[petsc-users] Using PETSC for a CFD solver
Mohammad Bahaa m.bahaa.eldein at gmail.com
Mon Mar 10 09:36:47 CDT 2014
I'm pretty new to PETSC, so pardon me if the question is primitive somehow,
I used *METIS *to partition my grid (represented by a system of linear
equations Ax=b) to a number of sub-grids, say 4 sub-grids, with 4 different
systems of linear Equations (A1x1=b1, A2x2=b2, ...), can anyone post an
example showing how to solve these "n" sub-systems simultaneously, I've
tried the following program, but it's not working correctly, as when I
use *MatGetOwnershipRange
*in each process I find that A1 ownership range is 1/4 the matrix size for
the first process, while it should be all of it.
subroutine test_drive_2
      implicit none
!                    Include files
!  This program uses CPP for preprocessing, as indicated by the use of
!  PETSc include files in the directory petsc/include/finclude.  This
!  convention enables use of the CPP preprocessor, which allows the use
!  of the #include statements that define PETSc objects and variables.
!  Use of the conventional Fortran include statements is also supported
!  In this case, the PETsc include files are located in the directory
!  petsc/include/foldinclude.
!  Since one must be very careful to include each file no more than once
!  in a Fortran routine, application programmers must exlicitly list
!  each file needed for the various PETSc components within their
!  program (unlike the C/C++ interface).
!  See the Fortran section of the PETSc users manual for details.
!  The following include statements are required for KSP Fortran programs:
!     petscsys.h    - base PETSc routines
!     petscvec.h    - vectors
!     petscmat.h    - matrices
!     petscksp.h    - Krylov subspace methods
!     petscpc.h     - preconditioners
!  Other include statements may be needed if using additional PETSc
!  routines in a Fortran program, e.g.,
!     petscviewer.h - viewers
!     petscis.h     - index sets
! main includes
#include <finclude/petscsys.h>
#include <finclude/petscvec.h>
#include <finclude/petscmat.h>
#include <finclude/petscksp.h>
#include <finclude/petscpc.h>
! includes for F90 specific functions
#include <finclude/petscvec.h90>
#include <finclude/petscmat.h90>
#include <finclude/petscksp.h90>
#include <finclude/petscpc.h90>
!                   Variable declarations
!  Variables:
!     ksp      - linear solver context
!     ksp      - Krylov subspace method context
!     pc       - preconditioner context
!     x, b, u  - approx solution, right-hand-side, exact solution vectors
!     A        - matrix that defines linear system
!     its      - iterations for convergence
!     norm     - norm of error in solution
      Vec              x,b,u
      Mat              A
      KSP              ksp
      PC               pc
      PetscReal        norm,tol
      PetscErrorCode   ierr
      PetscInt         i,n,col(3),its,i1,i2,i3
      PetscBool        flg
      PetscMPIInt      size,rank
      PetscScalar      none,one,value(3), testa
      PetscScalar, pointer :: xx_v(:)
      PetscScalar, allocatable, dimension(:) :: myx
      PetscOffset i_x
      !real(4) :: myx(10), myu(10), myb(10)
      !real(8), allocatable, dimension(:) :: myx
      integer :: ic, nc, ncmax, nz, ncols, j
      integer :: fileunit, ione
      integer, allocatable, dimension(:,:) :: neighb, cols
      integer, allocatable, dimension(:)   :: nnz, vcols
      real(8), allocatable, dimension(:,:) :: acoef, vals
      real(8), allocatable, dimension(:)   :: ap, su, vvals
      character (len=100)                  :: rankstring, filename, folder
      real(8) :: atol, rtol, dtol
      integer :: mxit, istart, iend
      real(8) :: rvar, minvalx
      call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
!                 Load the linear system
      !mbs read data file for experimentation
      !if(rank.EQ.0) read(*,'(A)'), folder
      folder = '60'
      write(rankstring,'(I)'), rank
      filename = trim(adjustl(folder)) // '/linearsys_' //
trim(adjustl(rankstring)) // '.txt'
      fileunit = 9000 + rank
      open(unit=fileunit, file=trim(filename))
      read(fileunit,*), ncmax
      read(fileunit,*),
      allocate( neighb(6,ncmax), acoef(6,ncmax), ap(ncmax), su(ncmax) )
      allocate( nnz(0:ncmax-1), cols(6,0:ncmax-1), vals(6,0:ncmax-1) )
      allocate( vcols(0:ncmax-1), vvals(0:ncmax-1) )
      !allocate( xx_v(ncmax), myx(ncmax) )
      !allocate( xx_v(0:ncmax), myx(0:ncmax) )
      allocate( myx(ncmax) )
      do i=1,nc
          read(fileunit,'(I)'), ic
          read(fileunit,'(6I)'), ( neighb(j,ic), j=1,6 )
          read(fileunit,'(6F)'), ( acoef(j,ic), j=1,6 )
          read(fileunit,'(2F)'), ap(ic), su(ic)
          read(fileunit,*),
      enddo
      close(fileunit)
      nz = 7
      nnz = 0
      do ic=0,nc-1
          ! values for coefficient matrix (diagonal)
          nnz(ic) = nnz(ic) + 1
          cols(nnz(ic),ic) = ic
          vals(nnz(ic),ic) = ap(ic+1)
          ! values for coefficient matrix (off diagonal)
          do j=1,6
              if(neighb(j,ic+1).GT.0)then
                  cols(nnz(ic),ic) = neighb(j,ic+1) - 1
                  vals(nnz(ic),ic) = acoef(j,ic+1)
              endif
          enddo
          ! values for RHS
          vcols(ic) = ic
          vvals(ic) = su(ic+1)
      enddo
      ! add dummy values for remaining rows (if any)
      if(ncmax.GT.nc)then
          do ic=nc,ncmax-1
              ! coeff matrix
              nnz(ic) = 1
              vals(nnz(ic),ic) = 1.0
              ! RHS
              vcols(ic) = ic
              vvals(ic) = 0.0
          enddo
      endif
      print*, 'rank', rank, 'says nc is', nc
!                 Beginning of program
      !if (size .ne. 1) then
      !   call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
      !   if (rank .eq. 0) then
      !      write(6,*) 'This is a uniprocessor example only!'
      !   endif
      !   SETERRQ(PETSC_COMM_WORLD,1,' ',ierr)
      !endif
      ione = 1
      none = -1.0
      one  = 1.0
      n    = ncmax
      i1 = 1
      i2 = 2
      i3 = 3
      call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-n',n,flg,ierr)
!         Compute the matrix and right-hand-side vector that define
!         the linear system, Ax = b.
!  Create matrix.  When using MatCreate(), the matrix format can
!  be specified at runtime.
      call MatCreate(PETSC_COMM_WORLD,A,ierr)
      !call MatCreateSeqAij(PETSC_COMM_SELF,A,ierr)
      call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,n,n,ierr)
      call MatSetFromOptions(A,ierr)
      call MatSetUp(A,ierr)
      call MatGetOwnershipRange(A,istart,iend,ierr)
      print*, rank, istart, iend
!  Assemble matrix.
!   - Note that MatSetValues() uses 0-based row and column numbers
!     in Fortran as well as in C (as set here in the array "col").
  !    value(1) = -1.0
  !    value(2) = 2.0
  !    value(3) = -1.0
  !    do 50 i=1,n-2
  !       col(1) = i-1
  !       col(2) = i
  !       col(3) = i+1
  !       call MatSetValues(A,i1,i,i3,col,value,INSERT_VALUES,ierr)
  !50  continue
  !    i = n - 1
  !    col(1) = n - 2
  !    col(2) = n - 1
  !    call MatSetValues(A,i1,i,i2,col,value,INSERT_VALUES,ierr)
  !    i = 0
  !    col(1) = 0
  !    col(2) = 1
  !    value(1) = 2.0
  !    value(2) = -1.0
  !    call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
  !    call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
       do ic=0,ncmax-1
           call
MatSetValues(A,ione,ic,nnz(ic),cols(1:nnz(ic),ic),vals(1:nnz(ic),ic),INSERT_VALUES,ierr)
       enddo
!  Create vectors.  Note that we form 1 vector from scratch and
!  then duplicate as needed.
      call VecCreate(PETSC_COMM_WORLD,x,ierr)
      !call VecCreateSeq(PETSC_COMM_SELF,x,ierr)
      call VecSetSizes(x,PETSC_DECIDE,n,ierr)
      call VecSetFromOptions(x,ierr)
      call VecDuplicate(x,b,ierr)
      call VecDuplicate(x,u,ierr)
!  Set exact solution; then compute right-hand-side vector.
      call VecSet(u,one,ierr)
      call VecSet(x,one*10,ierr)
      !call MatMult(A,u,b,ierr)
      ! set source terms vector
      call VecSetValues(b,ncmax,vcols,vvals,INSERT_VALUES,ierr)
      call VecAssemblyBegin(b,ierr)
      call VecAssemblyEnd(b,ierr)
!          Create the linear solver and set various options
!  Create linear solver context
      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
!  Set operators. Here the matrix that defines the linear system
!  also serves as the preconditioning matrix.
      call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
!  Set linear solver defaults for this problem (optional).
!   - By extracting the KSP and PC contexts from the KSP context,
!     we can then directly directly call any KSP and PC routines
!     to set various options.
!   - The following four statements are optional; all of these
!     parameters could alternatively be specified at runtime via
!     KSPSetFromOptions();
      call KSPGetPC(ksp,pc,ierr)
      call PCSetType(pc,PCJACOBI,ierr)
      atol = 1.d-12
      rtol = 1.d-12
      dtol = 1.d10
      mxit = 100
!      call KSPSetTolerances(ksp,tol,PETSC_DEFAULT_DOUBLE_PRECISION,     &
!     &     PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,ierr)
       call KSPSetTolerances(ksp,atol,rtol,dtol,mxit,ierr)
!  Set runtime options, e.g.,
!      -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
!  These options will override those specified above as long as
!  KSPSetFromOptions() is called _after_ any other customization
!  routines.
      call KSPSetFromOptions(ksp,ierr)
!                      Solve the linear system
      call KSPSetType(ksp,KSPBCGS,ierr)
      call KSPSolve(ksp,b,x,ierr)
!  View solver info; we could instead use the option -ksp_view
      !call KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD,ierr)
!                      Check solution and clean up
      call VecGetArrayF90(x,xx_v,ierr)
      !xx_v = 5.1d0
      !do ic=1,ncmax
      !    myx(ic) = xx_v(ic)
      !enddo
      myx = xx_v
      !call VecGetArray(x,myx,i_x,ierr)
      !value = x_array(i_x + 1)
      !call VecRestoreArray(x,myx,i_x,ierr)
      !rvar = xx_v(3)
      call VecRestoreArrayF90(x,xx_v,ierr)
      !call VecGetArrayF90(b,xx_v,ierr)
      !myb = xx_v
      !call VecRestoreArrayF90(x,xx_v,ierr)
      !call VecView(x,PETSC_VIEWER_STDOUT_SELF)
      !call MatView(a,PETSC_VIEWER_STDOUT_SELF)
      !print*, 'rank', rank, 'says max x is', maxval(myx)
     ! print*, xx_v
!  Check the error
      call MatMult(A,x,u,ierr)
      call VecAXPY(u,none,b,ierr)
      call VecNorm(u,NORM_2,norm,ierr)
      call KSPGetIterationNumber(ksp,its,ierr)
      if (norm .gt. 1.e-12) then
        write(6,100) norm,its
      else
        write(6,200) its
      endif
 100  format('Norm of error = ',e11.4,',  Iterations = ',i5)
 200  format('Norm of error < 1.e-12,Iterations = ',i5)
      !call KSPGetSolution(ksp,myx)
      minvalx = 1.0e15
      do ic=1,ncmax
          if(myx(ic).LT.minvalx) minvalx = myx(ic)
      enddo
      !write(*,300), rank, maxval(myx(1:nc)), minvalx
      if(rank.EQ.0) print*, myx
300 format('Rank ', I1, ' says max/min x are: ', F12.4, ' / ', F12.4)
!  Free work space.  All PETSc objects should be destroyed when they
!  are no longer needed.
      call VecDestroy(x,ierr)
      call VecDestroy(u,ierr)
      call VecDestroy(b,ierr)
      call MatDestroy(A,ierr)
      call KSPDestroy(ksp,ierr)
      call PetscFinalize(ierr)
      continue
end
Mohamamd Bahaa ElDin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140310/6f11b8d3/attachment-0001.html>
