[petsc-users] Irritating behavior of MUMPS with PETSc
Matthew Knepley
knepley at gmail.com
Wed Jun 25 10:08:57 CDT 2014
On Wed, Jun 25, 2014 at 7:09 AM, Gunnar Jansen <jansen.gunnar at gmail.com>
wrote:
> You are right about the queuing system. The job is submitted with a PBS
> script specifying the number of nodes/processors. On the cluster petsc is
> configured in a module environment which sets the appropriate flags for
> compilers/rules etc.
> The same exact job script on the same exact nodes with a standard krylov
> method does not give any trouble but executes nicely on all processors (and
> also give the correct result).
> Therefore my suspicion is a missing flag in the mumps interface. Is this
> maybe rather a topic for the mumps-dev team?
I doubt this. The whole point of MPI is to shield code from these details.
Can you first try this system with SuperLU_dist?
MAtt
> Best, Gunnar
> 2014-06-25 15:52 GMT+02:00 Dave May <dave.mayhem23 at gmail.com>:
> This sounds weird.
>> The launch line you provided doesn't include any information regarding
>> how many processors (nodes/nodes per core to use). I presume you are using
>> a queuing system. My guess is that there could be an issue with either (i)
>> your job script, (ii) the configuration of the job scheduler on the
>> machine, or (iii) the mpi installation on the machine.
>> Have you been able to successfully run other petsc (or any mpi) codes
>> with the same launch options (2 nodes, 3 procs per node)?
>> Cheers.
>> Dave
>> On 25 June 2014 15:44, Gunnar Jansen <jansen.gunnar at gmail.com> wrote:
>>> Hi,
>>> i try to solve a problem in parallel with MUMPS as the direct solver. As
>>> long as I run the program on only 1 node with 6 processors everything works
>>> fine! But using 2 nodes with 3 processors each gets mumps stuck in the
>>> factorization.
>>> For the purpose of testing I run the ex2.c on a resolution of 100x100
>>> (which is of course way to small for a direct solver in parallel).
>>> The code is run with :
>>> mpirun ./ex2 -on_error_abort -pc_type lu -pc_factor_mat_solver_package
>>> mumps -ksp_type preonly -log_summary -options_left -m 100 -n 100
>>> -mat_mumps_icntl_4 3
>>> The petsc-configuration I used is:
>>> --prefix=/opt/Petsc/3.4.4.extended --with-mpi=yes
>>> --with-mpi-dir=/opt/Openmpi/1.9a/ --with-debugging=no --download-mumps
>>> --download-scalapack --download-parmetis --download-metis
>>> Is this common behavior? Or is there an error in the petsc configuration
>>> I am using here?
>>> Best,
>>> Gunnar
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140625/35be0b51/attachment-0001.html>
