[petsc-users] having issues with nullspace
Mohammad Mirzadeh
mirzadeh at gmail.com
Thu Mar 6 17:24:33 CST 2014
Hi guys,
I have a discretization of Poisson equation with Neumann bc for embedded
boundary grids in such a way that that nullspace is not the usual constant
vector. Instead the nullspace is constant in the domain of interest and
zero elsewhere.
I compute this nullspace myself and have checked it against MATLAB by
dumping the matrix and computing the nullspace explicitly using null
function -- they match and there is only this single vector. Then I take
this calculated vector and subtract it off the matrix and rhs.
However, I am having convergence issues. For instance this is the output of
ksp_monitor_true_residual for one particular run:
0 KSP preconditioned resid norm 3.033840960250e+02 true resid norm
2.332886580745e-01 ||r(i)||/||b|| 1.000000000000e+00
1 KSP preconditioned resid norm 1.018974811826e+01 true resid norm
1.941629896918e-02 ||r(i)||/||b|| 8.322864527335e-02
2 KSP preconditioned resid norm 5.450493684941e-02 true resid norm
1.029339589324e-02 ||r(i)||/||b|| 4.412300185615e-02
3 KSP preconditioned resid norm 3.944064039516e-02 true resid norm
1.030277925024e-02 ||r(i)||/||b|| 4.416322394443e-02
4 KSP preconditioned resid norm 6.286181172600e-05 true resid norm
1.030243055045e-02 ||r(i)||/||b|| 4.416172923059e-02
5 KSP preconditioned resid norm 4.349133658643e-06 true resid norm
1.030239080406e-02 ||r(i)||/||b|| 4.416155885630e-02
6 KSP preconditioned resid norm 9.279429568232e-08 true resid norm
1.030239169298e-02 ||r(i)||/||b|| 4.416156266666e-02
7 KSP preconditioned resid norm 3.032522248740e-09 true resid norm
1.030239175066e-02 ||r(i)||/||b|| 4.416156291393e-02
8 KSP preconditioned resid norm 6.533747246875e-09 true resid norm
1.030239175718e-02 ||r(i)||/||b|| 4.416156294184e-02
9 KSP preconditioned resid norm 6.083185162500e-12 true resid norm
1.030239175259e-02 ||r(i)||/||b|| 4.416156292220e-02
10 KSP preconditioned resid norm 5.510319622225e-12 true resid norm
1.030239175259e-02 ||r(i)||/||b|| 4.416156292221e-02
11 KSP preconditioned resid norm 5.456758524534e-12 true resid norm
12 KSP preconditioned resid norm 5.456756081783e-12 true resid norm
13 KSP preconditioned resid norm 5.456755930952e-12 true resid norm
14 KSP preconditioned resid norm 5.456755930949e-12 true resid norm
15 KSP preconditioned resid norm 5.456755930949e-12 true resid norm
As you can see, the true residual is quite large and moreover it does
not reduce beyond a certain point. This is using hypre as
preconditioner, but the situation is equally bad with several other
preconditioner (ilu, sor, jacobi, or even none). As for the solution
itself, the error has poor to none convergence under grid refinement.
All this suggests that the linear system is not converging in my case.
Do you have any idea/suggestions why this is happening and how I can avoid it?
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140306/8eeef3cd/attachment.html>
