[petsc-users] DMDA questions
Wed Mar 5 12:56:00 CST 2014
On Wed, Mar 5, 2014 at 12:54 PM, Xiangdong <epscodes at gmail.com> wrote:
> If I first define a DM, and obtain the solution vector on this DM (through
> non multigrid method).  However, given that this DM is so fine, I may only
> need to save/view the solution on a coarsen grid. Is there some functions
> available in petsc for this instead of writing my own vec scatter?
Interpolation between general DMs does not make sense because we do not
prescribe anything
about the function representation. DMDA has interpolation routines, and so
does DMPlex.
   Matt
> Thank you.
> Xiangdong
> On Mon, Mar 3, 2014 at 9:58 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Xiangdong <epscodes at gmail.com> writes:
>> > Could you please expand it a little more on using DMCoarsenHookAdd to
>> > restrict a fine vector on a coarse grid? The only example I can find is
>> > ex48 in snes. It is not clear how the coarsen vector are generated from
>> > that example.
>> Look at the use in src/ts/impls/implicit/theta/theta.c
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140305/4604b358/attachment.html>
