Residual norm 3.943330717423e-01
2338 KSP Residual norm 3.943330717402e-01
2339 KSP Residual norm 3.943330717402e-01
2340 KSP Residual norm 3.943330717350e-01
2341 KSP Residual norm 3.943330717350e-01
2342 KSP Residual norm 3.943330717350e-01
2343 KSP Residual norm 3.943330717350e-01
2344 KSP Residual norm 3.943330717349e-01
2345 KSP Residual norm 3.943330717349e-01
2346 KSP Residual norm 3.943330717349e-01
2347 KSP Residual norm 3.943330717349e-01
2348 KSP Residual norm 3.943330717349e-01
2349 KSP Residual norm 3.943330717348e-01
2350 KSP Residual norm 3.943330717348e-01
2351 KSP Residual norm 3.943330717347e-01
2352 KSP Residual norm 3.943330717346e-01
2353 KSP Residual norm 3.943330717345e-01
2354 KSP Residual norm 3.943330717344e-01
2355 KSP Residual norm 3.943330717339e-01
2356 KSP Residual norm 3.943330717337e-01
2357 KSP Residual norm 3.943330717330e-01
2358 KSP Residual norm 3.943330717311e-01
2359 KSP Residual norm 3.943330717311e-01
2360 KSP Residual norm 3.943330717290e-01
2361 KSP Residual norm 3.943330717272e-01
2362 KSP Residual norm 3.943330717272e-01
2363 KSP Residual norm 3.943330717232e-01
2364 KSP Residual norm 3.943330717089e-01
2365 KSP Residual norm 3.943330717036e-01
2366 KSP Residual norm 3.943330717036e-01
2367 KSP Residual norm 3.943330716992e-01
2368 KSP Residual norm 3.943330716976e-01
2369 KSP Residual norm 3.943330716976e-01
2370 KSP Residual norm 3.943330716933e-01
2371 KSP Residual norm 3.943330716933e-01
2372 KSP Residual norm 3.943330716933e-01
2373 KSP Residual norm 3.943330716933e-01
2374 KSP Residual norm 3.943330716933e-01
2375 KSP Residual norm 3.943330716933e-01
2376 KSP Residual norm 3.943330716932e-01
2377 KSP Residual norm 3.943330716932e-01
2378 KSP Residual norm 3.943330716932e-01
2379 KSP Residual norm 3.943330716932e-01
2380 KSP Residual norm 3.943330716931e-01
2381 KSP Residual norm 3.943330716931e-01
2382 KSP Residual norm 3.943330716930e-01
2383 KSP Residual norm 3.943330716929e-01
2384 KSP Residual norm 3.943330716929e-01
2385 KSP Residual norm 3.943330716925e-01
2386 KSP Residual norm 3.943330716923e-01
2387 KSP Residual norm 3.943330716918e-01
2388 KSP Residual norm 3.943330716903e-01
2389 KSP Residual norm 3.943330716903e-01
2390 KSP Residual norm 3.943330716886e-01
2391 KSP Residual norm 3.943330716873e-01
2392 KSP Residual norm 3.943330716873e-01
2393 KSP Residual norm 3.943330716842e-01
2394 KSP Residual norm 3.943330716732e-01
2395 KSP Residual norm 3.943330716691e-01
2396 KSP Residual norm 3.943330716690e-01
2397 KSP Residual norm 3.943330716657e-01
2398 KSP Residual norm 3.943330716644e-01
2399 KSP Residual norm 3.943330716644e-01
2400 KSP Residual norm 3.943330716613e-01
2401 KSP Residual norm 3.943330716613e-01
2402 KSP Residual norm 3.943330716613e-01
2403 KSP Residual norm 3.943330716613e-01
2404 KSP Residual norm 3.943330716612e-01
2405 KSP Residual norm 3.943330716612e-01
2406 KSP Residual norm 3.943330716612e-01
2407 KSP Residual norm 3.943330716612e-01
2408 KSP Residual norm 3.943330716612e-01
2409 KSP Residual norm 3.943330716612e-01
2410 KSP Residual norm 3.943330716612e-01
2411 KSP Residual norm 3.943330716611e-01
2412 KSP Residual norm 3.943330716610e-01
2413 KSP Residual norm 3.943330716610e-01
2414 KSP Residual norm 3.943330716610e-01
2415 KSP Residual norm 3.943330716606e-01
2416 KSP Residual norm 3.943330716605e-01
2417 KSP Residual norm 3.943330716601e-01
2418 KSP Residual norm 3.943330716590e-01
2419 KSP Residual norm 3.943330716590e-01
2420 KSP Residual norm 3.943330716577e-01
2421 KSP Residual norm 3.943330716567e-01
2422 KSP Residual norm 3.943330716566e-01
2423 KSP Residual norm 3.943330716543e-01
2424 KSP Residual norm 3.943330716458e-01
2425 KSP Residual norm 3.943330716426e-01
2426 KSP Residual norm 3.943330716426e-01
2427 KSP Residual norm 3.943330716400e-01
2428 KSP Residual norm 3.943330716390e-01
2429 KSP Residual norm 3.943330716390e-01
2430 KSP Residual norm 3.943330716365e-01
2431 KSP Residual norm 3.943330716365e-01
2432 KSP Residual norm 3.943330716365e-01
2433 KSP Residual norm 3.943330716365e-01
2434 KSP Residual norm 3.943330716365e-01
2435 KSP Residual norm 3.943330716365e-01
2436 KSP Residual norm 3.943330716365e-01
2437 KSP Residual norm 3.943330716365e-01
2438 KSP Residual norm 3.943330716365e-01
2439 KSP Residual norm 3.943330716364e-01
2440 KSP Residual norm 3.943330716364e-01
2441 KSP Residual norm 3.943330716364e-01
2442 KSP Residual norm 3.943330716363e-01
2443 KSP Residual norm 3.943330716363e-01
2444 KSP Residual norm 3.943330716363e-01
2445 KSP Residual norm 3.943330716360e-01
2446 KSP Residual norm 3.943330716360e-01
2447 KSP Residual norm 3.943330716356e-01
2448 KSP Residual norm 3.943330716347e-01
2449 KSP Residual norm 3.943330716347e-01
2450 KSP Residual norm 3.943330716338e-01
2451 KSP Residual norm 3.943330716330e-01
2452 KSP Residual norm 3.943330716330e-01
2453 KSP Residual norm 3.943330716311e-01
2454 KSP Residual norm 3.943330716246e-01
2455 KSP Residual norm 3.943330716221e-01
2456 KSP Residual norm 3.943330716221e-01
2457 KSP Residual norm 3.943330716201e-01
2458 KSP Residual norm 3.943330716193e-01
2459 KSP Residual norm 3.943330716193e-01
2460 KSP Residual norm 3.943330716176e-01
2461 KSP Residual norm 3.943330716176e-01
2462 KSP Residual norm 3.943330716176e-01
2463 KSP Residual norm 3.943330716176e-01
2464 KSP Residual norm 3.943330716176e-01
2465 KSP Residual norm 3.943330716176e-01
2466 KSP Residual norm 3.943330716176e-01
2467 KSP Residual norm 3.943330716176e-01
2468 KSP Residual norm 3.943330716176e-01
2469 KSP Residual norm 3.943330716175e-01
2470 KSP Residual norm 3.943330716175e-01
2471 KSP Residual norm 3.943330716175e-01
2472 KSP Residual norm 3.943330716174e-01
2473 KSP Residual norm 3.943330716174e-01
2474 KSP Residual norm 3.943330716174e-01
2475 KSP Residual norm 3.943330716172e-01
2476 KSP Residual norm 3.943330716171e-01
2477 KSP Residual norm 3.943330716169e-01
2478 KSP Residual norm 3.943330716162e-01
2479 KSP Residual norm 3.943330716162e-01
2480 KSP Residual norm 3.943330716154e-01
2481 KSP Residual norm 3.943330716148e-01
2482 KSP Residual norm 3.943330716148e-01
2483 KSP Residual norm 3.943330716134e-01
2484 KSP Residual norm 3.943330716084e-01
2485 KSP Residual norm 3.943330716065e-01
2486 KSP Residual norm 3.943330716064e-01
2487 KSP Residual norm 3.943330716049e-01
2488 KSP Residual norm 3.943330716043e-01
2489 KSP Residual norm 3.943330716043e-01
2490 KSP Residual norm 3.943330716028e-01
2491 KSP Residual norm 3.943330716028e-01
2492 KSP Residual norm 3.943330716028e-01
2493 KSP Residual norm 3.943330716028e-01
2494 KSP Residual norm 3.943330716028e-01
2495 KSP Residual norm 3.943330716028e-01
2496 KSP Residual norm 3.943330716028e-01
2497 KSP Residual norm 3.943330716028e-01
2498 KSP Residual norm 3.943330716028e-01
2499 KSP Residual norm 3.943330716027e-01
2500 KSP Residual norm 3.943330716027e-01
2501 KSP Residual norm 3.943330716027e-01
2502 KSP Residual norm 3.943330716027e-01
2503 KSP Residual norm 3.943330716027e-01
2504 KSP Residual norm 3.943330716026e-01
2505 KSP Residual norm 3.943330716025e-01
2506 KSP Residual norm 3.943330716024e-01
2507 KSP Residual norm 3.943330716022e-01
2508 KSP Residual norm 3.943330716017e-01
2509 KSP Residual norm 3.943330716017e-01
2510 KSP Residual norm 3.943330716011e-01
2511 KSP Residual norm 3.943330716007e-01
2512 KSP Residual norm 3.943330716007e-01
2513 KSP Residual norm 3.943330715996e-01
2514 KSP Residual norm 3.943330715957e-01
2515 KSP Residual norm 3.943330715942e-01
2516 KSP Residual norm 3.943330715942e-01
2517 KSP Residual norm 3.943330715930e-01
2518 KSP Residual norm 3.943330715926e-01
2519 KSP Residual norm 3.943330715926e-01
2520 KSP Residual norm 3.943330715912e-01
2521 KSP Residual norm 3.943330715912e-01
2522 KSP Residual norm 3.943330715912e-01
2523 KSP Residual norm 3.943330715912e-01
2524 KSP Residual norm 3.943330715912e-01
2525 KSP Residual norm 3.943330715912e-01
2526 KSP Residual norm 3.943330715912e-01
2527 KSP Residual norm 3.943330715912e-01
2528 KSP Residual norm 3.943330715912e-01
2529 KSP Residual norm 3.943330715912e-01
2530 KSP Residual norm 3.943330715912e-01
2531 KSP Residual norm 3.943330715912e-01
2532 KSP Residual norm 3.943330715911e-01
2533 KSP Residual norm 3.943330715911e-01
2534 KSP Residual norm 3.943330715911e-01
2535 KSP Residual norm 3.943330715910e-01
2536 KSP Residual norm 3.943330715910e-01
2537 KSP Residual norm 3.943330715908e-01
2538 KSP Residual norm 3.943330715904e-01
2539 KSP Residual norm 3.943330715904e-01
2540 KSP Residual norm 3.943330715900e-01
2541 KSP Residual norm 3.943330715896e-01
2542 KSP Residual norm 3.943330715896e-01
2543 KSP Residual norm 3.943330715888e-01
2544 KSP Residual norm 3.943330715857e-01
2545 KSP Residual norm 3.943330715846e-01
2546 KSP Residual norm 3.943330715846e-01
2547 KSP Residual norm 3.943330715837e-01
2548 KSP Residual norm 3.943330715833e-01
2549 KSP Residual norm 3.943330715833e-01
2550 KSP Residual norm 3.943330715824e-01
2551 KSP Residual norm 3.943330715824e-01
2552 KSP Residual norm 3.943330715824e-01
2553 KSP Residual norm 3.943330715824e-01
2554 KSP Residual norm 3.943330715824e-01
2555 KSP Residual norm 3.943330715824e-01
2556 KSP Residual norm 3.943330715824e-01
2557 KSP Residual norm 3.943330715824e-01
2558 KSP Residual norm 3.943330715824e-01
2559 KSP Residual norm 3.943330715824e-01
2560 KSP Residual norm 3.943330715824e-01
2561 KSP Residual norm 3.943330715824e-01
2562 KSP Residual norm 3.943330715823e-01
2563 KSP Residual norm 3.943330715823e-01
2564 KSP Residual norm 3.943330715823e-01
2565 KSP Residual norm 3.943330715822e-01
2566 KSP Residual norm 3.943330715822e-01
2567 KSP Residual norm 3.943330715821e-01
2568 KSP Residual norm 3.943330715818e-01
2569 KSP Residual norm 3.943330715818e-01
2570 KSP Residual norm 3.943330715814e-01
2571 KSP Residual norm 3.943330715811e-01
2572 KSP Residual norm 3.943330715811e-01
2573 KSP Residual norm 3.943330715805e-01
2574 KSP Residual norm 3.943330715782e-01
2575 KSP Residual norm 3.943330715773e-01
2576 KSP Residual norm 3.943330715773e-01
2577 KSP Residual norm 3.943330715766e-01
2578 KSP Residual norm 3.943330715763e-01
2579 KSP Residual norm 3.943330715763e-01
2580 KSP Residual norm 3.943330715757e-01
2581 KSP Residual norm 3.943330715757e-01
2582 KSP Residual norm 3.943330715757e-01
2583 KSP Residual norm 3.943330715757e-01
2584 KSP Residual norm 3.943330715757e-01
2585 KSP Residual norm 3.943330715757e-01
2586 KSP Residual norm 3.943330715757e-01
2587 KSP Residual norm 3.943330715757e-01
2588 KSP Residual norm 3.943330715757e-01
2589 KSP Residual norm 3.943330715756e-01
2590 KSP Residual norm 3.943330715756e-01
2591 KSP Residual norm 3.943330715756e-01
2592 KSP Residual norm 3.943330715756e-01
2593 KSP Residual norm 3.943330715756e-01
2594 KSP Residual norm 3.943330715756e-01
2595 KSP Residual norm 3.943330715755e-01
2596 KSP Residual norm 3.943330715755e-01
2597 KSP Residual norm 3.943330715754e-01
2598 KSP Residual norm 3.943330715752e-01
2599 KSP Residual norm 3.943330715752e-01
2600 KSP Residual norm 3.943330715749e-01
2601 KSP Residual norm 3.943330715747e-01
2602 KSP Residual norm 3.943330715747e-01
2603 KSP Residual norm 3.943330715742e-01
2604 KSP Residual norm 3.943330715724e-01
2605 KSP Residual norm 3.943330715717e-01
2606 KSP Residual norm 3.943330715717e-01
2607 KSP Residual norm 3.943330715712e-01
2608 KSP Residual norm 3.943330715710e-01
2609 KSP Residual norm 3.943330715710e-01
2610 KSP Residual norm 3.943330715705e-01
2611 KSP Residual norm 3.943330715705e-01
2612 KSP Residual norm 3.943330715705e-01
2613 KSP Residual norm 3.943330715705e-01
2614 KSP Residual norm 3.943330715705e-01
2615 KSP Residual norm 3.943330715705e-01
2616 KSP Residual norm 3.943330715705e-01
2617 KSP Residual norm 3.943330715705e-01
2618 KSP Residual norm 3.943330715705e-01
2619 KSP Residual norm 3.943330715704e-01
2620 KSP Residual norm 3.943330715704e-01
2621 KSP Residual norm 3.943330715704e-01
2622 KSP Residual norm 3.943330715704e-01
2623 KSP Residual norm 3.943330715704e-01
2624 KSP Residual norm 3.943330715704e-01
2625 KSP Residual norm 3.943330715704e-01
2626 KSP Residual norm 3.943330715703e-01
2627 KSP Residual norm 3.943330715703e-01
2628 KSP Residual norm 3.943330715701e-01
2629 KSP Residual norm 3.943330715701e-01
2630 KSP Residual norm 3.943330715699e-01
2631 KSP Residual norm 3.943330715697e-01
2632 KSP Residual norm 3.943330715697e-01
2633 KSP Residual norm 3.943330715693e-01
2634 KSP Residual norm 3.943330715679e-01
2635 KSP Residual norm 3.943330715674e-01
2636 KSP Residual norm 3.943330715674e-01
2637 KSP Residual norm 3.943330715670e-01
2638 KSP Residual norm 3.943330715668e-01
2639 KSP Residual norm 3.943330715668e-01
2640 KSP Residual norm 3.943330715663e-01
2641 KSP Residual norm 3.943330715663e-01
2642 KSP Residual norm 3.943330715663e-01
2643 KSP Residual norm 3.943330715663e-01
2644 KSP Residual norm 3.943330715663e-01
2645 KSP Residual norm 3.943330715663e-01
2646 KSP Residual norm 3.943330715663e-01
2647 KSP Residual norm 3.943330715663e-01
2648 KSP Residual norm 3.943330715663e-01
2649 KSP Residual norm 3.943330715663e-01
2650 KSP Residual norm 3.943330715663e-01
2651 KSP Residual norm 3.943330715663e-01
2652 KSP Residual norm 3.943330715663e-01
2653 KSP Residual norm 3.943330715663e-01
2654 KSP Residual norm 3.943330715663e-01
2655 KSP Residual norm 3.943330715663e-01
2656 KSP Residual norm 3.943330715663e-01
2657 KSP Residual norm 3.943330715662e-01
2658 KSP Residual norm 3.943330715661e-01
2659 KSP Residual norm 3.943330715661e-01
2660 KSP Residual norm 3.943330715659e-01
2661 KSP Residual norm 3.943330715658e-01
2662 KSP Residual norm 3.943330715658e-01
2663 KSP Residual norm 3.943330715655e-01
2664 KSP Residual norm 3.943330715644e-01
2665 KSP Residual norm 3.943330715640e-01
2666 KSP Residual norm 3.943330715640e-01
2667 KSP Residual norm 3.943330715637e-01
2668 KSP Residual norm 3.943330715635e-01
2669 KSP Residual norm 3.943330715635e-01
2670 KSP Residual norm 3.943330715634e-01
2671 KSP Residual norm 3.943330715634e-01
2672 KSP Residual norm 3.943330715634e-01
2673 KSP Residual norm 3.943330715634e-01
2674 KSP Residual norm 3.943330715634e-01
2675 KSP Residual norm 3.943330715634e-01
2676 KSP Residual norm 3.943330715634e-01
2677 KSP Residual norm 3.943330715633e-01
2678 KSP Residual norm 3.943330715633e-01
2679 KSP Residual norm 3.943330715633e-01
2680 KSP Residual norm 3.943330715633e-01
2681 KSP Residual norm 3.943330715633e-01
2682 KSP Residual norm 3.943330715633e-01
2683 KSP Residual norm 3.943330715633e-01
2684 KSP Residual norm 3.943330715633e-01
2685 KSP Residual norm 3.943330715633e-01
2686 KSP Residual norm 3.943330715633e-01
2687 KSP Residual norm 3.943330715632e-01
2688 KSP Residual norm 3.943330715631e-01
2689 KSP Residual norm 3.943330715631e-01
2690 KSP Residual norm 3.943330715630e-01
2691 KSP Residual norm 3.943330715629e-01
2692 KSP Residual norm 3.943330715629e-01
2693 KSP Residual norm 3.943330715627e-01
2694 KSP Residual norm 3.943330715619e-01
2695 KSP Residual norm 3.943330715615e-01
2696 KSP Residual norm 3.943330715615e-01
2697 KSP Residual norm 3.943330715613e-01
2698 KSP Residual norm 3.943330715612e-01
2699 KSP Residual norm 3.943330715612e-01
2700 KSP Residual norm 3.943330715609e-01
2701 KSP Residual norm 3.943330715609e-01
2702 KSP Residual norm 3.943330715609e-01
2703 KSP Residual norm 3.943330715609e-01
2704 KSP Residual norm 3.943330715609e-01
2705 KSP Residual norm 3.943330715609e-01
2706 KSP Residual norm 3.943330715609e-01
2707 KSP Residual norm 3.943330715609e-01
2708 KSP Residual norm 3.943330715609e-01
2709 KSP Residual norm 3.943330715609e-01
2710 KSP Residual norm 3.943330715609e-01
2711 KSP Residual norm 3.943330715609e-01
2712 KSP Residual norm 3.943330715609e-01
2713 KSP Residual norm 3.943330715609e-01
2714 KSP Residual norm 3.943330715608e-01
2715 KSP Residual norm 3.943330715608e-01
2716 KSP Residual norm 3.943330715608e-01
2717 KSP Residual norm 3.943330715608e-01
2718 KSP Residual norm 3.943330715607e-01
2719 KSP Residual norm 3.943330715607e-01
2720 KSP Residual norm 3.943330715606e-01
2721 KSP Residual norm 3.943330715605e-01
2722 KSP Residual norm 3.943330715605e-01
2723 KSP Residual norm 3.943330715603e-01
2724 KSP Residual norm 3.943330715597e-01
2725 KSP Residual norm 3.943330715595e-01
2726 KSP Residual norm 3.943330715595e-01
2727 KSP Residual norm 3.943330715593e-01
2728 KSP Residual norm 3.943330715592e-01
2729 KSP Residual norm 3.943330715592e-01
2730 KSP Residual norm 3.943330715591e-01
2731 KSP Residual norm 3.943330715591e-01
2732 KSP Residual norm 3.943330715591e-01
2733 KSP Residual norm 3.943330715591e-01
2734 KSP Residual norm 3.943330715591e-01
2735 KSP Residual norm 3.943330715591e-01
2736 KSP Residual norm 3.943330715591e-01
2737 KSP Residual norm 3.943330715591e-01
2738 KSP Residual norm 3.943330715591e-01
2739 KSP Residual norm 3.943330715591e-01
2740 KSP Residual norm 3.943330715591e-01
2741 KSP Residual norm 3.943330715591e-01
2742 KSP Residual norm 3.943330715591e-01
2743 KSP Residual norm 3.943330715591e-01
2744 KSP Residual norm 3.943330715591e-01
2745 KSP Residual norm 3.943330715591e-01
2746 KSP Residual norm 3.943330715591e-01
2747 KSP Residual norm 3.943330715590e-01
2748 KSP Residual norm 3.943330715590e-01
2749 KSP Residual norm 3.943330715590e-01
2750 KSP Residual norm 3.943330715589e-01
2751 KSP Residual norm 3.943330715588e-01
2752 KSP Residual norm 3.943330715588e-01
2753 KSP Residual norm 3.943330715587e-01
2754 KSP Residual norm 3.943330715582e-01
2755 KSP Residual norm 3.943330715580e-01
2756 KSP Residual norm 3.943330715580e-01
2757 KSP Residual norm 3.943330715579e-01
2758 KSP Residual norm 3.943330715578e-01
2759 KSP Residual norm 3.943330715578e-01
2760 KSP Residual norm 3.943330715576e-01
2761 KSP Residual norm 3.943330715576e-01
2762 KSP Residual norm 3.943330715576e-01
2763 KSP Residual norm 3.943330715576e-01
2764 KSP Residual norm 3.943330715576e-01
2765 KSP Residual norm 3.943330715576e-01
2766 KSP Residual norm 3.943330715576e-01
2767 KSP Residual norm 3.943330715576e-01
2768 KSP Residual norm 3.943330715576e-01
2769 KSP Residual norm 3.943330715576e-01
2770 KSP Residual norm 3.943330715576e-01
2771 KSP Residual norm 3.943330715576e-01
2772 KSP Residual norm 3.943330715576e-01
2773 KSP Residual norm 3.943330715576e-01
2774 KSP Residual norm 3.943330715576e-01
2775 KSP Residual norm 3.943330715576e-01
2776 KSP Residual norm 3.943330715576e-01
2777 KSP Residual norm 3.943330715576e-01
2778 KSP Residual norm 3.943330715575e-01
2779 KSP Residual norm 3.943330715575e-01
2780 KSP Residual norm 3.943330715575e-01
2781 KSP Residual norm 3.943330715574e-01
2782 KSP Residual norm 3.943330715574e-01
2783 KSP Residual norm 3.943330715573e-01
2784 KSP Residual norm 3.943330715569e-01
2785 KSP Residual norm 3.943330715568e-01
2786 KSP Residual norm 3.943330715568e-01
2787 KSP Residual norm 3.943330715567e-01
2788 KSP Residual norm 3.943330715566e-01
2789 KSP Residual norm 3.943330715566e-01
2790 KSP Residual norm 3.943330715565e-01
2791 KSP Residual norm 3.943330715565e-01
2792 KSP Residual norm 3.943330715565e-01
2793 KSP Residual norm 3.943330715565e-01
2794 KSP Residual norm 3.943330715565e-01
2795 KSP Residual norm 3.943330715565e-01
2796 KSP Residual norm 3.943330715565e-01
2797 KSP Residual norm 3.943330715565e-01
2798 KSP Residual norm 3.943330715565e-01
2799 KSP Residual norm 3.943330715565e-01
2800 KSP Residual norm 3.943330715565e-01
2801 KSP Residual norm 3.943330715565e-01
2802 KSP Residual norm 3.943330715565e-01
2803 KSP Residual norm 3.943330715565e-01
2804 KSP Residual norm 3.943330715565e-01
2805 KSP Residual norm 3.943330715565e-01
2806 KSP Residual norm 3.943330715565e-01
2807 KSP Residual norm 3.943330715565e-01
2808 KSP Residual norm 3.943330715564e-01
2809 KSP Residual norm 3.943330715564e-01
2810 KSP Residual norm 3.943330715564e-01
2811 KSP Residual norm 3.943330715563e-01
2812 KSP Residual norm 3.943330715563e-01
2813 KSP Residual norm 3.943330715563e-01
2814 KSP Residual norm 3.943330715560e-01
2815 KSP Residual norm 3.943330715559e-01
2816 KSP Residual norm 3.943330715559e-01
2817 KSP Residual norm 3.943330715558e-01
2818 KSP Residual norm 3.943330715557e-01
2819 KSP Residual norm 3.943330715557e-01
2820 KSP Residual norm 3.943330715556e-01
2821 KSP Residual norm 3.943330715556e-01
2822 KSP Residual norm 3.943330715556e-01
2823 KSP Residual norm 3.943330715556e-01
2824 KSP Residual norm 3.943330715556e-01
2825 KSP Residual norm 3.943330715556e-01
2826 KSP Residual norm 3.943330715556e-01
2827 KSP Residual norm 3.943330715556e-01
2828 KSP Residual norm 3.943330715556e-01
2829 KSP Residual norm 3.943330715556e-01
2830 KSP Residual norm 3.943330715556e-01
2831 KSP Residual norm 3.943330715556e-01
2832 KSP Residual norm 3.943330715556e-01
2833 KSP Residual norm 3.943330715556e-01
2834 KSP Residual norm 3.943330715556e-01
2835 KSP Residual norm 3.943330715555e-01
2836 KSP Residual norm 3.943330715555e-01
2837 KSP Residual norm 3.943330715555e-01
2838 KSP Residual norm 3.943330715555e-01
2839 KSP Residual norm 3.943330715555e-01
2840 KSP Residual norm 3.943330715555e-01
2841 KSP Residual norm 3.943330715554e-01
2842 KSP Residual norm 3.943330715554e-01
2843 KSP Residual norm 3.943330715554e-01
2844 KSP Residual norm 3.943330715551e-01
2845 KSP Residual norm 3.943330715551e-01
2846 KSP Residual norm 3.943330715551e-01
2847 KSP Residual norm 3.943330715550e-01
2848 KSP Residual norm 3.943330715550e-01
2849 KSP Residual norm 3.943330715550e-01
2850 KSP Residual norm 3.943330715550e-01
2851 KSP Residual norm 3.943330715550e-01
2852 KSP Residual norm 3.943330715550e-01
2853 KSP Residual norm 3.943330715550e-01
2854 KSP Residual norm 3.943330715550e-01
2855 KSP Residual norm 3.943330715550e-01
2856 KSP Residual norm 3.943330715550e-01
2857 KSP Residual norm 3.943330715550e-01
2858 KSP Residual norm 3.943330715550e-01
2859 KSP Residual norm 3.943330715550e-01
2860 KSP Residual norm 3.943330715550e-01
2861 KSP Residual norm 3.943330715550e-01
2862 KSP Residual norm 3.943330715550e-01
2863 KSP Residual norm 3.943330715550e-01
2864 KSP Residual norm 3.943330715550e-01
2865 KSP Residual norm 3.943330715550e-01
2866 KSP Residual norm 3.943330715550e-01
2867 KSP Residual norm 3.943330715550e-01
2868 KSP Residual norm 3.943330715549e-01
2869 KSP Residual norm 3.943330715549e-01
2870 KSP Residual norm 3.943330715549e-01
2871 KSP Residual norm 3.943330715549e-01
2872 KSP Residual norm 3.943330715549e-01
2873 KSP Residual norm 3.943330715548e-01
2874 KSP Residual norm 3.943330715547e-01
2875 KSP Residual norm 3.943330715546e-01
2876 KSP Residual norm 3.943330715546e-01
2877 KSP Residual norm 3.943330715545e-01
2878 KSP Residual norm 3.943330715545e-01
2879 KSP Residual norm 3.943330715545e-01
2880 KSP Residual norm 3.943330715545e-01
2881 KSP Residual norm 3.943330715545e-01
2882 KSP Residual norm 3.943330715545e-01
2883 KSP Residual norm 3.943330715545e-01
2884 KSP Residual norm 3.943330715545e-01
2885 KSP Residual norm 3.943330715545e-01
2886 KSP Residual norm 3.943330715545e-01
2887 KSP Residual norm 3.943330715545e-01
2888 KSP Residual norm 3.943330715545e-01
2889 KSP Residual norm 3.943330715545e-01
2890 KSP Residual norm 3.943330715545e-01
2891 KSP Residual norm 3.943330715545e-01
2892 KSP Residual norm 3.943330715545e-01
2893 KSP Residual norm 3.943330715545e-01
2894 KSP Residual norm 3.943330715545e-01
2895 KSP Residual norm 3.943330715545e-01
2896 KSP Residual norm 3.943330715545e-01
2897 KSP Residual norm 3.943330715545e-01
2898 KSP Residual norm 3.943330715545e-01
2899 KSP Residual norm 3.943330715545e-01
2900 KSP Residual norm 3.943330715544e-01
2901 KSP Residual norm 3.943330715544e-01
2902 KSP Residual norm 3.943330715544e-01
2903 KSP Residual norm 3.943330715544e-01
2904 KSP Residual norm 3.943330715543e-01
2905 KSP Residual norm 3.943330715542e-01
2906 KSP Residual norm 3.943330715542e-01
2907 KSP Residual norm 3.943330715542e-01
2908 KSP Residual norm 3.943330715542e-01
2909 KSP Residual norm 3.943330715542e-01
2910 KSP Residual norm 3.943330715541e-01
2911 KSP Residual norm 3.943330715541e-01
2912 KSP Residual norm 3.943330715541e-01
2913 KSP Residual norm 3.943330715541e-01
2914 KSP Residual norm 3.943330715541e-01
2915 KSP Residual norm 3.943330715541e-01
2916 KSP Residual norm 3.943330715541e-01
2917 KSP Residual norm 3.943330715541e-01
2918 KSP Residual norm 3.943330715541e-01
2919 KSP Residual norm 3.943330715541e-01
2920 KSP Residual norm 3.943330715541e-01
2921 KSP Residual norm 3.943330715541e-01
2922 KSP Residual norm 3.943330715541e-01
2923 KSP Residual norm 3.943330715541e-01
2924 KSP Residual norm 3.943330715541e-01
2925 KSP Residual norm 3.943330715541e-01
2926 KSP Residual norm 3.943330715541e-01
2927 KSP Residual norm 3.943330715541e-01
2928 KSP Residual norm 3.943330715540e-01
2929 KSP Residual norm 3.943330715540e-01
2930 KSP Residual norm 3.943330715540e-01
2931 KSP Residual norm 3.943330715540e-01
2932 KSP Residual norm 3.943330715540e-01
2933 KSP Residual norm 3.943330715540e-01
2934 KSP Residual norm 3.943330715539e-01
2935 KSP Residual norm 3.943330715538e-01
2936 KSP Residual norm 3.943330715538e-01
2937 KSP Residual norm 3.943330715538e-01
2938 KSP Residual norm 3.943330715538e-01
2939 KSP Residual norm 3.943330715538e-01
2940 KSP Residual norm 3.943330715536e-01
2941 KSP Residual norm 3.943330715536e-01
2942 KSP Residual norm 3.943330715536e-01
2943 KSP Residual norm 3.943330715536e-01
2944 KSP Residual norm 3.943330715536e-01
2945 KSP Residual norm 3.943330715536e-01
2946 KSP Residual norm 3.943330715536e-01
2947 KSP Residual norm 3.943330715536e-01
2948 KSP Residual norm 3.943330715536e-01
2949 KSP Residual norm 3.943330715536e-01
2950 KSP Residual norm 3.943330715536e-01
2951 KSP Residual norm 3.943330715536e-01
2952 KSP Residual norm 3.943330715536e-01
2953 KSP Residual norm 3.943330715536e-01
2954 KSP Residual norm 3.943330715536e-01
2955 KSP Residual norm 3.943330715536e-01
2956 KSP Residual norm 3.943330715536e-01
2957 KSP Residual norm 3.943330715536e-01
2958 KSP Residual norm 3.943330715536e-01
2959 KSP Residual norm 3.943330715536e-01
2960 KSP Residual norm 3.943330715536e-01
2961 KSP Residual norm 3.943330715536e-01
2962 KSP Residual norm 3.943330715536e-01
2963 KSP Residual norm 3.943330715535e-01
2964 KSP Residual norm 3.943330715535e-01
2965 KSP Residual norm 3.943330715534e-01
2966 KSP Residual norm 3.943330715534e-01
2967 KSP Residual norm 3.943330715534e-01
2968 KSP Residual norm 3.943330715534e-01
2969 KSP Residual norm 3.943330715534e-01
2970 KSP Residual norm 3.943330715532e-01
2971 KSP Residual norm 3.943330715532e-01
2972 KSP Residual norm 3.943330715532e-01
2973 KSP Residual norm 3.943330715532e-01
2974 KSP Residual norm 3.943330715532e-01
2975 KSP Residual norm 3.943330715532e-01
2976 KSP Residual norm 3.943330715532e-01
2977 KSP Residual norm 3.943330715532e-01
2978 KSP Residual norm 3.943330715532e-01
2979 KSP Residual norm 3.943330715532e-01
2980 KSP Residual norm 3.943330715532e-01
2981 KSP Residual norm 3.943330715532e-01
2982 KSP Residual norm 3.943330715532e-01
2983 KSP Residual norm 3.943330715532e-01
2984 KSP Residual norm 3.943330715532e-01
2985 KSP Residual norm 3.943330715532e-01
2986 KSP Residual norm 3.943330715532e-01
2987 KSP Residual norm 3.943330715532e-01
2988 KSP Residual norm 3.943330715532e-01
2989 KSP Residual norm 3.943330715532e-01
2990 KSP Residual norm 3.943330715531e-01
2991 KSP Residual norm 3.943330715531e-01
2992 KSP Residual norm 3.943330715531e-01
2993 KSP Residual norm 3.943330715531e-01
2994 KSP Residual norm 3.943330715531e-01
2995 KSP Residual norm 3.943330715530e-01
2996 KSP Residual norm 3.943330715530e-01
2997 KSP Residual norm 3.943330715530e-01
2998 KSP Residual norm 3.943330715530e-01
2999 KSP Residual norm 3.943330715530e-01
3000 KSP Residual norm 3.943330715531e-01
3001 KSP Residual norm 3.943330715531e-01
3002 KSP Residual norm 3.943330715531e-01
3003 KSP Residual norm 3.943330715531e-01
3004 KSP Residual norm 3.943330715531e-01
3005 KSP Residual norm 3.943330715531e-01
3006 KSP Residual norm 3.943330715531e-01
3007 KSP Residual norm 3.943330715531e-01
3008 KSP Residual norm 3.943330715531e-01
3009 KSP Residual norm 3.943330715531e-01
3010 KSP Residual norm 3.943330715531e-01
3011 KSP Residual norm 3.943330715531e-01
3012 KSP Residual norm 3.943330715530e-01
3013 KSP Residual norm 3.943330715530e-01
3014 KSP Residual norm 3.943330715530e-01
3015 KSP Residual norm 3.943330715530e-01
3016 KSP Residual norm 3.943330715530e-01
3017 KSP Residual norm 3.943330715530e-01
3018 KSP Residual norm 3.943330715530e-01
3019 KSP Residual norm 3.943330715530e-01
3020 KSP Residual norm 3.943330715530e-01
3021 KSP Residual norm 3.943330715530e-01
3022 KSP Residual norm 3.943330715530e-01
3023 KSP Residual norm 3.943330715530e-01
3024 KSP Residual norm 3.943330715530e-01
3025 KSP Residual norm 3.943330715529e-01
3026 KSP Residual norm 3.943330715529e-01
3027 KSP Residual norm 3.943330715529e-01
3028 KSP Residual norm 3.943330715529e-01
3029 KSP Residual norm 3.943330715529e-01
3030 KSP Residual norm 3.943330715529e-01
3031 KSP Residual norm 3.943330715529e-01
3032 KSP Residual norm 3.943330715529e-01
3033 KSP Residual norm 3.943330715529e-01
3034 KSP Residual norm 3.943330715529e-01
3035 KSP Residual norm 3.943330715529e-01
3036 KSP Residual norm 3.943330715529e-01
3037 KSP Residual norm 3.943330715529e-01
3038 KSP Residual norm 3.943330715529e-01
3039 KSP Residual norm 3.943330715529e-01
3040 KSP Residual norm 3.943330715529e-01
3041 KSP Residual norm 3.943330715529e-01
3042 KSP Residual norm 3.943330715529e-01
3043 KSP Residual norm 3.943330715529e-01
3044 KSP Residual norm 3.943330715529e-01
3045 KSP Residual norm 3.943330715529e-01
3046 KSP Residual norm 3.943330715529e-01
3047 KSP Residual norm 3.943330715529e-01
3048 KSP Residual norm 3.943330715529e-01
3049 KSP Residual norm 3.943330715529e-01
3050 KSP Residual norm 3.943330715529e-01
3051 KSP Residual norm 3.943330715529e-01
3052 KSP Residual norm 3.943330715529e-01
3053 KSP Residual norm 3.943330715529e-01
3054 KSP Residual norm 3.943330715529e-01
3055 KSP Residual norm 3.943330715529e-01
3056 KSP Residual norm 3.943330715529e-01
3057 KSP Residual norm 3.943330715528e-01
3058 KSP Residual norm 3.943330715528e-01
3059 KSP Residual norm 3.943330715528e-01
3060 KSP Residual norm 3.943330715529e-01
3061 KSP Residual norm 3.943330715529e-01
3062 KSP Residual norm 3.943330715529e-01
3063 KSP Residual norm 3.943330715529e-01
3064 KSP Residual norm 3.943330715529e-01
3065 KSP Residual norm 3.943330715529e-01
3066 KSP Residual norm 3.943330715529e-01
3067 KSP Residual norm 3.943330715529e-01
3068 KSP Residual norm 3.943330715529e-01
3069 KSP Residual norm 3.943330715529e-01
3070 KSP Residual norm 3.943330715529e-01
3071 KSP Residual norm 3.943330715529e-01
3072 KSP Residual norm 3.943330715529e-01
3073 KSP Residual norm 3.943330715529e-01
3074 KSP Residual norm 3.943330715529e-01
3075 KSP Residual norm 3.943330715529e-01
3076 KSP Residual norm 3.943330715529e-01
3077 KSP Residual norm 3.943330715529e-01
3078 KSP Residual norm 3.943330715529e-01
3079 KSP Residual norm 3.943330715529e-01
3080 KSP Residual norm 3.943330715529e-01
3081 KSP Residual norm 3.943330715529e-01
3082 KSP Residual norm 3.943330715529e-01
3083 KSP Residual norm 3.943330715529e-01
3084 KSP Residual norm 3.943330715528e-01
3085 KSP Residual norm 3.943330715528e-01
3086 KSP Residual norm 3.943330715528e-01
3087 KSP Residual norm 3.943330715528e-01
3088 KSP Residual norm 3.943330715528e-01
3089 KSP Residual norm 3.943330715528e-01
3090 KSP Residual norm 3.943330715528e-01
3091 KSP Residual norm 3.943330715528e-01
3092 KSP Residual norm 3.943330715528e-01
3093 KSP Residual norm 3.943330715528e-01
3094 KSP Residual norm 3.943330715528e-01
3095 KSP Residual norm 3.943330715528e-01
3096 KSP Residual norm 3.943330715528e-01
3097 KSP Residual norm 3.943330715528e-01
3098 KSP Residual norm 3.943330715528e-01
3099 KSP Residual norm 3.943330715528e-01
3100 KSP Residual norm 3.943330715528e-01
3101 KSP Residual norm 3.943330715528e-01
3102 KSP Residual norm 3.943330715528e-01
3103 KSP Residual norm 3.943330715528e-01
3104 KSP Residual norm 3.943330715528e-01
3105 KSP Residual norm 3.943330715528e-01
3106 KSP Residual norm 3.943330715528e-01
3107 KSP Residual norm 3.943330715528e-01
3108 KSP Residual norm 3.943330715528e-01
3109 KSP Residual norm 3.943330715528e-01
3110 KSP Residual norm 3.943330715528e-01
3111 KSP Residual norm 3.943330715528e-01
3112 KSP Residual norm 3.943330715528e-01
3113 KSP Residual norm 3.943330715528e-01
3114 KSP Residual norm 3.943330715528e-01
3115 KSP Residual norm 3.943330715528e-01
3116 KSP Residual norm 3.943330715528e-01
3117 KSP Residual norm 3.943330715528e-01
3118 KSP Residual norm 3.943330715528e-01
3119 KSP Residual norm 3.943330715528e-01
3120 KSP Residual norm 3.943330715528e-01
3121 KSP Residual norm 3.943330715528e-01
3122 KSP Residual norm 3.943330715528e-01
3123 KSP Residual norm 3.943330715528e-01
3124 KSP Residual norm 3.943330715528e-01
3125 KSP Residual norm 3.943330715528e-01
3126 KSP Residual norm 3.943330715528e-01
3127 KSP Residual norm 3.943330715528e-01
3128 KSP Residual norm 3.943330715528e-01
3129 KSP Residual norm 3.943330715528e-01
3130 KSP Residual norm 3.943330715528e-01
3131 KSP Residual norm 3.943330715528e-01
3132 KSP Residual norm 3.943330715528e-01
3133 KSP Residual norm 3.943330715528e-01
3134 KSP Residual norm 3.943330715528e-01
3135 KSP Residual norm 3.943330715528e-01
3136 KSP Residual norm 3.943330715528e-01
3137 KSP Residual norm 3.943330715528e-01
3138 KSP Residual norm 3.943330715528e-01
3139 KSP Residual norm 3.943330715528e-01
3140 KSP Residual norm 3.943330715528e-01
3141 KSP Residual norm 3.943330715528e-01
3142 KSP Residual norm 3.943330715528e-01
3143 KSP Residual norm 3.943330715528e-01
3144 KSP Residual norm 3.943330715527e-01
3145 KSP Residual norm 3.943330715527e-01
3146 KSP Residual norm 3.943330715527e-01
3147 KSP Residual norm 3.943330715527e-01
3148 KSP Residual norm 3.943330715527e-01
3149 KSP Residual norm 3.943330715527e-01
3150 KSP Residual norm 3.943330715527e-01
3151 KSP Residual norm 3.943330715527e-01
3152 KSP Residual norm 3.943330715527e-01
3153 KSP Residual norm 3.943330715527e-01
3154 KSP Residual norm 3.943330715527e-01
3155 KSP Residual norm 3.943330715527e-01
3156 KSP Residual norm 3.943330715527e-01
3157 KSP Residual norm 3.943330715527e-01
3158 KSP Residual norm 3.943330715527e-01
3159 KSP Residual norm 3.943330715527e-01
3160 KSP Residual norm 3.943330715527e-01
3161 KSP Residual norm 3.943330715527e-01
3162 KSP Residual norm 3.943330715527e-01
3163 KSP Residual norm 3.943330715527e-01
3164 KSP Residual norm 3.943330715527e-01
3165 KSP Residual norm 3.943330715527e-01
3166 KSP Residual norm 3.943330715527e-01
3167 KSP Residual norm 3.943330715527e-01
3168 KSP Residual norm 3.943330715527e-01
3169 KSP Residual norm 3.943330715527e-01
3170 KSP Residual norm 3.943330715527e-01
3171 KSP Residual norm 3.943330715527e-01
3172 KSP Residual norm 3.943330715527e-01
3173 KSP Residual norm 3.943330715527e-01
3174 KSP Residual norm 3.943330715527e-01
3175 KSP Residual norm 3.943330715527e-01
3176 KSP Residual norm 3.943330715527e-01
3177 KSP Residual norm 3.943330715527e-01
3178 KSP Residual norm 3.943330715527e-01
3179 KSP Residual norm 3.943330715527e-01
3180 KSP Residual norm 3.943330715526e-01
3181 KSP Residual norm 3.943330715526e-01
3182 KSP Residual norm 3.943330715526e-01
3183 KSP Residual norm 3.943330715526e-01
3184 KSP Residual norm 3.943330715526e-01
3185 KSP Residual norm 3.943330715526e-01
3186 KSP Residual norm 3.943330715526e-01
3187 KSP Residual norm 3.943330715526e-01
3188 KSP Residual norm 3.943330715526e-01
3189 KSP Residual norm 3.943330715526e-01
3190 KSP Residual norm 3.943330715526e-01
3191 KSP Residual norm 3.943330715526e-01
3192 KSP Residual norm 3.943330715526e-01
3193 KSP Residual norm 3.943330715526e-01
3194 KSP Residual norm 3.943330715526e-01
3195 KSP Residual norm 3.943330715526e-01
3196 KSP Residual norm 3.943330715526e-01
3197 KSP Residual norm 3.943330715526e-01
3198 KSP Residual norm 3.943330715526e-01
3199 KSP Residual norm 3.943330715526e-01
3200 KSP Residual norm 3.943330715526e-01
3201 KSP Residual norm 3.943330715526e-01
3202 KSP Residual norm 3.943330715526e-01
3203 KSP Residual norm 3.943330715526e-01
3204 KSP Residual norm 3.943330715526e-01
3205 KSP Residual norm 3.943330715526e-01
3206 KSP Residual norm 3.943330715526e-01
3207 KSP Residual norm 3.943330715526e-01
3208 KSP Residual norm 3.943330715526e-01
3209 KSP Residual norm 3.943330715526e-01
3210 KSP Residual norm 3.943330715529e-01
3211 KSP Residual norm 3.943330715529e-01
3212 KSP Residual norm 3.943330715529e-01
3213 KSP Residual norm 3.943330715529e-01
3214 KSP Residual norm 3.943330715529e-01
3215 KSP Residual norm 3.943330715529e-01
3216 KSP Residual norm 3.943330715529e-01
3217 KSP Residual norm 3.943330715529e-01
3218 KSP Residual norm 3.943330715529e-01
3219 KSP Residual norm 3.943330715529e-01
3220 KSP Residual norm 3.943330715529e-01
3221 KSP Residual norm 3.943330715529e-01
3222 KSP Residual norm 3.943330715529e-01
3223 KSP Residual norm 3.943330715529e-01
3224 KSP Residual norm 3.943330715529e-01
3225 KSP Residual norm 3.943330715529e-01
3226 KSP Residual norm 3.943330715529e-01
3227 KSP Residual norm 3.943330715529e-01
3228 KSP Residual norm 3.943330715529e-01
3229 KSP Residual norm 3.943330715529e-01
3230 KSP Residual norm 3.943330715529e-01
3231 KSP Residual norm 3.943330715529e-01
3232 KSP Residual norm 3.943330715529e-01
3233 KSP Residual norm 3.943330715529e-01
3234 KSP Residual norm 3.943330715529e-01
3235 KSP Residual norm 3.943330715529e-01
3236 KSP Residual norm 3.943330715529e-01
3237 KSP Residual norm 3.943330715529e-01
3238 KSP Residual norm 3.943330715529e-01
3239 KSP Residual norm 3.943330715529e-01
3240 KSP Residual norm 3.943330715529e-01
3241 KSP Residual norm 3.943330715529e-01
3242 KSP Residual norm 3.943330715529e-01
3243 KSP Residual norm 3.943330715529e-01
3244 KSP Residual norm 3.943330715529e-01
3245 KSP Residual norm 3.943330715529e-01
3246 KSP Residual norm 3.943330715529e-01
3247 KSP Residual norm 3.943330715529e-01
3248 KSP Residual norm 3.943330715529e-01
3249 KSP Residual norm 3.943330715529e-01
3250 KSP Residual norm 3.943330715529e-01
3251 KSP Residual norm 3.943330715529e-01
3252 KSP Residual norm 3.943330715529e-01
3253 KSP Residual norm 3.943330715529e-01
3254 KSP Residual norm 3.943330715529e-01
3255 KSP Residual norm 3.943330715529e-01
3256 KSP Residual norm 3.943330715529e-01
3257 KSP Residual norm 3.943330715529e-01
3258 KSP Residual norm 3.943330715529e-01
3259 KSP Residual norm 3.943330715529e-01
3260 KSP Residual norm 3.943330715529e-01
3261 KSP Residual norm 3.943330715529e-01
3262 KSP Residual norm 3.943330715529e-01
3263 KSP Residual norm 3.943330715529e-01
3264 KSP Residual norm 3.943330715529e-01
3265 KSP Residual norm 3.943330715529e-01
3266 KSP Residual norm 3.943330715529e-01
3267 KSP Residual norm 3.943330715529e-01
3268 KSP Residual norm 3.943330715529e-01
3269 KSP Residual norm 3.943330715529e-01
3270 KSP Residual norm 3.943330715530e-01
3271 KSP Residual norm 3.943330715530e-01
3272 KSP Residual norm 3.943330715530e-01
3273 KSP Residual norm 3.943330715530e-01
3274 KSP Residual norm 3.943330715530e-01
3275 KSP Residual norm 3.943330715530e-01
3276 KSP Residual norm 3.943330715530e-01
3277 KSP Residual norm 3.943330715530e-01
3278 KSP Residual norm 3.943330715530e-01
3279 KSP Residual norm 3.943330715530e-01
3280 KSP Residual norm 3.943330715530e-01
3281 KSP Residual norm 3.943330715530e-01
3282 KSP Residual norm 3.943330715530e-01
3283 KSP Residual norm 3.943330715530e-01
3284 KSP Residual norm 3.943330715530e-01
3285 KSP Residual norm 3.943330715530e-01
3286 KSP Residual norm 3.943330715530e-01
3287 KSP Residual norm 3.943330715530e-01
3288 KSP Residual norm 3.943330715530e-01
3289 KSP Residual norm 3.943330715530e-01
3290 KSP Residual norm 3.943330715530e-01
3291 KSP Residual norm 3.943330715530e-01
3292 KSP Residual norm 3.943330715530e-01
3293 KSP Residual norm 3.943330715530e-01
3294 KSP Residual norm 3.943330715530e-01
3295 KSP Residual norm 3.943330715530e-01
3296 KSP Residual norm 3.943330715530e-01
3297 KSP Residual norm 3.943330715530e-01
3298 KSP Residual norm 3.943330715530e-01
3299 KSP Residual norm 3.943330715530e-01
3300 KSP Residual norm 3.943330715529e-01
3301 KSP Residual norm 3.943330715529e-01
3302 KSP Residual norm 3.943330715529e-01
3303 KSP Residual norm 3.943330715529e-01
3304 KSP Residual norm 3.943330715529e-01
3305 KSP Residual norm 3.943330715529e-01
3306 KSP Residual norm 3.943330715529e-01
3307 KSP Residual norm 3.943330715529e-01
3308 KSP Residual norm 3.943330715529e-01
3309 KSP Residual norm 3.943330715529e-01
3310 KSP Residual norm 3.943330715529e-01
3311 KSP Residual norm 3.943330715529e-01
3312 KSP Residual norm 3.943330715529e-01
3313 KSP Residual norm 3.943330715529e-01
3314 KSP Residual norm 3.943330715529e-01
3315 KSP Residual norm 3.943330715529e-01
3316 KSP Residual norm 3.943330715529e-01
3317 KSP Residual norm 3.943330715529e-01
3318 KSP Residual norm 3.943330715529e-01
3319 KSP Residual norm 3.943330715529e-01
3320 KSP Residual norm 3.943330715529e-01
3321 KSP Residual norm 3.943330715529e-01
3322 KSP Residual norm 3.943330715529e-01
3323 KSP Residual norm 3.943330715529e-01
3324 KSP Residual norm 3.943330715529e-01
3325 KSP Residual norm 3.943330715529e-01
3326 KSP Residual norm 3.943330715529e-01
3327 KSP Residual norm 3.943330715528e-01
3328 KSP Residual norm 3.943330715528e-01
3329 KSP Residual norm 3.943330715528e-01
3330 KSP Residual norm 3.943330715531e-01
3331 KSP Residual norm 3.943330715531e-01
3332 KSP Residual norm 3.943330715531e-01
3333 KSP Residual norm 3.943330715531e-01
3334 KSP Residual norm 3.943330715531e-01
3335 KSP Residual norm 3.943330715531e-01
3336 KSP Residual norm 3.943330715531e-01
3337 KSP Residual norm 3.943330715531e-01
3338 KSP Residual norm 3.943330715531e-01
3339 KSP Residual norm 3.943330715531e-01
3340 KSP Residual norm 3.943330715531e-01
3341 KSP Residual norm 3.943330715531e-01
3342 KSP Residual norm 3.943330715531e-01
3343 KSP Residual norm 3.943330715531e-01
3344 KSP Residual norm 3.943330715531e-01
3345 KSP Residual norm 3.943330715531e-01
3346 KSP Residual norm 3.943330715531e-01
3347 KSP Residual norm 3.943330715531e-01
3348 KSP Residual norm 3.943330715531e-01
3349 KSP Residual norm 3.943330715531e-01
3350 KSP Residual norm 3.943330715531e-01
3351 KSP Residual norm 3.943330715531e-01
3352 KSP Residual norm 3.943330715531e-01
3353 KSP Residual norm 3.943330715531e-01
3354 KSP Residual norm 3.943330715531e-01
3355 KSP Residual norm 3.943330715531e-01
3356 KSP Residual norm 3.943330715531e-01
3357 KSP Residual norm 3.943330715531e-01
3358 KSP Residual norm 3.943330715531e-01
3359 KSP Residual norm 3.943330715531e-01
3360 KSP Residual norm 3.943330715530e-01
3361 KSP Residual norm 3.943330715530e-01
3362 KSP Residual norm 3.943330715530e-01
3363 KSP Residual norm 3.943330715530e-01
3364 KSP Residual norm 3.943330715530e-01
3365 KSP Residual norm 3.943330715530e-01
3366 KSP Residual norm 3.943330715530e-01
3367 KSP Residual norm 3.943330715530e-01
3368 KSP Residual norm 3.943330715530e-01
3369 KSP Residual norm 3.943330715530e-01
3370 KSP Residual norm 3.943330715530e-01
3371 KSP Residual norm 3.943330715530e-01
3372 KSP Residual norm 3.943330715530e-01
3373 KSP Residual norm 3.943330715530e-01
3374 KSP Residual norm 3.943330715530e-01
3375 KSP Residual norm 3.943330715530e-01
3376 KSP Residual norm 3.943330715530e-01
3377 KSP Residual norm 3.943330715530e-01
3378 KSP Residual norm 3.943330715530e-01
3379 KSP Residual norm 3.943330715530e-01
3380 KSP Residual norm 3.943330715530e-01
3381 KSP Residual norm 3.943330715530e-01
3382 KSP Residual norm 3.943330715530e-01
3383 KSP Residual norm 3.943330715530e-01
3384 KSP Residual norm 3.943330715530e-01
3385 KSP Residual norm 3.943330715530e-01
3386 KSP Residual norm 3.943330715530e-01
3387 KSP Residual norm 3.943330715530e-01
3388 KSP Residual norm 3.943330715530e-01
3389 KSP Residual norm 3.943330715530e-01
3390 KSP Residual norm 3.943330715530e-01
3391 KSP Residual norm 3.943330715530e-01
3392 KSP Residual norm 3.943330715530e-01
3393 KSP Residual norm 3.943330715530e-01
3394 KSP Residual norm 3.943330715530e-01
3395 KSP Residual norm 3.943330715530e-01
3396 KSP Residual norm 3.943330715530e-01
3397 KSP Residual norm 3.943330715530e-01
3398 KSP Residual norm 3.943330715530e-01
3399 KSP Residual norm 3.943330715530e-01
3400 KSP Residual norm 3.943330715530e-01
3401 KSP Residual norm 3.943330715530e-01
3402 KSP Residual norm 3.943330715530e-01
3403 KSP Residual norm 3.943330715530e-01
3404 KSP Residual norm 3.943330715530e-01
3405 KSP Residual norm 3.943330715530e-01
3406 KSP Residual norm 3.943330715530e-01
3407 KSP Residual norm 3.943330715530e-01
3408 KSP Residual norm 3.943330715530e-01
3409 KSP Residual norm 3.943330715530e-01
3410 KSP Residual norm 3.943330715530e-01
3411 KSP Residual norm 3.943330715530e-01
3412 KSP Residual norm 3.943330715530e-01
3413 KSP Residual norm 3.943330715530e-01
3414 KSP Residual norm 3.943330715530e-01
3415 KSP Residual norm 3.943330715530e-01
3416 KSP Residual norm 3.943330715530e-01
3417 KSP Residual norm 3.943330715530e-01
3418 KSP Residual norm 3.943330715530e-01
3419 KSP Residual norm 3.943330715530e-01
3420 KSP Residual norm 3.943330715530e-01
3421 KSP Residual norm 3.943330715530e-01
3422 KSP Residual norm 3.943330715530e-01
3423 KSP Residual norm 3.943330715530e-01
3424 KSP Residual norm 3.943330715530e-01
3425 KSP Residual norm 3.943330715530e-01
3426 KSP Residual norm 3.943330715530e-01
3427 KSP Residual norm 3.943330715530e-01
3428 KSP Residual norm 3.943330715530e-01
3429 KSP Residual norm 3.943330715530e-01
3430 KSP Residual norm 3.943330715530e-01
3431 KSP Residual norm 3.943330715530e-01
3432 KSP Residual norm 3.943330715530e-01
3433 KSP Residual norm 3.943330715530e-01
3434 KSP Residual norm 3.943330715530e-01
3435 KSP Residual norm 3.943330715530e-01
3436 KSP Residual norm 3.943330715530e-01
3437 KSP Residual norm 3.943330715530e-01
3438 KSP Residual norm 3.943330715530e-01
3439 KSP Residual norm 3.943330715530e-01
3440 KSP Residual norm 3.943330715530e-01
3441 KSP Residual norm 3.943330715530e-01
3442 KSP Residual norm 3.943330715530e-01
3443 KSP Residual norm 3.943330715530e-01
3444 KSP Residual norm 3.943330715530e-01
3445 KSP Residual norm 3.943330715530e-01
3446 KSP Residual norm 3.943330715530e-01
3447 KSP Residual norm 3.943330715530e-01
3448 KSP Residual norm 3.943330715530e-01
3449 KSP Residual norm 3.943330715530e-01
3450 KSP Residual norm 3.943330715529e-01
3451 KSP Residual norm 3.943330715529e-01
3452 KSP Residual norm 3.943330715529e-01
3453 KSP Residual norm 3.943330715529e-01
3454 KSP Residual norm 3.943330715529e-01
3455 KSP Residual norm 3.943330715529e-01
3456 KSP Residual norm 3.943330715529e-01
3457 KSP Residual norm 3.943330715529e-01
3458 KSP Residual norm 3.943330715529e-01
3459 KSP Residual norm 3.943330715529e-01
3460 KSP Residual norm 3.943330715529e-01
3461 KSP Residual norm 3.943330715529e-01
3462 KSP Residual norm 3.943330715529e-01
3463 KSP Residual norm 3.943330715529e-01
3464 KSP Residual norm 3.943330715529e-01
3465 KSP Residual norm 3.943330715529e-01
3466 KSP Residual norm 3.943330715529e-01
3467 KSP Residual norm 3.943330715529e-01
3468 KSP Residual norm 3.943330715529e-01
3469 KSP Residual norm 3.943330715529e-01
3470 KSP Residual norm 3.943330715529e-01
3471 KSP Residual norm 3.943330715529e-01
3472 KSP Residual norm 3.943330715529e-01
3473 KSP Residual norm 3.943330715529e-01
3474 KSP Residual norm 3.943330715529e-01
3475 KSP Residual norm 3.943330715529e-01
3476 KSP Residual norm 3.943330715529e-01
3477 KSP Residual norm 3.943330715529e-01
3478 KSP Residual norm 3.943330715529e-01
3479 KSP Residual norm 3.943330715529e-01
3480 KSP Residual norm 3.943330715531e-01
3481 KSP Residual norm 3.943330715531e-01
3482 KSP Residual norm 3.943330715531e-01
3483 KSP Residual norm 3.943330715531e-01
3484 KSP Residual norm 3.943330715531e-01
3485 KSP Residual norm 3.943330715531e-01
3486 KSP Residual norm 3.943330715531e-01
3487 KSP Residual norm 3.943330715531e-01
3488 KSP Residual norm 3.943330715531e-01
3489 KSP Residual norm 3.943330715531e-01
3490 KSP Residual norm 3.943330715531e-01
3491 KSP Residual norm 3.943330715531e-01
3492 KSP Residual norm 3.943330715531e-01
3493 KSP Residual norm 3.943330715531e-01
3494 KSP Residual norm 3.943330715531e-01
3495 KSP Residual norm 3.943330715531e-01
3496 KSP Residual norm 3.943330715531e-01
3497 KSP Residual norm 3.943330715531e-01
3498 KSP Residual norm 3.943330715531e-01
3499 KSP Residual norm 3.943330715531e-01
3500 KSP Residual norm 3.943330715531e-01
3501 KSP Residual norm 3.943330715531e-01
3502 KSP Residual norm 3.943330715531e-01
3503 KSP Residual norm 3.943330715531e-01
3504 KSP Residual norm 3.943330715531e-01
3505 KSP Residual norm 3.943330715531e-01
3506 KSP Residual norm 3.943330715531e-01
3507 KSP Residual norm 3.943330715531e-01
3508 KSP Residual norm 3.943330715531e-01
3509 KSP Residual norm 3.943330715531e-01
3510 KSP Residual norm 3.943330715527e-01
3511 KSP Residual norm 3.943330715527e-01
3512 KSP Residual norm 3.943330715527e-01
3513 KSP Residual norm 3.943330715527e-01
3514 KSP Residual norm 3.943330715527e-01
3515 KSP Residual norm 3.943330715527e-01
3516 KSP Residual norm 3.943330715527e-01
3517 KSP Residual norm 3.943330715527e-01
3518 KSP Residual norm 3.943330715527e-01
3519 KSP Residual norm 3.943330715527e-01
3520 KSP Residual norm 3.943330715527e-01
3521 KSP Residual norm 3.943330715527e-01
3522 KSP Residual norm 3.943330715527e-01
3523 KSP Residual norm 3.943330715527e-01
3524 KSP Residual norm 3.943330715527e-01
3525 KSP Residual norm 3.943330715527e-01
3526 KSP Residual norm 3.943330715527e-01
3527 KSP Residual norm 3.943330715527e-01
3528 KSP Residual norm 3.943330715527e-01
3529 KSP Residual norm 3.943330715527e-01
3530 KSP Residual norm 3.943330715527e-01
3531 KSP Residual norm 3.943330715527e-01
3532 KSP Residual norm 3.943330715527e-01
3533 KSP Residual norm 3.943330715527e-01
3534 KSP Residual norm 3.943330715527e-01
3535 KSP Residual norm 3.943330715527e-01
3536 KSP Residual norm 3.943330715527e-01
3537 KSP Residual norm 3.943330715527e-01
3538 KSP Residual norm 3.943330715527e-01
3539 KSP Residual norm 3.943330715527e-01
3540 KSP Residual norm 3.943330715530e-01
3541 KSP Residual norm 3.943330715530e-01
3542 KSP Residual norm 3.943330715530e-01
3543 KSP Residual norm 3.943330715530e-01
3544 KSP Residual norm 3.943330715530e-01
3545 KSP Residual norm 3.943330715530e-01
3546 KSP Residual norm 3.943330715530e-01
3547 KSP Residual norm 3.943330715530e-01
3548 KSP Residual norm 3.943330715530e-01
3549 KSP Residual norm 3.943330715530e-01
3550 KSP Residual norm 3.943330715530e-01
3551 KSP Residual norm 3.943330715530e-01
3552 KSP Residual norm 3.943330715530e-01
3553 KSP Residual norm 3.943330715530e-01
3554 KSP Residual norm 3.943330715530e-01
3555 KSP Residual norm 3.943330715530e-01
3556 KSP Residual norm 3.943330715530e-01
3557 KSP Residual norm 3.943330715530e-01
3558 KSP Residual norm 3.943330715530e-01
3559 KSP Residual norm 3.943330715530e-01
3560 KSP Residual norm 3.943330715530e-01
3561 KSP Residual norm 3.943330715530e-01
3562 KSP Residual norm 3.943330715530e-01
3563 KSP Residual norm 3.943330715530e-01
3564 KSP Residual norm 3.943330715530e-01
3565 KSP Residual norm 3.943330715530e-01
3566 KSP Residual norm 3.943330715530e-01
3567 KSP Residual norm 3.943330715530e-01
3568 KSP Residual norm 3.943330715530e-01
3569 KSP Residual norm 3.943330715530e-01
3570 KSP Residual norm 3.943330715528e-01
3571 KSP Residual norm 3.943330715528e-01
3572 KSP Residual norm 3.943330715528e-01
3573 KSP Residual norm 3.943330715528e-01
3574 KSP Residual norm 3.943330715528e-01
3575 KSP Residual norm 3.943330715528e-01
3576 KSP Residual norm 3.943330715528e-01
3577 KSP Residual norm 3.943330715528e-01
3578 KSP Residual norm 3.943330715528e-01
3579 KSP Residual norm 3.943330715528e-01
3580 KSP Residual norm 3.943330715528e-01
3581 KSP Residual norm 3.943330715528e-01
3582 KSP Residual norm 3.943330715528e-01
3583 KSP Residual norm 3.943330715528e-01
3584 KSP Residual norm 3.943330715528e-01
3585 KSP Residual norm 3.943330715528e-01
3586 KSP Residual norm 3.943330715528e-01
3587 KSP Residual norm 3.943330715528e-01
3588 KSP Residual norm 3.943330715528e-01
3589 KSP Residual norm 3.943330715528e-01
3590 KSP Residual norm 3.943330715528e-01
3591 KSP Residual norm 3.943330715528e-01
3592 KSP Residual norm 3.943330715528e-01
3593 KSP Residual norm 3.943330715528e-01
3594 KSP Residual norm 3.943330715528e-01
3595 KSP Residual norm 3.943330715528e-01
3596 KSP Residual norm 3.943330715528e-01
3597 KSP Residual norm 3.943330715528e-01
3598 KSP Residual norm 3.943330715528e-01
3599 KSP Residual norm 3.943330715528e-01
3600 KSP Residual norm 3.943330715528e-01
3601 KSP Residual norm 3.943330715528e-01
3602 KSP Residual norm 3.943330715528e-01
3603 KSP Residual norm 3.943330715528e-01
3604 KSP Residual norm 3.943330715528e-01
3605 KSP Residual norm 3.943330715528e-01
3606 KSP Residual norm 3.943330715528e-01
3607 KSP Residual norm 3.943330715528e-01
3608 KSP Residual norm 3.943330715528e-01
3609 KSP Residual norm 3.943330715528e-01
3610 KSP Residual norm 3.943330715528e-01
3611 KSP Residual norm 3.943330715528e-01
3612 KSP Residual norm 3.943330715528e-01
3613 KSP Residual norm 3.943330715528e-01
3614 KSP Residual norm 3.943330715528e-01
3615 KSP Residual norm 3.943330715528e-01
3616 KSP Residual norm 3.943330715528e-01
3617 KSP Residual norm 3.943330715528e-01
3618 KSP Residual norm 3.943330715528e-01
3619 KSP Residual norm 3.943330715528e-01
3620 KSP Residual norm 3.943330715528e-01
3621 KSP Residual norm 3.943330715528e-01
3622 KSP Residual norm 3.943330715528e-01
3623 KSP Residual norm 3.943330715528e-01
3624 KSP Residual norm 3.943330715528e-01
3625 KSP Residual norm 3.943330715528e-01
3626 KSP Residual norm 3.943330715528e-01
3627 KSP Residual norm 3.943330715528e-01
3628 KSP Residual norm 3.943330715528e-01
3629 KSP Residual norm 3.943330715528e-01
3630 KSP Residual norm 3.943330715528e-01
3631 KSP Residual norm 3.943330715528e-01
3632 KSP Residual norm 3.943330715528e-01
3633 KSP Residual norm 3.943330715528e-01
3634 KSP Residual norm 3.943330715528e-01
3635 KSP Residual norm 3.943330715528e-01
3636 KSP Residual norm 3.943330715528e-01
3637 KSP Residual norm 3.943330715528e-01
3638 KSP Residual norm 3.943330715528e-01
3639 KSP Residual norm 3.943330715528e-01
3640 KSP Residual norm 3.943330715528e-01
3641 KSP Residual norm 3.943330715528e-01
3642 KSP Residual norm 3.943330715528e-01
3643 KSP Residual norm 3.943330715528e-01
3644 KSP Residual norm 3.943330715528e-01
3645 KSP Residual norm 3.943330715528e-01
3646 KSP Residual norm 3.943330715528e-01
3647 KSP Residual norm 3.943330715528e-01
3648 KSP Residual norm 3.943330715528e-01
3649 KSP Residual norm 3.943330715528e-01
3650 KSP Residual norm 3.943330715528e-01
3651 KSP Residual norm 3.943330715528e-01
3652 KSP Residual norm 3.943330715528e-01
3653 KSP Residual norm 3.943330715528e-01
3654 KSP Residual norm 3.943330715528e-01
3655 KSP Residual norm 3.943330715528e-01
3656 KSP Residual norm 3.943330715528e-01
3657 KSP Residual norm 3.943330715528e-01
3658 KSP Residual norm 3.943330715528e-01
3659 KSP Residual norm 3.943330715528e-01
3660 KSP Residual norm 3.943330715527e-01
3661 KSP Residual norm 3.943330715527e-01
3662 KSP Residual norm 3.943330715527e-01
3663 KSP Residual norm 3.943330715527e-01
3664 KSP Residual norm 3.943330715527e-01
3665 KSP Residual norm 3.943330715527e-01
3666 KSP Residual norm 3.943330715527e-01
3667 KSP Residual norm 3.943330715527e-01
3668 KSP Residual norm 3.943330715527e-01
3669 KSP Residual norm 3.943330715527e-01
3670 KSP Residual norm 3.943330715527e-01
3671 KSP Residual norm 3.943330715527e-01
3672 KSP Residual norm 3.943330715527e-01
3673 KSP Residual norm 3.943330715527e-01
3674 KSP Residual norm 3.943330715527e-01
3675 KSP Residual norm 3.943330715527e-01
3676 KSP Residual norm 3.943330715527e-01
3677 KSP Residual norm 3.943330715527e-01
3678 KSP Residual norm 3.943330715527e-01
3679 KSP Residual norm 3.943330715527e-01
3680 KSP Residual norm 3.943330715527e-01
3681 KSP Residual norm 3.943330715527e-01
3682 KSP Residual norm 3.943330715527e-01
3683 KSP Residual norm 3.943330715527e-01
3684 KSP Residual norm 3.943330715527e-01
3685 KSP Residual norm 3.943330715527e-01
3686 KSP Residual norm 3.943330715527e-01
3687 KSP Residual norm 3.943330715527e-01
3688 KSP Residual norm 3.943330715527e-01
3689 KSP Residual norm 3.943330715527e-01
3690 KSP Residual norm 3.943330715529e-01
3691 KSP Residual norm 3.943330715529e-01
3692 KSP Residual norm 3.943330715529e-01
3693 KSP Residual norm 3.943330715529e-01
3694 KSP Residual norm 3.943330715529e-01
3695 KSP Residual norm 3.943330715529e-01
3696 KSP Residual norm 3.943330715529e-01
3697 KSP Residual norm 3.943330715529e-01
3698 KSP Residual norm 3.943330715529e-01
3699 KSP Residual norm 3.943330715529e-01
3700 KSP Residual norm 3.943330715529e-01
3701 KSP Residual norm 3.943330715529e-01
3702 KSP Residual norm 3.943330715529e-01
3703 KSP Residual norm 3.943330715529e-01
3704 KSP Residual norm 3.943330715529e-01
3705 KSP Residual norm 3.943330715529e-01
3706 KSP Residual norm 3.943330715529e-01
3707 KSP Residual norm 3.943330715529e-01
3708 KSP Residual norm 3.943330715529e-01
3709 KSP Residual norm 3.943330715529e-01
3710 KSP Residual norm 3.943330715529e-01
3711 KSP Residual norm 3.943330715529e-01
3712 KSP Residual norm 3.943330715529e-01
3713 KSP Residual norm 3.943330715529e-01
3714 KSP Residual norm 3.943330715529e-01
3715 KSP Residual norm 3.943330715529e-01
3716 KSP Residual norm 3.943330715529e-01
3717 KSP Residual norm 3.943330715529e-01
3718 KSP Residual norm 3.943330715529e-01
3719 KSP Residual norm 3.943330715529e-01
3720 KSP Residual norm 3.943330715529e-01
3721 KSP Residual norm 3.943330715529e-01
3722 KSP Residual norm 3.943330715529e-01
3723 KSP Residual norm 3.943330715529e-01
3724 KSP Residual norm 3.943330715529e-01
3725 KSP Residual norm 3.943330715529e-01
3726 KSP Residual norm 3.943330715529e-01
3727 KSP Residual norm 3.943330715529e-01
3728 KSP Residual norm 3.943330715529e-01
3729 KSP Residual norm 3.943330715529e-01
3730 KSP Residual norm 3.943330715529e-01
3731 KSP Residual norm 3.943330715529e-01
3732 KSP Residual norm 3.943330715529e-01
3733 KSP Residual norm 3.943330715529e-01
3734 KSP Residual norm 3.943330715529e-01
3735 KSP Residual norm 3.943330715529e-01
3736 KSP Residual norm 3.943330715529e-01
3737 KSP Residual norm 3.943330715529e-01
3738 KSP Residual norm 3.943330715529e-01
3739 KSP Residual norm 3.943330715529e-01
3740 KSP Residual norm 3.943330715529e-01
3741 KSP Residual norm 3.943330715529e-01
3742 KSP Residual norm 3.943330715529e-01
3743 KSP Residual norm 3.943330715529e-01
3744 KSP Residual norm 3.943330715529e-01
3745 KSP Residual norm 3.943330715529e-01
3746 KSP Residual norm 3.943330715529e-01
3747 KSP Residual norm 3.943330715529e-01
3748 KSP Residual norm 3.943330715529e-01
3749 KSP Residual norm 3.943330715529e-01
3750 KSP Residual norm 3.943330715530e-01
3751 KSP Residual norm 3.943330715530e-01
3752 KSP Residual norm 3.943330715530e-01
3753 KSP Residual norm 3.943330715530e-01
3754 KSP Residual norm 3.943330715530e-01
3755 KSP Residual norm 3.943330715530e-01
3756 KSP Residual norm 3.943330715530e-01
3757 KSP Residual norm 3.943330715530e-01
3758 KSP Residual norm 3.943330715530e-01
3759 KSP Residual norm 3.943330715530e-01
3760 KSP Residual norm 3.943330715530e-01
3761 KSP Residual norm 3.943330715530e-01
3762 KSP Residual norm 3.943330715530e-01
3763 KSP Residual norm 3.943330715530e-01
3764 KSP Residual norm 3.943330715530e-01
3765 KSP Residual norm 3.943330715530e-01
3766 KSP Residual norm 3.943330715530e-01
3767 KSP Residual norm 3.943330715530e-01
3768 KSP Residual norm 3.943330715530e-01
3769 KSP Residual norm 3.943330715530e-01
3770 KSP Residual norm 3.943330715530e-01
3771 KSP Residual norm 3.943330715530e-01
3772 KSP Residual norm 3.943330715530e-01
3773 KSP Residual norm 3.943330715530e-01
3774 KSP Residual norm 3.943330715530e-01
3775 KSP Residual norm 3.943330715530e-01
3776 KSP Residual norm 3.943330715530e-01
3777 KSP Residual norm 3.943330715530e-01
3778 KSP Residual norm 3.943330715530e-01
3779 KSP Residual norm 3.943330715530e-01
3780 KSP Residual norm 3.943330715527e-01
3781 KSP Residual norm 3.943330715527e-01
3782 KSP Residual norm 3.943330715527e-01
3783 KSP Residual norm 3.943330715527e-01
3784 KSP Residual norm 3.943330715527e-01
3785 KSP Residual norm 3.943330715527e-01
3786 KSP Residual norm 3.943330715527e-01
3787 KSP Residual norm 3.943330715527e-01
3788 KSP Residual norm 3.943330715527e-01
3789 KSP Residual norm 3.943330715527e-01
3790 KSP Residual norm 3.943330715527e-01
3791 KSP Residual norm 3.943330715527e-01
3792 KSP Residual norm 3.943330715527e-01
3793 KSP Residual norm 3.943330715527e-01
3794 KSP Residual norm 3.943330715527e-01
3795 KSP Residual norm 3.943330715527e-01
3796 KSP Residual norm 3.943330715527e-01
3797 KSP Residual norm 3.943330715527e-01
3798 KSP Residual norm 3.943330715527e-01
3799 KSP Residual norm 3.943330715527e-01
3800 KSP Residual norm 3.943330715527e-01
3801 KSP Residual norm 3.943330715527e-01
3802 KSP Residual norm 3.943330715527e-01
3803 KSP Residual norm 3.943330715527e-01
3804 KSP Residual norm 3.943330715527e-01
3805 KSP Residual norm 3.943330715527e-01
3806 KSP Residual norm 3.943330715527e-01
3807 KSP Residual norm 3.943330715527e-01
3808 KSP Residual norm 3.943330715527e-01
3809 KSP Residual norm 3.943330715527e-01
3810 KSP Residual norm 3.943330715528e-01
3811 KSP Residual norm 3.943330715528e-01
3812 KSP Residual norm 3.943330715528e-01
3813 KSP Residual norm 3.943330715528e-01
3814 KSP Residual norm 3.943330715528e-01
3815 KSP Residual norm 3.943330715528e-01
3816 KSP Residual norm 3.943330715528e-01
3817 KSP Residual norm 3.943330715528e-01
3818 KSP Residual norm 3.943330715528e-01
3819 KSP Residual norm 3.943330715528e-01
3820 KSP Residual norm 3.943330715528e-01
3821 KSP Residual norm 3.943330715528e-01
3822 KSP Residual norm 3.943330715528e-01
3823 KSP Residual norm 3.943330715528e-01
3824 KSP Residual norm 3.943330715528e-01
3825 KSP Residual norm 3.943330715528e-01
3826 KSP Residual norm 3.943330715528e-01
3827 KSP Residual norm 3.943330715528e-01
3828 KSP Residual norm 3.943330715528e-01
3829 KSP Residual norm 3.943330715528e-01
3830 KSP Residual norm 3.943330715528e-01
3831 KSP Residual norm 3.943330715528e-01
3832 KSP Residual norm 3.943330715528e-01
3833 KSP Residual norm 3.943330715528e-01
3834 KSP Residual norm 3.943330715528e-01
3835 KSP Residual norm 3.943330715528e-01
3836 KSP Residual norm 3.943330715528e-01
3837 KSP Residual norm 3.943330715528e-01
3838 KSP Residual norm 3.943330715528e-01
3839 KSP Residual norm 3.943330715528e-01
3840 KSP Residual norm 3.943330715527e-01
3841 KSP Residual norm 3.943330715527e-01
3842 KSP Residual norm 3.943330715527e-01
3843 KSP Residual norm 3.943330715527e-01
3844 KSP Residual norm 3.943330715527e-01
3845 KSP Residual norm 3.943330715527e-01
3846 KSP Residual norm 3.943330715527e-01
3847 KSP Residual norm 3.943330715527e-01
3848 KSP Residual norm 3.943330715527e-01
3849 KSP Residual norm 3.943330715527e-01
3850 KSP Residual norm 3.943330715527e-01
3851 KSP Residual norm 3.943330715527e-01
3852 KSP Residual norm 3.943330715527e-01
3853 KSP Residual norm 3.943330715527e-01
3854 KSP Residual norm 3.943330715527e-01
3855 KSP Residual norm 3.943330715527e-01
3856 KSP Residual norm 3.943330715527e-01
3857 KSP Residual norm 3.943330715527e-01
3858 KSP Residual norm 3.943330715527e-01
3859 KSP Residual norm 3.943330715527e-01
3860 KSP Residual norm 3.943330715527e-01
3861 KSP Residual norm 3.943330715527e-01
3862 KSP Residual norm 3.943330715527e-01
3863 KSP Residual norm 3.943330715527e-01
3864 KSP Residual norm 3.943330715527e-01
3865 KSP Residual norm 3.943330715527e-01
3866 KSP Residual norm 3.943330715527e-01
3867 KSP Residual norm 3.943330715527e-01
3868 KSP Residual norm 3.943330715527e-01
3869 KSP Residual norm 3.943330715527e-01
3870 KSP Residual norm 3.943330715525e-01
3871 KSP Residual norm 3.943330715525e-01
3872 KSP Residual norm 3.943330715525e-01
3873 KSP Residual norm 3.943330715525e-01
3874 KSP Residual norm 3.943330715525e-01
3875 KSP Residual norm 3.943330715525e-01
3876 KSP Residual norm 3.943330715525e-01
3877 KSP Residual norm 3.943330715525e-01
3878 KSP Residual norm 3.943330715525e-01
3879 KSP Residual norm 3.943330715525e-01
3880 KSP Residual norm 3.943330715525e-01
3881 KSP Residual norm 3.943330715525e-01
3882 KSP Residual norm 3.943330715525e-01
3883 KSP Residual norm 3.943330715525e-01
3884 KSP Residual norm 3.943330715525e-01
3885 KSP Residual norm 3.943330715525e-01
3886 KSP Residual norm 3.943330715525e-01
3887 KSP Residual norm 3.943330715525e-01
3888 KSP Residual norm 3.943330715525e-01
3889 KSP Residual norm 3.943330715525e-01
3890 KSP Residual norm 3.943330715525e-01
3891 KSP Residual norm 3.943330715525e-01
3892 KSP Residual norm 3.943330715525e-01
3893 KSP Residual norm 3.943330715525e-01
3894 KSP Residual norm 3.943330715525e-01
3895 KSP Residual norm 3.943330715525e-01
3896 KSP Residual norm 3.943330715525e-01
3897 KSP Residual norm 3.943330715525e-01
3898 KSP Residual norm 3.943330715525e-01
3899 KSP Residual norm 3.943330715525e-01
3900 KSP Residual norm 3.943330715529e-01
3901 KSP Residual norm 3.943330715529e-01
3902 KSP Residual norm 3.943330715529e-01
3903 KSP Residual norm 3.943330715529e-01
3904 KSP Residual norm 3.943330715529e-01
3905 KSP Residual norm 3.943330715529e-01
3906 KSP Residual norm 3.943330715529e-01
3907 KSP Residual norm 3.943330715529e-01
3908 KSP Residual norm 3.943330715529e-01
3909 KSP Residual norm 3.943330715529e-01
3910 KSP Residual norm 3.943330715529e-01
3911 KSP Residual norm 3.943330715529e-01
3912 KSP Residual norm 3.943330715529e-01
3913 KSP Residual norm 3.943330715529e-01
3914 KSP Residual norm 3.943330715529e-01
3915 KSP Residual norm 3.943330715529e-01
3916 KSP Residual norm 3.943330715529e-01
3917 KSP Residual norm 3.943330715529e-01
3918 KSP Residual norm 3.943330715529e-01
3919 KSP Residual norm 3.943330715529e-01
3920 KSP Residual norm 3.943330715529e-01
3921 KSP Residual norm 3.943330715529e-01
3922 KSP Residual norm 3.943330715529e-01
3923 KSP Residual norm 3.943330715529e-01
3924 KSP Residual norm 3.943330715529e-01
3925 KSP Residual norm 3.943330715529e-01
3926 KSP Residual norm 3.943330715529e-01
3927 KSP Residual norm 3.943330715529e-01
3928 KSP Residual norm 3.943330715529e-01
3929 KSP Residual norm 3.943330715529e-01
3930 KSP Residual norm 3.943330715529e-01
3931 KSP Residual norm 3.943330715529e-01
3932 KSP Residual norm 3.943330715529e-01
3933 KSP Residual norm 3.943330715529e-01
3934 KSP Residual norm 3.943330715529e-01
3935 KSP Residual norm 3.943330715529e-01
3936 KSP Residual norm 3.943330715529e-01
3937 KSP Residual norm 3.943330715529e-01
3938 KSP Residual norm 3.943330715529e-01
3939 KSP Residual norm 3.943330715529e-01
3940 KSP Residual norm 3.943330715529e-01
3941 KSP Residual norm 3.943330715529e-01
3942 KSP Residual norm 3.943330715529e-01
3943 KSP Residual norm 3.943330715529e-01
3944 KSP Residual norm 3.943330715529e-01
3945 KSP Residual norm 3.943330715529e-01
3946 KSP Residual norm 3.943330715529e-01
3947 KSP Residual norm 3.943330715529e-01
3948 KSP Residual norm 3.943330715529e-01
3949 KSP Residual norm 3.943330715529e-01
3950 KSP Residual norm 3.943330715529e-01
3951 KSP Residual norm 3.943330715529e-01
3952 KSP Residual norm 3.943330715529e-01
3953 KSP Residual norm 3.943330715529e-01
3954 KSP Residual norm 3.943330715529e-01
3955 KSP Residual norm 3.943330715529e-01
3956 KSP Residual norm 3.943330715529e-01
3957 KSP Residual norm 3.943330715529e-01
3958 KSP Residual norm 3.943330715529e-01
3959 KSP Residual norm 3.943330715529e-01
3960 KSP Residual norm 3.943330715529e-01
3961 KSP Residual norm 3.943330715529e-01
3962 KSP Residual norm 3.943330715529e-01
3963 KSP Residual norm 3.943330715529e-01
3964 KSP Residual norm 3.943330715529e-01
3965 KSP Residual norm 3.943330715529e-01
3966 KSP Residual norm 3.943330715529e-01
3967 KSP Residual norm 3.943330715529e-01
3968 KSP Residual norm 3.943330715529e-01
3969 KSP Residual norm 3.943330715529e-01
3970 KSP Residual norm 3.943330715529e-01
3971 KSP Residual norm 3.943330715529e-01
3972 KSP Residual norm 3.943330715529e-01
3973 KSP Residual norm 3.943330715529e-01
3974 KSP Residual norm 3.943330715529e-01
3975 KSP Residual norm 3.943330715529e-01
3976 KSP Residual norm 3.943330715529e-01
3977 KSP Residual norm 3.943330715529e-01
3978 KSP Residual norm 3.943330715529e-01
3979 KSP Residual norm 3.943330715529e-01
3980 KSP Residual norm 3.943330715529e-01
3981 KSP Residual norm 3.943330715529e-01
3982 KSP Residual norm 3.943330715529e-01
3983 KSP Residual norm 3.943330715529e-01
3984 KSP Residual norm 3.943330715529e-01
3985 KSP Residual norm 3.943330715529e-01
3986 KSP Residual norm 3.943330715529e-01
3987 KSP Residual norm 3.943330715529e-01
3988 KSP Residual norm 3.943330715529e-01
3989 KSP Residual norm 3.943330715529e-01
3990 KSP Residual norm 3.943330715530e-01
3991 KSP Residual norm 3.943330715530e-01
3992 KSP Residual norm 3.943330715530e-01
3993 KSP Residual norm 3.943330715530e-01
3994 KSP Residual norm 3.943330715530e-01
3995 KSP Residual norm 3.943330715530e-01
3996 KSP Residual norm 3.943330715530e-01
3997 KSP Residual norm 3.943330715530e-01
3998 KSP Residual norm 3.943330715530e-01
3999 KSP Residual norm 3.943330715530e-01
4000 KSP Residual norm 3.943330715530e-01
4001 KSP Residual norm 3.943330715530e-01
4002 KSP Residual norm 3.943330715530e-01
4003 KSP Residual norm 3.943330715530e-01
4004 KSP Residual norm 3.943330715530e-01
4005 KSP Residual norm 3.943330715530e-01
4006 KSP Residual norm 3.943330715530e-01
4007 KSP Residual norm 3.943330715530e-01
4008 KSP Residual norm 3.943330715530e-01
4009 KSP Residual norm 3.943330715530e-01
4010 KSP Residual norm 3.943330715530e-01
4011 KSP Residual norm 3.943330715530e-01
4012 KSP Residual norm 3.943330715530e-01
4013 KSP Residual norm 3.943330715530e-01
4014 KSP Residual norm 3.943330715530e-01
4015 KSP Residual norm 3.943330715530e-01
4016 KSP Residual norm 3.943330715530e-01
4017 KSP Residual norm 3.943330715530e-01
4018 KSP Residual norm 3.943330715530e-01
4019 KSP Residual norm 3.943330715530e-01
4020 KSP Residual norm 3.943330715531e-01
4021 KSP Residual norm 3.943330715531e-01
4022 KSP Residual norm 3.943330715531e-01
4023 KSP Residual norm 3.943330715531e-01
4024 KSP Residual norm 3.943330715531e-01
4025 KSP Residual norm 3.943330715531e-01
4026 KSP Residual norm 3.943330715531e-01
4027 KSP Residual norm 3.943330715531e-01
4028 KSP Residual norm 3.943330715531e-01
4029 KSP Residual norm 3.943330715531e-01
4030 KSP Residual norm 3.943330715531e-01
4031 KSP Residual norm 3.943330715531e-01
4032 KSP Residual norm 3.943330715531e-01
4033 KSP Residual norm 3.943330715531e-01
4034 KSP Residual norm 3.943330715531e-01
4035 KSP Residual norm 3.943330715531e-01
4036 KSP Residual norm 3.943330715531e-01
4037 KSP Residual norm 3.943330715531e-01
4038 KSP Residual norm 3.943330715531e-01
4039 KSP Residual norm 3.943330715531e-01
4040 KSP Residual norm 3.943330715531e-01
4041 KSP Residual norm 3.943330715531e-01
4042 KSP Residual norm 3.943330715531e-01
4043 KSP Residual norm 3.943330715531e-01
4044 KSP Residual norm 3.943330715531e-01
4045 KSP Residual norm 3.943330715531e-01
4046 KSP Residual norm 3.943330715531e-01
4047 KSP Residual norm 3.943330715531e-01
4048 KSP Residual norm 3.943330715531e-01
4049 KSP Residual norm 3.943330715531e-01
4050 KSP Residual norm 3.943330715531e-01
4051 KSP Residual norm 3.943330715531e-01
4052 KSP Residual norm 3.943330715531e-01
4053 KSP Residual norm 3.943330715531e-01
4054 KSP Residual norm 3.943330715531e-01
4055 KSP Residual norm 3.943330715531e-01
4056 KSP Residual norm 3.943330715531e-01
4057 KSP Residual norm 3.943330715531e-01
4058 KSP Residual norm 3.943330715531e-01
4059 KSP Residual norm 3.943330715531e-01
4060 KSP Residual norm 3.943330715531e-01
4061 KSP Residual norm 3.943330715531e-01
4062 KSP Residual norm 3.943330715531e-01
4063 KSP Residual norm 3.943330715531e-01
4064 KSP Residual norm 3.943330715531e-01
4065 KSP Residual norm 3.943330715531e-01
4066 KSP Residual norm 3.943330715531e-01
4067 KSP Residual norm 3.943330715531e-01
4068 KSP Residual norm 3.943330715531e-01
4069 KSP Residual norm 3.943330715531e-01
4070 KSP Residual norm 3.943330715531e-01
4071 KSP Residual norm 3.943330715531e-01
4072 KSP Residual norm 3.943330715531e-01
4073 KSP Residual norm 3.943330715531e-01
4074 KSP Residual norm 3.943330715531e-01
4075 KSP Residual norm 3.943330715531e-01
4076 KSP Residual norm 3.943330715531e-01
4077 KSP Residual norm 3.943330715531e-01
4078 KSP Residual norm 3.943330715531e-01
4079 KSP Residual norm 3.943330715531e-01
4080 KSP Residual norm 3.943330715532e-01
4081 KSP Residual norm 3.943330715532e-01
4082 KSP Residual norm 3.943330715532e-01
4083 KSP Residual norm 3.943330715532e-01
4084 KSP Residual norm 3.943330715532e-01
4085 KSP Residual norm 3.943330715532e-01
4086 KSP Residual norm 3.943330715532e-01
4087 KSP Residual norm 3.943330715532e-01
4088 KSP Residual norm 3.943330715532e-01
4089 KSP Residual norm 3.943330715532e-01
4090 KSP Residual norm 3.943330715532e-01
4091 KSP Residual norm 3.943330715532e-01
4092 KSP Residual norm 3.943330715532e-01
4093 KSP Residual norm 3.943330715532e-01
4094 KSP Residual norm 3.943330715532e-01
4095 KSP Residual norm 3.943330715532e-01
4096 KSP Residual norm 3.943330715532e-01
4097 KSP Residual norm 3.943330715532e-01
4098 KSP Residual norm 3.943330715532e-01
4099 KSP Residual norm 3.943330715532e-01
4100 KSP Residual norm 3.943330715532e-01
4101 KSP Residual norm 3.943330715532e-01
4102 KSP Residual norm 3.943330715532e-01
4103 KSP Residual norm 3.943330715532e-01
4104 KSP Residual norm 3.943330715532e-01
4105 KSP Residual norm 3.943330715532e-01
4106 KSP Residual norm 3.943330715532e-01
4107 KSP Residual norm 3.943330715532e-01
4108 KSP Residual norm 3.943330715532e-01
4109 KSP Residual norm 3.943330715532e-01
4110 KSP Residual norm 3.943330715532e-01
4111 KSP Residual norm 3.943330715532e-01
4112 KSP Residual norm 3.943330715532e-01
4113 KSP Residual norm 3.943330715532e-01
4114 KSP Residual norm 3.943330715532e-01
4115 KSP Residual norm 3.943330715532e-01
4116 KSP Residual norm 3.943330715532e-01
4117 KSP Residual norm 3.943330715532e-01
4118 KSP Residual norm 3.943330715532e-01
4119 KSP Residual norm 3.943330715532e-01
4120 KSP Residual norm 3.943330715532e-01
4121 KSP Residual norm 3.943330715532e-01
4122 KSP Residual norm 3.943330715532e-01
4123 KSP Residual norm 3.943330715532e-01
4124 KSP Residual norm 3.943330715532e-01
4125 KSP Residual norm 3.943330715532e-01
4126 KSP Residual norm 3.943330715532e-01
4127 KSP Residual norm 3.943330715532e-01
4128 KSP Residual norm 3.943330715532e-01
4129 KSP Residual norm 3.943330715532e-01
4130 KSP Residual norm 3.943330715532e-01
4131 KSP Residual norm 3.943330715532e-01
4132 KSP Residual norm 3.943330715532e-01
4133 KSP Residual norm 3.943330715532e-01
4134 KSP Residual norm 3.943330715532e-01
4135 KSP Residual norm 3.943330715532e-01
4136 KSP Residual norm 3.943330715532e-01
4137 KSP Residual norm 3.943330715532e-01
4138 KSP Residual norm 3.943330715532e-01
4139 KSP Residual norm 3.943330715532e-01
4140 KSP Residual norm 3.943330715532e-01
4141 KSP Residual norm 3.943330715532e-01
4142 KSP Residual norm 3.943330715532e-01
4143 KSP Residual norm 3.943330715532e-01
4144 KSP Residual norm 3.943330715532e-01
4145 KSP Residual norm 3.943330715532e-01
4146 KSP Residual norm 3.943330715532e-01
4147 KSP Residual norm 3.943330715532e-01
4148 KSP Residual norm 3.943330715532e-01
4149 KSP Residual norm 3.943330715532e-01
4150 KSP Residual norm 3.943330715532e-01
4151 KSP Residual norm 3.943330715532e-01
4152 KSP Residual norm 3.943330715532e-01
4153 KSP Residual norm 3.943330715532e-01
4154 KSP Residual norm 3.943330715532e-01
4155 KSP Residual norm 3.943330715532e-01
4156 KSP Residual norm 3.943330715532e-01
4157 KSP Residual norm 3.943330715532e-01
4158 KSP Residual norm 3.943330715532e-01
4159 KSP Residual norm 3.943330715532e-01
4160 KSP Residual norm 3.943330715532e-01
4161 KSP Residual norm 3.943330715532e-01
4162 KSP Residual norm 3.943330715532e-01
4163 KSP Residual norm 3.943330715532e-01
4164 KSP Residual norm 3.943330715532e-01
4165 KSP Residual norm 3.943330715532e-01
4166 KSP Residual norm 3.943330715532e-01
4167 KSP Residual norm 3.943330715532e-01
4168 KSP Residual norm 3.943330715532e-01
4169 KSP Residual norm 3.943330715532e-01
4170 KSP Residual norm 3.943330715531e-01
4171 KSP Residual norm 3.943330715531e-01
4172 KSP Residual norm 3.943330715531e-01
4173 KSP Residual norm 3.943330715531e-01
4174 KSP Residual norm 3.943330715531e-01
4175 KSP Residual norm 3.943330715531e-01
4176 KSP Residual norm 3.943330715531e-01
4177 KSP Residual norm 3.943330715531e-01
4178 KSP Residual norm 3.943330715531e-01
4179 KSP Residual norm 3.943330715531e-01
4180 KSP Residual norm 3.943330715531e-01
4181 KSP Residual norm 3.943330715531e-01
4182 KSP Residual norm 3.943330715531e-01
4183 KSP Residual norm 3.943330715531e-01
4184 KSP Residual norm 3.943330715531e-01
4185 KSP Residual norm 3.943330715531e-01
4186 KSP Residual norm 3.943330715531e-01
4187 KSP Residual norm 3.943330715531e-01
4188 KSP Residual norm 3.943330715531e-01
4189 KSP Residual norm 3.943330715531e-01
4190 KSP Residual norm 3.943330715531e-01
4191 KSP Residual norm 3.943330715531e-01
4192 KSP Residual norm 3.943330715531e-01
4193 KSP Residual norm 3.943330715531e-01
4194 KSP Residual norm 3.943330715531e-01
4195 KSP Residual norm 3.943330715531e-01
4196 KSP Residual norm 3.943330715531e-01
4197 KSP Residual norm 3.943330715531e-01
4198 KSP Residual norm 3.943330715531e-01
4199 KSP Residual norm 3.943330715531e-01
4200 KSP Residual norm 3.943330715533e-01
4201 KSP Residual norm 3.943330715533e-01
4202 KSP Residual norm 3.943330715533e-01
4203 KSP Residual norm 3.943330715533e-01
4204 KSP Residual norm 3.943330715533e-01
4205 KSP Residual norm 3.943330715533e-01
4206 KSP Residual norm 3.943330715533e-01
4207 KSP Residual norm 3.943330715533e-01
4208 KSP Residual norm 3.943330715533e-01
4209 KSP Residual norm 3.943330715533e-01
4210 KSP Residual norm 3.943330715533e-01
4211 KSP Residual norm 3.943330715533e-01
4212 KSP Residual norm 3.943330715533e-01
4213 KSP Residual norm 3.943330715533e-01
4214 KSP Residual norm 3.943330715533e-01
4215 KSP Residual norm 3.943330715533e-01
4216 KSP Residual norm 3.943330715533e-01
4217 KSP Residual norm 3.943330715533e-01
4218 KSP Residual norm 3.943330715533e-01
4219 KSP Residual norm 3.943330715533e-01
4220 KSP Residual norm 3.943330715533e-01
4221 KSP Residual norm 3.943330715533e-01
4222 KSP Residual norm 3.943330715533e-01
4223 KSP Residual norm 3.943330715533e-01
4224 KSP Residual norm 3.943330715533e-01
4225 KSP Residual norm 3.943330715533e-01
4226 KSP Residual norm 3.943330715533e-01
4227 KSP Residual norm 3.943330715533e-01
4228 KSP Residual norm 3.943330715533e-01
4229 KSP Residual norm 3.943330715533e-01
4230 KSP Residual norm 3.943330715531e-01
4231 KSP Residual norm 3.943330715531e-01
4232 KSP Residual norm 3.943330715531e-01
4233 KSP Residual norm 3.943330715531e-01
4234 KSP Residual norm 3.943330715531e-01
4235 KSP Residual norm 3.943330715531e-01
4236 KSP Residual norm 3.943330715531e-01
4237 KSP Residual norm 3.943330715531e-01
4238 KSP Residual norm 3.943330715531e-01
4239 KSP Residual norm 3.943330715531e-01
4240 KSP Residual norm 3.943330715531e-01
4241 KSP Residual norm 3.943330715531e-01
4242 KSP Residual norm 3.943330715531e-01
4243 KSP Residual norm 3.943330715531e-01
4244 KSP Residual norm 3.943330715531e-01
4245 KSP Residual norm 3.943330715531e-01
4246 KSP Residual norm 3.943330715531e-01
4247 KSP Residual norm 3.943330715531e-01
4248 KSP Residual norm 3.943330715531e-01
4249 KSP Residual norm 3.943330715531e-01
4250 KSP Residual norm 3.943330715531e-01
4251 KSP Residual norm 3.943330715531e-01
4252 KSP Residual norm 3.943330715531e-01
4253 KSP Residual norm 3.943330715531e-01
4254 KSP Residual norm 3.943330715531e-01
4255 KSP Residual norm 3.943330715531e-01
4256 KSP Residual norm 3.943330715531e-01
4257 KSP Residual norm 3.943330715531e-01
4258 KSP Residual norm 3.943330715531e-01
4259 KSP Residual norm 3.943330715531e-01
4260 KSP Residual norm 3.943330715531e-01
4261 KSP Residual norm 3.943330715531e-01
4262 KSP Residual norm 3.943330715531e-01
4263 KSP Residual norm 3.943330715531e-01
4264 KSP Residual norm 3.943330715531e-01
4265 KSP Residual norm 3.943330715531e-01
4266 KSP Residual norm 3.943330715531e-01
4267 KSP Residual norm 3.943330715531e-01
4268 KSP Residual norm 3.943330715531e-01
4269 KSP Residual norm 3.943330715531e-01
4270 KSP Residual norm 3.943330715531e-01
4271 KSP Residual norm 3.943330715531e-01
4272 KSP Residual norm 3.943330715531e-01
4273 KSP Residual norm 3.943330715531e-01
4274 KSP Residual norm 3.943330715531e-01
4275 KSP Residual norm 3.943330715531e-01
4276 KSP Residual norm 3.943330715531e-01
4277 KSP Residual norm 3.943330715531e-01
4278 KSP Residual norm 3.943330715531e-01
4279 KSP Residual norm 3.943330715531e-01
4280 KSP Residual norm 3.943330715531e-01
4281 KSP Residual norm 3.943330715531e-01
4282 KSP Residual norm 3.943330715531e-01
4283 KSP Residual norm 3.943330715531e-01
4284 KSP Residual norm 3.943330715531e-01
4285 KSP Residual norm 3.943330715531e-01
4286 KSP Residual norm 3.943330715531e-01
4287 KSP Residual norm 3.943330715531e-01
4288 KSP Residual norm 3.943330715531e-01
4289 KSP Residual norm 3.943330715531e-01
4290 KSP Residual norm 3.943330715532e-01
4291 KSP Residual norm 3.943330715532e-01
4292 KSP Residual norm 3.943330715532e-01
4293 KSP Residual norm 3.943330715532e-01
4294 KSP Residual norm 3.943330715532e-01
4295 KSP Residual norm 3.943330715532e-01
4296 KSP Residual norm 3.943330715532e-01
4297 KSP Residual norm 3.943330715532e-01
4298 KSP Residual norm 3.943330715532e-01
4299 KSP Residual norm 3.943330715532e-01
4300 KSP Residual norm 3.943330715532e-01
4301 KSP Residual norm 3.943330715532e-01
4302 KSP Residual norm 3.943330715532e-01
4303 KSP Residual norm 3.943330715532e-01
4304 KSP Residual norm 3.943330715532e-01
4305 KSP Residual norm 3.943330715532e-01
4306 KSP Residual norm 3.943330715532e-01
4307 KSP Residual norm 3.943330715532e-01
4308 KSP Residual norm 3.943330715532e-01
4309 KSP Residual norm 3.943330715532e-01
4310 KSP Residual norm 3.943330715532e-01
4311 KSP Residual norm 3.943330715532e-01
4312 KSP Residual norm 3.943330715532e-01
4313 KSP Residual norm 3.943330715532e-01
4314 KSP Residual norm 3.943330715532e-01
4315 KSP Residual norm 3.943330715532e-01
4316 KSP Residual norm 3.943330715532e-01
4317 KSP Residual norm 3.943330715532e-01
4318 KSP Residual norm 3.943330715532e-01
4319 KSP Residual norm 3.943330715532e-01
4320 KSP Residual norm 3.943330715532e-01
4321 KSP Residual norm 3.943330715532e-01
4322 KSP Residual norm 3.943330715532e-01
4323 KSP Residual norm 3.943330715532e-01
4324 KSP Residual norm 3.943330715532e-01
4325 KSP Residual norm 3.943330715532e-01
4326 KSP Residual norm 3.943330715532e-01
4327 KSP Residual norm 3.943330715532e-01
4328 KSP Residual norm 3.943330715532e-01
4329 KSP Residual norm 3.943330715532e-01
4330 KSP Residual norm 3.943330715532e-01
4331 KSP Residual norm 3.943330715532e-01
4332 KSP Residual norm 3.943330715532e-01
4333 KSP Residual norm 3.943330715532e-01
4334 KSP Residual norm 3.943330715532e-01
4335 KSP Residual norm 3.943330715532e-01
4336 KSP Residual norm 3.943330715532e-01
4337 KSP Residual norm 3.943330715532e-01
4338 KSP Residual norm 3.943330715532e-01
4339 KSP Residual norm 3.943330715532e-01
4340 KSP Residual norm 3.943330715532e-01
4341 KSP Residual norm 3.943330715532e-01
4342 KSP Residual norm 3.943330715532e-01
4343 KSP Residual norm 3.943330715532e-01
4344 KSP Residual norm 3.943330715532e-01
4345 KSP Residual norm 3.943330715532e-01
4346 KSP Residual norm 3.943330715532e-01
4347 KSP Residual norm 3.943330715532e-01
4348 KSP Residual norm 3.943330715532e-01
4349 KSP Residual norm 3.943330715532e-01
4350 KSP Residual norm 3.943330715532e-01
4351 KSP Residual norm 3.943330715532e-01
4352 KSP Residual norm 3.943330715532e-01
4353 KSP Residual norm 3.943330715532e-01
4354 KSP Residual norm 3.943330715532e-01
4355 KSP Residual norm 3.943330715532e-01
4356 KSP Residual norm 3.943330715532e-01
4357 KSP Residual norm 3.943330715532e-01
4358 KSP Residual norm 3.943330715532e-01
4359 KSP Residual norm 3.943330715532e-01
4360 KSP Residual norm 3.943330715532e-01
4361 KSP Residual norm 3.943330715532e-01
4362 KSP Residual norm 3.943330715532e-01
4363 KSP Residual norm 3.943330715532e-01
4364 KSP Residual norm 3.943330715532e-01
4365 KSP Residual norm 3.943330715532e-01
4366 KSP Residual norm 3.943330715532e-01
4367 KSP Residual norm 3.943330715532e-01
4368 KSP Residual norm 3.943330715532e-01
4369 KSP Residual norm 3.943330715532e-01
4370 KSP Residual norm 3.943330715532e-01
4371 KSP Residual norm 3.943330715532e-01
4372 KSP Residual norm 3.943330715532e-01
4373 KSP Residual norm 3.943330715532e-01
4374 KSP Residual norm 3.943330715532e-01
4375 KSP Residual norm 3.943330715532e-01
4376 KSP Residual norm 3.943330715532e-01
4377 KSP Residual norm 3.943330715532e-01
4378 KSP Residual norm 3.943330715532e-01
4379 KSP Residual norm 3.943330715532e-01
4380 KSP Residual norm 3.943330715532e-01
4381 KSP Residual norm 3.943330715532e-01
4382 KSP Residual norm 3.943330715532e-01
4383 KSP Residual norm 3.943330715532e-01
4384 KSP Residual norm 3.943330715532e-01
4385 KSP Residual norm 3.943330715532e-01
4386 KSP Residual norm 3.943330715532e-01
4387 KSP Residual norm 3.943330715532e-01
4388 KSP Residual norm 3.943330715532e-01
4389 KSP Residual norm 3.943330715532e-01
4390 KSP Residual norm 3.943330715532e-01
4391 KSP Residual norm 3.943330715532e-01
4392 KSP Residual norm 3.943330715532e-01
4393 KSP Residual norm 3.943330715532e-01
4394 KSP Residual norm 3.943330715532e-01
4395 KSP Residual norm 3.943330715532e-01
4396 KSP Residual norm 3.943330715532e-01
4397 KSP Residual norm 3.943330715532e-01
4398 KSP Residual norm 3.943330715532e-01
4399 KSP Residual norm 3.943330715532e-01
4400 KSP Residual norm 3.943330715532e-01
4401 KSP Residual norm 3.943330715532e-01
4402 KSP Residual norm 3.943330715532e-01
4403 KSP Residual norm 3.943330715532e-01
4404 KSP Residual norm 3.943330715532e-01
4405 KSP Residual norm 3.943330715532e-01
4406 KSP Residual norm 3.943330715532e-01
4407 KSP Residual norm 3.943330715532e-01
4408 KSP Residual norm 3.943330715532e-01
4409 KSP Residual norm 3.943330715532e-01
4410 KSP Residual norm 3.943330715532e-01
4411 KSP Residual norm 3.943330715532e-01
4412 KSP Residual norm 3.943330715532e-01
4413 KSP Residual norm 3.943330715532e-01
4414 KSP Residual norm 3.943330715532e-01
4415 KSP Residual norm 3.943330715532e-01
4416 KSP Residual norm 3.943330715532e-01
4417 KSP Residual norm 3.943330715532e-01
4418 KSP Residual norm 3.943330715532e-01
4419 KSP Residual norm 3.943330715532e-01
4420 KSP Residual norm 3.943330715532e-01
4421 KSP Residual norm 3.943330715532e-01
4422 KSP Residual norm 3.943330715532e-01
4423 KSP Residual norm 3.943330715532e-01
4424 KSP Residual norm 3.943330715532e-01
4425 KSP Residual norm 3.943330715532e-01
4426 KSP Residual norm 3.943330715532e-01
4427 KSP Residual norm 3.943330715532e-01
4428 KSP Residual norm 3.943330715532e-01
4429 KSP Residual norm 3.943330715532e-01
4430 KSP Residual norm 3.943330715532e-01
4431 KSP Residual norm 3.943330715532e-01
4432 KSP Residual norm 3.943330715532e-01
4433 KSP Residual norm 3.943330715532e-01
4434 KSP Residual norm 3.943330715532e-01
4435 KSP Residual norm 3.943330715532e-01
4436 KSP Residual norm 3.943330715532e-01
4437 KSP Residual norm 3.943330715532e-01
4438 KSP Residual norm 3.943330715532e-01
4439 KSP Residual norm 3.943330715532e-01
4440 KSP Residual norm 3.943330715530e-01
4441 KSP Residual norm 3.943330715530e-01
4442 KSP Residual norm 3.943330715530e-01
4443 KSP Residual norm 3.943330715530e-01
4444 KSP Residual norm 3.943330715530e-01
4445 KSP Residual norm 3.943330715530e-01
4446 KSP Residual norm 3.943330715530e-01
4447 KSP Residual norm 3.943330715530e-01
4448 KSP Residual norm 3.943330715530e-01
4449 KSP Residual norm 3.943330715530e-01
4450 KSP Residual norm 3.943330715530e-01
4451 KSP Residual norm 3.943330715530e-01
4452 KSP Residual norm 3.943330715530e-01
4453 KSP Residual norm 3.943330715530e-01
4454 KSP Residual norm 3.943330715530e-01
4455 KSP Residual norm 3.943330715530e-01
4456 KSP Residual norm 3.943330715530e-01
4457 KSP Residual norm 3.943330715530e-01
4458 KSP Residual norm 3.943330715530e-01
4459 KSP Residual norm 3.943330715530e-01
4460 KSP Residual norm 3.943330715530e-01
4461 KSP Residual norm 3.943330715530e-01
4462 KSP Residual norm 3.943330715530e-01
4463 KSP Residual norm 3.943330715530e-01
4464 KSP Residual norm 3.943330715530e-01
4465 KSP Residual norm 3.943330715530e-01
4466 KSP Residual norm 3.943330715530e-01
4467 KSP Residual norm 3.943330715530e-01
4468 KSP Residual norm 3.943330715530e-01
4469 KSP Residual norm 3.943330715530e-01
4470 KSP Residual norm 3.943330715532e-01
4471 KSP Residual norm 3.943330715532e-01
4472 KSP Residual norm 3.943330715532e-01
4473 KSP Residual norm 3.943330715532e-01
4474 KSP Residual norm 3.943330715532e-01
4475 KSP Residual norm 3.943330715532e-01
4476 KSP Residual norm 3.943330715532e-01
4477 KSP Residual norm 3.943330715532e-01
4478 KSP Residual norm 3.943330715532e-01
4479 KSP Residual norm 3.943330715532e-01
4480 KSP Residual norm 3.943330715532e-01
4481 KSP Residual norm 3.943330715532e-01
4482 KSP Residual norm 3.943330715532e-01
4483 KSP Residual norm 3.943330715532e-01
4484 KSP Residual norm 3.943330715532e-01
4485 KSP Residual norm 3.943330715532e-01
4486 KSP Residual norm 3.943330715532e-01
4487 KSP Residual norm 3.943330715532e-01
4488 KSP Residual norm 3.943330715532e-01
4489 KSP Residual norm 3.943330715532e-01
4490 KSP Residual norm 3.943330715532e-01
4491 KSP Residual norm 3.943330715532e-01
4492 KSP Residual norm 3.943330715532e-01
4493 KSP Residual norm 3.943330715532e-01
4494 KSP Residual norm 3.943330715532e-01
4495 KSP Residual norm 3.943330715532e-01
4496 KSP Residual norm 3.943330715532e-01
4497 KSP Residual norm 3.943330715532e-01
4498 KSP Residual norm 3.943330715532e-01
4499 KSP Residual norm 3.943330715532e-01
4500 KSP Residual norm 3.943330715531e-01
4501 KSP Residual norm 3.943330715531e-01
4502 KSP Residual norm 3.943330715531e-01
4503 KSP Residual norm 3.943330715531e-01
4504 KSP Residual norm 3.943330715531e-01
4505 KSP Residual norm 3.943330715531e-01
4506 KSP Residual norm 3.943330715531e-01
4507 KSP Residual norm 3.943330715531e-01
4508 KSP Residual norm 3.943330715531e-01
4509 KSP Residual norm 3.943330715531e-01
4510 KSP Residual norm 3.943330715531e-01
4511 KSP Residual norm 3.943330715531e-01
4512 KSP Residual norm 3.943330715531e-01
4513 KSP Residual norm 3.943330715531e-01
4514 KSP Residual norm 3.943330715531e-01
4515 KSP Residual norm 3.943330715531e-01
4516 KSP Residual norm 3.943330715531e-01
4517 KSP Residual norm 3.943330715531e-01
4518 KSP Residual norm 3.943330715531e-01
4519 KSP Residual norm 3.943330715531e-01
4520 KSP Residual norm 3.943330715531e-01
4521 KSP Residual norm 3.943330715531e-01
4522 KSP Residual norm 3.943330715531e-01
4523 KSP Residual norm 3.943330715531e-01
4524 KSP Residual norm 3.943330715531e-01
4525 KSP Residual norm 3.943330715531e-01
4526 KSP Residual norm 3.943330715531e-01
4527 KSP Residual norm 3.943330715531e-01
4528 KSP Residual norm 3.943330715531e-01
4529 KSP Residual norm 3.943330715531e-01
4530 KSP Residual norm 3.943330715532e-01
4531 KSP Residual norm 3.943330715532e-01
4532 KSP Residual norm 3.943330715532e-01
4533 KSP Residual norm 3.943330715532e-01
4534 KSP Residual norm 3.943330715532e-01
4535 KSP Residual norm 3.943330715532e-01
4536 KSP Residual norm 3.943330715532e-01
4537 KSP Residual norm 3.943330715532e-01
4538 KSP Residual norm 3.943330715532e-01
4539 KSP Residual norm 3.943330715532e-01
4540 KSP Residual norm 3.943330715532e-01
4541 KSP Residual norm 3.943330715532e-01
4542 KSP Residual norm 3.943330715532e-01
4543 KSP Residual norm 3.943330715532e-01
4544 KSP Residual norm 3.943330715532e-01
4545 KSP Residual norm 3.943330715532e-01
4546 KSP Residual norm 3.943330715532e-01
4547 KSP Residual norm 3.943330715532e-01
4548 KSP Residual norm 3.943330715532e-01
4549 KSP Residual norm 3.943330715532e-01
4550 KSP Residual norm 3.943330715532e-01
4551 KSP Residual norm 3.943330715532e-01
4552 KSP Residual norm 3.943330715532e-01
4553 KSP Residual norm 3.943330715532e-01
4554 KSP Residual norm 3.943330715532e-01
4555 KSP Residual norm 3.943330715532e-01
4556 KSP Residual norm 3.943330715532e-01
4557 KSP Residual norm 3.943330715532e-01
4558 KSP Residual norm 3.943330715532e-01
4559 KSP Residual norm 3.943330715532e-01
4560 KSP Residual norm 3.943330715535e-01
4561 KSP Residual norm 3.943330715535e-01
4562 KSP Residual norm 3.943330715535e-01
4563 KSP Residual norm 3.943330715535e-01
4564 KSP Residual norm 3.943330715535e-01
4565 KSP Residual norm 3.943330715535e-01
4566 KSP Residual norm 3.943330715535e-01
4567 KSP Residual norm 3.943330715535e-01
4568 KSP Residual norm 3.943330715535e-01
4569 KSP Residual norm 3.943330715535e-01
4570 KSP Residual norm 3.943330715535e-01
4571 KSP Residual norm 3.943330715535e-01
4572 KSP Residual norm 3.943330715535e-01
4573 KSP Residual norm 3.943330715535e-01
4574 KSP Residual norm 3.943330715535e-01
4575 KSP Residual norm 3.943330715535e-01
4576 KSP Residual norm 3.943330715535e-01
4577 KSP Residual norm 3.943330715535e-01
4578 KSP Residual norm 3.943330715535e-01
4579 KSP Residual norm 3.943330715535e-01
4580 KSP Residual norm 3.943330715535e-01
4581 KSP Residual norm 3.943330715535e-01
4582 KSP Residual norm 3.943330715535e-01
4583 KSP Residual norm 3.943330715535e-01
4584 KSP Residual norm 3.943330715535e-01
4585 KSP Residual norm 3.943330715535e-01
4586 KSP Residual norm 3.943330715535e-01
4587 KSP Residual norm 3.943330715535e-01
4588 KSP Residual norm 3.943330715535e-01
4589 KSP Residual norm 3.943330715535e-01
4590 KSP Residual norm 3.943330715533e-01
4591 KSP Residual norm 3.943330715533e-01
4592 KSP Residual norm 3.943330715533e-01
4593 KSP Residual norm 3.943330715533e-01
4594 KSP Residual norm 3.943330715533e-01
4595 KSP Residual norm 3.943330715533e-01
4596 KSP Residual norm 3.943330715533e-01
4597 KSP Residual norm 3.943330715533e-01
4598 KSP Residual norm 3.943330715533e-01
4599 KSP Residual norm 3.943330715533e-01
4600 KSP Residual norm 3.943330715533e-01
4601 KSP Residual norm 3.943330715533e-01
4602 KSP Residual norm 3.943330715533e-01
4603 KSP Residual norm 3.943330715533e-01
4604 KSP Residual norm 3.943330715533e-01
4605 KSP Residual norm 3.943330715533e-01
4606 KSP Residual norm 3.943330715533e-01
4607 KSP Residual norm 3.943330715533e-01
4608 KSP Residual norm 3.943330715533e-01
4609 KSP Residual norm 3.943330715533e-01
4610 KSP Residual norm 3.943330715533e-01
4611 KSP Residual norm 3.943330715533e-01
4612 KSP Residual norm 3.943330715533e-01
4613 KSP Residual norm 3.943330715533e-01
4614 KSP Residual norm 3.943330715533e-01
4615 KSP Residual norm 3.943330715533e-01
4616 KSP Residual norm 3.943330715533e-01
4617 KSP Residual norm 3.943330715533e-01
4618 KSP Residual norm 3.943330715533e-01
4619 KSP Residual norm 3.943330715533e-01
4620 KSP Residual norm 3.943330715532e-01
4621 KSP Residual norm 3.943330715532e-01
4622 KSP Residual norm 3.943330715532e-01
4623 KSP Residual norm 3.943330715532e-01
4624 KSP Residual norm 3.943330715532e-01
4625 KSP Residual norm 3.943330715532e-01
4626 KSP Residual norm 3.943330715532e-01
4627 KSP Residual norm 3.943330715532e-01
4628 KSP Residual norm 3.943330715532e-01
4629 KSP Residual norm 3.943330715532e-01
4630 KSP Residual norm 3.943330715532e-01
4631 KSP Residual norm 3.943330715532e-01
4632 KSP Residual norm 3.943330715532e-01
4633 KSP Residual norm 3.943330715532e-01
4634 KSP Residual norm 3.943330715532e-01
4635 KSP Residual norm 3.943330715532e-01
4636 KSP Residual norm 3.943330715532e-01
4637 KSP Residual norm 3.943330715532e-01
4638 KSP Residual norm 3.943330715532e-01
4639 KSP Residual norm 3.943330715532e-01
4640 KSP Residual norm 3.943330715532e-01
4641 KSP Residual norm 3.943330715532e-01
4642 KSP Residual norm 3.943330715532e-01
4643 KSP Residual norm 3.943330715532e-01
4644 KSP Residual norm 3.943330715532e-01
4645 KSP Residual norm 3.943330715532e-01
4646 KSP Residual norm 3.943330715532e-01
4647 KSP Residual norm 3.943330715532e-01
4648 KSP Residual norm 3.943330715532e-01
4649 KSP Residual norm 3.943330715532e-01
4650 KSP Residual norm 3.943330715531e-01
4651 KSP Residual norm 3.943330715531e-01
4652 KSP Residual norm 3.943330715531e-01
4653 KSP Residual norm 3.943330715531e-01
4654 KSP Residual norm 3.943330715531e-01
4655 KSP Residual norm 3.943330715531e-01
4656 KSP Residual norm 3.943330715531e-01
4657 KSP Residual norm 3.943330715531e-01
4658 KSP Residual norm 3.943330715531e-01
4659 KSP Residual norm 3.943330715531e-01
4660 KSP Residual norm 3.943330715531e-01
4661 KSP Residual norm 3.943330715531e-01
4662 KSP Residual norm 3.943330715531e-01
4663 KSP Residual norm 3.943330715531e-01
4664 KSP Residual norm 3.943330715531e-01
4665 KSP Residual norm 3.943330715531e-01
4666 KSP Residual norm 3.943330715531e-01
4667 KSP Residual norm 3.943330715531e-01
4668 KSP Residual norm 3.943330715531e-01
4669 KSP Residual norm 3.943330715531e-01
4670 KSP Residual norm 3.943330715531e-01
4671 KSP Residual norm 3.943330715531e-01
4672 KSP Residual norm 3.943330715531e-01
4673 KSP Residual norm 3.943330715531e-01
4674 KSP Residual norm 3.943330715531e-01
4675 KSP Residual norm 3.943330715531e-01
4676 KSP Residual norm 3.943330715531e-01
4677 KSP Residual norm 3.943330715531e-01
4678 KSP Residual norm 3.943330715531e-01
4679 KSP Residual norm 3.943330715531e-01
4680 KSP Residual norm 3.943330715530e-01
4681 KSP Residual norm 3.943330715530e-01
4682 KSP Residual norm 3.943330715530e-01
4683 KSP Residual norm 3.943330715530e-01
4684 KSP Residual norm 3.943330715530e-01
4685 KSP Residual norm 3.943330715530e-01
4686 KSP Residual norm 3.943330715530e-01
4687 KSP Residual norm 3.943330715530e-01
4688 KSP Residual norm 3.943330715530e-01
4689 KSP Residual norm 3.943330715530e-01
4690 KSP Residual norm 3.943330715530e-01
4691 KSP Residual norm 3.943330715530e-01
4692 KSP Residual norm 3.943330715530e-01
4693 KSP Residual norm 3.943330715530e-01
4694 KSP Residual norm 3.943330715530e-01
4695 KSP Residual norm 3.943330715530e-01
4696 KSP Residual norm 3.943330715530e-01
4697 KSP Residual norm 3.943330715530e-01
4698 KSP Residual norm 3.943330715530e-01
4699 KSP Residual norm 3.943330715530e-01
4700 KSP Residual norm 3.943330715530e-01
4701 KSP Residual norm 3.943330715530e-01
4702 KSP Residual norm 3.943330715530e-01
4703 KSP Residual norm 3.943330715530e-01
4704 KSP Residual norm 3.943330715530e-01
4705 KSP Residual norm 3.943330715530e-01
4706 KSP Residual norm 3.943330715530e-01
4707 KSP Residual norm 3.943330715530e-01
4708 KSP Residual norm 3.943330715530e-01
4709 KSP Residual norm 3.943330715530e-01
4710 KSP Residual norm 3.943330715532e-01
4711 KSP Residual norm 3.943330715532e-01
4712 KSP Residual norm 3.943330715532e-01
4713 KSP Residual norm 3.943330715532e-01
4714 KSP Residual norm 3.943330715532e-01
4715 KSP Residual norm 3.943330715532e-01
4716 KSP Residual norm 3.943330715532e-01
4717 KSP Residual norm 3.943330715532e-01
4718 KSP Residual norm 3.943330715532e-01
4719 KSP Residual norm 3.943330715532e-01
4720 KSP Residual norm 3.943330715532e-01
4721 KSP Residual norm 3.943330715532e-01
4722 KSP Residual norm 3.943330715532e-01
4723 KSP Residual norm 3.943330715532e-01
4724 KSP Residual norm 3.943330715532e-01
4725 KSP Residual norm 3.943330715532e-01
4726 KSP Residual norm 3.943330715532e-01
4727 KSP Residual norm 3.943330715532e-01
4728 KSP Residual norm 3.943330715532e-01
4729 KSP Residual norm 3.943330715532e-01
4730 KSP Residual norm 3.943330715532e-01
4731 KSP Residual norm 3.943330715532e-01
4732 KSP Residual norm 3.943330715532e-01
4733 KSP Residual norm 3.943330715532e-01
4734 KSP Residual norm 3.943330715532e-01
4735 KSP Residual norm 3.943330715532e-01
4736 KSP Residual norm 3.943330715532e-01
4737 KSP Residual norm 3.943330715532e-01
4738 KSP Residual norm 3.943330715532e-01
4739 KSP Residual norm 3.943330715532e-01
4740 KSP Residual norm 3.943330715530e-01
4741 KSP Residual norm 3.943330715530e-01
4742 KSP Residual norm 3.943330715530e-01
4743 KSP Residual norm 3.943330715530e-01
4744 KSP Residual norm 3.943330715530e-01
4745 KSP Residual norm 3.943330715530e-01
4746 KSP Residual norm 3.943330715530e-01
4747 KSP Residual norm 3.943330715530e-01
4748 KSP Residual norm 3.943330715530e-01
4749 KSP Residual norm 3.943330715530e-01
4750 KSP Residual norm 3.943330715530e-01
4751 KSP Residual norm 3.943330715530e-01
4752 KSP Residual norm 3.943330715530e-01
4753 KSP Residual norm 3.943330715530e-01
4754 KSP Residual norm 3.943330715530e-01
4755 KSP Residual norm 3.943330715530e-01
4756 KSP Residual norm 3.943330715530e-01
4757 KSP Residual norm 3.943330715530e-01
4758 KSP Residual norm 3.943330715530e-01
4759 KSP Residual norm 3.943330715530e-01
4760 KSP Residual norm 3.943330715530e-01
4761 KSP Residual norm 3.943330715530e-01
4762 KSP Residual norm 3.943330715530e-01
4763 KSP Residual norm 3.943330715530e-01
4764 KSP Residual norm 3.943330715530e-01
4765 KSP Residual norm 3.943330715530e-01
4766 KSP Residual norm 3.943330715530e-01
4767 KSP Residual norm 3.943330715530e-01
4768 KSP Residual norm 3.943330715530e-01
4769 KSP Residual norm 3.943330715530e-01
4770 KSP Residual norm 3.943330715530e-01
4771 KSP Residual norm 3.943330715530e-01
4772 KSP Residual norm 3.943330715530e-01
4773 KSP Residual norm 3.943330715530e-01
4774 KSP Residual norm 3.943330715530e-01
4775 KSP Residual norm 3.943330715530e-01
4776 KSP Residual norm 3.943330715530e-01
4777 KSP Residual norm 3.943330715530e-01
4778 KSP Residual norm 3.943330715530e-01
4779 KSP Residual norm 3.943330715530e-01
4780 KSP Residual norm 3.943330715530e-01
4781 KSP Residual norm 3.943330715530e-01
4782 KSP Residual norm 3.943330715530e-01
4783 KSP Residual norm 3.943330715530e-01
4784 KSP Residual norm 3.943330715530e-01
4785 KSP Residual norm 3.943330715530e-01
4786 KSP Residual norm 3.943330715530e-01
4787 KSP Residual norm 3.943330715530e-01
4788 KSP Residual norm 3.943330715530e-01
4789 KSP Residual norm 3.943330715530e-01
4790 KSP Residual norm 3.943330715530e-01
4791 KSP Residual norm 3.943330715530e-01
4792 KSP Residual norm 3.943330715530e-01
4793 KSP Residual norm 3.943330715530e-01
4794 KSP Residual norm 3.943330715530e-01
4795 KSP Residual norm 3.943330715530e-01
4796 KSP Residual norm 3.943330715530e-01
4797 KSP Residual norm 3.943330715530e-01
4798 KSP Residual norm 3.943330715530e-01
4799 KSP Residual norm 3.943330715530e-01
4800 KSP Residual norm 3.943330715530e-01
4801 KSP Residual norm 3.943330715530e-01
4802 KSP Residual norm 3.943330715530e-01
4803 KSP Residual norm 3.943330715530e-01
4804 KSP Residual norm 3.943330715530e-01
4805 KSP Residual norm 3.943330715530e-01
4806 KSP Residual norm 3.943330715530e-01
4807 KSP Residual norm 3.943330715530e-01
4808 KSP Residual norm 3.943330715530e-01
4809 KSP Residual norm 3.943330715530e-01
4810 KSP Residual norm 3.943330715530e-01
4811 KSP Residual norm 3.943330715530e-01
4812 KSP Residual norm 3.943330715530e-01
4813 KSP Residual norm 3.943330715530e-01
4814 KSP Residual norm 3.943330715530e-01
4815 KSP Residual norm 3.943330715530e-01
4816 KSP Residual norm 3.943330715530e-01
4817 KSP Residual norm 3.943330715530e-01
4818 KSP Residual norm 3.943330715530e-01
4819 KSP Residual norm 3.943330715530e-01
4820 KSP Residual norm 3.943330715530e-01
4821 KSP Residual norm 3.943330715530e-01
4822 KSP Residual norm 3.943330715530e-01
4823 KSP Residual norm 3.943330715530e-01
4824 KSP Residual norm 3.943330715530e-01
4825 KSP Residual norm 3.943330715530e-01
4826 KSP Residual norm 3.943330715530e-01
4827 KSP Residual norm 3.943330715530e-01
4828 KSP Residual norm 3.943330715530e-01
4829 KSP Residual norm 3.943330715530e-01
4830 KSP Residual norm 3.943330715531e-01
4831 KSP Residual norm 3.943330715531e-01
4832 KSP Residual norm 3.943330715531e-01
4833 KSP Residual norm 3.943330715531e-01
4834 KSP Residual norm 3.943330715531e-01
4835 KSP Residual norm 3.943330715531e-01
4836 KSP Residual norm 3.943330715531e-01
4837 KSP Residual norm 3.943330715531e-01
4838 KSP Residual norm 3.943330715531e-01
4839 KSP Residual norm 3.943330715531e-01
4840 KSP Residual norm 3.943330715531e-01
4841 KSP Residual norm 3.943330715531e-01
4842 KSP Residual norm 3.943330715531e-01
4843 KSP Residual norm 3.943330715531e-01
4844 KSP Residual norm 3.943330715531e-01
4845 KSP Residual norm 3.943330715531e-01
4846 KSP Residual norm 3.943330715531e-01
4847 KSP Residual norm 3.943330715531e-01
4848 KSP Residual norm 3.943330715531e-01
4849 KSP Residual norm 3.943330715531e-01
4850 KSP Residual norm 3.943330715531e-01
4851 KSP Residual norm 3.943330715531e-01
4852 KSP Residual norm 3.943330715531e-01
4853 KSP Residual norm 3.943330715531e-01
4854 KSP Residual norm 3.943330715531e-01
4855 KSP Residual norm 3.943330715531e-01
4856 KSP Residual norm 3.943330715531e-01
4857 KSP Residual norm 3.943330715531e-01
4858 KSP Residual norm 3.943330715531e-01
4859 KSP Residual norm 3.943330715531e-01
4860 KSP Residual norm 3.943330715530e-01
4861 KSP Residual norm 3.943330715530e-01
4862 KSP Residual norm 3.943330715530e-01
4863 KSP Residual norm 3.943330715530e-01
4864 KSP Residual norm 3.943330715530e-01
4865 KSP Residual norm 3.943330715530e-01
4866 KSP Residual norm 3.943330715530e-01
4867 KSP Residual norm 3.943330715530e-01
4868 KSP Residual norm 3.943330715530e-01
4869 KSP Residual norm 3.943330715530e-01
4870 KSP Residual norm 3.943330715530e-01
4871 KSP Residual norm 3.943330715530e-01
4872 KSP Residual norm 3.943330715530e-01
4873 KSP Residual norm 3.943330715530e-01
4874 KSP Residual norm 3.943330715530e-01
4875 KSP Residual norm 3.943330715530e-01
4876 KSP Residual norm 3.943330715530e-01
4877 KSP Residual norm 3.943330715530e-01
4878 KSP Residual norm 3.943330715530e-01
4879 KSP Residual norm 3.943330715530e-01
4880 KSP Residual norm 3.943330715530e-01
4881 KSP Residual norm 3.943330715530e-01
4882 KSP Residual norm 3.943330715530e-01
4883 KSP Residual norm 3.943330715530e-01
4884 KSP Residual norm 3.943330715530e-01
4885 KSP Residual norm 3.943330715530e-01
4886 KSP Residual norm 3.943330715530e-01
4887 KSP Residual norm 3.943330715530e-01
4888 KSP Residual norm 3.943330715530e-01
4889 KSP Residual norm 3.943330715530e-01
4890 KSP Residual norm 3.943330715530e-01
4891 KSP Residual norm 3.943330715530e-01
4892 KSP Residual norm 3.943330715530e-01
4893 KSP Residual norm 3.943330715530e-01
4894 KSP Residual norm 3.943330715530e-01
4895 KSP Residual norm 3.943330715530e-01
4896 KSP Residual norm 3.943330715530e-01
4897 KSP Residual norm 3.943330715530e-01
4898 KSP Residual norm 3.943330715530e-01
4899 KSP Residual norm 3.943330715530e-01
4900 KSP Residual norm 3.943330715530e-01
4901 KSP Residual norm 3.943330715530e-01
4902 KSP Residual norm 3.943330715530e-01
4903 KSP Residual norm 3.943330715530e-01
4904 KSP Residual norm 3.943330715530e-01
4905 KSP Residual norm 3.943330715530e-01
4906 KSP Residual norm 3.943330715530e-01
4907 KSP Residual norm 3.943330715530e-01
4908 KSP Residual norm 3.943330715530e-01
4909 KSP Residual norm 3.943330715530e-01
4910 KSP Residual norm 3.943330715530e-01
4911 KSP Residual norm 3.943330715530e-01
4912 KSP Residual norm 3.943330715530e-01
4913 KSP Residual norm 3.943330715530e-01
4914 KSP Residual norm 3.943330715530e-01
4915 KSP Residual norm 3.943330715530e-01
4916 KSP Residual norm 3.943330715530e-01
4917 KSP Residual norm 3.943330715530e-01
4918 KSP Residual norm 3.943330715530e-01
4919 KSP Residual norm 3.943330715530e-01
4920 KSP Residual norm 3.943330715532e-01
4921 KSP Residual norm 3.943330715532e-01
4922 KSP Residual norm 3.943330715532e-01
4923 KSP Residual norm 3.943330715532e-01
4924 KSP Residual norm 3.943330715532e-01
4925 KSP Residual norm 3.943330715532e-01
4926 KSP Residual norm 3.943330715532e-01
4927 KSP Residual norm 3.943330715532e-01
4928 KSP Residual norm 3.943330715532e-01
4929 KSP Residual norm 3.943330715532e-01
4930 KSP Residual norm 3.943330715532e-01
4931 KSP Residual norm 3.943330715532e-01
4932 KSP Residual norm 3.943330715532e-01
4933 KSP Residual norm 3.943330715532e-01
4934 KSP Residual norm 3.943330715532e-01
4935 KSP Residual norm 3.943330715532e-01
4936 KSP Residual norm 3.943330715532e-01
4937 KSP Residual norm 3.943330715532e-01
4938 KSP Residual norm 3.943330715532e-01
4939 KSP Residual norm 3.943330715532e-01
4940 KSP Residual norm 3.943330715532e-01
4941 KSP Residual norm 3.943330715532e-01
4942 KSP Residual norm 3.943330715532e-01
4943 KSP Residual norm 3.943330715532e-01
4944 KSP Residual norm 3.943330715532e-01
4945 KSP Residual norm 3.943330715532e-01
4946 KSP Residual norm 3.943330715532e-01
4947 KSP Residual norm 3.943330715532e-01
4948 KSP Residual norm 3.943330715532e-01
4949 KSP Residual norm 3.943330715532e-01
4950 KSP Residual norm 3.943330715531e-01
4951 KSP Residual norm 3.943330715531e-01
4952 KSP Residual norm 3.943330715531e-01
4953 KSP Residual norm 3.943330715531e-01
4954 KSP Residual norm 3.943330715531e-01
4955 KSP Residual norm 3.943330715531e-01
4956 KSP Residual norm 3.943330715531e-01
4957 KSP Residual norm 3.943330715531e-01
4958 KSP Residual norm 3.943330715531e-01
4959 KSP Residual norm 3.943330715531e-01
4960 KSP Residual norm 3.943330715531e-01
4961 KSP Residual norm 3.943330715531e-01
4962 KSP Residual norm 3.943330715531e-01
4963 KSP Residual norm 3.943330715531e-01
4964 KSP Residual norm 3.943330715531e-01
4965 KSP Residual norm 3.943330715531e-01
4966 KSP Residual norm 3.943330715531e-01
4967 KSP Residual norm 3.943330715531e-01
4968 KSP Residual norm 3.943330715531e-01
4969 KSP Residual norm 3.943330715531e-01
4970 KSP Residual norm 3.943330715531e-01
4971 KSP Residual norm 3.943330715531e-01
4972 KSP Residual norm 3.943330715531e-01
4973 KSP Residual norm 3.943330715531e-01
4974 KSP Residual norm 3.943330715531e-01
4975 KSP Residual norm 3.943330715531e-01
4976 KSP Residual norm 3.943330715531e-01
4977 KSP Residual norm 3.943330715531e-01
4978 KSP Residual norm 3.943330715531e-01
4979 KSP Residual norm 3.943330715531e-01
4980 KSP Residual norm 3.943330715531e-01
4981 KSP Residual norm 3.943330715531e-01
4982 KSP Residual norm 3.943330715531e-01
4983 KSP Residual norm 3.943330715531e-01
4984 KSP Residual norm 3.943330715531e-01
4985 KSP Residual norm 3.943330715531e-01
4986 KSP Residual norm 3.943330715531e-01
4987 KSP Residual norm 3.943330715531e-01
4988 KSP Residual norm 3.943330715531e-01
4989 KSP Residual norm 3.943330715531e-01
4990 KSP Residual norm 3.943330715531e-01
4991 KSP Residual norm 3.943330715531e-01
4992 KSP Residual norm 3.943330715531e-01
4993 KSP Residual norm 3.943330715531e-01
4994 KSP Residual norm 3.943330715531e-01
4995 KSP Residual norm 3.943330715531e-01
4996 KSP Residual norm 3.943330715531e-01
4997 KSP Residual norm 3.943330715531e-01
4998 KSP Residual norm 3.943330715531e-01
4999 KSP Residual norm 3.943330715531e-01
5000 KSP Residual norm 3.943330715531e-01
5001 KSP Residual norm 3.943330715531e-01
5002 KSP Residual norm 3.943330715531e-01
5003 KSP Residual norm 3.943330715531e-01
5004 KSP Residual norm 3.943330715531e-01
5005 KSP Residual norm 3.943330715531e-01
5006 KSP Residual norm 3.943330715531e-01
5007 KSP Residual norm 3.943330715531e-01
5008 KSP Residual norm 3.943330715531e-01
5009 KSP Residual norm 3.943330715531e-01
5010 KSP Residual norm 3.943330715532e-01
5011 KSP Residual norm 3.943330715532e-01
5012 KSP Residual norm 3.943330715532e-01
5013 KSP Residual norm 3.943330715532e-01
5014 KSP Residual norm 3.943330715532e-01
5015 KSP Residual norm 3.943330715532e-01
5016 KSP Residual norm 3.943330715532e-01
5017 KSP Residual norm 3.943330715532e-01
5018 KSP Residual norm 3.943330715532e-01
5019 KSP Residual norm 3.943330715532e-01
5020 KSP Residual norm 3.943330715532e-01
5021 KSP Residual norm 3.943330715532e-01
5022 KSP Residual norm 3.943330715532e-01
5023 KSP Residual norm 3.943330715532e-01
5024 KSP Residual norm 3.943330715532e-01
5025 KSP Residual norm 3.943330715532e-01
5026 KSP Residual norm 3.943330715532e-01
5027 KSP Residual norm 3.943330715532e-01
5028 KSP Residual norm 3.943330715532e-01
5029 KSP Residual norm 3.943330715532e-01
5030 KSP Residual norm 3.943330715532e-01
5031 KSP Residual norm 3.943330715532e-01
5032 KSP Residual norm 3.943330715532e-01
5033 KSP Residual norm 3.943330715532e-01
5034 KSP Residual norm 3.943330715532e-01
5035 KSP Residual norm 3.943330715532e-01
5036 KSP Residual norm 3.943330715532e-01
5037 KSP Residual norm 3.943330715532e-01
5038 KSP Residual norm 3.943330715532e-01
5039 KSP Residual norm 3.943330715532e-01
5040 KSP Residual norm 3.943330715533e-01
5041 KSP Residual norm 3.943330715533e-01
5042 KSP Residual norm 3.943330715533e-01
5043 KSP Residual norm 3.943330715533e-01
5044 KSP Residual norm 3.943330715533e-01
5045 KSP Residual norm 3.943330715533e-01
5046 KSP Residual norm 3.943330715533e-01
5047 KSP Residual norm 3.943330715533e-01
5048 KSP Residual norm 3.943330715533e-01
5049 KSP Residual norm 3.943330715533e-01
5050 KSP Residual norm 3.943330715533e-01
5051 KSP Residual norm 3.943330715533e-01
5052 KSP Residual norm 3.943330715533e-01
5053 KSP Residual norm 3.943330715533e-01
5054 KSP Residual norm 3.943330715533e-01
5055 KSP Residual norm 3.943330715533e-01
5056 KSP Residual norm 3.943330715533e-01
5057 KSP Residual norm 3.943330715533e-01
5058 KSP Residual norm 3.943330715533e-01
5059 KSP Residual norm 3.943330715533e-01
5060 KSP Residual norm 3.943330715533e-01
5061 KSP Residual norm 3.943330715533e-01
5062 KSP Residual norm 3.943330715533e-01
5063 KSP Residual norm 3.943330715533e-01
5064 KSP Residual norm 3.943330715533e-01
5065 KSP Residual norm 3.943330715533e-01
5066 KSP Residual norm 3.943330715533e-01
5067 KSP Residual norm 3.943330715533e-01
5068 KSP Residual norm 3.943330715533e-01
5069 KSP Residual norm 3.943330715533e-01
5070 KSP Residual norm 3.943330715535e-01
5071 KSP Residual norm 3.943330715535e-01
5072 KSP Residual norm 3.943330715535e-01
5073 KSP Residual norm 3.943330715535e-01
5074 KSP Residual norm 3.943330715535e-01
5075 KSP Residual norm 3.943330715535e-01
5076 KSP Residual norm 3.943330715535e-01
5077 KSP Residual norm 3.943330715535e-01
5078 KSP Residual norm 3.943330715535e-01
5079 KSP Residual norm 3.943330715535e-01
5080 KSP Residual norm 3.943330715535e-01
5081 KSP Residual norm 3.943330715535e-01
5082 KSP Residual norm 3.943330715535e-01
5083 KSP Residual norm 3.943330715535e-01
5084 KSP Residual norm 3.943330715535e-01
5085 KSP Residual norm 3.943330715535e-01
5086 KSP Residual norm 3.943330715535e-01
5087 KSP Residual norm 3.943330715535e-01
5088 KSP Residual norm 3.943330715535e-01
5089 KSP Residual norm 3.943330715535e-01
5090 KSP Residual norm 3.943330715535e-01
5091 KSP Residual norm 3.943330715535e-01
5092 KSP Residual norm 3.943330715535e-01
5093 KSP Residual norm 3.943330715535e-01
5094 KSP Residual norm 3.943330715535e-01
5095 KSP Residual norm 3.943330715535e-01
5096 KSP Residual norm 3.943330715535e-01
5097 KSP Residual norm 3.943330715535e-01
5098 KSP Residual norm 3.943330715535e-01
5099 KSP Residual norm 3.943330715535e-01
5100 KSP Residual norm 3.943330715535e-01
5101 KSP Residual norm 3.943330715535e-01
5102 KSP Residual norm 3.943330715535e-01
5103 KSP Residual norm 3.943330715535e-01
5104 KSP Residual norm 3.943330715535e-01
5105 KSP Residual norm 3.943330715535e-01
5106 KSP Residual norm 3.943330715535e-01
5107 KSP Residual norm 3.943330715535e-01
5108 KSP Residual norm 3.943330715535e-01
5109 KSP Residual norm 3.943330715535e-01
5110 KSP Residual norm 3.943330715535e-01
5111 KSP Residual norm 3.943330715535e-01
5112 KSP Residual norm 3.943330715535e-01
5113 KSP Residual norm 3.943330715535e-01
5114 KSP Residual norm 3.943330715535e-01
5115 KSP Residual norm 3.943330715535e-01
5116 KSP Residual norm 3.943330715535e-01
5117 KSP Residual norm 3.943330715535e-01
5118 KSP Residual norm 3.943330715535e-01
5119 KSP Residual norm 3.943330715535e-01
5120 KSP Residual norm 3.943330715535e-01
5121 KSP Residual norm 3.943330715535e-01
5122 KSP Residual norm 3.943330715535e-01
5123 KSP Residual norm 3.943330715535e-01
5124 KSP Residual norm 3.943330715535e-01
5125 KSP Residual norm 3.943330715535e-01
5126 KSP Residual norm 3.943330715535e-01
5127 KSP Residual norm 3.943330715535e-01
5128 KSP Residual norm 3.943330715535e-01
5129 KSP Residual norm 3.943330715535e-01
5130 KSP Residual norm 3.943330715534e-01
5131 KSP Residual norm 3.943330715534e-01
5132 KSP Residual norm 3.943330715534e-01
5133 KSP Residual norm 3.943330715534e-01
5134 KSP Residual norm 3.943330715534e-01
5135 KSP Residual norm 3.943330715534e-01
5136 KSP Residual norm 3.943330715534e-01
5137 KSP Residual norm 3.943330715534e-01
5138 KSP Residual norm 3.943330715534e-01
5139 KSP Residual norm 3.943330715534e-01
5140 KSP Residual norm 3.943330715534e-01
5141 KSP Residual norm 3.943330715534e-01
5142 KSP Residual norm 3.943330715534e-01
5143 KSP Residual norm 3.943330715534e-01
5144 KSP Residual norm 3.943330715534e-01
5145 KSP Residual norm 3.943330715534e-01
5146 KSP Residual norm 3.943330715534e-01
5147 KSP Residual norm 3.943330715534e-01
5148 KSP Residual norm 3.943330715534e-01
5149 KSP Residual norm 3.943330715534e-01
5150 KSP Residual norm 3.943330715534e-01
5151 KSP Residual norm 3.943330715534e-01
5152 KSP Residual norm 3.943330715534e-01
5153 KSP Residual norm 3.943330715534e-01
5154 KSP Residual norm 3.943330715534e-01
5155 KSP Residual norm 3.943330715534e-01
5156 KSP Residual norm 3.943330715534e-01
5157 KSP Residual norm 3.943330715534e-01
5158 KSP Residual norm 3.943330715534e-01
5159 KSP Residual norm 3.943330715534e-01
5160 KSP Residual norm 3.943330715533e-01
5161 KSP Residual norm 3.943330715533e-01
5162 KSP Residual norm 3.943330715533e-01
5163 KSP Residual norm 3.943330715533e-01
5164 KSP Residual norm 3.943330715533e-01
5165 KSP Residual norm 3.943330715533e-01
5166 KSP Residual norm 3.943330715533e-01
5167 KSP Residual norm 3.943330715533e-01
5168 KSP Residual norm 3.943330715533e-01
5169 KSP Residual norm 3.943330715533e-01
5170 KSP Residual norm 3.943330715533e-01
5171 KSP Residual norm 3.943330715533e-01
5172 KSP Residual norm 3.943330715533e-01
5173 KSP Residual norm 3.943330715533e-01
5174 KSP Residual norm 3.943330715533e-01
5175 KSP Residual norm 3.943330715533e-01
5176 KSP Residual norm 3.943330715533e-01
5177 KSP Residual norm 3.943330715533e-01
5178 KSP Residual norm 3.943330715533e-01
5179 KSP Residual norm 3.943330715533e-01
5180 KSP Residual norm 3.943330715533e-01
5181 KSP Residual norm 3.943330715533e-01
5182 KSP Residual norm 3.943330715533e-01
5183 KSP Residual norm 3.943330715533e-01
5184 KSP Residual norm 3.943330715533e-01
5185 KSP Residual norm 3.943330715533e-01
5186 KSP Residual norm 3.943330715533e-01
5187 KSP Residual norm 3.943330715533e-01
5188 KSP Residual norm 3.943330715533e-01
5189 KSP Residual norm 3.943330715533e-01
5190 KSP Residual norm 3.943330715533e-01
5191 KSP Residual norm 3.943330715533e-01
5192 KSP Residual norm 3.943330715533e-01
5193 KSP Residual norm 3.943330715533e-01
5194 KSP Residual norm 3.943330715533e-01
5195 KSP Residual norm 3.943330715533e-01
5196 KSP Residual norm 3.943330715533e-01
5197 KSP Residual norm 3.943330715533e-01
5198 KSP Residual norm 3.943330715533e-01
5199 KSP Residual norm 3.943330715533e-01
5200 KSP Residual norm 3.943330715533e-01
5201 KSP Residual norm 3.943330715533e-01
5202 KSP Residual norm 3.943330715533e-01
5203 KSP Residual norm 3.943330715533e-01
5204 KSP Residual norm 3.943330715533e-01
5205 KSP Residual norm 3.943330715533e-01
5206 KSP Residual norm 3.943330715533e-01
5207 KSP Residual norm 3.943330715533e-01
5208 KSP Residual norm 3.943330715533e-01
5209 KSP Residual norm 3.943330715533e-01
5210 KSP Residual norm 3.943330715533e-01
5211 KSP Residual norm 3.943330715533e-01
5212 KSP Residual norm 3.943330715533e-01
5213 KSP Residual norm 3.943330715533e-01
5214 KSP Residual norm 3.943330715533e-01
5215 KSP Residual norm 3.943330715533e-01
5216 KSP Residual norm 3.943330715533e-01
5217 KSP Residual norm 3.943330715533e-01
5218 KSP Residual norm 3.943330715533e-01
5219 KSP Residual norm 3.943330715533e-01
5220 KSP Residual norm 3.943330715536e-01
5221 KSP Residual norm 3.943330715536e-01
5222 KSP Residual norm 3.943330715536e-01
5223 KSP Residual norm 3.943330715536e-01
5224 KSP Residual norm 3.943330715536e-01
5225 KSP Residual norm 3.943330715536e-01
5226 KSP Residual norm 3.943330715536e-01
5227 KSP Residual norm 3.943330715536e-01
5228 KSP Residual norm 3.943330715536e-01
5229 KSP Residual norm 3.943330715536e-01
5230 KSP Residual norm 3.943330715536e-01
5231 KSP Residual norm 3.943330715536e-01
5232 KSP Residual norm 3.943330715536e-01
5233 KSP Residual norm 3.943330715536e-01
5234 KSP Residual norm 3.943330715536e-01
5235 KSP Residual norm 3.943330715536e-01
5236 KSP Residual norm 3.943330715536e-01
5237 KSP Residual norm 3.943330715536e-01
5238 KSP Residual norm 3.943330715536e-01
5239 KSP Residual norm 3.943330715536e-01
5240 KSP Residual norm 3.943330715536e-01
5241 KSP Residual norm 3.943330715536e-01
5242 KSP Residual norm 3.943330715536e-01
5243 KSP Residual norm 3.943330715536e-01
5244 KSP Residual norm 3.943330715536e-01
5245 KSP Residual norm 3.943330715536e-01
5246 KSP Residual norm 3.943330715536e-01
5247 KSP Residual norm 3.943330715536e-01
5248 KSP Residual norm 3.943330715536e-01
5249 KSP Residual norm 3.943330715536e-01
5250 KSP Residual norm 3.943330715538e-01
5251 KSP Residual norm 3.943330715538e-01
5252 KSP Residual norm 3.943330715538e-01
5253 KSP Residual norm 3.943330715538e-01
5254 KSP Residual norm 3.943330715538e-01
5255 KSP Residual norm 3.943330715538e-01
5256 KSP Residual norm 3.943330715538e-01
5257 KSP Residual norm 3.943330715538e-01
5258 KSP Residual norm 3.943330715538e-01
5259 KSP Residual norm 3.943330715538e-01
5260 KSP Residual norm 3.943330715538e-01
5261 KSP Residual norm 3.943330715538e-01
5262 KSP Residual norm 3.943330715538e-01
5263 KSP Residual norm 3.943330715538e-01
5264 KSP Residual norm 3.943330715538e-01
5265 KSP Residual norm 3.943330715538e-01
5266 KSP Residual norm 3.943330715538e-01
5267 KSP Residual norm 3.943330715538e-01
5268 KSP Residual norm 3.943330715538e-01
5269 KSP Residual norm 3.943330715538e-01
5270 KSP Residual norm 3.943330715538e-01
5271 KSP Residual norm 3.943330715538e-01
5272 KSP Residual norm 3.943330715538e-01
5273 KSP Residual norm 3.943330715538e-01
5274 KSP Residual norm 3.943330715538e-01
5275 KSP Residual norm 3.943330715538e-01
5276 KSP Residual norm 3.943330715538e-01
5277 KSP Residual norm 3.943330715538e-01
5278 KSP Residual norm 3.943330715538e-01
5279 KSP Residual norm 3.943330715538e-01
5280 KSP Residual norm 3.943330715538e-01
5281 KSP Residual norm 3.943330715538e-01
5282 KSP Residual norm 3.943330715538e-01
5283 KSP Residual norm 3.943330715538e-01
5284 KSP Residual norm 3.943330715538e-01
5285 KSP Residual norm 3.943330715538e-01
5286 KSP Residual norm 3.943330715538e-01
5287 KSP Residual norm 3.943330715538e-01
5288 KSP Residual norm 3.943330715538e-01
5289 KSP Residual norm 3.943330715538e-01
5290 KSP Residual norm 3.943330715538e-01
5291 KSP Residual norm 3.943330715538e-01
5292 KSP Residual norm 3.943330715538e-01
5293 KSP Residual norm 3.943330715538e-01
5294 KSP Residual norm 3.943330715538e-01
5295 KSP Residual norm 3.943330715538e-01
5296 KSP Residual norm 3.943330715538e-01
5297 KSP Residual norm 3.943330715538e-01
5298 KSP Residual norm 3.943330715538e-01
5299 KSP Residual norm 3.943330715538e-01
5300 KSP Residual norm 3.943330715538e-01
5301 KSP Residual norm 3.943330715538e-01
5302 KSP Residual norm 3.943330715538e-01
5303 KSP Residual norm 3.943330715538e-01
5304 KSP Residual norm 3.943330715538e-01
5305 KSP Residual norm 3.943330715538e-01
5306 KSP Residual norm 3.943330715538e-01
5307 KSP Residual norm 3.943330715538e-01
5308 KSP Residual norm 3.943330715538e-01
5309 KSP Residual norm 3.943330715538e-01
5310 KSP Residual norm 3.943330715538e-01
5311 KSP Residual norm 3.943330715538e-01
5312 KSP Residual norm 3.943330715538e-01
5313 KSP Residual norm 3.943330715538e-01
5314 KSP Residual norm 3.943330715538e-01
5315 KSP Residual norm 3.943330715538e-01
5316 KSP Residual norm 3.943330715538e-01
5317 KSP Residual norm 3.943330715538e-01
5318 KSP Residual norm 3.943330715538e-01
5319 KSP Residual norm 3.943330715538e-01
5320 KSP Residual norm 3.943330715538e-01
5321 KSP Residual norm 3.943330715538e-01
5322 KSP Residual norm 3.943330715538e-01
5323 KSP Residual norm 3.943330715538e-01
5324 KSP Residual norm 3.943330715538e-01
5325 KSP Residual norm 3.943330715538e-01
5326 KSP Residual norm 3.943330715538e-01
5327 KSP Residual norm 3.943330715538e-01
5328 KSP Residual norm 3.943330715538e-01
5329 KSP Residual norm 3.943330715538e-01
5330 KSP Residual norm 3.943330715538e-01
5331 KSP Residual norm 3.943330715538e-01
5332 KSP Residual norm 3.943330715538e-01
5333 KSP Residual norm 3.943330715538e-01
5334 KSP Residual norm 3.943330715538e-01
5335 KSP Residual norm 3.943330715538e-01
5336 KSP Residual norm 3.943330715538e-01
5337 KSP Residual norm 3.943330715538e-01
5338 KSP Residual norm 3.943330715538e-01
5339 KSP Residual norm 3.943330715538e-01
5340 KSP Residual norm 3.943330715539e-01
5341 KSP Residual norm 3.943330715539e-01
5342 KSP Residual norm 3.943330715539e-01
5343 KSP Residual norm 3.943330715539e-01
5344 KSP Residual norm 3.943330715539e-01
5345 KSP Residual norm 3.943330715539e-01
5346 KSP Residual norm 3.943330715539e-01
5347 KSP Residual norm 3.943330715539e-01
5348 KSP Residual norm 3.943330715539e-01
5349 KSP Residual norm 3.943330715539e-01
5350 KSP Residual norm 3.943330715539e-01
5351 KSP Residual norm 3.943330715539e-01
5352 KSP Residual norm 3.943330715539e-01
5353 KSP Residual norm 3.943330715539e-01
5354 KSP Residual norm 3.943330715539e-01
5355 KSP Residual norm 3.943330715539e-01
5356 KSP Residual norm 3.943330715539e-01
5357 KSP Residual norm 3.943330715539e-01
5358 KSP Residual norm 3.943330715539e-01
5359 KSP Residual norm 3.943330715539e-01
5360 KSP Residual norm 3.943330715539e-01
5361 KSP Residual norm 3.943330715539e-01
5362 KSP Residual norm 3.943330715539e-01
5363 KSP Residual norm 3.943330715539e-01
5364 KSP Residual norm 3.943330715539e-01
5365 KSP Residual norm 3.943330715539e-01
5366 KSP Residual norm 3.943330715539e-01
5367 KSP Residual norm 3.943330715539e-01
5368 KSP Residual norm 3.943330715539e-01
5369 KSP Residual norm 3.943330715539e-01
5370 KSP Residual norm 3.943330715539e-01
5371 KSP Residual norm 3.943330715539e-01
5372 KSP Residual norm 3.943330715539e-01
5373 KSP Residual norm 3.943330715539e-01
5374 KSP Residual norm 3.943330715539e-01
5375 KSP Residual norm 3.943330715539e-01
5376 KSP Residual norm 3.943330715539e-01
5377 KSP Residual norm 3.943330715539e-01
5378 KSP Residual norm 3.943330715539e-01
5379 KSP Residual norm 3.943330715539e-01
5380 KSP Residual norm 3.943330715539e-01
5381 KSP Residual norm 3.943330715539e-01
5382 KSP Residual norm 3.943330715539e-01
5383 KSP Residual norm 3.943330715539e-01
5384 KSP Residual norm 3.943330715539e-01
5385 KSP Residual norm 3.943330715539e-01
5386 KSP Residual norm 3.943330715539e-01
5387 KSP Residual norm 3.943330715539e-01
5388 KSP Residual norm 3.943330715539e-01
5389 KSP Residual norm 3.943330715539e-01
5390 KSP Residual norm 3.943330715539e-01
5391 KSP Residual norm 3.943330715539e-01
5392 KSP Residual norm 3.943330715539e-01
5393 KSP Residual norm 3.943330715539e-01
5394 KSP Residual norm 3.943330715539e-01
5395 KSP Residual norm 3.943330715539e-01
5396 KSP Residual norm 3.943330715539e-01
5397 KSP Residual norm 3.943330715539e-01
5398 KSP Residual norm 3.943330715539e-01
5399 KSP Residual norm 3.943330715539e-01
5400 KSP Residual norm 3.943330715539e-01
5401 KSP Residual norm 3.943330715539e-01
5402 KSP Residual norm 3.943330715539e-01
5403 KSP Residual norm 3.943330715539e-01
5404 KSP Residual norm 3.943330715539e-01
5405 KSP Residual norm 3.943330715539e-01
5406 KSP Residual norm 3.943330715539e-01
5407 KSP Residual norm 3.943330715539e-01
5408 KSP Residual norm 3.943330715539e-01
5409 KSP Residual norm 3.943330715539e-01
5410 KSP Residual norm 3.943330715539e-01
5411 KSP Residual norm 3.943330715539e-01
5412 KSP Residual norm 3.943330715539e-01
5413 KSP Residual norm 3.943330715539e-01
5414 KSP Residual norm 3.943330715539e-01
5415 KSP Residual norm 3.943330715539e-01
5416 KSP Residual norm 3.943330715539e-01
5417 KSP Residual norm 3.943330715539e-01
5418 KSP Residual norm 3.943330715539e-01
5419 KSP Residual norm 3.943330715539e-01
5420 KSP Residual norm 3.943330715539e-01
5421 KSP Residual norm 3.943330715539e-01
5422 KSP Residual norm 3.943330715539e-01
5423 KSP Residual norm 3.943330715539e-01
5424 KSP Residual norm 3.943330715539e-01
5425 KSP Residual norm 3.943330715539e-01
5426 KSP Residual norm 3.943330715539e-01
5427 KSP Residual norm 3.943330715539e-01
5428 KSP Residual norm 3.943330715539e-01
5429 KSP Residual norm 3.943330715539e-01
5430 KSP Residual norm 3.943330715538e-01
5431 KSP Residual norm 3.943330715538e-01
5432 KSP Residual norm 3.943330715538e-01
5433 KSP Residual norm 3.943330715538e-01
5434 KSP Residual norm 3.943330715538e-01
5435 KSP Residual norm 3.943330715538e-01
5436 KSP Residual norm 3.943330715538e-01
5437 KSP Residual norm 3.943330715538e-01
5438 KSP Residual norm 3.943330715538e-01
5439 KSP Residual norm 3.943330715538e-01
5440 KSP Residual norm 3.943330715538e-01
5441 KSP Residual norm 3.943330715538e-01
5442 KSP Residual norm 3.943330715538e-01
5443 KSP Residual norm 3.943330715538e-01
5444 KSP Residual norm 3.943330715538e-01
5445 KSP Residual norm 3.943330715538e-01
5446 KSP Residual norm 3.943330715538e-01
5447 KSP Residual norm 3.943330715538e-01
5448 KSP Residual norm 3.943330715538e-01
5449 KSP Residual norm 3.943330715538e-01
5450 KSP Residual norm 3.943330715538e-01
5451 KSP Residual norm 3.943330715538e-01
5452 KSP Residual norm 3.943330715538e-01
5453 KSP Residual norm 3.943330715538e-01
5454 KSP Residual norm 3.943330715538e-01
5455 KSP Residual norm 3.943330715538e-01
5456 KSP Residual norm 3.943330715538e-01
5457 KSP Residual norm 3.943330715538e-01
5458 KSP Residual norm 3.943330715538e-01
5459 KSP Residual norm 3.943330715538e-01
5460 KSP Residual norm 3.943330715539e-01
5461 KSP Residual norm 3.943330715539e-01
5462 KSP Residual norm 3.943330715539e-01
5463 KSP Residual norm 3.943330715539e-01
5464 KSP Residual norm 3.943330715539e-01
5465 KSP Residual norm 3.943330715539e-01
5466 KSP Residual norm 3.943330715539e-01
5467 KSP Residual norm 3.943330715539e-01
5468 KSP Residual norm 3.943330715539e-01
5469 KSP Residual norm 3.943330715539e-01
5470 KSP Residual norm 3.943330715539e-01
5471 KSP Residual norm 3.943330715539e-01
5472 KSP Residual norm 3.943330715539e-01
5473 KSP Residual norm 3.943330715539e-01
5474 KSP Residual norm 3.943330715539e-01
5475 KSP Residual norm 3.943330715539e-01
5476 KSP Residual norm 3.943330715539e-01
5477 KSP Residual norm 3.943330715539e-01
5478 KSP Residual norm 3.943330715539e-01
5479 KSP Residual norm 3.943330715539e-01
5480 KSP Residual norm 3.943330715539e-01
5481 KSP Residual norm 3.943330715539e-01
5482 KSP Residual norm 3.943330715539e-01
5483 KSP Residual norm 3.943330715539e-01
5484 KSP Residual norm 3.943330715539e-01
5485 KSP Residual norm 3.943330715539e-01
5486 KSP Residual norm 3.943330715539e-01
5487 KSP Residual norm 3.943330715539e-01
5488 KSP Residual norm 3.943330715539e-01
5489 KSP Residual norm 3.943330715539e-01
5490 KSP Residual norm 3.943330715534e-01
5491 KSP Residual norm 3.943330715534e-01
5492 KSP Residual norm 3.943330715534e-01
5493 KSP Residual norm 3.943330715534e-01
5494 KSP Residual norm 3.943330715534e-01
5495 KSP Residual norm 3.943330715534e-01
5496 KSP Residual norm 3.943330715534e-01
5497 KSP Residual norm 3.943330715534e-01
5498 KSP Residual norm 3.943330715534e-01
5499 KSP Residual norm 3.943330715534e-01
5500 KSP Residual norm 3.943330715534e-01
5501 KSP Residual norm 3.943330715534e-01
5502 KSP Residual norm 3.943330715534e-01
5503 KSP Residual norm 3.943330715534e-01
5504 KSP Residual norm 3.943330715534e-01
5505 KSP Residual norm 3.943330715534e-01
5506 KSP Residual norm 3.943330715534e-01
5507 KSP Residual norm 3.943330715534e-01
5508 KSP Residual norm 3.943330715534e-01
5509 KSP Residual norm 3.943330715534e-01
5510 KSP Residual norm 3.943330715534e-01
5511 KSP Residual norm 3.943330715534e-01
5512 KSP Residual norm 3.943330715534e-01
5513 KSP Residual norm 3.943330715534e-01
5514 KSP Residual norm 3.943330715534e-01
5515 KSP Residual norm 3.943330715534e-01
5516 KSP Residual norm 3.943330715534e-01
5517 KSP Residual norm 3.943330715534e-01
5518 KSP Residual norm 3.943330715534e-01
5519 KSP Residual norm 3.943330715534e-01
5520 KSP Residual norm 3.943330715536e-01
5521 KSP Residual norm 3.943330715536e-01
5522 KSP Residual norm 3.943330715536e-01
5523 KSP Residual norm 3.943330715536e-01
5524 KSP Residual norm 3.943330715536e-01
5525 KSP Residual norm 3.943330715536e-01
5526 KSP Residual norm 3.943330715536e-01
5527 KSP Residual norm 3.943330715536e-01
5528 KSP Residual norm 3.943330715536e-01
5529 KSP Residual norm 3.943330715536e-01
5530 KSP Residual norm 3.943330715536e-01
5531 KSP Residual norm 3.943330715536e-01
5532 KSP Residual norm 3.943330715536e-01
5533 KSP Residual norm 3.943330715536e-01
5534 KSP Residual norm 3.943330715536e-01
5535 KSP Residual norm 3.943330715536e-01
5536 KSP Residual norm 3.943330715536e-01
5537 KSP Residual norm 3.943330715536e-01
5538 KSP Residual norm 3.943330715536e-01
5539 KSP Residual norm 3.943330715536e-01
5540 KSP Residual norm 3.943330715536e-01
5541 KSP Residual norm 3.943330715536e-01
5542 KSP Residual norm 3.943330715536e-01
5543 KSP Residual norm 3.943330715536e-01
5544 KSP Residual norm 3.943330715536e-01
5545 KSP Residual norm 3.943330715536e-01
5546 KSP Residual norm 3.943330715536e-01
5547 KSP Residual norm 3.943330715536e-01
5548 KSP Residual norm 3.943330715536e-01
5549 KSP Residual norm 3.943330715536e-01
5550 KSP Residual norm 3.943330715534e-01
5551 KSP Residual norm 3.943330715534e-01
5552 KSP Residual norm 3.943330715534e-01
5553 KSP Residual norm 3.943330715534e-01
5554 KSP Residual norm 3.943330715534e-01
5555 KSP Residual norm 3.943330715534e-01
5556 KSP Residual norm 3.943330715534e-01
5557 KSP Residual norm 3.943330715534e-01
5558 KSP Residual norm 3.943330715534e-01
5559 KSP Residual norm 3.943330715534e-01
5560 KSP Residual norm 3.943330715534e-01
5561 KSP Residual norm 3.943330715534e-01
5562 KSP Residual norm 3.943330715534e-01
5563 KSP Residual norm 3.943330715534e-01
5564 KSP Residual norm 3.943330715534e-01
5565 KSP Residual norm 3.943330715534e-01
5566 KSP Residual norm 3.943330715534e-01
5567 KSP Residual norm 3.943330715534e-01
5568 KSP Residual norm 3.943330715534e-01
5569 KSP Residual norm 3.943330715534e-01
5570 KSP Residual norm 3.943330715534e-01
5571 KSP Residual norm 3.943330715534e-01
5572 KSP Residual norm 3.943330715534e-01
5573 KSP Residual norm 3.943330715534e-01
5574 KSP Residual norm 3.943330715534e-01
5575 KSP Residual norm 3.943330715534e-01
5576 KSP Residual norm 3.943330715534e-01
5577 KSP Residual norm 3.943330715534e-01
5578 KSP Residual norm 3.943330715534e-01
5579 KSP Residual norm 3.943330715534e-01
5580 KSP Residual norm 3.943330715534e-01
5581 KSP Residual norm 3.943330715534e-01
5582 KSP Residual norm 3.943330715534e-01
5583 KSP Residual norm 3.943330715534e-01
5584 KSP Residual norm 3.943330715534e-01
5585 KSP Residual norm 3.943330715534e-01
5586 KSP Residual norm 3.943330715534e-01
5587 KSP Residual norm 3.943330715534e-01
5588 KSP Residual norm 3.943330715534e-01
5589 KSP Residual norm 3.943330715534e-01
5590 KSP Residual norm 3.943330715534e-01
5591 KSP Residual norm 3.943330715534e-01
5592 KSP Residual norm 3.943330715534e-01
5593 KSP Residual norm 3.943330715534e-01
5594 KSP Residual norm 3.943330715534e-01
5595 KSP Residual norm 3.943330715534e-01
5596 KSP Residual norm 3.943330715534e-01
5597 KSP Residual norm 3.943330715534e-01
5598 KSP Residual norm 3.943330715534e-01
5599 KSP Residual norm 3.943330715534e-01
5600 KSP Residual norm 3.943330715534e-01
5601 KSP Residual norm 3.943330715534e-01
5602 KSP Residual norm 3.943330715534e-01
5603 KSP Residual norm 3.943330715534e-01
5604 KSP Residual norm 3.943330715534e-01
5605 KSP Residual norm 3.943330715534e-01
5606 KSP Residual norm 3.943330715534e-01
5607 KSP Residual norm 3.943330715534e-01
5608 KSP Residual norm 3.943330715534e-01
5609 KSP Residual norm 3.943330715534e-01
5610 KSP Residual norm 3.943330715536e-01
5611 KSP Residual norm 3.943330715536e-01
5612 KSP Residual norm 3.943330715536e-01
5613 KSP Residual norm 3.943330715536e-01
5614 KSP Residual norm 3.943330715536e-01
5615 KSP Residual norm 3.943330715536e-01
5616 KSP Residual norm 3.943330715536e-01
5617 KSP Residual norm 3.943330715536e-01
5618 KSP Residual norm 3.943330715536e-01
5619 KSP Residual norm 3.943330715536e-01
5620 KSP Residual norm 3.943330715536e-01
5621 KSP Residual norm 3.943330715536e-01
5622 KSP Residual norm 3.943330715536e-01
5623 KSP Residual norm 3.943330715536e-01
5624 KSP Residual norm 3.943330715536e-01
5625 KSP Residual norm 3.943330715536e-01
5626 KSP Residual norm 3.943330715536e-01
5627 KSP Residual norm 3.943330715536e-01
5628 KSP Residual norm 3.943330715536e-01
5629 KSP Residual norm 3.943330715536e-01
5630 KSP Residual norm 3.943330715536e-01
5631 KSP Residual norm 3.943330715536e-01
5632 KSP Residual norm 3.943330715536e-01
5633 KSP Residual norm 3.943330715536e-01
5634 KSP Residual norm 3.943330715536e-01
5635 KSP Residual norm 3.943330715536e-01
5636 KSP Residual norm 3.943330715536e-01
5637 KSP Residual norm 3.943330715536e-01
5638 KSP Residual norm 3.943330715536e-01
5639 KSP Residual norm 3.943330715536e-01
5640 KSP Residual norm 3.943330715535e-01
5641 KSP Residual norm 3.943330715535e-01
5642 KSP Residual norm 3.943330715535e-01
5643 KSP Residual norm 3.943330715535e-01
5644 KSP Residual norm 3.943330715535e-01
5645 KSP Residual norm 3.943330715535e-01
5646 KSP Residual norm 3.943330715535e-01
5647 KSP Residual norm 3.943330715535e-01
5648 KSP Residual norm 3.943330715535e-01
5649 KSP Residual norm 3.943330715535e-01
5650 KSP Residual norm 3.943330715535e-01
5651 KSP Residual norm 3.943330715535e-01
5652 KSP Residual norm 3.943330715535e-01
5653 KSP Residual norm 3.943330715535e-01
5654 KSP Residual norm 3.943330715535e-01
5655 KSP Residual norm 3.943330715535e-01
5656 KSP Residual norm 3.943330715535e-01
5657 KSP Residual norm 3.943330715535e-01
5658 KSP Residual norm 3.943330715535e-01
5659 KSP Residual norm 3.943330715535e-01
5660 KSP Residual norm 3.943330715535e-01
5661 KSP Residual norm 3.943330715535e-01
5662 KSP Residual norm 3.943330715535e-01
5663 KSP Residual norm 3.943330715535e-01
5664 KSP Residual norm 3.943330715535e-01
5665 KSP Residual norm 3.943330715535e-01
5666 KSP Residual norm 3.943330715535e-01
5667 KSP Residual norm 3.943330715535e-01
5668 KSP Residual norm 3.943330715535e-01
5669 KSP Residual norm 3.943330715535e-01
5670 KSP Residual norm 3.943330715536e-01
5671 KSP Residual norm 3.943330715536e-01
5672 KSP Residual norm 3.943330715536e-01
5673 KSP Residual norm 3.943330715536e-01
5674 KSP Residual norm 3.943330715536e-01
5675 KSP Residual norm 3.943330715536e-01
5676 KSP Residual norm 3.943330715536e-01
5677 KSP Residual norm 3.943330715536e-01
5678 KSP Residual norm 3.943330715536e-01
5679 KSP Residual norm 3.943330715536e-01
5680 KSP Residual norm 3.943330715536e-01
5681 KSP Residual norm 3.943330715536e-01
5682 KSP Residual norm 3.943330715536e-01
5683 KSP Residual norm 3.943330715536e-01
5684 KSP Residual norm 3.943330715536e-01
5685 KSP Residual norm 3.943330715536e-01
5686 KSP Residual norm 3.943330715536e-01
5687 KSP Residual norm 3.943330715536e-01
5688 KSP Residual norm 3.943330715536e-01
5689 KSP Residual norm 3.943330715536e-01
5690 KSP Residual norm 3.943330715536e-01
5691 KSP Residual norm 3.943330715536e-01
5692 KSP Residual norm 3.943330715536e-01
5693 KSP Residual norm 3.943330715536e-01
5694 KSP Residual norm 3.943330715536e-01
5695 KSP Residual norm 3.943330715536e-01
5696 KSP Residual norm 3.943330715536e-01
5697 KSP Residual norm 3.943330715536e-01
5698 KSP Residual norm 3.943330715536e-01
5699 KSP Residual norm 3.943330715536e-01
5700 KSP Residual norm 3.943330715535e-01
5701 KSP Residual norm 3.943330715535e-01
5702 KSP Residual norm 3.943330715535e-01
5703 KSP Residual norm 3.943330715535e-01
5704 KSP Residual norm 3.943330715535e-01
5705 KSP Residual norm 3.943330715535e-01
5706 KSP Residual norm 3.943330715535e-01
5707 KSP Residual norm 3.943330715535e-01
5708 KSP Residual norm 3.943330715535e-01
5709 KSP Residual norm 3.943330715535e-01
5710 KSP Residual norm 3.943330715535e-01
5711 KSP Residual norm 3.943330715535e-01
5712 KSP Residual norm 3.943330715535e-01
5713 KSP Residual norm 3.943330715535e-01
5714 KSP Residual norm 3.943330715535e-01
5715 KSP Residual norm 3.943330715535e-01
5716 KSP Residual norm 3.943330715535e-01
5717 KSP Residual norm 3.943330715535e-01
5718 KSP Residual norm 3.943330715535e-01
5719 KSP Residual norm 3.943330715535e-01
5720 KSP Residual norm 3.943330715535e-01
5721 KSP Residual norm 3.943330715535e-01
5722 KSP Residual norm 3.943330715535e-01
5723 KSP Residual norm 3.943330715535e-01
5724 KSP Residual norm 3.943330715535e-01
5725 KSP Residual norm 3.943330715535e-01
5726 KSP Residual norm 3.943330715535e-01
5727 KSP Residual norm 3.943330715535e-01
5728 KSP Residual norm 3.943330715535e-01
5729 KSP Residual norm 3.943330715535e-01
5730 KSP Residual norm 3.943330715534e-01
5731 KSP Residual norm 3.943330715534e-01
5732 KSP Residual norm 3.943330715534e-01
5733 KSP Residual norm 3.943330715534e-01
5734 KSP Residual norm 3.943330715534e-01
5735 KSP Residual norm 3.943330715534e-01
5736 KSP Residual norm 3.943330715534e-01
5737 KSP Residual norm 3.943330715534e-01
5738 KSP Residual norm 3.943330715534e-01
5739 KSP Residual norm 3.943330715534e-01
5740 KSP Residual norm 3.943330715534e-01
5741 KSP Residual norm 3.943330715534e-01
5742 KSP Residual norm 3.943330715534e-01
5743 KSP Residual norm 3.943330715534e-01
5744 KSP Residual norm 3.943330715534e-01
5745 KSP Residual norm 3.943330715534e-01
5746 KSP Residual norm 3.943330715534e-01
5747 KSP Residual norm 3.943330715534e-01
5748 KSP Residual norm 3.943330715534e-01
5749 KSP Residual norm 3.943330715534e-01
5750 KSP Residual norm 3.943330715534e-01
5751 KSP Residual norm 3.943330715534e-01
5752 KSP Residual norm 3.943330715534e-01
5753 KSP Residual norm 3.943330715534e-01
5754 KSP Residual norm 3.943330715534e-01
5755 KSP Residual norm 3.943330715534e-01
5756 KSP Residual norm 3.943330715534e-01
5757 KSP Residual norm 3.943330715534e-01
5758 KSP Residual norm 3.943330715534e-01
5759 KSP Residual norm 3.943330715534e-01
5760 KSP Residual norm 3.943330715535e-01
5761 KSP Residual norm 3.943330715535e-01
5762 KSP Residual norm 3.943330715535e-01
5763 KSP Residual norm 3.943330715535e-01
5764 KSP Residual norm 3.943330715535e-01
5765 KSP Residual norm 3.943330715535e-01
5766 KSP Residual norm 3.943330715535e-01
5767 KSP Residual norm 3.943330715535e-01
5768 KSP Residual norm 3.943330715535e-01
5769 KSP Residual norm 3.943330715535e-01
5770 KSP Residual norm 3.943330715535e-01
5771 KSP Residual norm 3.943330715535e-01
5772 KSP Residual norm 3.943330715535e-01
5773 KSP Residual norm 3.943330715535e-01
5774 KSP Residual norm 3.943330715535e-01
5775 KSP Residual norm 3.943330715535e-01
5776 KSP Residual norm 3.943330715535e-01
5777 KSP Residual norm 3.943330715535e-01
5778 KSP Residual norm 3.943330715535e-01
5779 KSP Residual norm 3.943330715535e-01
5780 KSP Residual norm 3.943330715535e-01
5781 KSP Residual norm 3.943330715535e-01
5782 KSP Residual norm 3.943330715535e-01
5783 KSP Residual norm 3.943330715535e-01
5784 KSP Residual norm 3.943330715535e-01
5785 KSP Residual norm 3.943330715535e-01
5786 KSP Residual norm 3.943330715535e-01
5787 KSP Residual norm 3.943330715535e-01
5788 KSP Residual norm 3.943330715535e-01
5789 KSP Residual norm 3.943330715535e-01
5790 KSP Residual norm 3.943330715531e-01
5791 KSP Residual norm 3.943330715531e-01
5792 KSP Residual norm 3.943330715531e-01
5793 KSP Residual norm 3.943330715531e-01
5794 KSP Residual norm 3.943330715531e-01
5795 KSP Residual norm 3.943330715531e-01
5796 KSP Residual norm 3.943330715531e-01
5797 KSP Residual norm 3.943330715531e-01
5798 KSP Residual norm 3.943330715531e-01
5799 KSP Residual norm 3.943330715531e-01
5800 KSP Residual norm 3.943330715531e-01
5801 KSP Residual norm 3.943330715531e-01
5802 KSP Residual norm 3.943330715531e-01
5803 KSP Residual norm 3.943330715531e-01
5804 KSP Residual norm 3.943330715531e-01
5805 KSP Residual norm 3.943330715531e-01
5806 KSP Residual norm 3.943330715531e-01
5807 KSP Residual norm 3.943330715531e-01
5808 KSP Residual norm 3.943330715531e-01
5809 KSP Residual norm 3.943330715531e-01
5810 KSP Residual norm 3.943330715531e-01
5811 KSP Residual norm 3.943330715531e-01
5812 KSP Residual norm 3.943330715531e-01
5813 KSP Residual norm 3.943330715531e-01
5814 KSP Residual norm 3.943330715531e-01
5815 KSP Residual norm 3.943330715531e-01
5816 KSP Residual norm 3.943330715531e-01
5817 KSP Residual norm 3.943330715531e-01
5818 KSP Residual norm 3.943330715531e-01
5819 KSP Residual norm 3.943330715531e-01
5820 KSP Residual norm 3.943330715531e-01
5821 KSP Residual norm 3.943330715531e-01
5822 KSP Residual norm 3.943330715531e-01
5823 KSP Residual norm 3.943330715531e-01
5824 KSP Residual norm 3.943330715531e-01
5825 KSP Residual norm 3.943330715531e-01
5826 KSP Residual norm 3.943330715531e-01
5827 KSP Residual norm 3.943330715531e-01
5828 KSP Residual norm 3.943330715531e-01
5829 KSP Residual norm 3.943330715531e-01
5830 KSP Residual norm 3.943330715531e-01
5831 KSP Residual norm 3.943330715531e-01
5832 KSP Residual norm 3.943330715531e-01
5833 KSP Residual norm 3.943330715531e-01
5834 KSP Residual norm 3.943330715531e-01
5835 KSP Residual norm 3.943330715531e-01
5836 KSP Residual norm 3.943330715531e-01
5837 KSP Residual norm 3.943330715531e-01
5838 KSP Residual norm 3.943330715531e-01
5839 KSP Residual norm 3.943330715531e-01
5840 KSP Residual norm 3.943330715531e-01
5841 KSP Residual norm 3.943330715531e-01
5842 KSP Residual norm 3.943330715531e-01
5843 KSP Residual norm 3.943330715531e-01
5844 KSP Residual norm 3.943330715531e-01
5845 KSP Residual norm 3.943330715531e-01
5846 KSP Residual norm 3.943330715531e-01
5847 KSP Residual norm 3.943330715531e-01
5848 KSP Residual norm 3.943330715531e-01
5849 KSP Residual norm 3.943330715531e-01
5850 KSP Residual norm 3.943330715533e-01
5851 KSP Residual norm 3.943330715533e-01
5852 KSP Residual norm 3.943330715533e-01
5853 KSP Residual norm 3.943330715533e-01
5854 KSP Residual norm 3.943330715533e-01
5855 KSP Residual norm 3.943330715533e-01
5856 KSP Residual norm 3.943330715533e-01
5857 KSP Residual norm 3.943330715533e-01
5858 KSP Residual norm 3.943330715533e-01
5859 KSP Residual norm 3.943330715533e-01
5860 KSP Residual norm 3.943330715533e-01
5861 KSP Residual norm 3.943330715533e-01
5862 KSP Residual norm 3.943330715533e-01
5863 KSP Residual norm 3.943330715533e-01
5864 KSP Residual norm 3.943330715533e-01
5865 KSP Residual norm 3.943330715533e-01
5866 KSP Residual norm 3.943330715533e-01
5867 KSP Residual norm 3.943330715533e-01
5868 KSP Residual norm 3.943330715533e-01
5869 KSP Residual norm 3.943330715533e-01
5870 KSP Residual norm 3.943330715533e-01
5871 KSP Residual norm 3.943330715533e-01
5872 KSP Residual norm 3.943330715533e-01
5873 KSP Residual norm 3.943330715533e-01
5874 KSP Residual norm 3.943330715533e-01
5875 KSP Residual norm 3.943330715533e-01
5876 KSP Residual norm 3.943330715533e-01
5877 KSP Residual norm 3.943330715533e-01
5878 KSP Residual norm 3.943330715533e-01
5879 KSP Residual norm 3.943330715533e-01
5880 KSP Residual norm 3.943330715534e-01
5881 KSP Residual norm 3.943330715534e-01
5882 KSP Residual norm 3.943330715534e-01
5883 KSP Residual norm 3.943330715534e-01
5884 KSP Residual norm 3.943330715534e-01
5885 KSP Residual norm 3.943330715534e-01
5886 KSP Residual norm 3.943330715534e-01
5887 KSP Residual norm 3.943330715534e-01
5888 KSP Residual norm 3.943330715534e-01
5889 KSP Residual norm 3.943330715534e-01
5890 KSP Residual norm 3.943330715534e-01
5891 KSP Residual norm 3.943330715534e-01
5892 KSP Residual norm 3.943330715534e-01
5893 KSP Residual norm 3.943330715534e-01
5894 KSP Residual norm 3.943330715534e-01
5895 KSP Residual norm 3.943330715534e-01
5896 KSP Residual norm 3.943330715534e-01
5897 KSP Residual norm 3.943330715534e-01
5898 KSP Residual norm 3.943330715534e-01
5899 KSP Residual norm 3.943330715534e-01
5900 KSP Residual norm 3.943330715534e-01
5901 KSP Residual norm 3.943330715534e-01
5902 KSP Residual norm 3.943330715534e-01
5903 KSP Residual norm 3.943330715534e-01
5904 KSP Residual norm 3.943330715534e-01
5905 KSP Residual norm 3.943330715534e-01
5906 KSP Residual norm 3.943330715534e-01
5907 KSP Residual norm 3.943330715534e-01
5908 KSP Residual norm 3.943330715534e-01
5909 KSP Residual norm 3.943330715534e-01
5910 KSP Residual norm 3.943330715537e-01
5911 KSP Residual norm 3.943330715537e-01
5912 KSP Residual norm 3.943330715537e-01
5913 KSP Residual norm 3.943330715537e-01
5914 KSP Residual norm 3.943330715537e-01
5915 KSP Residual norm 3.943330715537e-01
5916 KSP Residual norm 3.943330715537e-01
5917 KSP Residual norm 3.943330715537e-01
5918 KSP Residual norm 3.943330715537e-01
5919 KSP Residual norm 3.943330715537e-01
5920 KSP Residual norm 3.943330715537e-01
5921 KSP Residual norm 3.943330715537e-01
5922 KSP Residual norm 3.943330715537e-01
5923 KSP Residual norm 3.943330715537e-01
5924 KSP Residual norm 3.943330715537e-01
5925 KSP Residual norm 3.943330715537e-01
5926 KSP Residual norm 3.943330715537e-01
5927 KSP Residual norm 3.943330715537e-01
5928 KSP Residual norm 3.943330715537e-01
5929 KSP Residual norm 3.943330715537e-01
5930 KSP Residual norm 3.943330715537e-01
5931 KSP Residual norm 3.943330715537e-01
5932 KSP Residual norm 3.943330715537e-01
5933 KSP Residual norm 3.943330715537e-01
5934 KSP Residual norm 3.943330715537e-01
5935 KSP Residual norm 3.943330715537e-01
5936 KSP Residual norm 3.943330715537e-01
5937 KSP Residual norm 3.943330715537e-01
5938 KSP Residual norm 3.943330715537e-01
5939 KSP Residual norm 3.943330715537e-01
5940 KSP Residual norm 3.943330715536e-01
5941 KSP Residual norm 3.943330715536e-01
5942 KSP Residual norm 3.943330715536e-01
5943 KSP Residual norm 3.943330715536e-01
5944 KSP Residual norm 3.943330715536e-01
5945 KSP Residual norm 3.943330715536e-01
5946 KSP Residual norm 3.943330715536e-01
5947 KSP Residual norm 3.943330715536e-01
5948 KSP Residual norm 3.943330715536e-01
5949 KSP Residual norm 3.943330715536e-01
5950 KSP Residual norm 3.943330715536e-01
5951 KSP Residual norm 3.943330715536e-01
5952 KSP Residual norm 3.943330715536e-01
5953 KSP Residual norm 3.943330715536e-01
5954 KSP Residual norm 3.943330715536e-01
5955 KSP Residual norm 3.943330715536e-01
5956 KSP Residual norm 3.943330715536e-01
5957 KSP Residual norm 3.943330715536e-01
5958 KSP Residual norm 3.943330715536e-01
5959 KSP Residual norm 3.943330715536e-01
5960 KSP Residual norm 3.943330715536e-01
5961 KSP Residual norm 3.943330715536e-01
5962 KSP Residual norm 3.943330715536e-01
5963 KSP Residual norm 3.943330715536e-01
5964 KSP Residual norm 3.943330715536e-01
5965 KSP Residual norm 3.943330715536e-01
5966 KSP Residual norm 3.943330715536e-01
5967 KSP Residual norm 3.943330715536e-01
5968 KSP Residual norm 3.943330715536e-01
5969 KSP Residual norm 3.943330715536e-01
5970 KSP Residual norm 3.943330715535e-01
5971 KSP Residual norm 3.943330715535e-01
5972 KSP Residual norm 3.943330715535e-01
5973 KSP Residual norm 3.943330715535e-01
5974 KSP Residual norm 3.943330715535e-01
5975 KSP Residual norm 3.943330715535e-01
5976 KSP Residual norm 3.943330715535e-01
5977 KSP Residual norm 3.943330715535e-01
5978 KSP Residual norm 3.943330715535e-01
5979 KSP Residual norm 3.943330715535e-01
5980 KSP Residual norm 3.943330715535e-01
5981 KSP Residual norm 3.943330715535e-01
5982 KSP Residual norm 3.943330715535e-01
5983 KSP Residual norm 3.943330715535e-01
5984 KSP Residual norm 3.943330715535e-01
5985 KSP Residual norm 3.943330715535e-01
5986 KSP Residual norm 3.943330715535e-01
5987 KSP Residual norm 3.943330715535e-01
5988 KSP Residual norm 3.943330715535e-01
5989 KSP Residual norm 3.943330715535e-01
5990 KSP Residual norm 3.943330715535e-01
5991 KSP Residual norm 3.943330715535e-01
5992 KSP Residual norm 3.943330715535e-01
5993 KSP Residual norm 3.943330715535e-01
5994 KSP Residual norm 3.943330715535e-01
5995 KSP Residual norm 3.943330715535e-01
5996 KSP Residual norm 3.943330715535e-01
5997 KSP Residual norm 3.943330715535e-01
5998 KSP Residual norm 3.943330715535e-01
5999 KSP Residual norm 3.943330715535e-01
6000 KSP Residual norm 3.943330715535e-01
6001 KSP Residual norm 3.943330715535e-01
6002 KSP Residual norm 3.943330715535e-01
6003 KSP Residual norm 3.943330715535e-01
6004 KSP Residual norm 3.943330715535e-01
6005 KSP Residual norm 3.943330715535e-01
6006 KSP Residual norm 3.943330715535e-01
6007 KSP Residual norm 3.943330715535e-01
6008 KSP Residual norm 3.943330715535e-01
6009 KSP Residual norm 3.943330715535e-01
6010 KSP Residual norm 3.943330715535e-01
6011 KSP Residual norm 3.943330715535e-01
6012 KSP Residual norm 3.943330715535e-01
6013 KSP Residual norm 3.943330715535e-01
6014 KSP Residual norm 3.943330715535e-01
6015 KSP Residual norm 3.943330715535e-01
6016 KSP Residual norm 3.943330715535e-01
6017 KSP Residual norm 3.943330715535e-01
6018 KSP Residual norm 3.943330715535e-01
6019 KSP Residual norm 3.943330715535e-01
6020 KSP Residual norm 3.943330715535e-01
6021 KSP Residual norm 3.943330715535e-01
6022 KSP Residual norm 3.943330715535e-01
6023 KSP Residual norm 3.943330715535e-01
6024 KSP Residual norm 3.943330715535e-01
6025 KSP Residual norm 3.943330715535e-01
6026 KSP Residual norm 3.943330715535e-01
6027 KSP Residual norm 3.943330715535e-01
6028 KSP Residual norm 3.943330715535e-01
6029 KSP Residual norm 3.943330715535e-01
6030 KSP Residual norm 3.943330715534e-01
6031 KSP Residual norm 3.943330715534e-01
6032 KSP Residual norm 3.943330715534e-01
6033 KSP Residual norm 3.943330715534e-01
6034 KSP Residual norm 3.943330715534e-01
6035 KSP Residual norm 3.943330715534e-01
6036 KSP Residual norm 3.943330715534e-01
6037 KSP Residual norm 3.943330715534e-01
6038 KSP Residual norm 3.943330715534e-01
6039 KSP Residual norm 3.943330715534e-01
6040 KSP Residual norm 3.943330715534e-01
6041 KSP Residual norm 3.943330715534e-01
6042 KSP Residual norm 3.943330715534e-01
6043 KSP Residual norm 3.943330715534e-01
6044 KSP Residual norm 3.943330715534e-01
6045 KSP Residual norm 3.943330715534e-01
6046 KSP Residual norm 3.943330715534e-01
6047 KSP Residual norm 3.943330715534e-01
6048 KSP Residual norm 3.943330715534e-01
6049 KSP Residual norm 3.943330715534e-01
6050 KSP Residual norm 3.943330715534e-01
6051 KSP Residual norm 3.943330715534e-01
6052 KSP Residual norm 3.943330715534e-01
6053 KSP Residual norm 3.943330715534e-01
6054 KSP Residual norm 3.943330715534e-01
6055 KSP Residual norm 3.943330715534e-01
6056 KSP Residual norm 3.943330715534e-01
6057 KSP Residual norm 3.943330715534e-01
6058 KSP Residual norm 3.943330715534e-01
6059 KSP Residual norm 3.943330715534e-01
6060 KSP Residual norm 3.943330715536e-01
6061 KSP Residual norm 3.943330715536e-01
6062 KSP Residual norm 3.943330715536e-01
6063 KSP Residual norm 3.943330715536e-01
6064 KSP Residual norm 3.943330715536e-01
6065 KSP Residual norm 3.943330715536e-01
6066 KSP Residual norm 3.943330715536e-01
6067 KSP Residual norm 3.943330715536e-01
6068 KSP Residual norm 3.943330715536e-01
6069 KSP Residual norm 3.943330715536e-01
6070 KSP Residual norm 3.943330715536e-01
6071 KSP Residual norm 3.943330715536e-01
6072 KSP Residual norm 3.943330715536e-01
6073 KSP Residual norm 3.943330715536e-01
6074 KSP Residual norm 3.943330715536e-01
6075 KSP Residual norm 3.943330715536e-01
6076 KSP Residual norm 3.943330715536e-01
6077 KSP Residual norm 3.943330715536e-01
6078 KSP Residual norm 3.943330715536e-01
6079 KSP Residual norm 3.943330715536e-01
6080 KSP Residual norm 3.943330715536e-01
6081 KSP Residual norm 3.943330715536e-01
6082 KSP Residual norm 3.943330715536e-01
6083 KSP Residual norm 3.943330715536e-01
6084 KSP Residual norm 3.943330715536e-01
6085 KSP Residual norm 3.943330715536e-01
6086 KSP Residual norm 3.943330715536e-01
6087 KSP Residual norm 3.943330715536e-01
6088 KSP Residual norm 3.943330715536e-01
6089 KSP Residual norm 3.943330715536e-01
6090 KSP Residual norm 3.943330715534e-01
6091 KSP Residual norm 3.943330715534e-01
6092 KSP Residual norm 3.943330715534e-01
6093 KSP Residual norm 3.943330715534e-01
6094 KSP Residual norm 3.943330715534e-01
6095 KSP Residual norm 3.943330715534e-01
6096 KSP Residual norm 3.943330715534e-01
6097 KSP Residual norm 3.943330715534e-01
6098 KSP Residual norm 3.943330715534e-01
6099 KSP Residual norm 3.943330715534e-01
6100 KSP Residual norm 3.943330715534e-01
6101 KSP Residual norm 3.943330715534e-01
6102 KSP Residual norm 3.943330715534e-01
6103 KSP Residual norm 3.943330715534e-01
6104 KSP Residual norm 3.943330715534e-01
6105 KSP Residual norm 3.943330715534e-01
6106 KSP Residual norm 3.943330715534e-01
6107 KSP Residual norm 3.943330715534e-01
6108 KSP Residual norm 3.943330715534e-01
6109 KSP Residual norm 3.943330715534e-01
6110 KSP Residual norm 3.943330715534e-01
6111 KSP Residual norm 3.943330715534e-01
6112 KSP Residual norm 3.943330715534e-01
6113 KSP Residual norm 3.943330715534e-01
6114 KSP Residual norm 3.943330715534e-01
6115 KSP Residual norm 3.943330715534e-01
6116 KSP Residual norm 3.943330715534e-01
6117 KSP Residual norm 3.943330715534e-01
6118 KSP Residual norm 3.943330715534e-01
6119 KSP Residual norm 3.943330715534e-01
6120 KSP Residual norm 3.943330715536e-01
6121 KSP Residual norm 3.943330715536e-01
6122 KSP Residual norm 3.943330715536e-01
6123 KSP Residual norm 3.943330715536e-01
6124 KSP Residual norm 3.943330715536e-01
6125 KSP Residual norm 3.943330715536e-01
6126 KSP Residual norm 3.943330715536e-01
6127 KSP Residual norm 3.943330715536e-01
6128 KSP Residual norm 3.943330715536e-01
6129 KSP Residual norm 3.943330715536e-01
6130 KSP Residual norm 3.943330715536e-01
6131 KSP Residual norm 3.943330715536e-01
6132 KSP Residual norm 3.943330715536e-01
6133 KSP Residual norm 3.943330715536e-01
6134 KSP Residual norm 3.943330715536e-01
6135 KSP Residual norm 3.943330715536e-01
6136 KSP Residual norm 3.943330715536e-01
6137 KSP Residual norm 3.943330715536e-01
6138 KSP Residual norm 3.943330715536e-01
6139 KSP Residual norm 3.943330715536e-01
6140 KSP Residual norm 3.943330715536e-01
6141 KSP Residual norm 3.943330715536e-01
6142 KSP Residual norm 3.943330715536e-01
6143 KSP Residual norm 3.943330715536e-01
6144 KSP Residual norm 3.943330715536e-01
6145 KSP Residual norm 3.943330715536e-01
6146 KSP Residual norm 3.943330715536e-01
6147 KSP Residual norm 3.943330715536e-01
6148 KSP Residual norm 3.943330715536e-01
6149 KSP Residual norm 3.943330715536e-01
6150 KSP Residual norm 3.943330715534e-01
6151 KSP Residual norm 3.943330715534e-01
6152 KSP Residual norm 3.943330715534e-01
6153 KSP Residual norm 3.943330715534e-01
6154 KSP Residual norm 3.943330715534e-01
6155 KSP Residual norm 3.943330715534e-01
6156 KSP Residual norm 3.943330715534e-01
6157 KSP Residual norm 3.943330715534e-01
6158 KSP Residual norm 3.943330715534e-01
6159 KSP Residual norm 3.943330715534e-01
6160 KSP Residual norm 3.943330715534e-01
6161 KSP Residual norm 3.943330715534e-01
6162 KSP Residual norm 3.943330715534e-01
6163 KSP Residual norm 3.943330715534e-01
6164 KSP Residual norm 3.943330715534e-01
6165 KSP Residual norm 3.943330715534e-01
6166 KSP Residual norm 3.943330715534e-01
6167 KSP Residual norm 3.943330715534e-01
6168 KSP Residual norm 3.943330715534e-01
6169 KSP Residual norm 3.943330715534e-01
6170 KSP Residual norm 3.943330715534e-01
6171 KSP Residual norm 3.943330715534e-01
6172 KSP Residual norm 3.943330715534e-01
6173 KSP Residual norm 3.943330715534e-01
6174 KSP Residual norm 3.943330715534e-01
6175 KSP Residual norm 3.943330715534e-01
6176 KSP Residual norm 3.943330715534e-01
6177 KSP Residual norm 3.943330715534e-01
6178 KSP Residual norm 3.943330715534e-01
6179 KSP Residual norm 3.943330715534e-01
6180 KSP Residual norm 3.943330715536e-01
6181 KSP Residual norm 3.943330715536e-01
6182 KSP Residual norm 3.943330715536e-01
6183 KSP Residual norm 3.943330715536e-01
6184 KSP Residual norm 3.943330715536e-01
6185 KSP Residual norm 3.943330715536e-01
6186 KSP Residual norm 3.943330715536e-01
6187 KSP Residual norm 3.943330715536e-01
6188 KSP Residual norm 3.943330715536e-01
6189 KSP Residual norm 3.943330715536e-01
6190 KSP Residual norm 3.943330715536e-01
6191 KSP Residual norm 3.943330715536e-01
6192 KSP Residual norm 3.943330715536e-01
6193 KSP Residual norm 3.943330715536e-01
6194 KSP Residual norm 3.943330715536e-01
6195 KSP Residual norm 3.943330715536e-01
6196 KSP Residual norm 3.943330715536e-01
6197 KSP Residual norm 3.943330715536e-01
6198 KSP Residual norm 3.943330715536e-01
6199 KSP Residual norm 3.943330715536e-01
6200 KSP Residual norm 3.943330715536e-01
6201 KSP Residual norm 3.943330715536e-01
6202 KSP Residual norm 3.943330715536e-01
6203 KSP Residual norm 3.943330715536e-01
6204 KSP Residual norm 3.943330715536e-01
6205 KSP Residual norm 3.943330715536e-01
6206 KSP Residual norm 3.943330715536e-01
6207 KSP Residual norm 3.943330715536e-01
6208 KSP Residual norm 3.943330715536e-01
6209 KSP Residual norm 3.943330715536e-01
6210 KSP Residual norm 3.943330715533e-01
6211 KSP Residual norm 3.943330715533e-01
6212 KSP Residual norm 3.943330715533e-01
6213 KSP Residual norm 3.943330715533e-01
6214 KSP Residual norm 3.943330715533e-01
6215 KSP Residual norm 3.943330715533e-01
6216 KSP Residual norm 3.943330715533e-01
6217 KSP Residual norm 3.943330715533e-01
6218 KSP Residual norm 3.943330715533e-01
6219 KSP Residual norm 3.943330715533e-01
6220 KSP Residual norm 3.943330715533e-01
6221 KSP Residual norm 3.943330715533e-01
6222 KSP Residual norm 3.943330715533e-01
6223 KSP Residual norm 3.943330715533e-01
6224 KSP Residual norm 3.943330715533e-01
6225 KSP Residual norm 3.943330715533e-01
6226 KSP Residual norm 3.943330715533e-01
6227 KSP Residual norm 3.943330715533e-01
6228 KSP Residual norm 3.943330715533e-01
6229 KSP Residual norm 3.943330715533e-01
6230 KSP Residual norm 3.943330715533e-01
6231 KSP Residual norm 3.943330715533e-01
6232 KSP Residual norm 3.943330715533e-01
6233 KSP Residual norm 3.943330715533e-01
6234 KSP Residual norm 3.943330715533e-01
6235 KSP Residual norm 3.943330715533e-01
6236 KSP Residual norm 3.943330715533e-01
6237 KSP Residual norm 3.943330715533e-01
6238 KSP Residual norm 3.943330715533e-01
6239 KSP Residual norm 3.943330715533e-01
6240 KSP Residual norm 3.943330715531e-01
6241 KSP Residual norm 3.943330715531e-01
6242 KSP Residual norm 3.943330715531e-01
6243 KSP Residual norm 3.943330715531e-01
6244 KSP Residual norm 3.943330715531e-01
6245 KSP Residual norm 3.943330715531e-01
6246 KSP Residual norm 3.943330715531e-01
6247 KSP Residual norm 3.943330715531e-01
6248 KSP Residual norm 3.943330715531e-01
6249 KSP Residual norm 3.943330715531e-01
6250 KSP Residual norm 3.943330715531e-01
6251 KSP Residual norm 3.943330715531e-01
6252 KSP Residual norm 3.943330715531e-01
6253 KSP Residual norm 3.943330715531e-01
6254 KSP Residual norm 3.943330715531e-01
6255 KSP Residual norm 3.943330715531e-01
6256 KSP Residual norm 3.943330715531e-01
6257 KSP Residual norm 3.943330715531e-01
6258 KSP Residual norm 3.943330715531e-01
6259 KSP Residual norm 3.943330715531e-01
6260 KSP Residual norm 3.943330715531e-01
6261 KSP Residual norm 3.943330715531e-01
6262 KSP Residual norm 3.943330715531e-01
6263 KSP Residual norm 3.943330715531e-01
6264 KSP Residual norm 3.943330715531e-01
6265 KSP Residual norm 3.943330715531e-01
6266 KSP Residual norm 3.943330715531e-01
6267 KSP Residual norm 3.943330715531e-01
6268 KSP Residual norm 3.943330715531e-01
6269 KSP Residual norm 3.943330715531e-01
6270 KSP Residual norm 3.943330715534e-01
6271 KSP Residual norm 3.943330715534e-01
6272 KSP Residual norm 3.943330715534e-01
6273 KSP Residual norm 3.943330715534e-01
6274 KSP Residual norm 3.943330715534e-01
6275 KSP Residual norm 3.943330715534e-01
6276 KSP Residual norm 3.943330715534e-01
6277 KSP Residual norm 3.943330715534e-01
6278 KSP Residual norm 3.943330715534e-01
6279 KSP Residual norm 3.943330715534e-01
6280 KSP Residual norm 3.943330715534e-01
6281 KSP Residual norm 3.943330715534e-01
6282 KSP Residual norm 3.943330715534e-01
6283 KSP Residual norm 3.943330715534e-01
6284 KSP Residual norm 3.943330715534e-01
6285 KSP Residual norm 3.943330715534e-01
6286 KSP Residual norm 3.943330715534e-01
6287 KSP Residual norm 3.943330715534e-01
6288 KSP Residual norm 3.943330715534e-01
6289 KSP Residual norm 3.943330715534e-01
6290 KSP Residual norm 3.943330715534e-01
6291 KSP Residual norm 3.943330715534e-01
6292 KSP Residual norm 3.943330715534e-01
6293 KSP Residual norm 3.943330715534e-01
6294 KSP Residual norm 3.943330715534e-01
6295 KSP Residual norm 3.943330715534e-01
6296 KSP Residual norm 3.943330715534e-01
6297 KSP Residual norm 3.943330715534e-01
6298 KSP Residual norm 3.943330715534e-01
6299 KSP Residual norm 3.943330715534e-01
6300 KSP Residual norm 3.943330715534e-01
6301 KSP Residual norm 3.943330715534e-01
6302 KSP Residual norm 3.943330715534e-01
6303 KSP Residual norm 3.943330715534e-01
6304 KSP Residual norm 3.943330715534e-01
6305 KSP Residual norm 3.943330715534e-01
6306 KSP Residual norm 3.943330715534e-01
6307 KSP Residual norm 3.943330715534e-01
6308 KSP Residual norm 3.943330715534e-01
6309 KSP Residual norm 3.943330715534e-01
6310 KSP Residual norm 3.943330715534e-01
6311 KSP Residual norm 3.943330715534e-01
6312 KSP Residual norm 3.943330715534e-01
6313 KSP Residual norm 3.943330715534e-01
6314 KSP Residual norm 3.943330715534e-01
6315 KSP Residual norm 3.943330715534e-01
6316 KSP Residual norm 3.943330715534e-01
6317 KSP Residual norm 3.943330715534e-01
6318 KSP Residual norm 3.943330715534e-01
6319 KSP Residual norm 3.943330715534e-01
6320 KSP Residual norm 3.943330715534e-01
6321 KSP Residual norm 3.943330715534e-01
6322 KSP Residual norm 3.943330715534e-01
6323 KSP Residual norm 3.943330715534e-01
6324 KSP Residual norm 3.943330715534e-01
6325 KSP Residual norm 3.943330715534e-01
6326 KSP Residual norm 3.943330715534e-01
6327 KSP Residual norm 3.943330715534e-01
6328 KSP Residual norm 3.943330715534e-01
6329 KSP Residual norm 3.943330715534e-01
6330 KSP Residual norm 3.943330715537e-01
6331 KSP Residual norm 3.943330715537e-01
6332 KSP Residual norm 3.943330715537e-01
6333 KSP Residual norm 3.943330715537e-01
6334 KSP Residual norm 3.943330715537e-01
6335 KSP Residual norm 3.943330715537e-01
6336 KSP Residual norm 3.943330715537e-01
6337 KSP Residual norm 3.943330715537e-01
6338 KSP Residual norm 3.943330715537e-01
6339 KSP Residual norm 3.943330715537e-01
6340 KSP Residual norm 3.943330715537e-01
6341 KSP Residual norm 3.943330715537e-01
6342 KSP Residual norm 3.943330715537e-01
6343 KSP Residual norm 3.943330715537e-01
6344 KSP Residual norm 3.943330715537e-01
6345 KSP Residual norm 3.943330715537e-01
6346 KSP Residual norm 3.943330715537e-01
6347 KSP Residual norm 3.943330715537e-01
6348 KSP Residual norm 3.943330715537e-01
6349 KSP Residual norm 3.943330715537e-01
6350 KSP Residual norm 3.943330715537e-01
6351 KSP Residual norm 3.943330715537e-01
6352 KSP Residual norm 3.943330715537e-01
6353 KSP Residual norm 3.943330715537e-01
6354 KSP Residual norm 3.943330715537e-01
6355 KSP Residual norm 3.943330715537e-01
6356 KSP Residual norm 3.943330715537e-01
6357 KSP Residual norm 3.943330715537e-01
6358 KSP Residual norm 3.943330715537e-01
6359 KSP Residual norm 3.943330715537e-01
6360 KSP Residual norm 3.943330715535e-01
6361 KSP Residual norm 3.943330715535e-01
6362 KSP Residual norm 3.943330715535e-01
6363 KSP Residual norm 3.943330715535e-01
6364 KSP Residual norm 3.943330715535e-01
6365 KSP Residual norm 3.943330715535e-01
6366 KSP Residual norm 3.943330715535e-01
6367 KSP Residual norm 3.943330715535e-01
6368 KSP Residual norm 3.943330715535e-01
6369 KSP Residual norm 3.943330715535e-01
6370 KSP Residual norm 3.943330715535e-01
6371 KSP Residual norm 3.943330715535e-01
6372 KSP Residual norm 3.943330715535e-01
6373 KSP Residual norm 3.943330715535e-01
6374 KSP Residual norm 3.943330715535e-01
6375 KSP Residual norm 3.943330715535e-01
6376 KSP Residual norm 3.943330715535e-01
6377 KSP Residual norm 3.943330715535e-01
6378 KSP Residual norm 3.943330715535e-01
6379 KSP Residual norm 3.943330715535e-01
6380 KSP Residual norm 3.943330715535e-01
6381 KSP Residual norm 3.943330715535e-01
6382 KSP Residual norm 3.943330715535e-01
6383 KSP Residual norm 3.943330715535e-01
6384 KSP Residual norm 3.943330715535e-01
6385 KSP Residual norm 3.943330715535e-01
6386 KSP Residual norm 3.943330715535e-01
6387 KSP Residual norm 3.943330715535e-01
6388 KSP Residual norm 3.943330715535e-01
6389 KSP Residual norm 3.943330715535e-01
6390 KSP Residual norm 3.943330715537e-01
6391 KSP Residual norm 3.943330715537e-01
6392 KSP Residual norm 3.943330715537e-01
6393 KSP Residual norm 3.943330715537e-01
6394 KSP Residual norm 3.943330715537e-01
6395 KSP Residual norm 3.943330715537e-01
6396 KSP Residual norm 3.943330715537e-01
6397 KSP Residual norm 3.943330715537e-01
6398 KSP Residual norm 3.943330715537e-01
6399 KSP Residual norm 3.943330715537e-01
6400 KSP Residual norm 3.943330715537e-01
6401 KSP Residual norm 3.943330715537e-01
6402 KSP Residual norm 3.943330715537e-01
6403 KSP Residual norm 3.943330715537e-01
6404 KSP Residual norm 3.943330715537e-01
6405 KSP Residual norm 3.943330715537e-01
6406 KSP Residual norm 3.943330715537e-01
6407 KSP Residual norm 3.943330715537e-01
6408 KSP Residual norm 3.943330715537e-01
6409 KSP Residual norm 3.943330715537e-01
6410 KSP Residual norm 3.943330715537e-01
6411 KSP Residual norm 3.943330715537e-01
6412 KSP Residual norm 3.943330715537e-01
6413 KSP Residual norm 3.943330715537e-01
6414 KSP Residual norm 3.943330715537e-01
6415 KSP Residual norm 3.943330715537e-01
6416 KSP Residual norm 3.943330715537e-01
6417 KSP Residual norm 3.943330715537e-01
6418 KSP Residual norm 3.943330715537e-01
6419 KSP Residual norm 3.943330715537e-01
6420 KSP Residual norm 3.943330715536e-01
6421 KSP Residual norm 3.943330715536e-01
6422 KSP Residual norm 3.943330715536e-01
6423 KSP Residual norm 3.943330715536e-01
6424 KSP Residual norm 3.943330715536e-01
6425 KSP Residual norm 3.943330715536e-01
6426 KSP Residual norm 3.943330715536e-01
6427 KSP Residual norm 3.943330715536e-01
6428 KSP Residual norm 3.943330715536e-01
6429 KSP Residual norm 3.943330715536e-01
6430 KSP Residual norm 3.943330715536e-01
6431 KSP Residual norm 3.943330715536e-01
6432 KSP Residual norm 3.943330715536e-01
6433 KSP Residual norm 3.943330715536e-01
6434 KSP Residual norm 3.943330715536e-01
6435 KSP Residual norm 3.943330715536e-01
6436 KSP Residual norm 3.943330715536e-01
6437 KSP Residual norm 3.943330715536e-01
6438 KSP Residual norm 3.943330715536e-01
6439 KSP Residual norm 3.943330715536e-01
6440 KSP Residual norm 3.943330715536e-01
6441 KSP Residual norm 3.943330715536e-01
6442 KSP Residual norm 3.943330715536e-01
6443 KSP Residual norm 3.943330715536e-01
6444 KSP Residual norm 3.943330715536e-01
6445 KSP Residual norm 3.943330715536e-01
6446 KSP Residual norm 3.943330715536e-01
6447 KSP Residual norm 3.943330715536e-01
6448 KSP Residual norm 3.943330715536e-01
6449 KSP Residual norm 3.943330715536e-01
6450 KSP Residual norm 3.943330715539e-01
6451 KSP Residual norm 3.943330715539e-01
6452 KSP Residual norm 3.943330715539e-01
6453 KSP Residual norm 3.943330715539e-01
6454 KSP Residual norm 3.943330715539e-01
6455 KSP Residual norm 3.943330715539e-01
6456 KSP Residual norm 3.943330715539e-01
6457 KSP Residual norm 3.943330715539e-01
6458 KSP Residual norm 3.943330715539e-01
6459 KSP Residual norm 3.943330715539e-01
6460 KSP Residual norm 3.943330715539e-01
6461 KSP Residual norm 3.943330715539e-01
6462 KSP Residual norm 3.943330715539e-01
6463 KSP Residual norm 3.943330715539e-01
6464 KSP Residual norm 3.943330715539e-01
6465 KSP Residual norm 3.943330715539e-01
6466 KSP Residual norm 3.943330715539e-01
6467 KSP Residual norm 3.943330715539e-01
6468 KSP Residual norm 3.943330715539e-01
6469 KSP Residual norm 3.943330715539e-01
6470 KSP Residual norm 3.943330715539e-01
6471 KSP Residual norm 3.943330715539e-01
6472 KSP Residual norm 3.943330715539e-01
6473 KSP Residual norm 3.943330715539e-01
6474 KSP Residual norm 3.943330715539e-01
6475 KSP Residual norm 3.943330715539e-01
6476 KSP Residual norm 3.943330715539e-01
6477 KSP Residual norm 3.943330715539e-01
6478 KSP Residual norm 3.943330715539e-01
6479 KSP Residual norm 3.943330715539e-01
6480 KSP Residual norm 3.943330715539e-01
6481 KSP Residual norm 3.943330715539e-01
6482 KSP Residual norm 3.943330715539e-01
6483 KSP Residual norm 3.943330715539e-01
6484 KSP Residual norm 3.943330715539e-01
6485 KSP Residual norm 3.943330715539e-01
6486 KSP Residual norm 3.943330715539e-01
6487 KSP Residual norm 3.943330715539e-01
6488 KSP Residual norm 3.943330715539e-01
6489 KSP Residual norm 3.943330715539e-01
6490 KSP Residual norm 3.943330715539e-01
6491 KSP Residual norm 3.943330715539e-01
6492 KSP Residual norm 3.943330715539e-01
6493 KSP Residual norm 3.943330715539e-01
6494 KSP Residual norm 3.943330715539e-01
6495 KSP Residual norm 3.943330715539e-01
6496 KSP Residual norm 3.943330715539e-01
6497 KSP Residual norm 3.943330715539e-01
6498 KSP Residual norm 3.943330715539e-01
6499 KSP Residual norm 3.943330715539e-01
6500 KSP Residual norm 3.943330715539e-01
6501 KSP Residual norm 3.943330715539e-01
6502 KSP Residual norm 3.943330715539e-01
6503 KSP Residual norm 3.943330715539e-01
6504 KSP Residual norm 3.943330715539e-01
6505 KSP Residual norm 3.943330715539e-01
6506 KSP Residual norm 3.943330715539e-01
6507 KSP Residual norm 3.943330715539e-01
6508 KSP Residual norm 3.943330715539e-01
6509 KSP Residual norm 3.943330715539e-01
6510 KSP Residual norm 3.943330715540e-01
6511 KSP Residual norm 3.943330715540e-01
6512 KSP Residual norm 3.943330715540e-01
6513 KSP Residual norm 3.943330715540e-01
6514 KSP Residual norm 3.943330715540e-01
6515 KSP Residual norm 3.943330715540e-01
6516 KSP Residual norm 3.943330715540e-01
6517 KSP Residual norm 3.943330715540e-01
6518 KSP Residual norm 3.943330715540e-01
6519 KSP Residual norm 3.943330715540e-01
6520 KSP Residual norm 3.943330715540e-01
6521 KSP Residual norm 3.943330715540e-01
6522 KSP Residual norm 3.943330715540e-01
6523 KSP Residual norm 3.943330715540e-01
6524 KSP Residual norm 3.943330715540e-01
6525 KSP Residual norm 3.943330715540e-01
6526 KSP Residual norm 3.943330715540e-01
6527 KSP Residual norm 3.943330715540e-01
6528 KSP Residual norm 3.943330715540e-01
6529 KSP Residual norm 3.943330715540e-01
6530 KSP Residual norm 3.943330715540e-01
6531 KSP Residual norm 3.943330715540e-01
6532 KSP Residual norm 3.943330715540e-01
6533 KSP Residual norm 3.943330715540e-01
6534 KSP Residual norm 3.943330715540e-01
6535 KSP Residual norm 3.943330715540e-01
6536 KSP Residual norm 3.943330715540e-01
6537 KSP Residual norm 3.943330715540e-01
6538 KSP Residual norm 3.943330715540e-01
6539 KSP Residual norm 3.943330715540e-01
6540 KSP Residual norm 3.943330715540e-01
6541 KSP Residual norm 3.943330715540e-01
6542 KSP Residual norm 3.943330715540e-01
6543 KSP Residual norm 3.943330715540e-01
6544 KSP Residual norm 3.943330715540e-01
6545 KSP Residual norm 3.943330715540e-01
6546 KSP Residual norm 3.943330715540e-01
6547 KSP Residual norm 3.943330715540e-01
6548 KSP Residual norm 3.943330715540e-01
6549 KSP Residual norm 3.943330715540e-01
6550 KSP Residual norm 3.943330715540e-01
6551 KSP Residual norm 3.943330715540e-01
6552 KSP Residual norm 3.943330715540e-01
6553 KSP Residual norm 3.943330715540e-01
6554 KSP Residual norm 3.943330715540e-01
6555 KSP Residual norm 3.943330715540e-01
6556 KSP Residual norm 3.943330715540e-01
6557 KSP Residual norm 3.943330715540e-01
6558 KSP Residual norm 3.943330715540e-01
6559 KSP Residual norm 3.943330715540e-01
6560 KSP Residual norm 3.943330715540e-01
6561 KSP Residual norm 3.943330715540e-01
6562 KSP Residual norm 3.943330715540e-01
6563 KSP Residual norm 3.943330715540e-01
6564 KSP Residual norm 3.943330715540e-01
6565 KSP Residual norm 3.943330715540e-01
6566 KSP Residual norm 3.943330715540e-01
6567 KSP Residual norm 3.943330715540e-01
6568 KSP Residual norm 3.943330715540e-01
6569 KSP Residual norm 3.943330715540e-01
6570 KSP Residual norm 3.943330715539e-01
6571 KSP Residual norm 3.943330715539e-01
6572 KSP Residual norm 3.943330715539e-01
6573 KSP Residual norm 3.943330715539e-01
6574 KSP Residual norm 3.943330715539e-01
6575 KSP Residual norm 3.943330715539e-01
6576 KSP Residual norm 3.943330715539e-01
6577 KSP Residual norm 3.943330715539e-01
6578 KSP Residual norm 3.943330715539e-01
6579 KSP Residual norm 3.943330715539e-01
6580 KSP Residual norm 3.943330715539e-01
6581 KSP Residual norm 3.943330715539e-01
6582 KSP Residual norm 3.943330715539e-01
6583 KSP Residual norm 3.943330715539e-01
6584 KSP Residual norm 3.943330715539e-01
6585 KSP Residual norm 3.943330715539e-01
6586 KSP Residual norm 3.943330715539e-01
6587 KSP Residual norm 3.943330715539e-01
6588 KSP Residual norm 3.943330715539e-01
6589 KSP Residual norm 3.943330715539e-01
6590 KSP Residual norm 3.943330715539e-01
6591 KSP Residual norm 3.943330715539e-01
6592 KSP Residual norm 3.943330715539e-01
6593 KSP Residual norm 3.943330715539e-01
6594 KSP Residual norm 3.943330715539e-01
6595 KSP Residual norm 3.943330715539e-01
6596 KSP Residual norm 3.943330715539e-01
6597 KSP Residual norm 3.943330715539e-01
6598 KSP Residual norm 3.943330715539e-01
6599 KSP Residual norm 3.943330715539e-01
6600 KSP Residual norm 3.943330715540e-01
6601 KSP Residual norm 3.943330715540e-01
6602 KSP Residual norm 3.943330715540e-01
6603 KSP Residual norm 3.943330715540e-01
6604 KSP Residual norm 3.943330715540e-01
6605 KSP Residual norm 3.943330715540e-01
6606 KSP Residual norm 3.943330715540e-01
6607 KSP Residual norm 3.943330715540e-01
6608 KSP Residual norm 3.943330715540e-01
6609 KSP Residual norm 3.943330715540e-01
6610 KSP Residual norm 3.943330715540e-01
6611 KSP Residual norm 3.943330715540e-01
6612 KSP Residual norm 3.943330715540e-01
6613 KSP Residual norm 3.943330715540e-01
6614 KSP Residual norm 3.943330715540e-01
6615 KSP Residual norm 3.943330715540e-01
6616 KSP Residual norm 3.943330715540e-01
6617 KSP Residual norm 3.943330715540e-01
6618 KSP Residual norm 3.943330715540e-01
6619 KSP Residual norm 3.943330715540e-01
6620 KSP Residual norm 3.943330715540e-01
6621 KSP Residual norm 3.943330715540e-01
6622 KSP Residual norm 3.943330715540e-01
6623 KSP Residual norm 3.943330715540e-01
6624 KSP Residual norm 3.943330715540e-01
6625 KSP Residual norm 3.943330715540e-01
6626 KSP Residual norm 3.943330715540e-01
6627 KSP Residual norm 3.943330715540e-01
6628 KSP Residual norm 3.943330715540e-01
6629 KSP Residual norm 3.943330715540e-01
6630 KSP Residual norm 3.943330715538e-01
6631 KSP Residual norm 3.943330715538e-01
6632 KSP Residual norm 3.943330715538e-01
6633 KSP Residual norm 3.943330715538e-01
6634 KSP Residual norm 3.943330715538e-01
6635 KSP Residual norm 3.943330715538e-01
6636 KSP Residual norm 3.943330715538e-01
6637 KSP Residual norm 3.943330715538e-01
6638 KSP Residual norm 3.943330715538e-01
6639 KSP Residual norm 3.943330715538e-01
6640 KSP Residual norm 3.943330715538e-01
6641 KSP Residual norm 3.943330715538e-01
6642 KSP Residual norm 3.943330715538e-01
6643 KSP Residual norm 3.943330715538e-01
6644 KSP Residual norm 3.943330715538e-01
6645 KSP Residual norm 3.943330715538e-01
6646 KSP Residual norm 3.943330715538e-01
6647 KSP Residual norm 3.943330715538e-01
6648 KSP Residual norm 3.943330715538e-01
6649 KSP Residual norm 3.943330715538e-01
6650 KSP Residual norm 3.943330715538e-01
6651 KSP Residual norm 3.943330715538e-01
6652 KSP Residual norm 3.943330715538e-01
6653 KSP Residual norm 3.943330715538e-01
6654 KSP Residual norm 3.943330715538e-01
6655 KSP Residual norm 3.943330715538e-01
6656 KSP Residual norm 3.943330715538e-01
6657 KSP Residual norm 3.943330715538e-01
6658 KSP Residual norm 3.943330715538e-01
6659 KSP Residual norm 3.943330715538e-01
6660 KSP Residual norm 3.943330715541e-01
6661 KSP Residual norm 3.943330715541e-01
6662 KSP Residual norm 3.943330715541e-01
6663 KSP Residual norm 3.943330715541e-01
6664 KSP Residual norm 3.943330715541e-01
6665 KSP Residual norm 3.943330715541e-01
6666 KSP Residual norm 3.943330715541e-01
6667 KSP Residual norm 3.943330715541e-01
6668 KSP Residual norm 3.943330715541e-01
6669 KSP Residual norm 3.943330715541e-01
6670 KSP Residual norm 3.943330715541e-01
6671 KSP Residual norm 3.943330715541e-01
6672 KSP Residual norm 3.943330715541e-01
6673 KSP Residual norm 3.943330715541e-01
6674 KSP Residual norm 3.943330715541e-01
6675 KSP Residual norm 3.943330715541e-01
6676 KSP Residual norm 3.943330715541e-01
6677 KSP Residual norm 3.943330715541e-01
6678 KSP Residual norm 3.943330715541e-01
6679 KSP Residual norm 3.943330715541e-01
6680 KSP Residual norm 3.943330715541e-01
6681 KSP Residual norm 3.943330715541e-01
6682 KSP Residual norm 3.943330715541e-01
6683 KSP Residual norm 3.943330715541e-01
6684 KSP Residual norm 3.943330715541e-01
6685 KSP Residual norm 3.943330715541e-01
6686 KSP Residual norm 3.943330715541e-01
6687 KSP Residual norm 3.943330715541e-01
6688 KSP Residual norm 3.943330715541e-01
6689 KSP Residual norm 3.943330715541e-01
6690 KSP Residual norm 3.943330715539e-01
6691 KSP Residual norm 3.943330715539e-01
6692 KSP Residual norm 3.943330715539e-01
6693 KSP Residual norm 3.943330715539e-01
6694 KSP Residual norm 3.943330715539e-01
6695 KSP Residual norm 3.943330715539e-01
6696 KSP Residual norm 3.943330715539e-01
6697 KSP Residual norm 3.943330715539e-01
6698 KSP Residual norm 3.943330715539e-01
6699 KSP Residual norm 3.943330715539e-01
6700 KSP Residual norm 3.943330715539e-01
6701 KSP Residual norm 3.943330715539e-01
6702 KSP Residual norm 3.943330715539e-01
6703 KSP Residual norm 3.943330715539e-01
6704 KSP Residual norm 3.943330715539e-01
6705 KSP Residual norm 3.943330715539e-01
6706 KSP Residual norm 3.943330715539e-01
6707 KSP Residual norm 3.943330715539e-01
6708 KSP Residual norm 3.943330715539e-01
6709 KSP Residual norm 3.943330715539e-01
6710 KSP Residual norm 3.943330715539e-01
6711 KSP Residual norm 3.943330715539e-01
6712 KSP Residual norm 3.943330715539e-01
6713 KSP Residual norm 3.943330715539e-01
6714 KSP Residual norm 3.943330715539e-01
6715 KSP Residual norm 3.943330715539e-01
6716 KSP Residual norm 3.943330715539e-01
6717 KSP Residual norm 3.943330715539e-01
6718 KSP Residual norm 3.943330715539e-01
6719 KSP Residual norm 3.943330715539e-01
6720 KSP Residual norm 3.943330715540e-01
6721 KSP Residual norm 3.943330715540e-01
6722 KSP Residual norm 3.943330715540e-01
6723 KSP Residual norm 3.943330715540e-01
6724 KSP Residual norm 3.943330715540e-01
6725 KSP Residual norm 3.943330715540e-01
6726 KSP Residual norm 3.943330715540e-01
6727 KSP Residual norm 3.943330715540e-01
6728 KSP Residual norm 3.943330715540e-01
6729 KSP Residual norm 3.943330715540e-01
6730 KSP Residual norm 3.943330715540e-01
6731 KSP Residual norm 3.943330715540e-01
6732 KSP Residual norm 3.943330715540e-01
6733 KSP Residual norm 3.943330715540e-01
6734 KSP Residual norm 3.943330715540e-01
6735 KSP Residual norm 3.943330715540e-01
6736 KSP Residual norm 3.943330715540e-01
6737 KSP Residual norm 3.943330715540e-01
6738 KSP Residual norm 3.943330715540e-01
6739 KSP Residual norm 3.943330715540e-01
6740 KSP Residual norm 3.943330715540e-01
6741 KSP Residual norm 3.943330715540e-01
6742 KSP Residual norm 3.943330715540e-01
6743 KSP Residual norm 3.943330715540e-01
6744 KSP Residual norm 3.943330715540e-01
6745 KSP Residual norm 3.943330715540e-01
6746 KSP Residual norm 3.943330715540e-01
6747 KSP Residual norm 3.943330715540e-01
6748 KSP Residual norm 3.943330715540e-01
6749 KSP Residual norm 3.943330715540e-01
6750 KSP Residual norm 3.943330715540e-01
6751 KSP Residual norm 3.943330715540e-01
6752 KSP Residual norm 3.943330715540e-01
6753 KSP Residual norm 3.943330715540e-01
6754 KSP Residual norm 3.943330715540e-01
6755 KSP Residual norm 3.943330715540e-01
6756 KSP Residual norm 3.943330715540e-01
6757 KSP Residual norm 3.943330715540e-01
6758 KSP Residual norm 3.943330715540e-01
6759 KSP Residual norm 3.943330715540e-01
6760 KSP Residual norm 3.943330715540e-01
6761 KSP Residual norm 3.943330715540e-01
6762 KSP Residual norm 3.943330715540e-01
6763 KSP Residual norm 3.943330715540e-01
6764 KSP Residual norm 3.943330715540e-01
6765 KSP Residual norm 3.943330715540e-01
6766 KSP Residual norm 3.943330715540e-01
6767 KSP Residual norm 3.943330715540e-01
6768 KSP Residual norm 3.943330715540e-01
6769 KSP Residual norm 3.943330715540e-01
6770 KSP Residual norm 3.943330715540e-01
6771 KSP Residual norm 3.943330715540e-01
6772 KSP Residual norm 3.943330715540e-01
6773 KSP Residual norm 3.943330715540e-01
6774 KSP Residual norm 3.943330715540e-01
6775 KSP Residual norm 3.943330715540e-01
6776 KSP Residual norm 3.943330715540e-01
6777 KSP Residual norm 3.943330715540e-01
6778 KSP Residual norm 3.943330715540e-01
6779 KSP Residual norm 3.943330715540e-01
6780 KSP Residual norm 3.943330715541e-01
6781 KSP Residual norm 3.943330715541e-01
6782 KSP Residual norm 3.943330715541e-01
6783 KSP Residual norm 3.943330715541e-01
6784 KSP Residual norm 3.943330715541e-01
6785 KSP Residual norm 3.943330715541e-01
6786 KSP Residual norm 3.943330715541e-01
6787 KSP Residual norm 3.943330715541e-01
6788 KSP Residual norm 3.943330715541e-01
6789 KSP Residual norm 3.943330715541e-01
6790 KSP Residual norm 3.943330715541e-01
6791 KSP Residual norm 3.943330715541e-01
6792 KSP Residual norm 3.943330715541e-01
6793 KSP Residual norm 3.943330715541e-01
6794 KSP Residual norm 3.943330715541e-01
6795 KSP Residual norm 3.943330715541e-01
6796 KSP Residual norm 3.943330715541e-01
6797 KSP Residual norm 3.943330715541e-01
6798 KSP Residual norm 3.943330715541e-01
6799 KSP Residual norm 3.943330715541e-01
6800 KSP Residual norm 3.943330715541e-01
6801 KSP Residual norm 3.943330715541e-01
6802 KSP Residual norm 3.943330715541e-01
6803 KSP Residual norm 3.943330715541e-01
6804 KSP Residual norm 3.943330715541e-01
6805 KSP Residual norm 3.943330715541e-01
6806 KSP Residual norm 3.943330715541e-01
6807 KSP Residual norm 3.943330715541e-01
6808 KSP Residual norm 3.943330715541e-01
6809 KSP Residual norm 3.943330715541e-01
6810 KSP Residual norm 3.943330715539e-01
6811 KSP Residual norm 3.943330715539e-01
6812 KSP Residual norm 3.943330715539e-01
6813 KSP Residual norm 3.943330715539e-01
6814 KSP Residual norm 3.943330715539e-01
6815 KSP Residual norm 3.943330715539e-01
6816 KSP Residual norm 3.943330715539e-01
6817 KSP Residual norm 3.943330715539e-01
6818 KSP Residual norm 3.943330715539e-01
6819 KSP Residual norm 3.943330715539e-01
6820 KSP Residual norm 3.943330715539e-01
6821 KSP Residual norm 3.943330715539e-01
6822 KSP Residual norm 3.943330715539e-01
6823 KSP Residual norm 3.943330715539e-01
6824 KSP Residual norm 3.943330715539e-01
6825 KSP Residual norm 3.943330715539e-01
6826 KSP Residual norm 3.943330715539e-01
6827 KSP Residual norm 3.943330715539e-01
6828 KSP Residual norm 3.943330715539e-01
6829 KSP Residual norm 3.943330715539e-01
6830 KSP Residual norm 3.943330715539e-01
6831 KSP Residual norm 3.943330715539e-01
6832 KSP Residual norm 3.943330715539e-01
6833 KSP Residual norm 3.943330715539e-01
6834 KSP Residual norm 3.943330715539e-01
6835 KSP Residual norm 3.943330715539e-01
6836 KSP Residual norm 3.943330715539e-01
6837 KSP Residual norm 3.943330715539e-01
6838 KSP Residual norm 3.943330715539e-01
6839 KSP Residual norm 3.943330715539e-01
6840 KSP Residual norm 3.943330715539e-01
6841 KSP Residual norm 3.943330715539e-01
6842 KSP Residual norm 3.943330715539e-01
6843 KSP Residual norm 3.943330715539e-01
6844 KSP Residual norm 3.943330715539e-01
6845 KSP Residual norm 3.943330715539e-01
6846 KSP Residual norm 3.943330715539e-01
6847 KSP Residual norm 3.943330715539e-01
6848 KSP Residual norm 3.943330715539e-01
6849 KSP Residual norm 3.943330715539e-01
6850 KSP Residual norm 3.943330715539e-01
6851 KSP Residual norm 3.943330715539e-01
6852 KSP Residual norm 3.943330715539e-01
6853 KSP Residual norm 3.943330715539e-01
6854 KSP Residual norm 3.943330715539e-01
6855 KSP Residual norm 3.943330715539e-01
6856 KSP Residual norm 3.943330715539e-01
6857 KSP Residual norm 3.943330715539e-01
6858 KSP Residual norm 3.943330715539e-01
6859 KSP Residual norm 3.943330715539e-01
6860 KSP Residual norm 3.943330715539e-01
6861 KSP Residual norm 3.943330715539e-01
6862 KSP Residual norm 3.943330715539e-01
6863 KSP Residual norm 3.943330715539e-01
6864 KSP Residual norm 3.943330715539e-01
6865 KSP Residual norm 3.943330715539e-01
6866 KSP Residual norm 3.943330715539e-01
6867 KSP Residual norm 3.943330715539e-01
6868 KSP Residual norm 3.943330715539e-01
6869 KSP Residual norm 3.943330715539e-01
6870 KSP Residual norm 3.943330715539e-01
6871 KSP Residual norm 3.943330715539e-01
6872 KSP Residual norm 3.943330715539e-01
6873 KSP Residual norm 3.943330715539e-01
6874 KSP Residual norm 3.943330715539e-01
6875 KSP Residual norm 3.943330715539e-01
6876 KSP Residual norm 3.943330715539e-01
6877 KSP Residual norm 3.943330715539e-01
6878 KSP Residual norm 3.943330715539e-01
6879 KSP Residual norm 3.943330715539e-01
6880 KSP Residual norm 3.943330715539e-01
6881 KSP Residual norm 3.943330715539e-01
6882 KSP Residual norm 3.943330715539e-01
6883 KSP Residual norm 3.943330715539e-01
6884 KSP Residual norm 3.943330715539e-01
6885 KSP Residual norm 3.943330715539e-01
6886 KSP Residual norm 3.943330715539e-01
6887 KSP Residual norm 3.943330715539e-01
6888 KSP Residual norm 3.943330715539e-01
6889 KSP Residual norm 3.943330715539e-01
6890 KSP Residual norm 3.943330715539e-01
6891 KSP Residual norm 3.943330715539e-01
6892 KSP Residual norm 3.943330715539e-01
6893 KSP Residual norm 3.943330715539e-01
6894 KSP Residual norm 3.943330715539e-01
6895 KSP Residual norm 3.943330715539e-01
6896 KSP Residual norm 3.943330715539e-01
6897 KSP Residual norm 3.943330715539e-01
6898 KSP Residual norm 3.943330715539e-01
6899 KSP Residual norm 3.943330715539e-01
6900 KSP Residual norm 3.943330715542e-01
6901 KSP Residual norm 3.943330715542e-01
6902 KSP Residual norm 3.943330715542e-01
6903 KSP Residual norm 3.943330715542e-01
6904 KSP Residual norm 3.943330715542e-01
6905 KSP Residual norm 3.943330715542e-01
6906 KSP Residual norm 3.943330715542e-01
6907 KSP Residual norm 3.943330715542e-01
6908 KSP Residual norm 3.943330715542e-01
6909 KSP Residual norm 3.943330715542e-01
6910 KSP Residual norm 3.943330715542e-01
6911 KSP Residual norm 3.943330715542e-01
6912 KSP Residual norm 3.943330715542e-01
6913 KSP Residual norm 3.943330715542e-01
6914 KSP Residual norm 3.943330715542e-01
6915 KSP Residual norm 3.943330715542e-01
6916 KSP Residual norm 3.943330715542e-01
6917 KSP Residual norm 3.943330715542e-01
6918 KSP Residual norm 3.943330715542e-01
6919 KSP Residual norm 3.943330715542e-01
6920 KSP Residual norm 3.943330715542e-01
6921 KSP Residual norm 3.943330715542e-01
6922 KSP Residual norm 3.943330715542e-01
6923 KSP Residual norm 3.943330715542e-01
6924 KSP Residual norm 3.943330715542e-01
6925 KSP Residual norm 3.943330715542e-01
6926 KSP Residual norm 3.943330715542e-01
6927 KSP Residual norm 3.943330715542e-01
6928 KSP Residual norm 3.943330715542e-01
6929 KSP Residual norm 3.943330715542e-01
6930 KSP Residual norm 3.943330715541e-01
6931 KSP Residual norm 3.943330715541e-01
6932 KSP Residual norm 3.943330715541e-01
6933 KSP Residual norm 3.943330715541e-01
6934 KSP Residual norm 3.943330715541e-01
6935 KSP Residual norm 3.943330715541e-01
6936 KSP Residual norm 3.943330715541e-01
6937 KSP Residual norm 3.943330715541e-01
6938 KSP Residual norm 3.943330715541e-01
6939 KSP Residual norm 3.943330715541e-01
6940 KSP Residual norm 3.943330715541e-01
6941 KSP Residual norm 3.943330715541e-01
6942 KSP Residual norm 3.943330715541e-01
6943 KSP Residual norm 3.943330715541e-01
6944 KSP Residual norm 3.943330715541e-01
6945 KSP Residual norm 3.943330715541e-01
6946 KSP Residual norm 3.943330715541e-01
6947 KSP Residual norm 3.943330715541e-01
6948 KSP Residual norm 3.943330715541e-01
6949 KSP Residual norm 3.943330715541e-01
6950 KSP Residual norm 3.943330715541e-01
6951 KSP Residual norm 3.943330715541e-01
6952 KSP Residual norm 3.943330715541e-01
6953 KSP Residual norm 3.943330715541e-01
6954 KSP Residual norm 3.943330715541e-01
6955 KSP Residual norm 3.943330715541e-01
6956 KSP Residual norm 3.943330715541e-01
6957 KSP Residual norm 3.943330715541e-01
6958 KSP Residual norm 3.943330715541e-01
6959 KSP Residual norm 3.943330715541e-01
6960 KSP Residual norm 3.943330715538e-01
6961 KSP Residual norm 3.943330715538e-01
6962 KSP Residual norm 3.943330715538e-01
6963 KSP Residual norm 3.943330715538e-01
6964 KSP Residual norm 3.943330715538e-01
6965 KSP Residual norm 3.943330715538e-01
6966 KSP Residual norm 3.943330715538e-01
6967 KSP Residual norm 3.943330715538e-01
6968 KSP Residual norm 3.943330715538e-01
6969 KSP Residual norm 3.943330715538e-01
6970 KSP Residual norm 3.943330715538e-01
6971 KSP Residual norm 3.943330715538e-01
6972 KSP Residual norm 3.943330715538e-01
6973 KSP Residual norm 3.943330715538e-01
6974 KSP Residual norm 3.943330715538e-01
6975 KSP Residual norm 3.943330715538e-01
6976 KSP Residual norm 3.943330715538e-01
6977 KSP Residual norm 3.943330715538e-01
6978 KSP Residual norm 3.943330715538e-01
6979 KSP Residual norm 3.943330715538e-01
6980 KSP Residual norm 3.943330715538e-01
6981 KSP Residual norm 3.943330715538e-01
6982 KSP Residual norm 3.943330715538e-01
6983 KSP Residual norm 3.943330715538e-01
6984 KSP Residual norm 3.943330715538e-01
6985 KSP Residual norm 3.943330715538e-01
6986 KSP Residual norm 3.943330715538e-01
6987 KSP Residual norm 3.943330715538e-01
6988 KSP Residual norm 3.943330715538e-01
6989 KSP Residual norm 3.943330715538e-01
6990 KSP Residual norm 3.943330715539e-01
6991 KSP Residual norm 3.943330715539e-01
6992 KSP Residual norm 3.943330715539e-01
6993 KSP Residual norm 3.943330715539e-01
6994 KSP Residual norm 3.943330715539e-01
6995 KSP Residual norm 3.943330715539e-01
6996 KSP Residual norm 3.943330715539e-01
6997 KSP Residual norm 3.943330715539e-01
6998 KSP Residual norm 3.943330715539e-01
6999 KSP Residual norm 3.943330715539e-01
7000 KSP Residual norm 3.943330715539e-01
7001 KSP Residual norm 3.943330715539e-01
7002 KSP Residual norm 3.943330715539e-01
7003 KSP Residual norm 3.943330715539e-01
7004 KSP Residual norm 3.943330715539e-01
7005 KSP Residual norm 3.943330715539e-01
7006 KSP Residual norm 3.943330715539e-01
7007 KSP Residual norm 3.943330715539e-01
7008 KSP Residual norm 3.943330715539e-01
7009 KSP Residual norm 3.943330715539e-01
7010 KSP Residual norm 3.943330715539e-01
7011 KSP Residual norm 3.943330715539e-01
7012 KSP Residual norm 3.943330715539e-01
7013 KSP Residual norm 3.943330715539e-01
7014 KSP Residual norm 3.943330715539e-01
7015 KSP Residual norm 3.943330715539e-01
7016 KSP Residual norm 3.943330715539e-01
7017 KSP Residual norm 3.943330715539e-01
7018 KSP Residual norm 3.943330715539e-01
7019 KSP Residual norm 3.943330715539e-01
7020 KSP Residual norm 3.943330715539e-01
7021 KSP Residual norm 3.943330715539e-01
7022 KSP Residual norm 3.943330715539e-01
7023 KSP Residual norm 3.943330715539e-01
7024 KSP Residual norm 3.943330715539e-01
7025 KSP Residual norm 3.943330715539e-01
7026 KSP Residual norm 3.943330715539e-01
7027 KSP Residual norm 3.943330715539e-01
7028 KSP Residual norm 3.943330715539e-01
7029 KSP Residual norm 3.943330715539e-01
7030 KSP Residual norm 3.943330715539e-01
7031 KSP Residual norm 3.943330715539e-01
7032 KSP Residual norm 3.943330715539e-01
7033 KSP Residual norm 3.943330715539e-01
7034 KSP Residual norm 3.943330715539e-01
7035 KSP Residual norm 3.943330715539e-01
7036 KSP Residual norm 3.943330715539e-01
7037 KSP Residual norm 3.943330715539e-01
7038 KSP Residual norm 3.943330715539e-01
7039 KSP Residual norm 3.943330715539e-01
7040 KSP Residual norm 3.943330715539e-01
7041 KSP Residual norm 3.943330715539e-01
7042 KSP Residual norm 3.943330715539e-01
7043 KSP Residual norm 3.943330715539e-01
7044 KSP Residual norm 3.943330715539e-01
7045 KSP Residual norm 3.943330715539e-01
7046 KSP Residual norm 3.943330715539e-01
7047 KSP Residual norm 3.943330715539e-01
7048 KSP Residual norm 3.943330715539e-01
7049 KSP Residual norm 3.943330715539e-01
7050 KSP Residual norm 3.943330715537e-01
7051 KSP Residual norm 3.943330715537e-01
7052 KSP Residual norm 3.943330715537e-01
7053 KSP Residual norm 3.943330715537e-01
7054 KSP Residual norm 3.943330715537e-01
7055 KSP Residual norm 3.943330715537e-01
7056 KSP Residual norm 3.943330715537e-01
7057 KSP Residual norm 3.943330715537e-01
7058 KSP Residual norm 3.943330715537e-01
7059 KSP Residual norm 3.943330715537e-01
7060 KSP Residual norm 3.943330715537e-01
7061 KSP Residual norm 3.943330715537e-01
7062 KSP Residual norm 3.943330715537e-01
7063 KSP Residual norm 3.943330715537e-01
7064 KSP Residual norm 3.943330715537e-01
7065 KSP Residual norm 3.943330715537e-01
7066 KSP Residual norm 3.943330715537e-01
7067 KSP Residual norm 3.943330715537e-01
7068 KSP Residual norm 3.943330715537e-01
7069 KSP Residual norm 3.943330715537e-01
7070 KSP Residual norm 3.943330715537e-01
7071 KSP Residual norm 3.943330715537e-01
7072 KSP Residual norm 3.943330715537e-01
7073 KSP Residual norm 3.943330715537e-01
7074 KSP Residual norm 3.943330715537e-01
7075 KSP Residual norm 3.943330715537e-01
7076 KSP Residual norm 3.943330715537e-01
7077 KSP Residual norm 3.943330715537e-01
7078 KSP Residual norm 3.943330715537e-01
7079 KSP Residual norm 3.943330715537e-01
7080 KSP Residual norm 3.943330715535e-01
7081 KSP Residual norm 3.943330715535e-01
7082 KSP Residual norm 3.943330715535e-01
7083 KSP Residual norm 3.943330715535e-01
7084 KSP Residual norm 3.943330715535e-01
7085 KSP Residual norm 3.943330715535e-01
7086 KSP Residual norm 3.943330715535e-01
7087 KSP Residual norm 3.943330715535e-01
7088 KSP Residual norm 3.943330715535e-01
7089 KSP Residual norm 3.943330715535e-01
7090 KSP Residual norm 3.943330715535e-01
7091 KSP Residual norm 3.943330715535e-01
7092 KSP Residual norm 3.943330715535e-01
7093 KSP Residual norm 3.943330715535e-01
7094 KSP Residual norm 3.943330715535e-01
7095 KSP Residual norm 3.943330715535e-01
7096 KSP Residual norm 3.943330715535e-01
7097 KSP Residual norm 3.943330715535e-01
7098 KSP Residual norm 3.943330715535e-01
7099 KSP Residual norm 3.943330715535e-01
7100 KSP Residual norm 3.943330715535e-01
7101 KSP Residual norm 3.943330715535e-01
7102 KSP Residual norm 3.943330715535e-01
7103 KSP Residual norm 3.943330715535e-01
7104 KSP Residual norm 3.943330715535e-01
7105 KSP Residual norm 3.943330715535e-01
7106 KSP Residual norm 3.943330715535e-01
7107 KSP Residual norm 3.943330715535e-01
7108 KSP Residual norm 3.943330715535e-01
7109 KSP Residual norm 3.943330715535e-01
7110 KSP Residual norm 3.943330715536e-01
7111 KSP Residual norm 3.943330715536e-01
7112 KSP Residual norm 3.943330715536e-01
7113 KSP Residual norm 3.943330715536e-01
7114 KSP Residual norm 3.943330715536e-01
7115 KSP Residual norm 3.943330715536e-01
7116 KSP Residual norm 3.943330715536e-01
7117 KSP Residual norm 3.943330715536e-01
7118 KSP Residual norm 3.943330715536e-01
7119 KSP Residual norm 3.943330715536e-01
7120 KSP Residual norm 3.943330715536e-01
7121 KSP Residual norm 3.943330715536e-01
7122 KSP Residual norm 3.943330715536e-01
7123 KSP Residual norm 3.943330715536e-01
7124 KSP Residual norm 3.943330715536e-01
7125 KSP Residual norm 3.943330715536e-01
7126 KSP Residual norm 3.943330715536e-01
7127 KSP Residual norm 3.943330715536e-01
7128 KSP Residual norm 3.943330715536e-01
7129 KSP Residual norm 3.943330715536e-01
7130 KSP Residual norm 3.943330715536e-01
7131 KSP Residual norm 3.943330715536e-01
7132 KSP Residual norm 3.943330715536e-01
7133 KSP Residual norm 3.943330715536e-01
7134 KSP Residual norm 3.943330715536e-01
7135 KSP Residual norm 3.943330715536e-01
7136 KSP Residual norm 3.943330715536e-01
7137 KSP Residual norm 3.943330715536e-01
7138 KSP Residual norm 3.943330715536e-01
7139 KSP Residual norm 3.943330715536e-01
7140 KSP Residual norm 3.943330715536e-01
7141 KSP Residual norm 3.943330715536e-01
7142 KSP Residual norm 3.943330715536e-01
7143 KSP Residual norm 3.943330715536e-01
7144 KSP Residual norm 3.943330715536e-01
7145 KSP Residual norm 3.943330715536e-01
7146 KSP Residual norm 3.943330715536e-01
7147 KSP Residual norm 3.943330715536e-01
7148 KSP Residual norm 3.943330715536e-01
7149 KSP Residual norm 3.943330715536e-01
7150 KSP Residual norm 3.943330715536e-01
7151 KSP Residual norm 3.943330715536e-01
7152 KSP Residual norm 3.943330715536e-01
7153 KSP Residual norm 3.943330715536e-01
7154 KSP Residual norm 3.943330715536e-01
7155 KSP Residual norm 3.943330715536e-01
7156 KSP Residual norm 3.943330715536e-01
7157 KSP Residual norm 3.943330715536e-01
7158 KSP Residual norm 3.943330715536e-01
7159 KSP Residual norm 3.943330715536e-01
7160 KSP Residual norm 3.943330715536e-01
7161 KSP Residual norm 3.943330715536e-01
7162 KSP Residual norm 3.943330715536e-01
7163 KSP Residual norm 3.943330715536e-01
7164 KSP Residual norm 3.943330715536e-01
7165 KSP Residual norm 3.943330715536e-01
7166 KSP Residual norm 3.943330715536e-01
7167 KSP Residual norm 3.943330715536e-01
7168 KSP Residual norm 3.943330715536e-01
7169 KSP Residual norm 3.943330715536e-01
7170 KSP Residual norm 3.943330715531e-01
7171 KSP Residual norm 3.943330715531e-01
7172 KSP Residual norm 3.943330715531e-01
7173 KSP Residual norm 3.943330715531e-01
7174 KSP Residual norm 3.943330715531e-01
7175 KSP Residual norm 3.943330715531e-01
7176 KSP Residual norm 3.943330715531e-01
7177 KSP Residual norm 3.943330715531e-01
7178 KSP Residual norm 3.943330715531e-01
7179 KSP Residual norm 3.943330715531e-01
7180 KSP Residual norm 3.943330715531e-01
7181 KSP Residual norm 3.943330715531e-01
7182 KSP Residual norm 3.943330715531e-01
7183 KSP Residual norm 3.943330715531e-01
7184 KSP Residual norm 3.943330715531e-01
7185 KSP Residual norm 3.943330715531e-01
7186 KSP Residual norm 3.943330715531e-01
7187 KSP Residual norm 3.943330715531e-01
7188 KSP Residual norm 3.943330715531e-01
7189 KSP Residual norm 3.943330715531e-01
7190 KSP Residual norm 3.943330715531e-01
7191 KSP Residual norm 3.943330715531e-01
7192 KSP Residual norm 3.943330715531e-01
7193 KSP Residual norm 3.943330715531e-01
7194 KSP Residual norm 3.943330715531e-01
7195 KSP Residual norm 3.943330715531e-01
7196 KSP Residual norm 3.943330715531e-01
7197 KSP Residual norm 3.943330715531e-01
7198 KSP Residual norm 3.943330715531e-01
7199 KSP Residual norm 3.943330715531e-01
7200 KSP Residual norm 3.943330715537e-01
7201 KSP Residual norm 3.943330715537e-01
7202 KSP Residual norm 3.943330715537e-01
7203 KSP Residual norm 3.943330715537e-01
7204 KSP Residual norm 3.943330715537e-01
7205 KSP Residual norm 3.943330715537e-01
7206 KSP Residual norm 3.943330715537e-01
7207 KSP Residual norm 3.943330715537e-01
7208 KSP Residual norm 3.943330715537e-01
7209 KSP Residual norm 3.943330715537e-01
7210 KSP Residual norm 3.943330715537e-01
7211 KSP Residual norm 3.943330715537e-01
7212 KSP Residual norm 3.943330715537e-01
7213 KSP Residual norm 3.943330715537e-01
7214 KSP Residual norm 3.943330715537e-01
7215 KSP Residual norm 3.943330715537e-01
7216 KSP Residual norm 3.943330715537e-01
7217 KSP Residual norm 3.943330715537e-01
7218 KSP Residual norm 3.943330715537e-01
7219 KSP Residual norm 3.943330715537e-01
7220 KSP Residual norm 3.943330715537e-01
7221 KSP Residual norm 3.943330715537e-01
7222 KSP Residual norm 3.943330715537e-01
7223 KSP Residual norm 3.943330715537e-01
7224 KSP Residual norm 3.943330715537e-01
7225 KSP Residual norm 3.943330715537e-01
7226 KSP Residual norm 3.943330715537e-01
7227 KSP Residual norm 3.943330715537e-01
7228 KSP Residual norm 3.943330715537e-01
7229 KSP Residual norm 3.943330715537e-01
7230 KSP Residual norm 3.943330715534e-01
7231 KSP Residual norm 3.943330715534e-01
7232 KSP Residual norm 3.943330715534e-01
7233 KSP Residual norm 3.943330715534e-01
7234 KSP Residual norm 3.943330715534e-01
7235 KSP Residual norm 3.943330715534e-01
7236 KSP Residual norm 3.943330715534e-01
7237 KSP Residual norm 3.943330715534e-01
7238 KSP Residual norm 3.943330715534e-01
7239 KSP Residual norm 3.943330715534e-01
7240 KSP Residual norm 3.943330715534e-01
7241 KSP Residual norm 3.943330715534e-01
7242 KSP Residual norm 3.943330715534e-01
7243 KSP Residual norm 3.943330715534e-01
7244 KSP Residual norm 3.943330715534e-01
7245 KSP Residual norm 3.943330715534e-01
7246 KSP Residual norm 3.943330715534e-01
7247 KSP Residual norm 3.943330715534e-01
7248 KSP Residual norm 3.943330715534e-01
7249 KSP Residual norm 3.943330715534e-01
7250 KSP Residual norm 3.943330715534e-01
7251 KSP Residual norm 3.943330715534e-01
7252 KSP Residual norm 3.943330715534e-01
7253 KSP Residual norm 3.943330715534e-01
7254 KSP Residual norm 3.943330715534e-01
7255 KSP Residual norm 3.943330715534e-01
7256 KSP Residual norm 3.943330715534e-01
7257 KSP Residual norm 3.943330715534e-01
7258 KSP Residual norm 3.943330715534e-01
7259 KSP Residual norm 3.943330715534e-01
7260 KSP Residual norm 3.943330715535e-01
7261 KSP Residual norm 3.943330715535e-01
7262 KSP Residual norm 3.943330715535e-01
7263 KSP Residual norm 3.943330715535e-01
7264 KSP Residual norm 3.943330715535e-01
7265 KSP Residual norm 3.943330715535e-01
7266 KSP Residual norm 3.943330715535e-01
7267 KSP Residual norm 3.943330715535e-01
7268 KSP Residual norm 3.943330715535e-01
7269 KSP Residual norm 3.943330715535e-01
7270 KSP Residual norm 3.943330715535e-01
7271 KSP Residual norm 3.943330715535e-01
7272 KSP Residual norm 3.943330715535e-01
7273 KSP Residual norm 3.943330715535e-01
7274 KSP Residual norm 3.943330715535e-01
7275 KSP Residual norm 3.943330715535e-01
7276 KSP Residual norm 3.943330715535e-01
7277 KSP Residual norm 3.943330715535e-01
7278 KSP Residual norm 3.943330715535e-01
7279 KSP Residual norm 3.943330715535e-01
7280 KSP Residual norm 3.943330715535e-01
7281 KSP Residual norm 3.943330715535e-01
7282 KSP Residual norm 3.943330715535e-01
7283 KSP Residual norm 3.943330715535e-01
7284 KSP Residual norm 3.943330715535e-01
7285 KSP Residual norm 3.943330715535e-01
7286 KSP Residual norm 3.943330715535e-01
7287 KSP Residual norm 3.943330715535e-01
7288 KSP Residual norm 3.943330715535e-01
7289 KSP Residual norm 3.943330715535e-01
7290 KSP Residual norm 3.943330715535e-01
7291 KSP Residual norm 3.943330715535e-01
7292 KSP Residual norm 3.943330715535e-01
7293 KSP Residual norm 3.943330715535e-01
7294 KSP Residual norm 3.943330715535e-01
7295 KSP Residual norm 3.943330715535e-01
7296 KSP Residual norm 3.943330715535e-01
7297 KSP Residual norm 3.943330715535e-01
7298 KSP Residual norm 3.943330715535e-01
7299 KSP Residual norm 3.943330715535e-01
7300 KSP Residual norm 3.943330715535e-01
7301 KSP Residual norm 3.943330715535e-01
7302 KSP Residual norm 3.943330715535e-01
7303 KSP Residual norm 3.943330715535e-01
7304 KSP Residual norm 3.943330715535e-01
7305 KSP Residual norm 3.943330715535e-01
7306 KSP Residual norm 3.943330715535e-01
7307 KSP Residual norm 3.943330715535e-01
7308 KSP Residual norm 3.943330715535e-01
7309 KSP Residual norm 3.943330715535e-01
7310 KSP Residual norm 3.943330715535e-01
7311 KSP Residual norm 3.943330715535e-01
7312 KSP Residual norm 3.943330715535e-01
7313 KSP Residual norm 3.943330715535e-01
7314 KSP Residual norm 3.943330715535e-01
7315 KSP Residual norm 3.943330715535e-01
7316 KSP Residual norm 3.943330715535e-01
7317 KSP Residual norm 3.943330715535e-01
7318 KSP Residual norm 3.943330715535e-01
7319 KSP Residual norm 3.943330715535e-01
7320 KSP Residual norm 3.943330715536e-01
7321 KSP Residual norm 3.943330715536e-01
7322 KSP Residual norm 3.943330715536e-01
7323 KSP Residual norm 3.943330715536e-01
7324 KSP Residual norm 3.943330715536e-01
7325 KSP Residual norm 3.943330715536e-01
7326 KSP Residual norm 3.943330715536e-01
7327 KSP Residual norm 3.943330715536e-01
7328 KSP Residual norm 3.943330715536e-01
7329 KSP Residual norm 3.943330715536e-01
7330 KSP Residual norm 3.943330715536e-01
7331 KSP Residual norm 3.943330715536e-01
7332 KSP Residual norm 3.943330715536e-01
7333 KSP Residual norm 3.943330715536e-01
7334 KSP Residual norm 3.943330715536e-01
7335 KSP Residual norm 3.943330715536e-01
7336 KSP Residual norm 3.943330715536e-01
7337 KSP Residual norm 3.943330715536e-01
7338 KSP Residual norm 3.943330715536e-01
7339 KSP Residual norm 3.943330715536e-01
7340 KSP Residual norm 3.943330715536e-01
7341 KSP Residual norm 3.943330715536e-01
7342 KSP Residual norm 3.943330715536e-01
7343 KSP Residual norm 3.943330715536e-01
7344 KSP Residual norm 3.943330715536e-01
7345 KSP Residual norm 3.943330715536e-01
7346 KSP Residual norm 3.943330715536e-01
7347 KSP Residual norm 3.943330715536e-01
7348 KSP Residual norm 3.943330715536e-01
7349 KSP Residual norm 3.943330715536e-01
7350 KSP Residual norm 3.943330715536e-01
7351 KSP Residual norm 3.943330715536e-01
7352 KSP Residual norm 3.943330715536e-01
7353 KSP Residual norm 3.943330715536e-01
7354 KSP Residual norm 3.943330715536e-01
7355 KSP Residual norm 3.943330715536e-01
7356 KSP Residual norm 3.943330715536e-01
7357 KSP Residual norm 3.943330715536e-01
7358 KSP Residual norm 3.943330715536e-01
7359 KSP Residual norm 3.943330715536e-01
7360 KSP Residual norm 3.943330715536e-01
7361 KSP Residual norm 3.943330715536e-01
7362 KSP Residual norm 3.943330715536e-01
7363 KSP Residual norm 3.943330715536e-01
7364 KSP Residual norm 3.943330715536e-01
7365 KSP Residual norm 3.943330715536e-01
7366 KSP Residual norm 3.943330715536e-01
7367 KSP Residual norm 3.943330715536e-01
7368 KSP Residual norm 3.943330715536e-01
7369 KSP Residual norm 3.943330715536e-01
7370 KSP Residual norm 3.943330715536e-01
7371 KSP Residual norm 3.943330715536e-01
7372 KSP Residual norm 3.943330715536e-01
7373 KSP Residual norm 3.943330715536e-01
7374 KSP Residual norm 3.943330715536e-01
7375 KSP Residual norm 3.943330715536e-01
7376 KSP Residual norm 3.943330715536e-01
7377 KSP Residual norm 3.943330715536e-01
7378 KSP Residual norm 3.943330715536e-01
7379 KSP Residual norm 3.943330715536e-01
7380 KSP Residual norm 3.943330715534e-01
7381 KSP Residual norm 3.943330715534e-01
7382 KSP Residual norm 3.943330715534e-01
7383 KSP Residual norm 3.943330715534e-01
7384 KSP Residual norm 3.943330715534e-01
7385 KSP Residual norm 3.943330715534e-01
7386 KSP Residual norm 3.943330715534e-01
7387 KSP Residual norm 3.943330715534e-01
7388 KSP Residual norm 3.943330715534e-01
7389 KSP Residual norm 3.943330715534e-01
7390 KSP Residual norm 3.943330715534e-01
7391 KSP Residual norm 3.943330715534e-01
7392 KSP Residual norm 3.943330715534e-01
7393 KSP Residual norm 3.943330715534e-01
7394 KSP Residual norm 3.943330715534e-01
7395 KSP Residual norm 3.943330715534e-01
7396 KSP Residual norm 3.943330715534e-01
7397 KSP Residual norm 3.943330715534e-01
7398 KSP Residual norm 3.943330715534e-01
7399 KSP Residual norm 3.943330715534e-01
7400 KSP Residual norm 3.943330715534e-01
7401 KSP Residual norm 3.943330715534e-01
7402 KSP Residual norm 3.943330715534e-01
7403 KSP Residual norm 3.943330715534e-01
7404 KSP Residual norm 3.943330715534e-01
7405 KSP Residual norm 3.943330715534e-01
7406 KSP Residual norm 3.943330715534e-01
7407 KSP Residual norm 3.943330715534e-01
7408 KSP Residual norm 3.943330715534e-01
7409 KSP Residual norm 3.943330715534e-01
7410 KSP Residual norm 3.943330715535e-01
7411 KSP Residual norm 3.943330715535e-01
7412 KSP Residual norm 3.943330715535e-01
7413 KSP Residual norm 3.943330715535e-01
7414 KSP Residual norm 3.943330715535e-01
7415 KSP Residual norm 3.943330715535e-01
7416 KSP Residual norm 3.943330715535e-01
7417 KSP Residual norm 3.943330715535e-01
7418 KSP Residual norm 3.943330715535e-01
7419 KSP Residual norm 3.943330715535e-01
7420 KSP Residual norm 3.943330715535e-01
7421 KSP Residual norm 3.943330715535e-01
7422 KSP Residual norm 3.943330715535e-01
7423 KSP Residual norm 3.943330715535e-01
7424 KSP Residual norm 3.943330715535e-01
7425 KSP Residual norm 3.943330715535e-01
7426 KSP Residual norm 3.943330715535e-01
7427 KSP Residual norm 3.943330715535e-01
7428 KSP Residual norm 3.943330715535e-01
7429 KSP Residual norm 3.943330715535e-01
7430 KSP Residual norm 3.943330715535e-01
7431 KSP Residual norm 3.943330715535e-01
7432 KSP Residual norm 3.943330715535e-01
7433 KSP Residual norm 3.943330715535e-01
7434 KSP Residual norm 3.943330715535e-01
7435 KSP Residual norm 3.943330715535e-01
7436 KSP Residual norm 3.943330715535e-01
7437 KSP Residual norm 3.943330715535e-01
7438 KSP Residual norm 3.943330715535e-01
7439 KSP Residual norm 3.943330715535e-01
7440 KSP Residual norm 3.943330715534e-01
7441 KSP Residual norm 3.943330715534e-01
7442 KSP Residual norm 3.943330715534e-01
7443 KSP Residual norm 3.943330715534e-01
7444 KSP Residual norm 3.943330715534e-01
7445 KSP Residual norm 3.943330715534e-01
7446 KSP Residual norm 3.943330715534e-01
7447 KSP Residual norm 3.943330715534e-01
7448 KSP Residual norm 3.943330715534e-01
7449 KSP Residual norm 3.943330715534e-01
7450 KSP Residual norm 3.943330715534e-01
7451 KSP Residual norm 3.943330715534e-01
7452 KSP Residual norm 3.943330715534e-01
7453 KSP Residual norm 3.943330715534e-01
7454 KSP Residual norm 3.943330715534e-01
7455 KSP Residual norm 3.943330715534e-01
7456 KSP Residual norm 3.943330715534e-01
7457 KSP Residual norm 3.943330715534e-01
7458 KSP Residual norm 3.943330715534e-01
7459 KSP Residual norm 3.943330715534e-01
7460 KSP Residual norm 3.943330715534e-01
7461 KSP Residual norm 3.943330715534e-01
7462 KSP Residual norm 3.943330715534e-01
7463 KSP Residual norm 3.943330715534e-01
7464 KSP Residual norm 3.943330715534e-01
7465 KSP Residual norm 3.943330715534e-01
7466 KSP Residual norm 3.943330715534e-01
7467 KSP Residual norm 3.943330715534e-01
7468 KSP Residual norm 3.943330715534e-01
7469 KSP Residual norm 3.943330715534e-01
7470 KSP Residual norm 3.943330715535e-01
7471 KSP Residual norm 3.943330715535e-01
7472 KSP Residual norm 3.943330715535e-01
7473 KSP Residual norm 3.943330715535e-01
7474 KSP Residual norm 3.943330715535e-01
7475 KSP Residual norm 3.943330715535e-01
7476 KSP Residual norm 3.943330715535e-01
7477 KSP Residual norm 3.943330715535e-01
7478 KSP Residual norm 3.943330715535e-01
7479 KSP Residual norm 3.943330715535e-01
7480 KSP Residual norm 3.943330715535e-01
7481 KSP Residual norm 3.943330715535e-01
7482 KSP Residual norm 3.943330715535e-01
7483 KSP Residual norm 3.943330715535e-01
7484 KSP Residual norm 3.943330715535e-01
7485 KSP Residual norm 3.943330715535e-01
7486 KSP Residual norm 3.943330715535e-01
7487 KSP Residual norm 3.943330715535e-01
7488 KSP Residual norm 3.943330715535e-01
7489 KSP Residual norm 3.943330715535e-01
7490 KSP Residual norm 3.943330715535e-01
7491 KSP Residual norm 3.943330715535e-01
7492 KSP Residual norm 3.943330715535e-01
7493 KSP Residual norm 3.943330715535e-01
7494 KSP Residual norm 3.943330715535e-01
7495 KSP Residual norm 3.943330715535e-01
7496 KSP Residual norm 3.943330715535e-01
7497 KSP Residual norm 3.943330715535e-01
7498 KSP Residual norm 3.943330715535e-01
7499 KSP Residual norm 3.943330715535e-01
7500 KSP Residual norm 3.943330715537e-01
7501 KSP Residual norm 3.943330715537e-01
7502 KSP Residual norm 3.943330715537e-01
7503 KSP Residual norm 3.943330715537e-01
7504 KSP Residual norm 3.943330715537e-01
7505 KSP Residual norm 3.943330715537e-01
7506 KSP Residual norm 3.943330715537e-01
7507 KSP Residual norm 3.943330715537e-01
7508 KSP Residual norm 3.943330715537e-01
7509 KSP Residual norm 3.943330715537e-01
7510 KSP Residual norm 3.943330715537e-01
7511 KSP Residual norm 3.943330715537e-01
7512 KSP Residual norm 3.943330715537e-01
7513 KSP Residual norm 3.943330715537e-01
7514 KSP Residual norm 3.943330715537e-01
7515 KSP Residual norm 3.943330715537e-01
7516 KSP Residual norm 3.943330715537e-01
7517 KSP Residual norm 3.943330715537e-01
7518 KSP Residual norm 3.943330715537e-01
7519 KSP Residual norm 3.943330715537e-01
7520 KSP Residual norm 3.943330715537e-01
7521 KSP Residual norm 3.943330715537e-01
7522 KSP Residual norm 3.943330715537e-01
7523 KSP Residual norm 3.943330715537e-01
7524 KSP Residual norm 3.943330715537e-01
7525 KSP Residual norm 3.943330715537e-01
7526 KSP Residual norm 3.943330715537e-01
7527 KSP Residual norm 3.943330715537e-01
7528 KSP Residual norm 3.943330715537e-01
7529 KSP Residual norm 3.943330715537e-01
7530 KSP Residual norm 3.943330715536e-01
7531 KSP Residual norm 3.943330715536e-01
7532 KSP Residual norm 3.943330715536e-01
7533 KSP Residual norm 3.943330715536e-01
7534 KSP Residual norm 3.943330715536e-01
7535 KSP Residual norm 3.943330715536e-01
7536 KSP Residual norm 3.943330715536e-01
7537 KSP Residual norm 3.943330715536e-01
7538 KSP Residual norm 3.943330715536e-01
7539 KSP Residual norm 3.943330715536e-01
7540 KSP Residual norm 3.943330715536e-01
7541 KSP Residual norm 3.943330715536e-01
7542 KSP Residual norm 3.943330715536e-01
7543 KSP Residual norm 3.943330715536e-01
7544 KSP Residual norm 3.943330715536e-01
7545 KSP Residual norm 3.943330715536e-01
7546 KSP Residual norm 3.943330715536e-01
7547 KSP Residual norm 3.943330715536e-01
7548 KSP Residual norm 3.943330715536e-01
7549 KSP Residual norm 3.943330715536e-01
7550 KSP Residual norm 3.943330715536e-01
7551 KSP Residual norm 3.943330715536e-01
7552 KSP Residual norm 3.943330715536e-01
7553 KSP Residual norm 3.943330715536e-01
7554 KSP Residual norm 3.943330715536e-01
7555 KSP Residual norm 3.943330715536e-01
7556 KSP Residual norm 3.943330715536e-01
7557 KSP Residual norm 3.943330715536e-01
7558 KSP Residual norm 3.943330715536e-01
7559 KSP Residual norm 3.943330715536e-01
7560 KSP Residual norm 3.943330715535e-01
7561 KSP Residual norm 3.943330715535e-01
7562 KSP Residual norm 3.943330715535e-01
7563 KSP Residual norm 3.943330715535e-01
7564 KSP Residual norm 3.943330715535e-01
7565 KSP Residual norm 3.943330715535e-01
7566 KSP Residual norm 3.943330715535e-01
7567 KSP Residual norm 3.943330715535e-01
7568 KSP Residual norm 3.943330715535e-01
7569 KSP Residual norm 3.943330715535e-01
7570 KSP Residual norm 3.943330715535e-01
7571 KSP Residual norm 3.943330715535e-01
7572 KSP Residual norm 3.943330715535e-01
7573 KSP Residual norm 3.943330715535e-01
7574 KSP Residual norm 3.943330715535e-01
7575 KSP Residual norm 3.943330715535e-01
7576 KSP Residual norm 3.943330715535e-01
7577 KSP Residual norm 3.943330715535e-01
7578 KSP Residual norm 3.943330715535e-01
7579 KSP Residual norm 3.943330715535e-01
7580 KSP Residual norm 3.943330715535e-01
7581 KSP Residual norm 3.943330715535e-01
7582 KSP Residual norm 3.943330715535e-01
7583 KSP Residual norm 3.943330715535e-01
7584 KSP Residual norm 3.943330715535e-01
7585 KSP Residual norm 3.943330715535e-01
7586 KSP Residual norm 3.943330715535e-01
7587 KSP Residual norm 3.943330715535e-01
7588 KSP Residual norm 3.943330715535e-01
7589 KSP Residual norm 3.943330715535e-01
7590 KSP Residual norm 3.943330715532e-01
7591 KSP Residual norm 3.943330715532e-01
7592 KSP Residual norm 3.943330715532e-01
7593 KSP Residual norm 3.943330715532e-01
7594 KSP Residual norm 3.943330715532e-01
7595 KSP Residual norm 3.943330715532e-01
7596 KSP Residual norm 3.943330715532e-01
7597 KSP Residual norm 3.943330715532e-01
7598 KSP Residual norm 3.943330715532e-01
7599 KSP Residual norm 3.943330715532e-01
7600 KSP Residual norm 3.943330715532e-01
7601 KSP Residual norm 3.943330715532e-01
7602 KSP Residual norm 3.943330715532e-01
7603 KSP Residual norm 3.943330715532e-01
7604 KSP Residual norm 3.943330715532e-01
7605 KSP Residual norm 3.943330715532e-01
7606 KSP Residual norm 3.943330715532e-01
7607 KSP Residual norm 3.943330715532e-01
7608 KSP Residual norm 3.943330715532e-01
7609 KSP Residual norm 3.943330715532e-01
7610 KSP Residual norm 3.943330715532e-01
7611 KSP Residual norm 3.943330715532e-01
7612 KSP Residual norm 3.943330715532e-01
7613 KSP Residual norm 3.943330715532e-01
7614 KSP Residual norm 3.943330715532e-01
7615 KSP Residual norm 3.943330715532e-01
7616 KSP Residual norm 3.943330715532e-01
7617 KSP Residual norm 3.943330715532e-01
7618 KSP Residual norm 3.943330715532e-01
7619 KSP Residual norm 3.943330715532e-01
7620 KSP Residual norm 3.943330715531e-01
7621 KSP Residual norm 3.943330715531e-01
7622 KSP Residual norm 3.943330715531e-01
7623 KSP Residual norm 3.943330715531e-01
7624 KSP Residual norm 3.943330715531e-01
7625 KSP Residual norm 3.943330715531e-01
7626 KSP Residual norm 3.943330715531e-01
7627 KSP Residual norm 3.943330715531e-01
7628 KSP Residual norm 3.943330715531e-01
7629 KSP Residual norm 3.943330715531e-01
7630 KSP Residual norm 3.943330715531e-01
7631 KSP Residual norm 3.943330715531e-01
7632 KSP Residual norm 3.943330715531e-01
7633 KSP Residual norm 3.943330715531e-01
7634 KSP Residual norm 3.943330715531e-01
7635 KSP Residual norm 3.943330715531e-01
7636 KSP Residual norm 3.943330715531e-01
7637 KSP Residual norm 3.943330715531e-01
7638 KSP Residual norm 3.943330715531e-01
7639 KSP Residual norm 3.943330715531e-01
7640 KSP Residual norm 3.943330715531e-01
7641 KSP Residual norm 3.943330715531e-01
7642 KSP Residual norm 3.943330715531e-01
7643 KSP Residual norm 3.943330715531e-01
7644 KSP Residual norm 3.943330715531e-01
7645 KSP Residual norm 3.943330715531e-01
7646 KSP Residual norm 3.943330715531e-01
7647 KSP Residual norm 3.943330715531e-01
7648 KSP Residual norm 3.943330715531e-01
7649 KSP Residual norm 3.943330715531e-01
7650 KSP Residual norm 3.943330715531e-01
7651 KSP Residual norm 3.943330715531e-01
7652 KSP Residual norm 3.943330715531e-01
7653 KSP Residual norm 3.943330715531e-01
7654 KSP Residual norm 3.943330715531e-01
7655 KSP Residual norm 3.943330715531e-01
7656 KSP Residual norm 3.943330715531e-01
7657 KSP Residual norm 3.943330715531e-01
7658 KSP Residual norm 3.943330715531e-01
7659 KSP Residual norm 3.943330715531e-01
7660 KSP Residual norm 3.943330715531e-01
7661 KSP Residual norm 3.943330715531e-01
7662 KSP Residual norm 3.943330715531e-01
7663 KSP Residual norm 3.943330715531e-01
7664 KSP Residual norm 3.943330715531e-01
7665 KSP Residual norm 3.943330715531e-01
7666 KSP Residual norm 3.943330715531e-01
7667 KSP Residual norm 3.943330715531e-01
7668 KSP Residual norm 3.943330715531e-01
7669 KSP Residual norm 3.943330715531e-01
7670 KSP Residual norm 3.943330715531e-01
7671 KSP Residual norm 3.943330715531e-01
7672 KSP Residual norm 3.943330715531e-01
7673 KSP Residual norm 3.943330715531e-01
7674 KSP Residual norm 3.943330715531e-01
7675 KSP Residual norm 3.943330715531e-01
7676 KSP Residual norm 3.943330715531e-01
7677 KSP Residual norm 3.943330715531e-01
7678 KSP Residual norm 3.943330715531e-01
7679 KSP Residual norm 3.943330715531e-01
7680 KSP Residual norm 3.943330715531e-01
7681 KSP Residual norm 3.943330715531e-01
7682 KSP Residual norm 3.943330715531e-01
7683 KSP Residual norm 3.943330715531e-01
7684 KSP Residual norm 3.943330715531e-01
7685 KSP Residual norm 3.943330715531e-01
7686 KSP Residual norm 3.943330715531e-01
7687 KSP Residual norm 3.943330715531e-01
7688 KSP Residual norm 3.943330715531e-01
7689 KSP Residual norm 3.943330715531e-01
7690 KSP Residual norm 3.943330715531e-01
7691 KSP Residual norm 3.943330715531e-01
7692 KSP Residual norm 3.943330715531e-01
7693 KSP Residual norm 3.943330715531e-01
7694 KSP Residual norm 3.943330715531e-01
7695 KSP Residual norm 3.943330715531e-01
7696 KSP Residual norm 3.943330715531e-01
7697 KSP Residual norm 3.943330715531e-01
7698 KSP Residual norm 3.943330715531e-01
7699 KSP Residual norm 3.943330715531e-01
7700 KSP Residual norm 3.943330715531e-01
7701 KSP Residual norm 3.943330715531e-01
7702 KSP Residual norm 3.943330715531e-01
7703 KSP Residual norm 3.943330715531e-01
7704 KSP Residual norm 3.943330715531e-01
7705 KSP Residual norm 3.943330715531e-01
7706 KSP Residual norm 3.943330715531e-01
7707 KSP Residual norm 3.943330715531e-01
7708 KSP Residual norm 3.943330715531e-01
7709 KSP Residual norm 3.943330715531e-01
7710 KSP Residual norm 3.943330715529e-01
7711 KSP Residual norm 3.943330715529e-01
7712 KSP Residual norm 3.943330715529e-01
7713 KSP Residual norm 3.943330715529e-01
7714 KSP Residual norm 3.943330715529e-01
7715 KSP Residual norm 3.943330715529e-01
7716 KSP Residual norm 3.943330715529e-01
7717 KSP Residual norm 3.943330715529e-01
7718 KSP Residual norm 3.943330715529e-01
7719 KSP Residual norm 3.943330715529e-01
7720 KSP Residual norm 3.943330715529e-01
7721 KSP Residual norm 3.943330715529e-01
7722 KSP Residual norm 3.943330715529e-01
7723 KSP Residual norm 3.943330715529e-01
7724 KSP Residual norm 3.943330715529e-01
7725 KSP Residual norm 3.943330715529e-01
7726 KSP Residual norm 3.943330715529e-01
7727 KSP Residual norm 3.943330715529e-01
7728 KSP Residual norm 3.943330715529e-01
7729 KSP Residual norm 3.943330715529e-01
7730 KSP Residual norm 3.943330715529e-01
7731 KSP Residual norm 3.943330715529e-01
7732 KSP Residual norm 3.943330715529e-01
7733 KSP Residual norm 3.943330715529e-01
7734 KSP Residual norm 3.943330715529e-01
7735 KSP Residual norm 3.943330715529e-01
7736 KSP Residual norm 3.943330715529e-01
7737 KSP Residual norm 3.943330715529e-01
7738 KSP Residual norm 3.943330715529e-01
7739 KSP Residual norm 3.943330715529e-01
7740 KSP Residual norm 3.943330715529e-01
7741 KSP Residual norm 3.943330715529e-01
7742 KSP Residual norm 3.943330715529e-01
7743 KSP Residual norm 3.943330715529e-01
7744 KSP Residual norm 3.943330715529e-01
7745 KSP Residual norm 3.943330715529e-01
7746 KSP Residual norm 3.943330715529e-01
7747 KSP Residual norm 3.943330715529e-01
7748 KSP Residual norm 3.943330715529e-01
7749 KSP Residual norm 3.943330715529e-01
7750 KSP Residual norm 3.943330715529e-01
7751 KSP Residual norm 3.943330715529e-01
7752 KSP Residual norm 3.943330715529e-01
7753 KSP Residual norm 3.943330715529e-01
7754 KSP Residual norm 3.943330715529e-01
7755 KSP Residual norm 3.943330715529e-01
7756 KSP Residual norm 3.943330715529e-01
7757 KSP Residual norm 3.943330715529e-01
7758 KSP Residual norm 3.943330715529e-01
7759 KSP Residual norm 3.943330715529e-01
7760 KSP Residual norm 3.943330715529e-01
7761 KSP Residual norm 3.943330715529e-01
7762 KSP Residual norm 3.943330715529e-01
7763 KSP Residual norm 3.943330715529e-01
7764 KSP Residual norm 3.943330715529e-01
7765 KSP Residual norm 3.943330715529e-01
7766 KSP Residual norm 3.943330715529e-01
7767 KSP Residual norm 3.943330715529e-01
7768 KSP Residual norm 3.943330715529e-01
7769 KSP Residual norm 3.943330715529e-01
7770 KSP Residual norm 3.943330715528e-01
7771 KSP Residual norm 3.943330715528e-01
7772 KSP Residual norm 3.943330715528e-01
7773 KSP Residual norm 3.943330715528e-01
7774 KSP Residual norm 3.943330715528e-01
7775 KSP Residual norm 3.943330715528e-01
7776 KSP Residual norm 3.943330715528e-01
7777 KSP Residual norm 3.943330715528e-01
7778 KSP Residual norm 3.943330715528e-01
7779 KSP Residual norm 3.943330715528e-01
7780 KSP Residual norm 3.943330715528e-01
7781 KSP Residual norm 3.943330715528e-01
7782 KSP Residual norm 3.943330715528e-01
7783 KSP Residual norm 3.943330715528e-01
7784 KSP Residual norm 3.943330715528e-01
7785 KSP Residual norm 3.943330715528e-01
7786 KSP Residual norm 3.943330715528e-01
7787 KSP Residual norm 3.943330715528e-01
7788 KSP Residual norm 3.943330715528e-01
7789 KSP Residual norm 3.943330715528e-01
7790 KSP Residual norm 3.943330715528e-01
7791 KSP Residual norm 3.943330715528e-01
7792 KSP Residual norm 3.943330715528e-01
7793 KSP Residual norm 3.943330715528e-01
7794 KSP Residual norm 3.943330715528e-01
7795 KSP Residual norm 3.943330715528e-01
7796 KSP Residual norm 3.943330715528e-01
7797 KSP Residual norm 3.943330715528e-01
7798 KSP Residual norm 3.943330715528e-01
7799 KSP Residual norm 3.943330715528e-01
7800 KSP Residual norm 3.943330715530e-01
7801 KSP Residual norm 3.943330715530e-01
7802 KSP Residual norm 3.943330715530e-01
7803 KSP Residual norm 3.943330715530e-01
7804 KSP Residual norm 3.943330715530e-01
7805 KSP Residual norm 3.943330715530e-01
7806 KSP Residual norm 3.943330715530e-01
7807 KSP Residual norm 3.943330715530e-01
7808 KSP Residual norm 3.943330715530e-01
7809 KSP Residual norm 3.943330715530e-01
7810 KSP Residual norm 3.943330715530e-01
7811 KSP Residual norm 3.943330715530e-01
7812 KSP Residual norm 3.943330715530e-01
7813 KSP Residual norm 3.943330715530e-01
7814 KSP Residual norm 3.943330715530e-01
7815 KSP Residual norm 3.943330715530e-01
7816 KSP Residual norm 3.943330715530e-01
7817 KSP Residual norm 3.943330715530e-01
7818 KSP Residual norm 3.943330715530e-01
7819 KSP Residual norm 3.943330715530e-01
7820 KSP Residual norm 3.943330715530e-01
7821 KSP Residual norm 3.943330715530e-01
7822 KSP Residual norm 3.943330715530e-01
7823 KSP Residual norm 3.943330715530e-01
7824 KSP Residual norm 3.943330715530e-01
7825 KSP Residual norm 3.943330715530e-01
7826 KSP Residual norm 3.943330715530e-01
7827 KSP Residual norm 3.943330715530e-01
7828 KSP Residual norm 3.943330715530e-01
7829 KSP Residual norm 3.943330715530e-01
7830 KSP Residual norm 3.943330715530e-01
7831 KSP Residual norm 3.943330715530e-01
7832 KSP Residual norm 3.943330715530e-01
7833 KSP Residual norm 3.943330715530e-01
7834 KSP Residual norm 3.943330715530e-01
7835 KSP Residual norm 3.943330715530e-01
7836 KSP Residual norm 3.943330715530e-01
7837 KSP Residual norm 3.943330715530e-01
7838 KSP Residual norm 3.943330715530e-01
7839 KSP Residual norm 3.943330715530e-01
7840 KSP Residual norm 3.943330715530e-01
7841 KSP Residual norm 3.943330715530e-01
7842 KSP Residual norm 3.943330715530e-01
7843 KSP Residual norm 3.943330715530e-01
7844 KSP Residual norm 3.943330715530e-01
7845 KSP Residual norm 3.943330715530e-01
7846 KSP Residual norm 3.943330715530e-01
7847 KSP Residual norm 3.943330715530e-01
7848 KSP Residual norm 3.943330715530e-01
7849 KSP Residual norm 3.943330715530e-01
7850 KSP Residual norm 3.943330715530e-01
7851 KSP Residual norm 3.943330715530e-01
7852 KSP Residual norm 3.943330715530e-01
7853 KSP Residual norm 3.943330715530e-01
7854 KSP Residual norm 3.943330715530e-01
7855 KSP Residual norm 3.943330715530e-01
7856 KSP Residual norm 3.943330715530e-01
7857 KSP Residual norm 3.943330715530e-01
7858 KSP Residual norm 3.943330715530e-01
7859 KSP Residual norm 3.943330715530e-01
7860 KSP Residual norm 3.943330715529e-01
7861 KSP Residual norm 3.943330715529e-01
7862 KSP Residual norm 3.943330715529e-01
7863 KSP Residual norm 3.943330715529e-01
7864 KSP Residual norm 3.943330715529e-01
7865 KSP Residual norm 3.943330715529e-01
7866 KSP Residual norm 3.943330715529e-01
7867 KSP Residual norm 3.943330715529e-01
7868 KSP Residual norm 3.943330715529e-01
7869 KSP Residual norm 3.943330715529e-01
7870 KSP Residual norm 3.943330715529e-01
7871 KSP Residual norm 3.943330715529e-01
7872 KSP Residual norm 3.943330715529e-01
7873 KSP Residual norm 3.943330715529e-01
7874 KSP Residual norm 3.943330715529e-01
7875 KSP Residual norm 3.943330715529e-01
7876 KSP Residual norm 3.943330715529e-01
7877 KSP Residual norm 3.943330715529e-01
7878 KSP Residual norm 3.943330715529e-01
7879 KSP Residual norm 3.943330715529e-01
7880 KSP Residual norm 3.943330715529e-01
7881 KSP Residual norm 3.943330715529e-01
7882 KSP Residual norm 3.943330715529e-01
7883 KSP Residual norm 3.943330715529e-01
7884 KSP Residual norm 3.943330715529e-01
7885 KSP Residual norm 3.943330715529e-01
7886 KSP Residual norm 3.943330715529e-01
7887 KSP Residual norm 3.943330715529e-01
7888 KSP Residual norm 3.943330715529e-01
7889 KSP Residual norm 3.943330715529e-01
7890 KSP Residual norm 3.943330715527e-01
7891 KSP Residual norm 3.943330715527e-01
7892 KSP Residual norm 3.943330715527e-01
7893 KSP Residual norm 3.943330715527e-01
7894 KSP Residual norm 3.943330715527e-01
7895 KSP Residual norm 3.943330715527e-01
7896 KSP Residual norm 3.943330715527e-01
7897 KSP Residual norm 3.943330715527e-01
7898 KSP Residual norm 3.943330715527e-01
7899 KSP Residual norm 3.943330715527e-01
7900 KSP Residual norm 3.943330715527e-01
7901 KSP Residual norm 3.943330715527e-01
7902 KSP Residual norm 3.943330715527e-01
7903 KSP Residual norm 3.943330715527e-01
7904 KSP Residual norm 3.943330715527e-01
7905 KSP Residual norm 3.943330715527e-01
7906 KSP Residual norm 3.943330715527e-01
7907 KSP Residual norm 3.943330715527e-01
7908 KSP Residual norm 3.943330715527e-01
7909 KSP Residual norm 3.943330715527e-01
7910 KSP Residual norm 3.943330715527e-01
7911 KSP Residual norm 3.943330715527e-01
7912 KSP Residual norm 3.943330715527e-01
7913 KSP Residual norm 3.943330715527e-01
7914 KSP Residual norm 3.943330715527e-01
7915 KSP Residual norm 3.943330715527e-01
7916 KSP Residual norm 3.943330715527e-01
7917 KSP Residual norm 3.943330715527e-01
7918 KSP Residual norm 3.943330715527e-01
7919 KSP Residual norm 3.943330715527e-01
7920 KSP Residual norm 3.943330715528e-01
7921 KSP Residual norm 3.943330715528e-01
7922 KSP Residual norm 3.943330715528e-01
7923 KSP Residual norm 3.943330715528e-01
7924 KSP Residual norm 3.943330715528e-01
7925 KSP Residual norm 3.943330715528e-01
7926 KSP Residual norm 3.943330715528e-01
7927 KSP Residual norm 3.943330715528e-01
7928 KSP Residual norm 3.943330715528e-01
7929 KSP Residual norm 3.943330715528e-01
7930 KSP Residual norm 3.943330715528e-01
7931 KSP Residual norm 3.943330715528e-01
7932 KSP Residual norm 3.943330715528e-01
7933 KSP Residual norm 3.943330715528e-01
7934 KSP Residual norm 3.943330715528e-01
7935 KSP Residual norm 3.943330715528e-01
7936 KSP Residual norm 3.943330715528e-01
7937 KSP Residual norm 3.943330715528e-01
7938 KSP Residual norm 3.943330715528e-01
7939 KSP Residual norm 3.943330715528e-01
7940 KSP Residual norm 3.943330715528e-01
7941 KSP Residual norm 3.943330715528e-01
7942 KSP Residual norm 3.943330715528e-01
7943 KSP Residual norm 3.943330715528e-01
7944 KSP Residual norm 3.943330715528e-01
7945 KSP Residual norm 3.943330715528e-01
7946 KSP Residual norm 3.943330715528e-01
7947 KSP Residual norm 3.943330715528e-01
7948 KSP Residual norm 3.943330715528e-01
7949 KSP Residual norm 3.943330715528e-01
7950 KSP Residual norm 3.943330715527e-01
7951 KSP Residual norm 3.943330715527e-01
7952 KSP Residual norm 3.943330715527e-01
7953 KSP Residual norm 3.943330715527e-01
7954 KSP Residual norm 3.943330715527e-01
7955 KSP Residual norm 3.943330715527e-01
7956 KSP Residual norm 3.943330715527e-01
7957 KSP Residual norm 3.943330715527e-01
7958 KSP Residual norm 3.943330715527e-01
7959 KSP Residual norm 3.943330715527e-01
7960 KSP Residual norm 3.943330715527e-01
7961 KSP Residual norm 3.943330715527e-01
7962 KSP Residual norm 3.943330715527e-01
7963 KSP Residual norm 3.943330715527e-01
7964 KSP Residual norm 3.943330715527e-01
7965 KSP Residual norm 3.943330715527e-01
7966 KSP Residual norm 3.943330715527e-01
7967 KSP Residual norm 3.943330715527e-01
7968 KSP Residual norm 3.943330715527e-01
7969 KSP Residual norm 3.943330715527e-01
7970 KSP Residual norm 3.943330715527e-01
7971 KSP Residual norm 3.943330715527e-01
7972 KSP Residual norm 3.943330715527e-01
7973 KSP Residual norm 3.943330715527e-01
7974 KSP Residual norm 3.943330715527e-01
7975 KSP Residual norm 3.943330715527e-01
7976 KSP Residual norm 3.943330715527e-01
7977 KSP Residual norm 3.943330715527e-01
7978 KSP Residual norm 3.943330715527e-01
7979 KSP Residual norm 3.943330715527e-01
7980 KSP Residual norm 3.943330715528e-01
7981 KSP Residual norm 3.943330715528e-01
7982 KSP Residual norm 3.943330715528e-01
7983 KSP Residual norm 3.943330715528e-01
7984 KSP Residual norm 3.943330715528e-01
7985 KSP Residual norm 3.943330715528e-01
7986 KSP Residual norm 3.943330715528e-01
7987 KSP Residual norm 3.943330715528e-01
7988 KSP Residual norm 3.943330715528e-01
7989 KSP Residual norm 3.943330715528e-01
7990 KSP Residual norm 3.943330715528e-01
7991 KSP Residual norm 3.943330715528e-01
7992 KSP Residual norm 3.943330715528e-01
7993 KSP Residual norm 3.943330715528e-01
7994 KSP Residual norm 3.943330715528e-01
7995 KSP Residual norm 3.943330715528e-01
7996 KSP Residual norm 3.943330715528e-01
7997 KSP Residual norm 3.943330715528e-01
7998 KSP Residual norm 3.943330715528e-01
7999 KSP Residual norm 3.943330715528e-01
8000 KSP Residual norm 3.943330715528e-01
8001 KSP Residual norm 3.943330715528e-01
8002 KSP Residual norm 3.943330715528e-01
8003 KSP Residual norm 3.943330715528e-01
8004 KSP Residual norm 3.943330715528e-01
8005 KSP Residual norm 3.943330715528e-01
8006 KSP Residual norm 3.943330715528e-01
8007 KSP Residual norm 3.943330715528e-01
8008 KSP Residual norm 3.943330715528e-01
8009 KSP Residual norm 3.943330715528e-01
8010 KSP Residual norm 3.943330715528e-01
8011 KSP Residual norm 3.943330715528e-01
8012 KSP Residual norm 3.943330715528e-01
8013 KSP Residual norm 3.943330715528e-01
8014 KSP Residual norm 3.943330715528e-01
8015 KSP Residual norm 3.943330715528e-01
8016 KSP Residual norm 3.943330715528e-01
8017 KSP Residual norm 3.943330715528e-01
8018 KSP Residual norm 3.943330715528e-01
8019 KSP Residual norm 3.943330715528e-01
8020 KSP Residual norm 3.943330715528e-01
8021 KSP Residual norm 3.943330715528e-01
8022 KSP Residual norm 3.943330715528e-01
8023 KSP Residual norm 3.943330715528e-01
8024 KSP Residual norm 3.943330715528e-01
8025 KSP Residual norm 3.943330715528e-01
8026 KSP Residual norm 3.943330715528e-01
8027 KSP Residual norm 3.943330715528e-01
8028 KSP Residual norm 3.943330715528e-01
8029 KSP Residual norm 3.943330715528e-01
8030 KSP Residual norm 3.943330715528e-01
8031 KSP Residual norm 3.943330715528e-01
8032 KSP Residual norm 3.943330715528e-01
8033 KSP Residual norm 3.943330715528e-01
8034 KSP Residual norm 3.943330715528e-01
8035 KSP Residual norm 3.943330715528e-01
8036 KSP Residual norm 3.943330715528e-01
8037 KSP Residual norm 3.943330715528e-01
8038 KSP Residual norm 3.943330715528e-01
8039 KSP Residual norm 3.943330715528e-01
8040 KSP Residual norm 3.943330715527e-01
8041 KSP Residual norm 3.943330715527e-01
8042 KSP Residual norm 3.943330715527e-01
8043 KSP Residual norm 3.943330715527e-01
8044 KSP Residual norm 3.943330715527e-01
8045 KSP Residual norm 3.943330715527e-01
8046 KSP Residual norm 3.943330715527e-01
8047 KSP Residual norm 3.943330715527e-01
8048 KSP Residual norm 3.943330715527e-01
8049 KSP Residual norm 3.943330715527e-01
8050 KSP Residual norm 3.943330715527e-01
8051 KSP Residual norm 3.943330715527e-01
8052 KSP Residual norm 3.943330715527e-01
8053 KSP Residual norm 3.943330715527e-01
8054 KSP Residual norm 3.943330715527e-01
8055 KSP Residual norm 3.943330715527e-01
8056 KSP Residual norm 3.943330715527e-01
8057 KSP Residual norm 3.943330715527e-01
8058 KSP Residual norm 3.943330715527e-01
8059 KSP Residual norm 3.943330715527e-01
8060 KSP Residual norm 3.943330715527e-01
8061 KSP Residual norm 3.943330715527e-01
8062 KSP Residual norm 3.943330715527e-01
8063 KSP Residual norm 3.943330715527e-01
8064 KSP Residual norm 3.943330715527e-01
8065 KSP Residual norm 3.943330715527e-01
8066 KSP Residual norm 3.943330715527e-01
8067 KSP Residual norm 3.943330715527e-01
8068 KSP Residual norm 3.943330715527e-01
8069 KSP Residual norm 3.943330715527e-01
8070 KSP Residual norm 3.943330715526e-01
8071 KSP Residual norm 3.943330715526e-01
8072 KSP Residual norm 3.943330715526e-01
8073 KSP Residual norm 3.943330715526e-01
8074 KSP Residual norm 3.943330715526e-01
8075 KSP Residual norm 3.943330715526e-01
8076 KSP Residual norm 3.943330715526e-01
8077 KSP Residual norm 3.943330715526e-01
8078 KSP Residual norm 3.943330715526e-01
8079 KSP Residual norm 3.943330715526e-01
8080 KSP Residual norm 3.943330715526e-01
8081 KSP Residual norm 3.943330715526e-01
8082 KSP Residual norm 3.943330715526e-01
8083 KSP Residual norm 3.943330715526e-01
8084 KSP Residual norm 3.943330715526e-01
8085 KSP Residual norm 3.943330715526e-01
8086 KSP Residual norm 3.943330715526e-01
8087 KSP Residual norm 3.943330715526e-01
8088 KSP Residual norm 3.943330715526e-01
8089 KSP Residual norm 3.943330715526e-01
8090 KSP Residual norm 3.943330715526e-01
8091 KSP Residual norm 3.943330715526e-01
8092 KSP Residual norm 3.943330715526e-01
8093 KSP Residual norm 3.943330715526e-01
8094 KSP Residual norm 3.943330715526e-01
8095 KSP Residual norm 3.943330715526e-01
8096 KSP Residual norm 3.943330715526e-01
8097 KSP Residual norm 3.943330715526e-01
8098 KSP Residual norm 3.943330715526e-01
8099 KSP Residual norm 3.943330715526e-01
8100 KSP Residual norm 3.943330715527e-01
8101 KSP Residual norm 3.943330715527e-01
8102 KSP Residual norm 3.943330715527e-01
8103 KSP Residual norm 3.943330715527e-01
8104 KSP Residual norm 3.943330715527e-01
8105 KSP Residual norm 3.943330715527e-01
8106 KSP Residual norm 3.943330715527e-01
8107 KSP Residual norm 3.943330715527e-01
8108 KSP Residual norm 3.943330715527e-01
8109 KSP Residual norm 3.943330715527e-01
8110 KSP Residual norm 3.943330715527e-01
8111 KSP Residual norm 3.943330715527e-01
8112 KSP Residual norm 3.943330715527e-01
8113 KSP Residual norm 3.943330715527e-01
8114 KSP Residual norm 3.943330715527e-01
8115 KSP Residual norm 3.943330715527e-01
8116 KSP Residual norm 3.943330715527e-01
8117 KSP Residual norm 3.943330715527e-01
8118 KSP Residual norm 3.943330715527e-01
8119 KSP Residual norm 3.943330715527e-01
8120 KSP Residual norm 3.943330715527e-01
8121 KSP Residual norm 3.943330715527e-01
8122 KSP Residual norm 3.943330715527e-01
8123 KSP Residual norm 3.943330715527e-01
8124 KSP Residual norm 3.943330715527e-01
8125 KSP Residual norm 3.943330715527e-01
8126 KSP Residual norm 3.943330715527e-01
8127 KSP Residual norm 3.943330715527e-01
8128 KSP Residual norm 3.943330715527e-01
8129 KSP Residual norm 3.943330715527e-01
8130 KSP Residual norm 3.943330715528e-01
8131 KSP Residual norm 3.943330715528e-01
8132 KSP Residual norm 3.943330715528e-01
8133 KSP Residual norm 3.943330715528e-01
8134 KSP Residual norm 3.943330715528e-01
8135 KSP Residual norm 3.943330715528e-01
8136 KSP Residual norm 3.943330715528e-01
8137 KSP Residual norm 3.943330715528e-01
8138 KSP Residual norm 3.943330715528e-01
8139 KSP Residual norm 3.943330715528e-01
8140 KSP Residual norm 3.943330715528e-01
8141 KSP Residual norm 3.943330715528e-01
8142 KSP Residual norm 3.943330715528e-01
8143 KSP Residual norm 3.943330715528e-01
8144 KSP Residual norm 3.943330715528e-01
8145 KSP Residual norm 3.943330715528e-01
8146 KSP Residual norm 3.943330715528e-01
8147 KSP Residual norm 3.943330715528e-01
8148 KSP Residual norm 3.943330715528e-01
8149 KSP Residual norm 3.943330715528e-01
8150 KSP Residual norm 3.943330715528e-01
8151 KSP Residual norm 3.943330715528e-01
8152 KSP Residual norm 3.943330715528e-01
8153 KSP Residual norm 3.943330715528e-01
8154 KSP Residual norm 3.943330715528e-01
8155 KSP Residual norm 3.943330715528e-01
8156 KSP Residual norm 3.943330715528e-01
8157 KSP Residual norm 3.943330715528e-01
8158 KSP Residual norm 3.943330715528e-01
8159 KSP Residual norm 3.943330715528e-01
8160 KSP Residual norm 3.943330715528e-01
8161 KSP Residual norm 3.943330715528e-01
8162 KSP Residual norm 3.943330715528e-01
8163 KSP Residual norm 3.943330715528e-01
8164 KSP Residual norm 3.943330715528e-01
8165 KSP Residual norm 3.943330715528e-01
8166 KSP Residual norm 3.943330715528e-01
8167 KSP Residual norm 3.943330715528e-01
8168 KSP Residual norm 3.943330715528e-01
8169 KSP Residual norm 3.943330715528e-01
8170 KSP Residual norm 3.943330715528e-01
8171 KSP Residual norm 3.943330715528e-01
8172 KSP Residual norm 3.943330715528e-01
8173 KSP Residual norm 3.943330715528e-01
8174 KSP Residual norm 3.943330715528e-01
8175 KSP Residual norm 3.943330715528e-01
8176 KSP Residual norm 3.943330715528e-01
8177 KSP Residual norm 3.943330715528e-01
8178 KSP Residual norm 3.943330715528e-01
8179 KSP Residual norm 3.943330715528e-01
8180 KSP Residual norm 3.943330715528e-01
8181 KSP Residual norm 3.943330715528e-01
8182 KSP Residual norm 3.943330715528e-01
8183 KSP Residual norm 3.943330715528e-01
8184 KSP Residual norm 3.943330715528e-01
8185 KSP Residual norm 3.943330715528e-01
8186 KSP Residual norm 3.943330715528e-01
8187 KSP Residual norm 3.943330715528e-01
8188 KSP Residual norm 3.943330715528e-01
8189 KSP Residual norm 3.943330715528e-01
8190 KSP Residual norm 3.943330715530e-01
8191 KSP Residual norm 3.943330715530e-01
8192 KSP Residual norm 3.943330715530e-01
8193 KSP Residual norm 3.943330715530e-01
8194 KSP Residual norm 3.943330715530e-01
8195 KSP Residual norm 3.943330715530e-01
8196 KSP Residual norm 3.943330715530e-01
8197 KSP Residual norm 3.943330715530e-01
8198 KSP Residual norm 3.943330715530e-01
8199 KSP Residual norm 3.943330715530e-01
8200 KSP Residual norm 3.943330715530e-01
8201 KSP Residual norm 3.943330715530e-01
8202 KSP Residual norm 3.943330715530e-01
8203 KSP Residual norm 3.943330715530e-01
8204 KSP Residual norm 3.943330715530e-01
8205 KSP Residual norm 3.943330715530e-01
8206 KSP Residual norm 3.943330715530e-01
8207 KSP Residual norm 3.943330715530e-01
8208 KSP Residual norm 3.943330715530e-01
8209 KSP Residual norm 3.943330715530e-01
8210 KSP Residual norm 3.943330715530e-01
8211 KSP Residual norm 3.943330715530e-01
8212 KSP Residual norm 3.943330715530e-01
8213 KSP Residual norm 3.943330715530e-01
8214 KSP Residual norm 3.943330715530e-01
8215 KSP Residual norm 3.943330715530e-01
8216 KSP Residual norm 3.943330715530e-01
8217 KSP Residual norm 3.943330715530e-01
8218 KSP Residual norm 3.943330715530e-01
8219 KSP Residual norm 3.943330715530e-01
8220 KSP Residual norm 3.943330715529e-01
8221 KSP Residual norm 3.943330715529e-01
8222 KSP Residual norm 3.943330715529e-01
8223 KSP Residual norm 3.943330715529e-01
8224 KSP Residual norm 3.943330715529e-01
8225 KSP Residual norm 3.943330715529e-01
8226 KSP Residual norm 3.943330715529e-01
8227 KSP Residual norm 3.943330715529e-01
8228 KSP Residual norm 3.943330715529e-01
8229 KSP Residual norm 3.943330715529e-01
8230 KSP Residual norm 3.943330715529e-01
8231 KSP Residual norm 3.943330715529e-01
8232 KSP Residual norm 3.943330715529e-01
8233 KSP Residual norm 3.943330715529e-01
8234 KSP Residual norm 3.943330715529e-01
8235 KSP Residual norm 3.943330715529e-01
8236 KSP Residual norm 3.943330715529e-01
8237 KSP Residual norm 3.943330715529e-01
8238 KSP Residual norm 3.943330715529e-01
8239 KSP Residual norm 3.943330715529e-01
8240 KSP Residual norm 3.943330715529e-01
8241 KSP Residual norm 3.943330715529e-01
8242 KSP Residual norm 3.943330715529e-01
8243 KSP Residual norm 3.943330715529e-01
8244 KSP Residual norm 3.943330715529e-01
8245 KSP Residual norm 3.943330715529e-01
8246 KSP Residual norm 3.943330715529e-01
8247 KSP Residual norm 3.943330715529e-01
8248 KSP Residual norm 3.943330715529e-01
8249 KSP Residual norm 3.943330715529e-01
8250 KSP Residual norm 3.943330715527e-01
8251 KSP Residual norm 3.943330715527e-01
8252 KSP Residual norm 3.943330715527e-01
8253 KSP Residual norm 3.943330715527e-01
8254 KSP Residual norm 3.943330715527e-01
8255 KSP Residual norm 3.943330715527e-01
8256 KSP Residual norm 3.943330715527e-01
8257 KSP Residual norm 3.943330715527e-01
8258 KSP Residual norm 3.943330715527e-01
8259 KSP Residual norm 3.943330715527e-01
8260 KSP Residual norm 3.943330715527e-01
8261 KSP Residual norm 3.943330715527e-01
8262 KSP Residual norm 3.943330715527e-01
8263 KSP Residual norm 3.943330715527e-01
8264 KSP Residual norm 3.943330715527e-01
8265 KSP Residual norm 3.943330715527e-01
8266 KSP Residual norm 3.943330715527e-01
8267 KSP Residual norm 3.943330715527e-01
8268 KSP Residual norm 3.943330715527e-01
8269 KSP Residual norm 3.943330715527e-01
8270 KSP Residual norm 3.943330715527e-01
8271 KSP Residual norm 3.943330715527e-01
8272 KSP Residual norm 3.943330715527e-01
8273 KSP Residual norm 3.943330715527e-01
8274 KSP Residual norm 3.943330715527e-01
8275 KSP Residual norm 3.943330715527e-01
8276 KSP Residual norm 3.943330715527e-01
8277 KSP Residual norm 3.943330715527e-01
8278 KSP Residual norm 3.943330715527e-01
8279 KSP Residual norm 3.943330715527e-01
8280 KSP Residual norm 3.943330715528e-01
8281 KSP Residual norm 3.943330715528e-01
8282 KSP Residual norm 3.943330715528e-01
8283 KSP Residual norm 3.943330715528e-01
8284 KSP Residual norm 3.943330715528e-01
8285 KSP Residual norm 3.943330715528e-01
8286 KSP Residual norm 3.943330715528e-01
8287 KSP Residual norm 3.943330715528e-01
8288 KSP Residual norm 3.943330715528e-01
8289 KSP Residual norm 3.943330715528e-01
8290 KSP Residual norm 3.943330715528e-01
8291 KSP Residual norm 3.943330715528e-01
8292 KSP Residual norm 3.943330715528e-01
8293 KSP Residual norm 3.943330715528e-01
8294 KSP Residual norm 3.943330715528e-01
8295 KSP Residual norm 3.943330715528e-01
8296 KSP Residual norm 3.943330715528e-01
8297 KSP Residual norm 3.943330715528e-01
8298 KSP Residual norm 3.943330715528e-01
8299 KSP Residual norm 3.943330715528e-01
8300 KSP Residual norm 3.943330715528e-01
8301 KSP Residual norm 3.943330715528e-01
8302 KSP Residual norm 3.943330715528e-01
8303 KSP Residual norm 3.943330715528e-01
8304 KSP Residual norm 3.943330715528e-01
8305 KSP Residual norm 3.943330715528e-01
8306 KSP Residual norm 3.943330715528e-01
8307 KSP Residual norm 3.943330715528e-01
8308 KSP Residual norm 3.943330715528e-01
8309 KSP Residual norm 3.943330715528e-01
8310 KSP Residual norm 3.943330715526e-01
8311 KSP Residual norm 3.943330715526e-01
8312 KSP Residual norm 3.943330715526e-01
8313 KSP Residual norm 3.943330715526e-01
8314 KSP Residual norm 3.943330715526e-01
8315 KSP Residual norm 3.943330715526e-01
8316 KSP Residual norm 3.943330715526e-01
8317 KSP Residual norm 3.943330715526e-01
8318 KSP Residual norm 3.943330715526e-01
8319 KSP Residual norm 3.943330715526e-01
8320 KSP Residual norm 3.943330715526e-01
8321 KSP Residual norm 3.943330715526e-01
8322 KSP Residual norm 3.943330715526e-01
8323 KSP Residual norm 3.943330715526e-01
8324 KSP Residual norm 3.943330715526e-01
8325 KSP Residual norm 3.943330715526e-01
8326 KSP Residual norm 3.943330715526e-01
8327 KSP Residual norm 3.943330715526e-01
8328 KSP Residual norm 3.943330715526e-01
8329 KSP Residual norm 3.943330715526e-01
8330 KSP Residual norm 3.943330715526e-01
8331 KSP Residual norm 3.943330715526e-01
8332 KSP Residual norm 3.943330715526e-01
8333 KSP Residual norm 3.943330715526e-01
8334 KSP Residual norm 3.943330715526e-01
8335 KSP Residual norm 3.943330715526e-01
8336 KSP Residual norm 3.943330715526e-01
8337 KSP Residual norm 3.943330715526e-01
8338 KSP Residual norm 3.943330715526e-01
8339 KSP Residual norm 3.943330715526e-01
8340 KSP Residual norm 3.943330715529e-01
8341 KSP Residual norm 3.943330715529e-01
8342 KSP Residual norm 3.943330715529e-01
8343 KSP Residual norm 3.943330715529e-01
8344 KSP Residual norm 3.943330715529e-01
8345 KSP Residual norm 3.943330715529e-01
8346 KSP Residual norm 3.943330715529e-01
8347 KSP Residual norm 3.943330715529e-01
8348 KSP Residual norm 3.943330715529e-01
8349 KSP Residual norm 3.943330715529e-01
8350 KSP Residual norm 3.943330715529e-01
8351 KSP Residual norm 3.943330715529e-01
8352 KSP Residual norm 3.943330715529e-01
8353 KSP Residual norm 3.943330715529e-01
8354 KSP Residual norm 3.943330715529e-01
8355 KSP Residual norm 3.943330715529e-01
8356 KSP Residual norm 3.943330715529e-01
8357 KSP Residual norm 3.943330715529e-01
8358 KSP Residual norm 3.943330715529e-01
8359 KSP Residual norm 3.943330715529e-01
8360 KSP Residual norm 3.943330715529e-01
8361 KSP Residual norm 3.943330715529e-01
8362 KSP Residual norm 3.943330715529e-01
8363 KSP Residual norm 3.943330715529e-01
8364 KSP Residual norm 3.943330715529e-01
8365 KSP Residual norm 3.943330715529e-01
8366 KSP Residual norm 3.943330715529e-01
8367 KSP Residual norm 3.943330715529e-01
8368 KSP Residual norm 3.943330715529e-01
8369 KSP Residual norm 3.943330715529e-01
8370 KSP Residual norm 3.943330715530e-01
8371 KSP Residual norm 3.943330715530e-01
8372 KSP Residual norm 3.943330715530e-01
8373 KSP Residual norm 3.943330715530e-01
8374 KSP Residual norm 3.943330715530e-01
8375 KSP Residual norm 3.943330715530e-01
8376 KSP Residual norm 3.943330715530e-01
8377 KSP Residual norm 3.943330715530e-01
8378 KSP Residual norm 3.943330715530e-01
8379 KSP Residual norm 3.943330715530e-01
8380 KSP Residual norm 3.943330715530e-01
8381 KSP Residual norm 3.943330715530e-01
8382 KSP Residual norm 3.943330715530e-01
8383 KSP Residual norm 3.943330715530e-01
8384 KSP Residual norm 3.943330715530e-01
8385 KSP Residual norm 3.943330715530e-01
8386 KSP Residual norm 3.943330715530e-01
8387 KSP Residual norm 3.943330715530e-01
8388 KSP Residual norm 3.943330715530e-01
8389 KSP Residual norm 3.943330715530e-01
8390 KSP Residual norm 3.943330715530e-01
8391 KSP Residual norm 3.943330715530e-01
8392 KSP Residual norm 3.943330715530e-01
8393 KSP Residual norm 3.943330715530e-01
8394 KSP Residual norm 3.943330715530e-01
8395 KSP Residual norm 3.943330715530e-01
8396 KSP Residual norm 3.943330715530e-01
8397 KSP Residual norm 3.943330715530e-01
8398 KSP Residual norm 3.943330715530e-01
8399 KSP Residual norm 3.943330715530e-01
8400 KSP Residual norm 3.943330715530e-01
8401 KSP Residual norm 3.943330715530e-01
8402 KSP Residual norm 3.943330715530e-01
8403 KSP Residual norm 3.943330715530e-01
8404 KSP Residual norm 3.943330715530e-01
8405 KSP Residual norm 3.943330715530e-01
8406 KSP Residual norm 3.943330715530e-01
8407 KSP Residual norm 3.943330715530e-01
8408 KSP Residual norm 3.943330715530e-01
8409 KSP Residual norm 3.943330715530e-01
8410 KSP Residual norm 3.943330715530e-01
8411 KSP Residual norm 3.943330715530e-01
8412 KSP Residual norm 3.943330715530e-01
8413 KSP Residual norm 3.943330715530e-01
8414 KSP Residual norm 3.943330715530e-01
8415 KSP Residual norm 3.943330715530e-01
8416 KSP Residual norm 3.943330715530e-01
8417 KSP Residual norm 3.943330715530e-01
8418 KSP Residual norm 3.943330715530e-01
8419 KSP Residual norm 3.943330715530e-01
8420 KSP Residual norm 3.943330715530e-01
8421 KSP Residual norm 3.943330715530e-01
8422 KSP Residual norm 3.943330715530e-01
8423 KSP Residual norm 3.943330715530e-01
8424 KSP Residual norm 3.943330715530e-01
8425 KSP Residual norm 3.943330715530e-01
8426 KSP Residual norm 3.943330715530e-01
8427 KSP Residual norm 3.943330715530e-01
8428 KSP Residual norm 3.943330715530e-01
8429 KSP Residual norm 3.943330715530e-01
8430 KSP Residual norm 3.943330715530e-01
8431 KSP Residual norm 3.943330715530e-01
8432 KSP Residual norm 3.943330715530e-01
8433 KSP Residual norm 3.943330715530e-01
8434 KSP Residual norm 3.943330715530e-01
8435 KSP Residual norm 3.943330715530e-01
8436 KSP Residual norm 3.943330715530e-01
8437 KSP Residual norm 3.943330715530e-01
8438 KSP Residual norm 3.943330715530e-01
8439 KSP Residual norm 3.943330715530e-01
8440 KSP Residual norm 3.943330715530e-01
8441 KSP Residual norm 3.943330715530e-01
8442 KSP Residual norm 3.943330715530e-01
8443 KSP Residual norm 3.943330715530e-01
8444 KSP Residual norm 3.943330715530e-01
8445 KSP Residual norm 3.943330715530e-01
8446 KSP Residual norm 3.943330715530e-01
8447 KSP Residual norm 3.943330715530e-01
8448 KSP Residual norm 3.943330715530e-01
8449 KSP Residual norm 3.943330715530e-01
8450 KSP Residual norm 3.943330715530e-01
8451 KSP Residual norm 3.943330715530e-01
8452 KSP Residual norm 3.943330715530e-01
8453 KSP Residual norm 3.943330715530e-01
8454 KSP Residual norm 3.943330715530e-01
8455 KSP Residual norm 3.943330715530e-01
8456 KSP Residual norm 3.943330715530e-01
8457 KSP Residual norm 3.943330715530e-01
8458 KSP Residual norm 3.943330715530e-01
8459 KSP Residual norm 3.943330715530e-01
8460 KSP Residual norm 3.943330715531e-01
8461 KSP Residual norm 3.943330715531e-01
8462 KSP Residual norm 3.943330715531e-01
8463 KSP Residual norm 3.943330715531e-01
8464 KSP Residual norm 3.943330715531e-01
8465 KSP Residual norm 3.943330715531e-01
8466 KSP Residual norm 3.943330715531e-01
8467 KSP Residual norm 3.943330715531e-01
8468 KSP Residual norm 3.943330715531e-01
8469 KSP Residual norm 3.943330715531e-01
8470 KSP Residual norm 3.943330715531e-01
8471 KSP Residual norm 3.943330715531e-01
8472 KSP Residual norm 3.943330715531e-01
8473 KSP Residual norm 3.943330715531e-01
8474 KSP Residual norm 3.943330715531e-01
8475 KSP Residual norm 3.943330715531e-01
8476 KSP Residual norm 3.943330715531e-01
8477 KSP Residual norm 3.943330715531e-01
8478 KSP Residual norm 3.943330715531e-01
8479 KSP Residual norm 3.943330715531e-01
8480 KSP Residual norm 3.943330715531e-01
8481 KSP Residual norm 3.943330715531e-01
8482 KSP Residual norm 3.943330715531e-01
8483 KSP Residual norm 3.943330715531e-01
8484 KSP Residual norm 3.943330715531e-01
8485 KSP Residual norm 3.943330715531e-01
8486 KSP Residual norm 3.943330715531e-01
8487 KSP Residual norm 3.943330715531e-01
8488 KSP Residual norm 3.943330715531e-01
8489 KSP Residual norm 3.943330715531e-01
8490 KSP Residual norm 3.943330715531e-01
8491 KSP Residual norm 3.943330715531e-01
8492 KSP Residual norm 3.943330715531e-01
8493 KSP Residual norm 3.943330715531e-01
8494 KSP Residual norm 3.943330715531e-01
8495 KSP Residual norm 3.943330715531e-01
8496 KSP Residual norm 3.943330715531e-01
8497 KSP Residual norm 3.943330715531e-01
8498 KSP Residual norm 3.943330715531e-01
8499 KSP Residual norm 3.943330715531e-01
8500 KSP Residual norm 3.943330715531e-01
8501 KSP Residual norm 3.943330715531e-01
8502 KSP Residual norm 3.943330715531e-01
8503 KSP Residual norm 3.943330715531e-01
8504 KSP Residual norm 3.943330715531e-01
8505 KSP Residual norm 3.943330715531e-01
8506 KSP Residual norm 3.943330715531e-01
8507 KSP Residual norm 3.943330715531e-01
8508 KSP Residual norm 3.943330715531e-01
8509 KSP Residual norm 3.943330715531e-01
8510 KSP Residual norm 3.943330715531e-01
8511 KSP Residual norm 3.943330715531e-01
8512 KSP Residual norm 3.943330715531e-01
8513 KSP Residual norm 3.943330715531e-01
8514 KSP Residual norm 3.943330715531e-01
8515 KSP Residual norm 3.943330715531e-01
8516 KSP Residual norm 3.943330715531e-01
8517 KSP Residual norm 3.943330715531e-01
8518 KSP Residual norm 3.943330715531e-01
8519 KSP Residual norm 3.943330715531e-01
8520 KSP Residual norm 3.943330715529e-01
8521 KSP Residual norm 3.943330715529e-01
8522 KSP Residual norm 3.943330715529e-01
8523 KSP Residual norm 3.943330715529e-01
8524 KSP Residual norm 3.943330715529e-01
8525 KSP Residual norm 3.943330715529e-01
8526 KSP Residual norm 3.943330715529e-01
8527 KSP Residual norm 3.943330715529e-01
8528 KSP Residual norm 3.943330715529e-01
8529 KSP Residual norm 3.943330715529e-01
8530 KSP Residual norm 3.943330715529e-01
8531 KSP Residual norm 3.943330715529e-01
8532 KSP Residual norm 3.943330715529e-01
8533 KSP Residual norm 3.943330715529e-01
8534 KSP Residual norm 3.943330715529e-01
8535 KSP Residual norm 3.943330715529e-01
8536 KSP Residual norm 3.943330715529e-01
8537 KSP Residual norm 3.943330715529e-01
8538 KSP Residual norm 3.943330715529e-01
8539 KSP Residual norm 3.943330715529e-01
8540 KSP Residual norm 3.943330715529e-01
8541 KSP Residual norm 3.943330715529e-01
8542 KSP Residual norm 3.943330715529e-01
8543 KSP Residual norm 3.943330715529e-01
8544 KSP Residual norm 3.943330715529e-01
8545 KSP Residual norm 3.943330715529e-01
8546 KSP Residual norm 3.943330715529e-01
8547 KSP Residual norm 3.943330715529e-01
8548 KSP Residual norm 3.943330715529e-01
8549 KSP Residual norm 3.943330715529e-01
8550 KSP Residual norm 3.943330715528e-01
8551 KSP Residual norm 3.943330715528e-01
8552 KSP Residual norm 3.943330715528e-01
8553 KSP Residual norm 3.943330715528e-01
8554 KSP Residual norm 3.943330715528e-01
8555 KSP Residual norm 3.943330715528e-01
8556 KSP Residual norm 3.943330715528e-01
8557 KSP Residual norm 3.943330715528e-01
8558 KSP Residual norm 3.943330715528e-01
8559 KSP Residual norm 3.943330715528e-01
8560 KSP Residual norm 3.943330715528e-01
8561 KSP Residual norm 3.943330715528e-01
8562 KSP Residual norm 3.943330715528e-01
8563 KSP Residual norm 3.943330715528e-01
8564 KSP Residual norm 3.943330715528e-01
8565 KSP Residual norm 3.943330715528e-01
8566 KSP Residual norm 3.943330715528e-01
8567 KSP Residual norm 3.943330715528e-01
8568 KSP Residual norm 3.943330715528e-01
8569 KSP Residual norm 3.943330715528e-01
8570 KSP Residual norm 3.943330715528e-01
8571 KSP Residual norm 3.943330715528e-01
8572 KSP Residual norm 3.943330715528e-01
8573 KSP Residual norm 3.943330715528e-01
8574 KSP Residual norm 3.943330715528e-01
8575 KSP Residual norm 3.943330715528e-01
8576 KSP Residual norm 3.943330715528e-01
8577 KSP Residual norm 3.943330715528e-01
8578 KSP Residual norm 3.943330715528e-01
8579 KSP Residual norm 3.943330715528e-01
8580 KSP Residual norm 3.943330715528e-01
8581 KSP Residual norm 3.943330715528e-01
8582 KSP Residual norm 3.943330715528e-01
8583 KSP Residual norm 3.943330715528e-01
8584 KSP Residual norm 3.943330715528e-01
8585 KSP Residual norm 3.943330715528e-01
8586 KSP Residual norm 3.943330715528e-01
8587 KSP Residual norm 3.943330715528e-01
8588 KSP Residual norm 3.943330715528e-01
8589 KSP Residual norm 3.943330715528e-01
8590 KSP Residual norm 3.943330715528e-01
8591 KSP Residual norm 3.943330715528e-01
8592 KSP Residual norm 3.943330715528e-01
8593 KSP Residual norm 3.943330715528e-01
8594 KSP Residual norm 3.943330715528e-01
8595 KSP Residual norm 3.943330715528e-01
8596 KSP Residual norm 3.943330715528e-01
8597 KSP Residual norm 3.943330715528e-01
8598 KSP Residual norm 3.943330715528e-01
8599 KSP Residual norm 3.943330715528e-01
8600 KSP Residual norm 3.943330715528e-01
8601 KSP Residual norm 3.943330715528e-01
8602 KSP Residual norm 3.943330715528e-01
8603 KSP Residual norm 3.943330715528e-01
8604 KSP Residual norm 3.943330715528e-01
8605 KSP Residual norm 3.943330715528e-01
8606 KSP Residual norm 3.943330715528e-01
8607 KSP Residual norm 3.943330715528e-01
8608 KSP Residual norm 3.943330715528e-01
8609 KSP Residual norm 3.943330715528e-01
8610 KSP Residual norm 3.943330715528e-01
8611 KSP Residual norm 3.943330715528e-01
8612 KSP Residual norm 3.943330715528e-01
8613 KSP Residual norm 3.943330715528e-01
8614 KSP Residual norm 3.943330715528e-01
8615 KSP Residual norm 3.943330715528e-01
8616 KSP Residual norm 3.943330715528e-01
8617 KSP Residual norm 3.943330715528e-01
8618 KSP Residual norm 3.943330715528e-01
8619 KSP Residual norm 3.943330715528e-01
8620 KSP Residual norm 3.943330715528e-01
8621 KSP Residual norm 3.943330715528e-01
8622 KSP Residual norm 3.943330715528e-01
8623 KSP Residual norm 3.943330715528e-01
8624 KSP Residual norm 3.943330715528e-01
8625 KSP Residual norm 3.943330715528e-01
8626 KSP Residual norm 3.943330715528e-01
8627 KSP Residual norm 3.943330715528e-01
8628 KSP Residual norm 3.943330715528e-01
8629 KSP Residual norm 3.943330715528e-01
8630 KSP Residual norm 3.943330715528e-01
8631 KSP Residual norm 3.943330715528e-01
8632 KSP Residual norm 3.943330715528e-01
8633 KSP Residual norm 3.943330715528e-01
8634 KSP Residual norm 3.943330715528e-01
8635 KSP Residual norm 3.943330715528e-01
8636 KSP Residual norm 3.943330715528e-01
8637 KSP Residual norm 3.943330715528e-01
8638 KSP Residual norm 3.943330715528e-01
8639 KSP Residual norm 3.943330715528e-01
8640 KSP Residual norm 3.943330715530e-01
8641 KSP Residual norm 3.943330715530e-01
8642 KSP Residual norm 3.943330715530e-01
8643 KSP Residual norm 3.943330715530e-01
8644 KSP Residual norm 3.943330715530e-01
8645 KSP Residual norm 3.943330715530e-01
8646 KSP Residual norm 3.943330715530e-01
8647 KSP Residual norm 3.943330715530e-01
8648 KSP Residual norm 3.943330715530e-01
8649 KSP Residual norm 3.943330715530e-01
8650 KSP Residual norm 3.943330715530e-01
8651 KSP Residual norm 3.943330715530e-01
8652 KSP Residual norm 3.943330715530e-01
8653 KSP Residual norm 3.943330715530e-01
8654 KSP Residual norm 3.943330715530e-01
8655 KSP Residual norm 3.943330715530e-01
8656 KSP Residual norm 3.943330715530e-01
8657 KSP Residual norm 3.943330715530e-01
8658 KSP Residual norm 3.943330715530e-01
8659 KSP Residual norm 3.943330715530e-01
8660 KSP Residual norm 3.943330715530e-01
8661 KSP Residual norm 3.943330715530e-01
8662 KSP Residual norm 3.943330715530e-01
8663 KSP Residual norm 3.943330715530e-01
8664 KSP Residual norm 3.943330715530e-01
8665 KSP Residual norm 3.943330715530e-01
8666 KSP Residual norm 3.943330715530e-01
8667 KSP Residual norm 3.943330715530e-01
8668 KSP Residual norm 3.943330715530e-01
8669 KSP Residual norm 3.943330715530e-01
8670 KSP Residual norm 3.943330715531e-01
8671 KSP Residual norm 3.943330715531e-01
8672 KSP Residual norm 3.943330715531e-01
8673 KSP Residual norm 3.943330715531e-01
8674 KSP Residual norm 3.943330715531e-01
8675 KSP Residual norm 3.943330715531e-01
8676 KSP Residual norm 3.943330715531e-01
8677 KSP Residual norm 3.943330715531e-01
8678 KSP Residual norm 3.943330715531e-01
8679 KSP Residual norm 3.943330715531e-01
8680 KSP Residual norm 3.943330715531e-01
8681 KSP Residual norm 3.943330715531e-01
8682 KSP Residual norm 3.943330715531e-01
8683 KSP Residual norm 3.943330715531e-01
8684 KSP Residual norm 3.943330715531e-01
8685 KSP Residual norm 3.943330715531e-01
8686 KSP Residual norm 3.943330715531e-01
8687 KSP Residual norm 3.943330715531e-01
8688 KSP Residual norm 3.943330715531e-01
8689 KSP Residual norm 3.943330715531e-01
8690 KSP Residual norm 3.943330715531e-01
8691 KSP Residual norm 3.943330715531e-01
8692 KSP Residual norm 3.943330715531e-01
8693 KSP Residual norm 3.943330715531e-01
8694 KSP Residual norm 3.943330715531e-01
8695 KSP Residual norm 3.943330715531e-01
8696 KSP Residual norm 3.943330715531e-01
8697 KSP Residual norm 3.943330715531e-01
8698 KSP Residual norm 3.943330715531e-01
8699 KSP Residual norm 3.943330715531e-01
8700 KSP Residual norm 3.943330715531e-01
8701 KSP Residual norm 3.943330715531e-01
8702 KSP Residual norm 3.943330715531e-01
8703 KSP Residual norm 3.943330715531e-01
8704 KSP Residual norm 3.943330715531e-01
8705 KSP Residual norm 3.943330715531e-01
8706 KSP Residual norm 3.943330715531e-01
8707 KSP Residual norm 3.943330715531e-01
8708 KSP Residual norm 3.943330715531e-01
8709 KSP Residual norm 3.943330715531e-01
8710 KSP Residual norm 3.943330715531e-01
8711 KSP Residual norm 3.943330715531e-01
8712 KSP Residual norm 3.943330715531e-01
8713 KSP Residual norm 3.943330715531e-01
8714 KSP Residual norm 3.943330715531e-01
8715 KSP Residual norm 3.943330715531e-01
8716 KSP Residual norm 3.943330715531e-01
8717 KSP Residual norm 3.943330715531e-01
8718 KSP Residual norm 3.943330715531e-01
8719 KSP Residual norm 3.943330715531e-01
8720 KSP Residual norm 3.943330715531e-01
8721 KSP Residual norm 3.943330715531e-01
8722 KSP Residual norm 3.943330715531e-01
8723 KSP Residual norm 3.943330715531e-01
8724 KSP Residual norm 3.943330715531e-01
8725 KSP Residual norm 3.943330715531e-01
8726 KSP Residual norm 3.943330715531e-01
8727 KSP Residual norm 3.943330715531e-01
8728 KSP Residual norm 3.943330715531e-01
8729 KSP Residual norm 3.943330715531e-01
8730 KSP Residual norm 3.943330715529e-01
8731 KSP Residual norm 3.943330715529e-01
8732 KSP Residual norm 3.943330715529e-01
8733 KSP Residual norm 3.943330715529e-01
8734 KSP Residual norm 3.943330715529e-01
8735 KSP Residual norm 3.943330715529e-01
8736 KSP Residual norm 3.943330715529e-01
8737 KSP Residual norm 3.943330715529e-01
8738 KSP Residual norm 3.943330715529e-01
8739 KSP Residual norm 3.943330715529e-01
8740 KSP Residual norm 3.943330715529e-01
8741 KSP Residual norm 3.943330715529e-01
8742 KSP Residual norm 3.943330715529e-01
8743 KSP Residual norm 3.943330715529e-01
8744 KSP Residual norm 3.943330715529e-01
8745 KSP Residual norm 3.943330715529e-01
8746 KSP Residual norm 3.943330715529e-01
8747 KSP Residual norm 3.943330715529e-01
8748 KSP Residual norm 3.943330715529e-01
8749 KSP Residual norm 3.943330715529e-01
8750 KSP Residual norm 3.943330715529e-01
8751 KSP Residual norm 3.943330715529e-01
8752 KSP Residual norm 3.943330715529e-01
8753 KSP Residual norm 3.943330715529e-01
8754 KSP Residual norm 3.943330715529e-01
8755 KSP Residual norm 3.943330715529e-01
8756 KSP Residual norm 3.943330715529e-01
8757 KSP Residual norm 3.943330715529e-01
8758 KSP Residual norm 3.943330715529e-01
8759 KSP Residual norm 3.943330715529e-01
8760 KSP Residual norm 3.943330715532e-01
8761 KSP Residual norm 3.943330715532e-01
8762 KSP Residual norm 3.943330715532e-01
8763 KSP Residual norm 3.943330715532e-01
8764 KSP Residual norm 3.943330715532e-01
8765 KSP Residual norm 3.943330715532e-01
8766 KSP Residual norm 3.943330715532e-01
8767 KSP Residual norm 3.943330715532e-01
8768 KSP Residual norm 3.943330715532e-01
8769 KSP Residual norm 3.943330715532e-01
8770 KSP Residual norm 3.943330715532e-01
8771 KSP Residual norm 3.943330715532e-01
8772 KSP Residual norm 3.943330715532e-01
8773 KSP Residual norm 3.943330715532e-01
8774 KSP Residual norm 3.943330715532e-01
8775 KSP Residual norm 3.943330715532e-01
8776 KSP Residual norm 3.943330715532e-01
8777 KSP Residual norm 3.943330715532e-01
8778 KSP Residual norm 3.943330715532e-01
8779 KSP Residual norm 3.943330715532e-01
8780 KSP Residual norm 3.943330715532e-01
8781 KSP Residual norm 3.943330715532e-01
8782 KSP Residual norm 3.943330715532e-01
8783 KSP Residual norm 3.943330715532e-01
8784 KSP Residual norm 3.943330715532e-01
8785 KSP Residual norm 3.943330715532e-01
8786 KSP Residual norm 3.943330715532e-01
8787 KSP Residual norm 3.943330715532e-01
8788 KSP Residual norm 3.943330715532e-01
8789 KSP Residual norm 3.943330715532e-01
8790 KSP Residual norm 3.943330715530e-01
8791 KSP Residual norm 3.943330715530e-01
8792 KSP Residual norm 3.943330715530e-01
8793 KSP Residual norm 3.943330715530e-01
8794 KSP Residual norm 3.943330715530e-01
8795 KSP Residual norm 3.943330715530e-01
8796 KSP Residual norm 3.943330715530e-01
8797 KSP Residual norm 3.943330715530e-01
8798 KSP Residual norm 3.943330715530e-01
8799 KSP Residual norm 3.943330715530e-01
8800 KSP Residual norm 3.943330715530e-01
8801 KSP Residual norm 3.943330715530e-01
8802 KSP Residual norm 3.943330715530e-01
8803 KSP Residual norm 3.943330715530e-01
8804 KSP Residual norm 3.943330715530e-01
8805 KSP Residual norm 3.943330715530e-01
8806 KSP Residual norm 3.943330715530e-01
8807 KSP Residual norm 3.943330715530e-01
8808 KSP Residual norm 3.943330715530e-01
8809 KSP Residual norm 3.943330715530e-01
8810 KSP Residual norm 3.943330715530e-01
8811 KSP Residual norm 3.943330715530e-01
8812 KSP Residual norm 3.943330715530e-01
8813 KSP Residual norm 3.943330715530e-01
8814 KSP Residual norm 3.943330715530e-01
8815 KSP Residual norm 3.943330715530e-01
8816 KSP Residual norm 3.943330715530e-01
8817 KSP Residual norm 3.943330715530e-01
8818 KSP Residual norm 3.943330715530e-01
8819 KSP Residual norm 3.943330715530e-01
8820 KSP Residual norm 3.943330715529e-01
8821 KSP Residual norm 3.943330715529e-01
8822 KSP Residual norm 3.943330715529e-01
8823 KSP Residual norm 3.943330715529e-01
8824 KSP Residual norm 3.943330715529e-01
8825 KSP Residual norm 3.943330715529e-01
8826 KSP Residual norm 3.943330715529e-01
8827 KSP Residual norm 3.943330715529e-01
8828 KSP Residual norm 3.943330715529e-01
8829 KSP Residual norm 3.943330715529e-01
8830 KSP Residual norm 3.943330715529e-01
8831 KSP Residual norm 3.943330715529e-01
8832 KSP Residual norm 3.943330715529e-01
8833 KSP Residual norm 3.943330715529e-01
8834 KSP Residual norm 3.943330715529e-01
8835 KSP Residual norm 3.943330715529e-01
8836 KSP Residual norm 3.943330715529e-01
8837 KSP Residual norm 3.943330715529e-01
8838 KSP Residual norm 3.943330715529e-01
8839 KSP Residual norm 3.943330715529e-01
8840 KSP Residual norm 3.943330715529e-01
8841 KSP Residual norm 3.943330715529e-01
8842 KSP Residual norm 3.943330715529e-01
8843 KSP Residual norm 3.943330715529e-01
8844 KSP Residual norm 3.943330715529e-01
8845 KSP Residual norm 3.943330715529e-01
8846 KSP Residual norm 3.943330715529e-01
8847 KSP Residual norm 3.943330715529e-01
8848 KSP Residual norm 3.943330715529e-01
8849 KSP Residual norm 3.943330715529e-01
8850 KSP Residual norm 3.943330715528e-01
8851 KSP Residual norm 3.943330715528e-01
8852 KSP Residual norm 3.943330715528e-01
8853 KSP Residual norm 3.943330715528e-01
8854 KSP Residual norm 3.943330715528e-01
8855 KSP Residual norm 3.943330715528e-01
8856 KSP Residual norm 3.943330715528e-01
8857 KSP Residual norm 3.943330715528e-01
8858 KSP Residual norm 3.943330715528e-01
8859 KSP Residual norm 3.943330715528e-01
8860 KSP Residual norm 3.943330715528e-01
8861 KSP Residual norm 3.943330715528e-01
8862 KSP Residual norm 3.943330715528e-01
8863 KSP Residual norm 3.943330715528e-01
8864 KSP Residual norm 3.943330715528e-01
8865 KSP Residual norm 3.943330715528e-01
8866 KSP Residual norm 3.943330715528e-01
8867 KSP Residual norm 3.943330715528e-01
8868 KSP Residual norm 3.943330715528e-01
8869 KSP Residual norm 3.943330715528e-01
8870 KSP Residual norm 3.943330715528e-01
8871 KSP Residual norm 3.943330715528e-01
8872 KSP Residual norm 3.943330715528e-01
8873 KSP Residual norm 3.943330715528e-01
8874 KSP Residual norm 3.943330715528e-01
8875 KSP Residual norm 3.943330715528e-01
8876 KSP Residual norm 3.943330715528e-01
8877 KSP Residual norm 3.943330715528e-01
8878 KSP Residual norm 3.943330715528e-01
8879 KSP Residual norm 3.943330715528e-01
8880 KSP Residual norm 3.943330715530e-01
8881 KSP Residual norm 3.943330715530e-01
8882 KSP Residual norm 3.943330715530e-01
8883 KSP Residual norm 3.943330715530e-01
8884 KSP Residual norm 3.943330715530e-01
8885 KSP Residual norm 3.943330715530e-01
8886 KSP Residual norm 3.943330715530e-01
8887 KSP Residual norm 3.943330715530e-01
8888 KSP Residual norm 3.943330715530e-01
8889 KSP Residual norm 3.943330715530e-01
8890 KSP Residual norm 3.943330715530e-01
8891 KSP Residual norm 3.943330715530e-01
8892 KSP Residual norm 3.943330715530e-01
8893 KSP Residual norm 3.943330715530e-01
8894 KSP Residual norm 3.943330715530e-01
8895 KSP Residual norm 3.943330715530e-01
8896 KSP Residual norm 3.943330715530e-01
8897 KSP Residual norm 3.943330715530e-01
8898 KSP Residual norm 3.943330715530e-01
8899 KSP Residual norm 3.943330715530e-01
8900 KSP Residual norm 3.943330715530e-01
8901 KSP Residual norm 3.943330715530e-01
8902 KSP Residual norm 3.943330715530e-01
8903 KSP Residual norm 3.943330715530e-01
8904 KSP Residual norm 3.943330715530e-01
8905 KSP Residual norm 3.943330715530e-01
8906 KSP Residual norm 3.943330715530e-01
8907 KSP Residual norm 3.943330715530e-01
8908 KSP Residual norm 3.943330715530e-01
8909 KSP Residual norm 3.943330715530e-01
8910 KSP Residual norm 3.943330715528e-01
8911 KSP Residual norm 3.943330715528e-01
8912 KSP Residual norm 3.943330715528e-01
8913 KSP Residual norm 3.943330715528e-01
8914 KSP Residual norm 3.943330715528e-01
8915 KSP Residual norm 3.943330715528e-01
8916 KSP Residual norm 3.943330715528e-01
8917 KSP Residual norm 3.943330715528e-01
8918 KSP Residual norm 3.943330715528e-01
8919 KSP Residual norm 3.943330715528e-01
8920 KSP Residual norm 3.943330715528e-01
8921 KSP Residual norm 3.943330715528e-01
8922 KSP Residual norm 3.943330715528e-01
8923 KSP Residual norm 3.943330715528e-01
8924 KSP Residual norm 3.943330715528e-01
8925 KSP Residual norm 3.943330715528e-01
8926 KSP Residual norm 3.943330715528e-01
8927 KSP Residual norm 3.943330715528e-01
8928 KSP Residual norm 3.943330715528e-01
8929 KSP Residual norm 3.943330715528e-01
8930 KSP Residual norm 3.943330715528e-01
8931 KSP Residual norm 3.943330715528e-01
8932 KSP Residual norm 3.943330715528e-01
8933 KSP Residual norm 3.943330715528e-01
8934 KSP Residual norm 3.943330715528e-01
8935 KSP Residual norm 3.943330715528e-01
8936 KSP Residual norm 3.943330715528e-01
8937 KSP Residual norm 3.943330715528e-01
8938 KSP Residual norm 3.943330715528e-01
8939 KSP Residual norm 3.943330715528e-01
8940 KSP Residual norm 3.943330715528e-01
8941 KSP Residual norm 3.943330715528e-01
8942 KSP Residual norm 3.943330715528e-01
8943 KSP Residual norm 3.943330715528e-01
8944 KSP Residual norm 3.943330715528e-01
8945 KSP Residual norm 3.943330715528e-01
8946 KSP Residual norm 3.943330715528e-01
8947 KSP Residual norm 3.943330715528e-01
8948 KSP Residual norm 3.943330715528e-01
8949 KSP Residual norm 3.943330715528e-01
8950 KSP Residual norm 3.943330715528e-01
8951 KSP Residual norm 3.943330715528e-01
8952 KSP Residual norm 3.943330715528e-01
8953 KSP Residual norm 3.943330715528e-01
8954 KSP Residual norm 3.943330715528e-01
8955 KSP Residual norm 3.943330715528e-01
8956 KSP Residual norm 3.943330715528e-01
8957 KSP Residual norm 3.943330715528e-01
8958 KSP Residual norm 3.943330715528e-01
8959 KSP Residual norm 3.943330715528e-01
8960 KSP Residual norm 3.943330715528e-01
8961 KSP Residual norm 3.943330715528e-01
8962 KSP Residual norm 3.943330715528e-01
8963 KSP Residual norm 3.943330715528e-01
8964 KSP Residual norm 3.943330715528e-01
8965 KSP Residual norm 3.943330715528e-01
8966 KSP Residual norm 3.943330715528e-01
8967 KSP Residual norm 3.943330715528e-01
8968 KSP Residual norm 3.943330715528e-01
8969 KSP Residual norm 3.943330715528e-01
8970 KSP Residual norm 3.943330715529e-01
8971 KSP Residual norm 3.943330715529e-01
8972 KSP Residual norm 3.943330715529e-01
8973 KSP Residual norm 3.943330715529e-01
8974 KSP Residual norm 3.943330715529e-01
8975 KSP Residual norm 3.943330715529e-01
8976 KSP Residual norm 3.943330715529e-01
8977 KSP Residual norm 3.943330715529e-01
8978 KSP Residual norm 3.943330715529e-01
8979 KSP Residual norm 3.943330715529e-01
8980 KSP Residual norm 3.943330715529e-01
8981 KSP Residual norm 3.943330715529e-01
8982 KSP Residual norm 3.943330715529e-01
8983 KSP Residual norm 3.943330715529e-01
8984 KSP Residual norm 3.943330715529e-01
8985 KSP Residual norm 3.943330715529e-01
8986 KSP Residual norm 3.943330715529e-01
8987 KSP Residual norm 3.943330715529e-01
8988 KSP Residual norm 3.943330715529e-01
8989 KSP Residual norm 3.943330715529e-01
8990 KSP Residual norm 3.943330715529e-01
8991 KSP Residual norm 3.943330715529e-01
8992 KSP Residual norm 3.943330715529e-01
8993 KSP Residual norm 3.943330715529e-01
8994 KSP Residual norm 3.943330715529e-01
8995 KSP Residual norm 3.943330715529e-01
8996 KSP Residual norm 3.943330715529e-01
8997 KSP Residual norm 3.943330715529e-01
8998 KSP Residual norm 3.943330715529e-01
8999 KSP Residual norm 3.943330715529e-01
9000 KSP Residual norm 3.943330715528e-01
9001 KSP Residual norm 3.943330715528e-01
9002 KSP Residual norm 3.943330715528e-01
9003 KSP Residual norm 3.943330715528e-01
9004 KSP Residual norm 3.943330715528e-01
9005 KSP Residual norm 3.943330715528e-01
9006 KSP Residual norm 3.943330715528e-01
9007 KSP Residual norm 3.943330715528e-01
9008 KSP Residual norm 3.943330715528e-01
9009 KSP Residual norm 3.943330715528e-01
9010 KSP Residual norm 3.943330715528e-01
9011 KSP Residual norm 3.943330715528e-01
9012 KSP Residual norm 3.943330715528e-01
9013 KSP Residual norm 3.943330715528e-01
9014 KSP Residual norm 3.943330715528e-01
9015 KSP Residual norm 3.943330715528e-01
9016 KSP Residual norm 3.943330715528e-01
9017 KSP Residual norm 3.943330715528e-01
9018 KSP Residual norm 3.943330715528e-01
9019 KSP Residual norm 3.943330715528e-01
9020 KSP Residual norm 3.943330715528e-01
9021 KSP Residual norm 3.943330715528e-01
9022 KSP Residual norm 3.943330715528e-01
9023 KSP Residual norm 3.943330715528e-01
9024 KSP Residual norm 3.943330715528e-01
9025 KSP Residual norm 3.943330715528e-01
9026 KSP Residual norm 3.943330715528e-01
9027 KSP Residual norm 3.943330715528e-01
9028 KSP Residual norm 3.943330715528e-01
9029 KSP Residual norm 3.943330715528e-01
9030 KSP Residual norm 3.943330715528e-01
9031 KSP Residual norm 3.943330715528e-01
9032 KSP Residual norm 3.943330715528e-01
9033 KSP Residual norm 3.943330715528e-01
9034 KSP Residual norm 3.943330715528e-01
9035 KSP Residual norm 3.943330715528e-01
9036 KSP Residual norm 3.943330715528e-01
9037 KSP Residual norm 3.943330715528e-01
9038 KSP Residual norm 3.943330715528e-01
9039 KSP Residual norm 3.943330715528e-01
9040 KSP Residual norm 3.943330715528e-01
9041 KSP Residual norm 3.943330715528e-01
9042 KSP Residual norm 3.943330715528e-01
9043 KSP Residual norm 3.943330715528e-01
9044 KSP Residual norm 3.943330715528e-01
9045 KSP Residual norm 3.943330715528e-01
9046 KSP Residual norm 3.943330715528e-01
9047 KSP Residual norm 3.943330715528e-01
9048 KSP Residual norm 3.943330715528e-01
9049 KSP Residual norm 3.943330715528e-01
9050 KSP Residual norm 3.943330715528e-01
9051 KSP Residual norm 3.943330715528e-01
9052 KSP Residual norm 3.943330715528e-01
9053 KSP Residual norm 3.943330715528e-01
9054 KSP Residual norm 3.943330715528e-01
9055 KSP Residual norm 3.943330715528e-01
9056 KSP Residual norm 3.943330715528e-01
9057 KSP Residual norm 3.943330715528e-01
9058 KSP Residual norm 3.943330715528e-01
9059 KSP Residual norm 3.943330715528e-01
9060 KSP Residual norm 3.943330715529e-01
9061 KSP Residual norm 3.943330715529e-01
9062 KSP Residual norm 3.943330715529e-01
9063 KSP Residual norm 3.943330715529e-01
9064 KSP Residual norm 3.943330715529e-01
9065 KSP Residual norm 3.943330715529e-01
9066 KSP Residual norm 3.943330715529e-01
9067 KSP Residual norm 3.943330715529e-01
9068 KSP Residual norm 3.943330715529e-01
9069 KSP Residual norm 3.943330715529e-01
9070 KSP Residual norm 3.943330715529e-01
9071 KSP Residual norm 3.943330715529e-01
9072 KSP Residual norm 3.943330715529e-01
9073 KSP Residual norm 3.943330715529e-01
9074 KSP Residual norm 3.943330715529e-01
9075 KSP Residual norm 3.943330715529e-01
9076 KSP Residual norm 3.943330715529e-01
9077 KSP Residual norm 3.943330715529e-01
9078 KSP Residual norm 3.943330715529e-01
9079 KSP Residual norm 3.943330715529e-01
9080 KSP Residual norm 3.943330715529e-01
9081 KSP Residual norm 3.943330715529e-01
9082 KSP Residual norm 3.943330715529e-01
9083 KSP Residual norm 3.943330715529e-01
9084 KSP Residual norm 3.943330715529e-01
9085 KSP Residual norm 3.943330715529e-01
9086 KSP Residual norm 3.943330715529e-01
9087 KSP Residual norm 3.943330715529e-01
9088 KSP Residual norm 3.943330715529e-01
9089 KSP Residual norm 3.943330715529e-01
9090 KSP Residual norm 3.943330715530e-01
9091 KSP Residual norm 3.943330715530e-01
9092 KSP Residual norm 3.943330715530e-01
9093 KSP Residual norm 3.943330715530e-01
9094 KSP Residual norm 3.943330715530e-01
9095 KSP Residual norm 3.943330715530e-01
9096 KSP Residual norm 3.943330715530e-01
9097 KSP Residual norm 3.943330715530e-01
9098 KSP Residual norm 3.943330715530e-01
9099 KSP Residual norm 3.943330715530e-01
9100 KSP Residual norm 3.943330715530e-01
9101 KSP Residual norm 3.943330715530e-01
9102 KSP Residual norm 3.943330715530e-01
9103 KSP Residual norm 3.943330715530e-01
9104 KSP Residual norm 3.943330715530e-01
9105 KSP Residual norm 3.943330715530e-01
9106 KSP Residual norm 3.943330715530e-01
9107 KSP Residual norm 3.943330715530e-01
9108 KSP Residual norm 3.943330715530e-01
9109 KSP Residual norm 3.943330715530e-01
9110 KSP Residual norm 3.943330715530e-01
9111 KSP Residual norm 3.943330715530e-01
9112 KSP Residual norm 3.943330715530e-01
9113 KSP Residual norm 3.943330715530e-01
9114 KSP Residual norm 3.943330715530e-01
9115 KSP Residual norm 3.943330715530e-01
9116 KSP Residual norm 3.943330715530e-01
9117 KSP Residual norm 3.943330715530e-01
9118 KSP Residual norm 3.943330715530e-01
9119 KSP Residual norm 3.943330715530e-01
9120 KSP Residual norm 3.943330715528e-01
9121 KSP Residual norm 3.943330715528e-01
9122 KSP Residual norm 3.943330715528e-01
9123 KSP Residual norm 3.943330715528e-01
9124 KSP Residual norm 3.943330715528e-01
9125 KSP Residual norm 3.943330715528e-01
9126 KSP Residual norm 3.943330715528e-01
9127 KSP Residual norm 3.943330715528e-01
9128 KSP Residual norm 3.943330715528e-01
9129 KSP Residual norm 3.943330715528e-01
9130 KSP Residual norm 3.943330715528e-01
9131 KSP Residual norm 3.943330715528e-01
9132 KSP Residual norm 3.943330715528e-01
9133 KSP Residual norm 3.943330715528e-01
9134 KSP Residual norm 3.943330715528e-01
9135 KSP Residual norm 3.943330715528e-01
9136 KSP Residual norm 3.943330715528e-01
9137 KSP Residual norm 3.943330715528e-01
9138 KSP Residual norm 3.943330715528e-01
9139 KSP Residual norm 3.943330715528e-01
9140 KSP Residual norm 3.943330715528e-01
9141 KSP Residual norm 3.943330715528e-01
9142 KSP Residual norm 3.943330715528e-01
9143 KSP Residual norm 3.943330715528e-01
9144 KSP Residual norm 3.943330715528e-01
9145 KSP Residual norm 3.943330715528e-01
9146 KSP Residual norm 3.943330715528e-01
9147 KSP Residual norm 3.943330715528e-01
9148 KSP Residual norm 3.943330715528e-01
9149 KSP Residual norm 3.943330715528e-01
9150 KSP Residual norm 3.943330715530e-01
9151 KSP Residual norm 3.943330715530e-01
9152 KSP Residual norm 3.943330715530e-01
9153 KSP Residual norm 3.943330715530e-01
9154 KSP Residual norm 3.943330715530e-01
9155 KSP Residual norm 3.943330715530e-01
9156 KSP Residual norm 3.943330715530e-01
9157 KSP Residual norm 3.943330715530e-01
9158 KSP Residual norm 3.943330715530e-01
9159 KSP Residual norm 3.943330715530e-01
9160 KSP Residual norm 3.943330715530e-01
9161 KSP Residual norm 3.943330715530e-01
9162 KSP Residual norm 3.943330715530e-01
9163 KSP Residual norm 3.943330715530e-01
9164 KSP Residual norm 3.943330715530e-01
9165 KSP Residual norm 3.943330715530e-01
9166 KSP Residual norm 3.943330715530e-01
9167 KSP Residual norm 3.943330715530e-01
9168 KSP Residual norm 3.943330715530e-01
9169 KSP Residual norm 3.943330715530e-01
9170 KSP Residual norm 3.943330715530e-01
9171 KSP Residual norm 3.943330715530e-01
9172 KSP Residual norm 3.943330715530e-01
9173 KSP Residual norm 3.943330715530e-01
9174 KSP Residual norm 3.943330715530e-01
9175 KSP Residual norm 3.943330715530e-01
9176 KSP Residual norm 3.943330715530e-01
9177 KSP Residual norm 3.943330715530e-01
9178 KSP Residual norm 3.943330715530e-01
9179 KSP Residual norm 3.943330715530e-01
9180 KSP Residual norm 3.943330715531e-01
9181 KSP Residual norm 3.943330715531e-01
9182 KSP Residual norm 3.943330715531e-01
9183 KSP Residual norm 3.943330715531e-01
9184 KSP Residual norm 3.943330715531e-01
9185 KSP Residual norm 3.943330715531e-01
9186 KSP Residual norm 3.943330715531e-01
9187 KSP Residual norm 3.943330715531e-01
9188 KSP Residual norm 3.943330715531e-01
9189 KSP Residual norm 3.943330715531e-01
9190 KSP Residual norm 3.943330715531e-01
9191 KSP Residual norm 3.943330715531e-01
9192 KSP Residual norm 3.943330715531e-01
9193 KSP Residual norm 3.943330715531e-01
9194 KSP Residual norm 3.943330715531e-01
9195 KSP Residual norm 3.943330715531e-01
9196 KSP Residual norm 3.943330715531e-01
9197 KSP Residual norm 3.943330715531e-01
9198 KSP Residual norm 3.943330715531e-01
9199 KSP Residual norm 3.943330715531e-01
9200 KSP Residual norm 3.943330715531e-01
9201 KSP Residual norm 3.943330715531e-01
9202 KSP Residual norm 3.943330715531e-01
9203 KSP Residual norm 3.943330715531e-01
9204 KSP Residual norm 3.943330715531e-01
9205 KSP Residual norm 3.943330715531e-01
9206 KSP Residual norm 3.943330715531e-01
9207 KSP Residual norm 3.943330715531e-01
9208 KSP Residual norm 3.943330715531e-01
9209 KSP Residual norm 3.943330715531e-01
9210 KSP Residual norm 3.943330715530e-01
9211 KSP Residual norm 3.943330715530e-01
9212 KSP Residual norm 3.943330715530e-01
9213 KSP Residual norm 3.943330715530e-01
9214 KSP Residual norm 3.943330715530e-01
9215 KSP Residual norm 3.943330715530e-01
9216 KSP Residual norm 3.943330715530e-01
9217 KSP Residual norm 3.943330715530e-01
9218 KSP Residual norm 3.943330715530e-01
9219 KSP Residual norm 3.943330715530e-01
9220 KSP Residual norm 3.943330715530e-01
9221 KSP Residual norm 3.943330715530e-01
9222 KSP Residual norm 3.943330715530e-01
9223 KSP Residual norm 3.943330715530e-01
9224 KSP Residual norm 3.943330715530e-01
9225 KSP Residual norm 3.943330715530e-01
9226 KSP Residual norm 3.943330715530e-01
9227 KSP Residual norm 3.943330715530e-01
9228 KSP Residual norm 3.943330715530e-01
9229 KSP Residual norm 3.943330715530e-01
9230 KSP Residual norm 3.943330715530e-01
9231 KSP Residual norm 3.943330715530e-01
9232 KSP Residual norm 3.943330715530e-01
9233 KSP Residual norm 3.943330715530e-01
9234 KSP Residual norm 3.943330715530e-01
9235 KSP Residual norm 3.943330715530e-01
9236 KSP Residual norm 3.943330715530e-01
9237 KSP Residual norm 3.943330715530e-01
9238 KSP Residual norm 3.943330715530e-01
9239 KSP Residual norm 3.943330715530e-01
9240 KSP Residual norm 3.943330715529e-01
9241 KSP Residual norm 3.943330715529e-01
9242 KSP Residual norm 3.943330715529e-01
9243 KSP Residual norm 3.943330715529e-01
9244 KSP Residual norm 3.943330715529e-01
9245 KSP Residual norm 3.943330715529e-01
9246 KSP Residual norm 3.943330715529e-01
9247 KSP Residual norm 3.943330715529e-01
9248 KSP Residual norm 3.943330715529e-01
9249 KSP Residual norm 3.943330715529e-01
9250 KSP Residual norm 3.943330715529e-01
9251 KSP Residual norm 3.943330715529e-01
9252 KSP Residual norm 3.943330715529e-01
9253 KSP Residual norm 3.943330715529e-01
9254 KSP Residual norm 3.943330715529e-01
9255 KSP Residual norm 3.943330715529e-01
9256 KSP Residual norm 3.943330715529e-01
9257 KSP Residual norm 3.943330715529e-01
9258 KSP Residual norm 3.943330715529e-01
9259 KSP Residual norm 3.943330715529e-01
9260 KSP Residual norm 3.943330715529e-01
9261 KSP Residual norm 3.943330715529e-01
9262 KSP Residual norm 3.943330715529e-01
9263 KSP Residual norm 3.943330715529e-01
9264 KSP Residual norm 3.943330715529e-01
9265 KSP Residual norm 3.943330715529e-01
9266 KSP Residual norm 3.943330715529e-01
9267 KSP Residual norm 3.943330715529e-01
9268 KSP Residual norm 3.943330715529e-01
9269 KSP Residual norm 3.943330715529e-01
9270 KSP Residual norm 3.943330715529e-01
9271 KSP Residual norm 3.943330715529e-01
9272 KSP Residual norm 3.943330715529e-01
9273 KSP Residual norm 3.943330715529e-01
9274 KSP Residual norm 3.943330715529e-01
9275 KSP Residual norm 3.943330715529e-01
9276 KSP Residual norm 3.943330715529e-01
9277 KSP Residual norm 3.943330715529e-01
9278 KSP Residual norm 3.943330715529e-01
9279 KSP Residual norm 3.943330715529e-01
9280 KSP Residual norm 3.943330715529e-01
9281 KSP Residual norm 3.943330715529e-01
9282 KSP Residual norm 3.943330715529e-01
9283 KSP Residual norm 3.943330715529e-01
9284 KSP Residual norm 3.943330715529e-01
9285 KSP Residual norm 3.943330715529e-01
9286 KSP Residual norm 3.943330715529e-01
9287 KSP Residual norm 3.943330715529e-01
9288 KSP Residual norm 3.943330715529e-01
9289 KSP Residual norm 3.943330715529e-01
9290 KSP Residual norm 3.943330715529e-01
9291 KSP Residual norm 3.943330715529e-01
9292 KSP Residual norm 3.943330715529e-01
9293 KSP Residual norm 3.943330715529e-01
9294 KSP Residual norm 3.943330715529e-01
9295 KSP Residual norm 3.943330715529e-01
9296 KSP Residual norm 3.943330715529e-01
9297 KSP Residual norm 3.943330715529e-01
9298 KSP Residual norm 3.943330715529e-01
9299 KSP Residual norm 3.943330715529e-01
9300 KSP Residual norm 3.943330715528e-01
9301 KSP Residual norm 3.943330715528e-01
9302 KSP Residual norm 3.943330715528e-01
9303 KSP Residual norm 3.943330715528e-01
9304 KSP Residual norm 3.943330715528e-01
9305 KSP Residual norm 3.943330715528e-01
9306 KSP Residual norm 3.943330715528e-01
9307 KSP Residual norm 3.943330715528e-01
9308 KSP Residual norm 3.943330715528e-01
9309 KSP Residual norm 3.943330715528e-01
9310 KSP Residual norm 3.943330715528e-01
9311 KSP Residual norm 3.943330715528e-01
9312 KSP Residual norm 3.943330715528e-01
9313 KSP Residual norm 3.943330715528e-01
9314 KSP Residual norm 3.943330715528e-01
9315 KSP Residual norm 3.943330715528e-01
9316 KSP Residual norm 3.943330715528e-01
9317 KSP Residual norm 3.943330715528e-01
9318 KSP Residual norm 3.943330715528e-01
9319 KSP Residual norm 3.943330715528e-01
9320 KSP Residual norm 3.943330715528e-01
9321 KSP Residual norm 3.943330715528e-01
9322 KSP Residual norm 3.943330715528e-01
9323 KSP Residual norm 3.943330715528e-01
9324 KSP Residual norm 3.943330715528e-01
9325 KSP Residual norm 3.943330715528e-01
9326 KSP Residual norm 3.943330715528e-01
9327 KSP Residual norm 3.943330715528e-01
9328 KSP Residual norm 3.943330715528e-01
9329 KSP Residual norm 3.943330715528e-01
9330 KSP Residual norm 3.943330715526e-01
9331 KSP Residual norm 3.943330715526e-01
9332 KSP Residual norm 3.943330715526e-01
9333 KSP Residual norm 3.943330715526e-01
9334 KSP Residual norm 3.943330715526e-01
9335 KSP Residual norm 3.943330715526e-01
9336 KSP Residual norm 3.943330715526e-01
9337 KSP Residual norm 3.943330715526e-01
9338 KSP Residual norm 3.943330715526e-01
9339 KSP Residual norm 3.943330715526e-01
9340 KSP Residual norm 3.943330715526e-01
9341 KSP Residual norm 3.943330715526e-01
9342 KSP Residual norm 3.943330715526e-01
9343 KSP Residual norm 3.943330715526e-01
9344 KSP Residual norm 3.943330715526e-01
9345 KSP Residual norm 3.943330715526e-01
9346 KSP Residual norm 3.943330715526e-01
9347 KSP Residual norm 3.943330715526e-01
9348 KSP Residual norm 3.943330715526e-01
9349 KSP Residual norm 3.943330715526e-01
9350 KSP Residual norm 3.943330715526e-01
9351 KSP Residual norm 3.943330715526e-01
9352 KSP Residual norm 3.943330715526e-01
9353 KSP Residual norm 3.943330715526e-01
9354 KSP Residual norm 3.943330715526e-01
9355 KSP Residual norm 3.943330715526e-01
9356 KSP Residual norm 3.943330715526e-01
9357 KSP Residual norm 3.943330715526e-01
9358 KSP Residual norm 3.943330715526e-01
9359 KSP Residual norm 3.943330715526e-01
9360 KSP Residual norm 3.943330715530e-01
9361 KSP Residual norm 3.943330715530e-01
9362 KSP Residual norm 3.943330715530e-01
9363 KSP Residual norm 3.943330715530e-01
9364 KSP Residual norm 3.943330715530e-01
9365 KSP Residual norm 3.943330715530e-01
9366 KSP Residual norm 3.943330715530e-01
9367 KSP Residual norm 3.943330715530e-01
9368 KSP Residual norm 3.943330715530e-01
9369 KSP Residual norm 3.943330715530e-01
9370 KSP Residual norm 3.943330715530e-01
9371 KSP Residual norm 3.943330715530e-01
9372 KSP Residual norm 3.943330715530e-01
9373 KSP Residual norm 3.943330715530e-01
9374 KSP Residual norm 3.943330715530e-01
9375 KSP Residual norm 3.943330715530e-01
9376 KSP Residual norm 3.943330715530e-01
9377 KSP Residual norm 3.943330715530e-01
9378 KSP Residual norm 3.943330715530e-01
9379 KSP Residual norm 3.943330715530e-01
9380 KSP Residual norm 3.943330715530e-01
9381 KSP Residual norm 3.943330715530e-01
9382 KSP Residual norm 3.943330715530e-01
9383 KSP Residual norm 3.943330715530e-01
9384 KSP Residual norm 3.943330715530e-01
9385 KSP Residual norm 3.943330715530e-01
9386 KSP Residual norm 3.943330715530e-01
9387 KSP Residual norm 3.943330715530e-01
9388 KSP Residual norm 3.943330715530e-01
9389 KSP Residual norm 3.943330715530e-01
9390 KSP Residual norm 3.943330715528e-01
9391 KSP Residual norm 3.943330715528e-01
9392 KSP Residual norm 3.943330715528e-01
9393 KSP Residual norm 3.943330715528e-01
9394 KSP Residual norm 3.943330715528e-01
9395 KSP Residual norm 3.943330715528e-01
9396 KSP Residual norm 3.943330715528e-01
9397 KSP Residual norm 3.943330715528e-01
9398 KSP Residual norm 3.943330715528e-01
9399 KSP Residual norm 3.943330715528e-01
9400 KSP Residual norm 3.943330715528e-01
9401 KSP Residual norm 3.943330715528e-01
9402 KSP Residual norm 3.943330715528e-01
9403 KSP Residual norm 3.943330715528e-01
9404 KSP Residual norm 3.943330715528e-01
9405 KSP Residual norm 3.943330715528e-01
9406 KSP Residual norm 3.943330715528e-01
9407 KSP Residual norm 3.943330715528e-01
9408 KSP Residual norm 3.943330715528e-01
9409 KSP Residual norm 3.943330715528e-01
9410 KSP Residual norm 3.943330715528e-01
9411 KSP Residual norm 3.943330715528e-01
9412 KSP Residual norm 3.943330715528e-01
9413 KSP Residual norm 3.943330715528e-01
9414 KSP Residual norm 3.943330715528e-01
9415 KSP Residual norm 3.943330715528e-01
9416 KSP Residual norm 3.943330715528e-01
9417 KSP Residual norm 3.943330715528e-01
9418 KSP Residual norm 3.943330715528e-01
9419 KSP Residual norm 3.943330715528e-01
9420 KSP Residual norm 3.943330715528e-01
9421 KSP Residual norm 3.943330715528e-01
9422 KSP Residual norm 3.943330715528e-01
9423 KSP Residual norm 3.943330715528e-01
9424 KSP Residual norm 3.943330715528e-01
9425 KSP Residual norm 3.943330715528e-01
9426 KSP Residual norm 3.943330715528e-01
9427 KSP Residual norm 3.943330715528e-01
9428 KSP Residual norm 3.943330715528e-01
9429 KSP Residual norm 3.943330715528e-01
9430 KSP Residual norm 3.943330715528e-01
9431 KSP Residual norm 3.943330715528e-01
9432 KSP Residual norm 3.943330715528e-01
9433 KSP Residual norm 3.943330715528e-01
9434 KSP Residual norm 3.943330715528e-01
9435 KSP Residual norm 3.943330715528e-01
9436 KSP Residual norm 3.943330715528e-01
9437 KSP Residual norm 3.943330715528e-01
9438 KSP Residual norm 3.943330715528e-01
9439 KSP Residual norm 3.943330715528e-01
9440 KSP Residual norm 3.943330715528e-01
9441 KSP Residual norm 3.943330715528e-01
9442 KSP Residual norm 3.943330715528e-01
9443 KSP Residual norm 3.943330715528e-01
9444 KSP Residual norm 3.943330715528e-01
9445 KSP Residual norm 3.943330715528e-01
9446 KSP Residual norm 3.943330715528e-01
9447 KSP Residual norm 3.943330715528e-01
9448 KSP Residual norm 3.943330715528e-01
9449 KSP Residual norm 3.943330715528e-01
9450 KSP Residual norm 3.943330715528e-01
9451 KSP Residual norm 3.943330715528e-01
9452 KSP Residual norm 3.943330715528e-01
9453 KSP Residual norm 3.943330715528e-01
9454 KSP Residual norm 3.943330715528e-01
9455 KSP Residual norm 3.943330715528e-01
9456 KSP Residual norm 3.943330715528e-01
9457 KSP Residual norm 3.943330715528e-01
9458 KSP Residual norm 3.943330715528e-01
9459 KSP Residual norm 3.943330715528e-01
9460 KSP Residual norm 3.943330715528e-01
9461 KSP Residual norm 3.943330715528e-01
9462 KSP Residual norm 3.943330715528e-01
9463 KSP Residual norm 3.943330715528e-01
9464 KSP Residual norm 3.943330715528e-01
9465 KSP Residual norm 3.943330715528e-01
9466 KSP Residual norm 3.943330715528e-01
9467 KSP Residual norm 3.943330715528e-01
9468 KSP Residual norm 3.943330715528e-01
9469 KSP Residual norm 3.943330715528e-01
9470 KSP Residual norm 3.943330715528e-01
9471 KSP Residual norm 3.943330715528e-01
9472 KSP Residual norm 3.943330715528e-01
9473 KSP Residual norm 3.943330715528e-01
9474 KSP Residual norm 3.943330715528e-01
9475 KSP Residual norm 3.943330715528e-01
9476 KSP Residual norm 3.943330715528e-01
9477 KSP Residual norm 3.943330715528e-01
9478 KSP Residual norm 3.943330715528e-01
9479 KSP Residual norm 3.943330715528e-01
9480 KSP Residual norm 3.943330715527e-01
9481 KSP Residual norm 3.943330715527e-01
9482 KSP Residual norm 3.943330715527e-01
9483 KSP Residual norm 3.943330715527e-01
9484 KSP Residual norm 3.943330715527e-01
9485 KSP Residual norm 3.943330715527e-01
9486 KSP Residual norm 3.943330715527e-01
9487 KSP Residual norm 3.943330715527e-01
9488 KSP Residual norm 3.943330715527e-01
9489 KSP Residual norm 3.943330715527e-01
9490 KSP Residual norm 3.943330715527e-01
9491 KSP Residual norm 3.943330715527e-01
9492 KSP Residual norm 3.943330715527e-01
9493 KSP Residual norm 3.943330715527e-01
9494 KSP Residual norm 3.943330715527e-01
9495 KSP Residual norm 3.943330715527e-01
9496 KSP Residual norm 3.943330715527e-01
9497 KSP Residual norm 3.943330715527e-01
9498 KSP Residual norm 3.943330715527e-01
9499 KSP Residual norm 3.943330715527e-01
9500 KSP Residual norm 3.943330715527e-01
9501 KSP Residual norm 3.943330715527e-01
9502 KSP Residual norm 3.943330715527e-01
9503 KSP Residual norm 3.943330715527e-01
9504 KSP Residual norm 3.943330715527e-01
9505 KSP Residual norm 3.943330715527e-01
9506 KSP Residual norm 3.943330715527e-01
9507 KSP Residual norm 3.943330715527e-01
9508 KSP Residual norm 3.943330715527e-01
9509 KSP Residual norm 3.943330715527e-01
9510 KSP Residual norm 3.943330715528e-01
9511 KSP Residual norm 3.943330715528e-01
9512 KSP Residual norm 3.943330715528e-01
9513 KSP Residual norm 3.943330715528e-01
9514 KSP Residual norm 3.943330715528e-01
9515 KSP Residual norm 3.943330715528e-01
9516 KSP Residual norm 3.943330715528e-01
9517 KSP Residual norm 3.943330715528e-01
9518 KSP Residual norm 3.943330715528e-01
9519 KSP Residual norm 3.943330715528e-01
9520 KSP Residual norm 3.943330715528e-01
9521 KSP Residual norm 3.943330715528e-01
9522 KSP Residual norm 3.943330715528e-01
9523 KSP Residual norm 3.943330715528e-01
9524 KSP Residual norm 3.943330715528e-01
9525 KSP Residual norm 3.943330715528e-01
9526 KSP Residual norm 3.943330715528e-01
9527 KSP Residual norm 3.943330715528e-01
9528 KSP Residual norm 3.943330715528e-01
9529 KSP Residual norm 3.943330715528e-01
9530 KSP Residual norm 3.943330715528e-01
9531 KSP Residual norm 3.943330715528e-01
9532 KSP Residual norm 3.943330715528e-01
9533 KSP Residual norm 3.943330715528e-01
9534 KSP Residual norm 3.943330715528e-01
9535 KSP Residual norm 3.943330715528e-01
9536 KSP Residual norm 3.943330715528e-01
9537 KSP Residual norm 3.943330715528e-01
9538 KSP Residual norm 3.943330715528e-01
9539 KSP Residual norm 3.943330715528e-01
9540 KSP Residual norm 3.943330715526e-01
9541 KSP Residual norm 3.943330715526e-01
9542 KSP Residual norm 3.943330715526e-01
9543 KSP Residual norm 3.943330715526e-01
9544 KSP Residual norm 3.943330715526e-01
9545 KSP Residual norm 3.943330715526e-01
9546 KSP Residual norm 3.943330715526e-01
9547 KSP Residual norm 3.943330715526e-01
9548 KSP Residual norm 3.943330715526e-01
9549 KSP Residual norm 3.943330715526e-01
9550 KSP Residual norm 3.943330715526e-01
9551 KSP Residual norm 3.943330715526e-01
9552 KSP Residual norm 3.943330715526e-01
9553 KSP Residual norm 3.943330715526e-01
9554 KSP Residual norm 3.943330715526e-01
9555 KSP Residual norm 3.943330715526e-01
9556 KSP Residual norm 3.943330715526e-01
9557 KSP Residual norm 3.943330715526e-01
9558 KSP Residual norm 3.943330715526e-01
9559 KSP Residual norm 3.943330715526e-01
9560 KSP Residual norm 3.943330715526e-01
9561 KSP Residual norm 3.943330715526e-01
9562 KSP Residual norm 3.943330715526e-01
9563 KSP Residual norm 3.943330715526e-01
9564 KSP Residual norm 3.943330715526e-01
9565 KSP Residual norm 3.943330715526e-01
9566 KSP Residual norm 3.943330715526e-01
9567 KSP Residual norm 3.943330715526e-01
9568 KSP Residual norm 3.943330715526e-01
9569 KSP Residual norm 3.943330715526e-01
9570 KSP Residual norm 3.943330715528e-01
9571 KSP Residual norm 3.943330715528e-01
9572 KSP Residual norm 3.943330715528e-01
9573 KSP Residual norm 3.943330715528e-01
9574 KSP Residual norm 3.943330715528e-01
9575 KSP Residual norm 3.943330715528e-01
9576 KSP Residual norm 3.943330715528e-01
9577 KSP Residual norm 3.943330715528e-01
9578 KSP Residual norm 3.943330715528e-01
9579 KSP Residual norm 3.943330715528e-01
9580 KSP Residual norm 3.943330715528e-01
9581 KSP Residual norm 3.943330715528e-01
9582 KSP Residual norm 3.943330715528e-01
9583 KSP Residual norm 3.943330715528e-01
9584 KSP Residual norm 3.943330715528e-01
9585 KSP Residual norm 3.943330715528e-01
9586 KSP Residual norm 3.943330715528e-01
9587 KSP Residual norm 3.943330715528e-01
9588 KSP Residual norm 3.943330715528e-01
9589 KSP Residual norm 3.943330715528e-01
9590 KSP Residual norm 3.943330715528e-01
9591 KSP Residual norm 3.943330715528e-01
9592 KSP Residual norm 3.943330715528e-01
9593 KSP Residual norm 3.943330715528e-01
9594 KSP Residual norm 3.943330715528e-01
9595 KSP Residual norm 3.943330715528e-01
9596 KSP Residual norm 3.943330715528e-01
9597 KSP Residual norm 3.943330715528e-01
9598 KSP Residual norm 3.943330715528e-01
9599 KSP Residual norm 3.943330715528e-01
9600 KSP Residual norm 3.943330715529e-01
9601 KSP Residual norm 3.943330715529e-01
9602 KSP Residual norm 3.943330715529e-01
9603 KSP Residual norm 3.943330715529e-01
9604 KSP Residual norm 3.943330715529e-01
9605 KSP Residual norm 3.943330715529e-01
9606 KSP Residual norm 3.943330715529e-01
9607 KSP Residual norm 3.943330715529e-01
9608 KSP Residual norm 3.943330715529e-01
9609 KSP Residual norm 3.943330715529e-01
9610 KSP Residual norm 3.943330715529e-01
9611 KSP Residual norm 3.943330715529e-01
9612 KSP Residual norm 3.943330715529e-01
9613 KSP Residual norm 3.943330715529e-01
9614 KSP Residual norm 3.943330715529e-01
9615 KSP Residual norm 3.943330715529e-01
9616 KSP Residual norm 3.943330715529e-01
9617 KSP Residual norm 3.943330715529e-01
9618 KSP Residual norm 3.943330715529e-01
9619 KSP Residual norm 3.943330715529e-01
9620 KSP Residual norm 3.943330715529e-01
9621 KSP Residual norm 3.943330715529e-01
9622 KSP Residual norm 3.943330715529e-01
9623 KSP Residual norm 3.943330715529e-01
9624 KSP Residual norm 3.943330715529e-01
9625 KSP Residual norm 3.943330715529e-01
9626 KSP Residual norm 3.943330715529e-01
9627 KSP Residual norm 3.943330715529e-01
9628 KSP Residual norm 3.943330715529e-01
9629 KSP Residual norm 3.943330715529e-01
9630 KSP Residual norm 3.943330715529e-01
9631 KSP Residual norm 3.943330715529e-01
9632 KSP Residual norm 3.943330715529e-01
9633 KSP Residual norm 3.943330715529e-01
9634 KSP Residual norm 3.943330715529e-01
9635 KSP Residual norm 3.943330715529e-01
9636 KSP Residual norm 3.943330715529e-01
9637 KSP Residual norm 3.943330715529e-01
9638 KSP Residual norm 3.943330715529e-01
9639 KSP Residual norm 3.943330715529e-01
9640 KSP Residual norm 3.943330715529e-01
9641 KSP Residual norm 3.943330715529e-01
9642 KSP Residual norm 3.943330715529e-01
9643 KSP Residual norm 3.943330715529e-01
9644 KSP Residual norm 3.943330715529e-01
9645 KSP Residual norm 3.943330715529e-01
9646 KSP Residual norm 3.943330715529e-01
9647 KSP Residual norm 3.943330715529e-01
9648 KSP Residual norm 3.943330715529e-01
9649 KSP Residual norm 3.943330715529e-01
9650 KSP Residual norm 3.943330715529e-01
9651 KSP Residual norm 3.943330715529e-01
9652 KSP Residual norm 3.943330715529e-01
9653 KSP Residual norm 3.943330715529e-01
9654 KSP Residual norm 3.943330715529e-01
9655 KSP Residual norm 3.943330715529e-01
9656 KSP Residual norm 3.943330715529e-01
9657 KSP Residual norm 3.943330715529e-01
9658 KSP Residual norm 3.943330715529e-01
9659 KSP Residual norm 3.943330715529e-01
9660 KSP Residual norm 3.943330715525e-01
9661 KSP Residual norm 3.943330715525e-01
9662 KSP Residual norm 3.943330715525e-01
9663 KSP Residual norm 3.943330715525e-01
9664 KSP Residual norm 3.943330715525e-01
9665 KSP Residual norm 3.943330715525e-01
9666 KSP Residual norm 3.943330715525e-01
9667 KSP Residual norm 3.943330715525e-01
9668 KSP Residual norm 3.943330715525e-01
9669 KSP Residual norm 3.943330715525e-01
9670 KSP Residual norm 3.943330715525e-01
9671 KSP Residual norm 3.943330715525e-01
9672 KSP Residual norm 3.943330715525e-01
9673 KSP Residual norm 3.943330715525e-01
9674 KSP Residual norm 3.943330715525e-01
9675 KSP Residual norm 3.943330715525e-01
9676 KSP Residual norm 3.943330715525e-01
9677 KSP Residual norm 3.943330715525e-01
9678 KSP Residual norm 3.943330715525e-01
9679 KSP Residual norm 3.943330715525e-01
9680 KSP Residual norm 3.943330715525e-01
9681 KSP Residual norm 3.943330715525e-01
9682 KSP Residual norm 3.943330715525e-01
9683 KSP Residual norm 3.943330715525e-01
9684 KSP Residual norm 3.943330715525e-01
9685 KSP Residual norm 3.943330715525e-01
9686 KSP Residual norm 3.943330715525e-01
9687 KSP Residual norm 3.943330715525e-01
9688 KSP Residual norm 3.943330715525e-01
9689 KSP Residual norm 3.943330715525e-01
9690 KSP Residual norm 3.943330715528e-01
9691 KSP Residual norm 3.943330715528e-01
9692 KSP Residual norm 3.943330715528e-01
9693 KSP Residual norm 3.943330715528e-01
9694 KSP Residual norm 3.943330715528e-01
9695 KSP Residual norm 3.943330715528e-01
9696 KSP Residual norm 3.943330715528e-01
9697 KSP Residual norm 3.943330715528e-01
9698 KSP Residual norm 3.943330715528e-01
9699 KSP Residual norm 3.943330715528e-01
9700 KSP Residual norm 3.943330715528e-01
9701 KSP Residual norm 3.943330715528e-01
9702 KSP Residual norm 3.943330715528e-01
9703 KSP Residual norm 3.943330715528e-01
9704 KSP Residual norm 3.943330715528e-01
9705 KSP Residual norm 3.943330715528e-01
9706 KSP Residual norm 3.943330715528e-01
9707 KSP Residual norm 3.943330715528e-01
9708 KSP Residual norm 3.943330715528e-01
9709 KSP Residual norm 3.943330715528e-01
9710 KSP Residual norm 3.943330715528e-01
9711 KSP Residual norm 3.943330715528e-01
9712 KSP Residual norm 3.943330715528e-01
9713 KSP Residual norm 3.943330715528e-01
9714 KSP Residual norm 3.943330715528e-01
9715 KSP Residual norm 3.943330715528e-01
9716 KSP Residual norm 3.943330715528e-01
9717 KSP Residual norm 3.943330715528e-01
9718 KSP Residual norm 3.943330715528e-01
9719 KSP Residual norm 3.943330715528e-01
9720 KSP Residual norm 3.943330715527e-01
9721 KSP Residual norm 3.943330715527e-01
9722 KSP Residual norm 3.943330715527e-01
9723 KSP Residual norm 3.943330715527e-01
9724 KSP Residual norm 3.943330715527e-01
9725 KSP Residual norm 3.943330715527e-01
9726 KSP Residual norm 3.943330715527e-01
9727 KSP Residual norm 3.943330715527e-01
9728 KSP Residual norm 3.943330715527e-01
9729 KSP Residual norm 3.943330715527e-01
9730 KSP Residual norm 3.943330715527e-01
9731 KSP Residual norm 3.943330715527e-01
9732 KSP Residual norm 3.943330715527e-01
9733 KSP Residual norm 3.943330715527e-01
9734 KSP Residual norm 3.943330715527e-01
9735 KSP Residual norm 3.943330715527e-01
9736 KSP Residual norm 3.943330715527e-01
9737 KSP Residual norm 3.943330715527e-01
9738 KSP Residual norm 3.943330715527e-01
9739 KSP Residual norm 3.943330715527e-01
9740 KSP Residual norm 3.943330715527e-01
9741 KSP Residual norm 3.943330715527e-01
9742 KSP Residual norm 3.943330715527e-01
9743 KSP Residual norm 3.943330715527e-01
9744 KSP Residual norm 3.943330715527e-01
9745 KSP Residual norm 3.943330715527e-01
9746 KSP Residual norm 3.943330715527e-01
9747 KSP Residual norm 3.943330715527e-01
9748 KSP Residual norm 3.943330715527e-01
9749 KSP Residual norm 3.943330715527e-01
9750 KSP Residual norm 3.943330715529e-01
9751 KSP Residual norm 3.943330715529e-01
9752 KSP Residual norm 3.943330715529e-01
9753 KSP Residual norm 3.943330715529e-01
9754 KSP Residual norm 3.943330715529e-01
9755 KSP Residual norm 3.943330715529e-01
9756 KSP Residual norm 3.943330715529e-01
9757 KSP Residual norm 3.943330715529e-01
9758 KSP Residual norm 3.943330715529e-01
9759 KSP Residual norm 3.943330715529e-01
9760 KSP Residual norm 3.943330715529e-01
9761 KSP Residual norm 3.943330715529e-01
9762 KSP Residual norm 3.943330715529e-01
9763 KSP Residual norm 3.943330715529e-01
9764 KSP Residual norm 3.943330715529e-01
9765 KSP Residual norm 3.943330715529e-01
9766 KSP Residual norm 3.943330715529e-01
9767 KSP Residual norm 3.943330715529e-01
9768 KSP Residual norm 3.943330715529e-01
9769 KSP Residual norm 3.943330715529e-01
9770 KSP Residual norm 3.943330715529e-01
9771 KSP Residual norm 3.943330715529e-01
9772 KSP Residual norm 3.943330715529e-01
9773 KSP Residual norm 3.943330715529e-01
9774 KSP Residual norm 3.943330715529e-01
9775 KSP Residual norm 3.943330715529e-01
9776 KSP Residual norm 3.943330715529e-01
9777 KSP Residual norm 3.943330715529e-01
9778 KSP Residual norm 3.943330715529e-01
9779 KSP Residual norm 3.943330715529e-01
9780 KSP Residual norm 3.943330715528e-01
9781 KSP Residual norm 3.943330715528e-01
9782 KSP Residual norm 3.943330715528e-01
9783 KSP Residual norm 3.943330715528e-01
9784 KSP Residual norm 3.943330715528e-01
9785 KSP Residual norm 3.943330715528e-01
9786 KSP Residual norm 3.943330715528e-01
9787 KSP Residual norm 3.943330715528e-01
9788 KSP Residual norm 3.943330715528e-01
9789 KSP Residual norm 3.943330715528e-01
9790 KSP Residual norm 3.943330715528e-01
9791 KSP Residual norm 3.943330715528e-01
9792 KSP Residual norm 3.943330715528e-01
9793 KSP Residual norm 3.943330715528e-01
9794 KSP Residual norm 3.943330715528e-01
9795 KSP Residual norm 3.943330715528e-01
9796 KSP Residual norm 3.943330715528e-01
9797 KSP Residual norm 3.943330715528e-01
9798 KSP Residual norm 3.943330715528e-01
9799 KSP Residual norm 3.943330715528e-01
9800 KSP Residual norm 3.943330715528e-01
9801 KSP Residual norm 3.943330715528e-01
9802 KSP Residual norm 3.943330715528e-01
9803 KSP Residual norm 3.943330715528e-01
9804 KSP Residual norm 3.943330715528e-01
9805 KSP Residual norm 3.943330715528e-01
9806 KSP Residual norm 3.943330715528e-01
9807 KSP Residual norm 3.943330715528e-01
9808 KSP Residual norm 3.943330715528e-01
9809 KSP Residual norm 3.943330715528e-01
9810 KSP Residual norm 3.943330715528e-01
9811 KSP Residual norm 3.943330715528e-01
9812 KSP Residual norm 3.943330715528e-01
9813 KSP Residual norm 3.943330715528e-01
9814 KSP Residual norm 3.943330715528e-01
9815 KSP Residual norm 3.943330715528e-01
9816 KSP Residual norm 3.943330715528e-01
9817 KSP Residual norm 3.943330715528e-01
9818 KSP Residual norm 3.943330715528e-01
9819 KSP Residual norm 3.943330715528e-01
9820 KSP Residual norm 3.943330715528e-01
9821 KSP Residual norm 3.943330715528e-01
9822 KSP Residual norm 3.943330715528e-01
9823 KSP Residual norm 3.943330715528e-01
9824 KSP Residual norm 3.943330715528e-01
9825 KSP Residual norm 3.943330715528e-01
9826 KSP Residual norm 3.943330715528e-01
9827 KSP Residual norm 3.943330715528e-01
9828 KSP Residual norm 3.943330715528e-01
9829 KSP Residual norm 3.943330715528e-01
9830 KSP Residual norm 3.943330715528e-01
9831 KSP Residual norm 3.943330715528e-01
9832 KSP Residual norm 3.943330715528e-01
9833 KSP Residual norm 3.943330715528e-01
9834 KSP Residual norm 3.943330715528e-01
9835 KSP Residual norm 3.943330715528e-01
9836 KSP Residual norm 3.943330715528e-01
9837 KSP Residual norm 3.943330715528e-01
9838 KSP Residual norm 3.943330715528e-01
9839 KSP Residual norm 3.943330715528e-01
9840 KSP Residual norm 3.943330715529e-01
9841 KSP Residual norm 3.943330715529e-01
9842 KSP Residual norm 3.943330715529e-01
9843 KSP Residual norm 3.943330715529e-01
9844 KSP Residual norm 3.943330715529e-01
9845 KSP Residual norm 3.943330715529e-01
9846 KSP Residual norm 3.943330715529e-01
9847 KSP Residual norm 3.943330715529e-01
9848 KSP Residual norm 3.943330715529e-01
9849 KSP Residual norm 3.943330715529e-01
9850 KSP Residual norm 3.943330715529e-01
9851 KSP Residual norm 3.943330715529e-01
9852 KSP Residual norm 3.943330715529e-01
9853 KSP Residual norm 3.943330715529e-01
9854 KSP Residual norm 3.943330715529e-01
9855 KSP Residual norm 3.943330715529e-01
9856 KSP Residual norm 3.943330715529e-01
9857 KSP Residual norm 3.943330715529e-01
9858 KSP Residual norm 3.943330715529e-01
9859 KSP Residual norm 3.943330715529e-01
9860 KSP Residual norm 3.943330715529e-01
9861 KSP Residual norm 3.943330715529e-01
9862 KSP Residual norm 3.943330715529e-01
9863 KSP Residual norm 3.943330715529e-01
9864 KSP Residual norm 3.943330715529e-01
9865 KSP Residual norm 3.943330715529e-01
9866 KSP Residual norm 3.943330715529e-01
9867 KSP Residual norm 3.943330715529e-01
9868 KSP Residual norm 3.943330715529e-01
9869 KSP Residual norm 3.943330715529e-01
9870 KSP Residual norm 3.943330715529e-01
9871 KSP Residual norm 3.943330715529e-01
9872 KSP Residual norm 3.943330715529e-01
9873 KSP Residual norm 3.943330715529e-01
9874 KSP Residual norm 3.943330715529e-01
9875 KSP Residual norm 3.943330715529e-01
9876 KSP Residual norm 3.943330715529e-01
9877 KSP Residual norm 3.943330715529e-01
9878 KSP Residual norm 3.943330715529e-01
9879 KSP Residual norm 3.943330715529e-01
9880 KSP Residual norm 3.943330715529e-01
9881 KSP Residual norm 3.943330715529e-01
9882 KSP Residual norm 3.943330715529e-01
9883 KSP Residual norm 3.943330715529e-01
9884 KSP Residual norm 3.943330715529e-01
9885 KSP Residual norm 3.943330715529e-01
9886 KSP Residual norm 3.943330715529e-01
9887 KSP Residual norm 3.943330715529e-01
9888 KSP Residual norm 3.943330715529e-01
9889 KSP Residual norm 3.943330715529e-01
9890 KSP Residual norm 3.943330715529e-01
9891 KSP Residual norm 3.943330715529e-01
9892 KSP Residual norm 3.943330715529e-01
9893 KSP Residual norm 3.943330715529e-01
9894 KSP Residual norm 3.943330715529e-01
9895 KSP Residual norm 3.943330715529e-01
9896 KSP Residual norm 3.943330715529e-01
9897 KSP Residual norm 3.943330715529e-01
9898 KSP Residual norm 3.943330715529e-01
9899 KSP Residual norm 3.943330715529e-01
9900 KSP Residual norm 3.943330715532e-01
9901 KSP Residual norm 3.943330715532e-01
9902 KSP Residual norm 3.943330715532e-01
9903 KSP Residual norm 3.943330715532e-01
9904 KSP Residual norm 3.943330715532e-01
9905 KSP Residual norm 3.943330715532e-01
9906 KSP Residual norm 3.943330715532e-01
9907 KSP Residual norm 3.943330715532e-01
9908 KSP Residual norm 3.943330715532e-01
9909 KSP Residual norm 3.943330715532e-01
9910 KSP Residual norm 3.943330715532e-01
9911 KSP Residual norm 3.943330715532e-01
9912 KSP Residual norm 3.943330715532e-01
9913 KSP Residual norm 3.943330715532e-01
9914 KSP Residual norm 3.943330715532e-01
9915 KSP Residual norm 3.943330715532e-01
9916 KSP Residual norm 3.943330715532e-01
9917 KSP Residual norm 3.943330715532e-01
9918 KSP Residual norm 3.943330715532e-01
9919 KSP Residual norm 3.943330715532e-01
9920 KSP Residual norm 3.943330715532e-01
9921 KSP Residual norm 3.943330715532e-01
9922 KSP Residual norm 3.943330715532e-01
9923 KSP Residual norm 3.943330715532e-01
9924 KSP Residual norm 3.943330715532e-01
9925 KSP Residual norm 3.943330715532e-01
9926 KSP Residual norm 3.943330715532e-01
9927 KSP Residual norm 3.943330715532e-01
9928 KSP Residual norm 3.943330715532e-01
9929 KSP Residual norm 3.943330715532e-01
9930 KSP Residual norm 3.943330715531e-01
9931 KSP Residual norm 3.943330715531e-01
9932 KSP Residual norm 3.943330715531e-01
9933 KSP Residual norm 3.943330715531e-01
9934 KSP Residual norm 3.943330715531e-01
9935 KSP Residual norm 3.943330715531e-01
9936 KSP Residual norm 3.943330715531e-01
9937 KSP Residual norm 3.943330715531e-01
9938 KSP Residual norm 3.943330715531e-01
9939 KSP Residual norm 3.943330715531e-01
9940 KSP Residual norm 3.943330715531e-01
9941 KSP Residual norm 3.943330715531e-01
9942 KSP Residual norm 3.943330715531e-01
9943 KSP Residual norm 3.943330715531e-01
9944 KSP Residual norm 3.943330715531e-01
9945 KSP Residual norm 3.943330715531e-01
9946 KSP Residual norm 3.943330715531e-01
9947 KSP Residual norm 3.943330715531e-01
9948 KSP Residual norm 3.943330715531e-01
9949 KSP Residual norm 3.943330715531e-01
9950 KSP Residual norm 3.943330715531e-01
9951 KSP Residual norm 3.943330715531e-01
9952 KSP Residual norm 3.943330715531e-01
9953 KSP Residual norm 3.943330715531e-01
9954 KSP Residual norm 3.943330715531e-01
9955 KSP Residual norm 3.943330715531e-01
9956 KSP Residual norm 3.943330715531e-01
9957 KSP Residual norm 3.943330715531e-01
9958 KSP Residual norm 3.943330715531e-01
9959 KSP Residual norm 3.943330715531e-01
9960 KSP Residual norm 3.943330715532e-01
9961 KSP Residual norm 3.943330715532e-01
9962 KSP Residual norm 3.943330715532e-01
9963 KSP Residual norm 3.943330715532e-01
9964 KSP Residual norm 3.943330715532e-01
9965 KSP Residual norm 3.943330715532e-01
9966 KSP Residual norm 3.943330715532e-01
9967 KSP Residual norm 3.943330715532e-01
9968 KSP Residual norm 3.943330715532e-01
9969 KSP Residual norm 3.943330715532e-01
9970 KSP Residual norm 3.943330715532e-01
9971 KSP Residual norm 3.943330715532e-01
9972 KSP Residual norm 3.943330715532e-01
9973 KSP Residual norm 3.943330715532e-01
9974 KSP Residual norm 3.943330715532e-01
9975 KSP Residual norm 3.943330715532e-01
9976 KSP Residual norm 3.943330715532e-01
9977 KSP Residual norm 3.943330715532e-01
9978 KSP Residual norm 3.943330715532e-01
9979 KSP Residual norm 3.943330715532e-01
9980 KSP Residual norm 3.943330715532e-01
9981 KSP Residual norm 3.943330715532e-01
9982 KSP Residual norm 3.943330715532e-01
9983 KSP Residual norm 3.943330715532e-01
9984 KSP Residual norm 3.943330715532e-01
9985 KSP Residual norm 3.943330715532e-01
9986 KSP Residual norm 3.943330715532e-01
9987 KSP Residual norm 3.943330715532e-01
9988 KSP Residual norm 3.943330715532e-01
9989 KSP Residual norm 3.943330715532e-01
9990 KSP Residual norm 3.943330715532e-01
9991 KSP Residual norm 3.943330715532e-01
9992 KSP Residual norm 3.943330715532e-01
9993 KSP Residual norm 3.943330715532e-01
9994 KSP Residual norm 3.943330715532e-01
9995 KSP Residual norm 3.943330715532e-01
9996 KSP Residual norm 3.943330715532e-01
9997 KSP Residual norm 3.943330715532e-01
9998 KSP Residual norm 3.943330715532e-01
9999 KSP Residual norm 3.943330715532e-01
10000 KSP Residual norm 3.943330715532e-01
KSP Object: 1 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=5, initial guess is zero
tolerances: relative=1e-08, absolute=1e-16, divergence=1e+16
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: fieldsplit
FieldSplit with Schur preconditioner, factorization FULL
Preconditioner for the Schur complement formed from A11
Split info:
Split number 0 Defined by IS
Split number 1 Defined by IS
KSP solver for A00 block
KSP Object: (fieldsplit_0_) 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
PC Object: (fieldsplit_0_) 1 MPI processes
type: lu
LU: out-of-place factorization
tolerance for zero pivot 2.22045e-14
matrix ordering: nd
factor fill ratio given 5, needed 1
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=2000, cols=2000
package used to perform factorization: petsc
total: nonzeros=40000, allocated nonzeros=40000
total number of mallocs used during MatSetValues calls =0
using I-node routines: found 400 nodes, limit used is 5
linear system matrix = precond matrix:
Mat Object: (fieldsplit_0_) 1 MPI processes
type: seqaij
KSP solver for S = A11 - A10 inv(A00) A01
KSP Object: (fieldsplit_1_) 1 MPI processes
type: preonly
PC Object: (fieldsplit_1_) 1 MPI processes
type: lu
matrix ordering: nd
factor fill ratio given 5, needed 2.62994
type: seqaij
rows=330, cols=330
total: nonzeros=20098, allocated nonzeros=20098
using I-node routines: found 106 nodes, limit used is 5
linear system matrix followed by preconditioner matrix:
Mat Object: (fieldsplit_1_) 1 MPI processes
type: schurcomplement
rows=330, cols=330
Schur complement A11 - A10 inv(A00) A01
A11
type: seqaij
rows=330, cols=330
total: nonzeros=7642, allocated nonzeros=7642
using I-node routines: found 121 nodes, limit used is 5
A10
type: seqaij
rows=330, cols=2000
total: nonzeros=22800, allocated nonzeros=22800
KSP of A00
type: preonly
type: lu
matrix ordering: nd
type: seqaij
type: seqaij
A01
type: seqaij
rows=2000, cols=330
type: seqaij
rows=330, cols=330
type: seqaij
rows=2330, cols=2330
total: nonzeros=93242, allocated nonzeros=93242
using I-node routines: found 521 nodes, limit used is 5
