[petsc-users] Unexpected "Out of memory error" with SLEPC
Mathis Friesdorf
mathisfriesdorf at gmail.com
Thu Jun 26 05:08:23 CDT 2014
Dear Karl,
thanks a lot! This indeed worked. I recompiled PETSC with
./configure --with-64-bit-indices=1
PETSC_ARCH = arch-linux2-c-debug-int64
and the error is gone. Again thanks for your help!
All the best, Mathis
On Wed, Jun 25, 2014 at 12:42 PM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> Hi Mathis,
> this looks very much like an integer overflow:
> http://www.mcs.anl.gov/petsc/documentation/faq.html#with-64-bit-indices
> Best regards,
> Karli
> On 06/25/2014 12:31 PM, Mathis Friesdorf wrote:
>> Dear all,
>> after a very useful email exchange with Jed Brown quite a while ago, I
>> was able to find the lowest eigenvalue of a large matrix which is
>> constructed as a tensor product. Admittedly the solution is a bit
>> hacked, but is based on a Matrix shell and Armadillo and therefore
>> reasonably fast. The problem seems to work well for smaller systems, but
>> once the vectors reach a certain size, I get "out of memory" errors. I
>> have tested the initialization of a vector of that size and
>> multiplication by the matrix. This works fine and takes roughly 20GB of
>> memory. There are 256 GB available, so I see no reason why the esp
>> solvers should complain. Does anyone have an idea what goes wrong here?
>> The error message is not very helpful and claims that a memory is
>> requested that is way beyond any reasonable number: /Memory requested
>> 18446744056529684480./
>> Thanks and all the best, Mathis Friesdorf
>> *Output of the Program:*
>> /mathis at n180:~/localisation$ ./local_plus 27/
>> /System Size: 27
>> [[30558,1],0]: A high-performance Open MPI point-to-point messaging module
>> was unable to find any relevant network interfaces:
>> Module: OpenFabrics (openib)
>> Host: n180
>> Another transport will be used instead, although this may result in
>> lower performance.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>> [0]PETSC ERROR: too large an object or bleeding by not properly
>> [0]PETSC ERROR: destroying unneeded objects.
>> [0]PETSC ERROR: Memory allocated 3221286704 Memory used by process
>> 3229827072
>> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
>> [0]PETSC ERROR: Memory requested 18446744056529684480!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 3.4.4, Mar, 13, 2014
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./local_plus on a arch-linux2-cxx-debug named n180 by
>> mathis Wed Jun 25 12:23:01 2014
>> [0]PETSC ERROR: Libraries linked from /home/mathis/bin_nodebug/lib
>> [0]PETSC ERROR: Configure run at Wed Jun 25 00:03:34 2014
>> [0]PETSC ERROR: Configure options PETSC_DIR=/home/mathis/petsc-3.4.4
>> --with-debugging=1 COPTFLAGS="-O3 -march=p4 -mtune=p4" --with-fortran=0
>> -with-mpi=1 --with-mpi-dir=/usr/lib/openmpi --with-clanguage=cxx
>> --prefix=/home/mathis/bin_nodebug
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: PetscMallocAlign() line 46 in
>> /home/mathis/petsc-3.4.4/src/sys/memory/mal.c
>> [0]PETSC ERROR: PetscTrMallocDefault() line 189 in
>> /home/mathis/petsc-3.4.4/src/sys/memory/mtr.c
>> [0]PETSC ERROR: VecDuplicateVecs_Contiguous() line 62 in
>> src/vec/contiguous.c
>> [0]PETSC ERROR: VecDuplicateVecs() line 589 in
>> /home/mathis/petsc-3.4.4/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: EPSAllocateSolution() line 51 in src/eps/interface/mem.c
>> [0]PETSC ERROR: EPSSetUp_KrylovSchur() line 141 in
>> src/eps/impls/krylov/krylovschur/krylovschur.c
>> [0]PETSC ERROR: EPSSetUp() line 147 in src/eps/interface/setup.c
>> [0]PETSC ERROR: EPSSolve() line 90 in src/eps/interface/solve.c
>> [0]PETSC ERROR: main() line 48 in local_plus.cpp
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 55.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> *Output of make:
>> */mathis at n180:~/localisation$ make local_plus
>> mpicxx -o local_plus.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
>> -Wno-unknown-pragmas -g -fPIC
>> -I/home/mathis/armadillo-4.300.8/include -lblas -llapack
>> -L/home/mathis/armadillo-4.300.8 -O3 -larmadillo -fomit-frame-pointer
>> -I/home/mathis/bin_nodebug/include -I/home/mathis/bin_nodebug/include
>> -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
>> -D__INSDIR__= -I/home/mathis/bin_nodebug
>> -I/home/mathis/bin_nodebug//include -I/home/mathis/bin_nodebug/include
>> local_plus.cpp
>> local_plus.cpp:22:0: warning: "__FUNCT__" redefined [enabled by default]
>> In file included from /home/mathis/bin_nodebug/include/petscvec.h:10:0,
>> from local_plus.cpp:10:
>> /home/mathis/bin_nodebug/include/petscviewer.h:386:0: note: this is the
>> location of the previous definition
>> g++ -o local_plus local_plus.o -Wl,-rpath,/home/mathis/bin_nodebug//lib
>> -L/home/mathis/bin_nodebug//lib -lslepc
>> -Wl,-rpath,/home/mathis/bin_nodebug/lib -L/home/mathis/bin_nodebug/lib
>> -lpetsc -llapack -lblas -lpthread -Wl,-rpath,/usr/lib/openmpi/lib
>> -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.7
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.7 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>> -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>> -L/lib/x86_64-linux-gnu -lmpi_cxx -lstdc++ -ldl -lmpi -lopen-rte
>> -lopen-pal -lnsl -lutil -lgcc_s -lpthread -ldl
>> /bin/rm -f local_plus.o
>> *Code:
>> *///Author: Mathis Friesdorf
>> //MathisFriesdorf at gmail.com <mailto:MathisFriesdorf at gmail.com>
>> static char help[] = "1D chain\n";
>> #include <iostream>
>> #include <typeinfo>
>> #include <armadillo>
>> #include <petscsys.h>
>> #include <petscvec.h>
>> #include <petscmat.h>
>> #include <slepcsys.h>
>> #include <slepceps.h>
>> #include <math.h>
>> #include <assert.h>
>> PetscErrorCode BathMult(Mat H, Vec x,Vec y);
>> PetscInt L=30,d=2,dsys;
>> PetscErrorCode ierr;
>> arma::mat hint = "1.0 0 0 0.0; 0 -1.0 2.0 0; 0 2.0 -1.0 0; 0 0 0 1.0;";
>> #define __FUNCT__ "main"
>> int main(int argc, char **argv)
>> Mat H;
>> EPS eps;
>> Vec xr,xi;
>> PetscScalar kr,ki;
>> PetscInt j, nconv;
>> L = strtol(argv[1],NULL,10);
>> dsys = pow(d,L);
>> printf("%s","System Size: ");
>> printf("%i",L);
>> printf("%s","\n");
>> SlepcInitialize(&argc,&argv,(char*)0,help);
>> MatCreateShell(PETSC_COMM_WORLD,dsys,dsys,dsys,dsys,NULL,&H);
>> MatShellSetOperation(H,MATOP_MULT,(void(*)())BathMult);
>> ierr = MatGetVecs(H,NULL,&xr); CHKERRQ(ierr);
>> ierr = MatGetVecs(H,NULL,&xi); CHKERRQ(ierr);
>> ierr = EPSCreate(PETSC_COMM_WORLD, &eps); CHKERRQ(ierr);
>> ierr = EPSSetOperators(eps, H, NULL); CHKERRQ(ierr);
>> ierr = EPSSetProblemType(eps, EPS_HEP); CHKERRQ(ierr);
>> ierr = EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL); CHKERRQ(ierr);
>> ierr = EPSSetFromOptions( eps ); CHKERRQ(ierr);
>> ierr = EPSSolve(eps); CHKERRQ(ierr);
>> ierr = EPSGetConverged(eps, &nconv); CHKERRQ(ierr);
>> for (j=0; j<1; j++) {
>> EPSGetEigenpair(eps, j, &kr, &ki, xr, xi);
>> printf("%s","Lowest Eigenvalue: ");
>> PetscPrintf(PETSC_COMM_WORLD,"%9F",kr);
>> PetscPrintf(PETSC_COMM_WORLD,"\n");
>> EPSDestroy(&eps);
>> ierr = SlepcFinalize();
>> return 0;
>> #undef __FUNCT__
>> #define __FUNCT__ "BathMult"
>> PetscErrorCode BathMult(Mat H, Vec x, Vec y)
>> PetscInt l;
>> uint slice;
>> PetscScalar *arrayin,*arrayout;
>> VecGetArray(x,&arrayin);
>> VecGetArray(y,&arrayout);
>> arma::cube A = arma::cube(arrayin,1,1,pow(d,L),
>> /*copy_aux_mem*/false,/*strict*/true);
>> arma::mat result = arma::mat(arrayout,pow(d,L),1,
>> for (l=0;l<L-1;l++){
>> A.reshape(pow(d,L-2-l),pow(d,2),pow(d,l));
>> result.reshape(pow(d,L-l),pow(d,l));
>> for (slice=0;slice<A.n_slices;slice++){
>> result.col(slice) += vectorise(A.slice(slice)*hint);
>> arrayin = A.memptr();
>> ierr = VecRestoreArray(x,&arrayin); CHKERRQ(ierr);
>> arrayout = result.memptr();
>> ierr = VecRestoreArray(y,&arrayout); CHKERRQ(ierr);
>> PetscFunctionReturn(0);
>> #undef __FUNCT__/*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140626/be2c7917/attachment-0001.html>
